- Installed Headers... doesnt feel the same?
- ???Crapy Grotyohann Y-Pipe???
- What is the best way to install an ASP crank pulley on an A4
- Hooker LT headers and y-pipe go on tomorrow
- fans wont turn off after header install
- Air restrictor mod
- Header tube Size?
- Anybody with random tech. cat back?
- Can MAFT be adjusted on the fly?
- DYNOTECH-VS-GROTS-VS-SLP BEST?
- Post pics of your Baker Hose
- In car camera, where to get?
- Is it ok to drive open headers over to the exhaust shop?
- Argh so I get the Holley manifold but now I hear it's crap?
- Paging CAMSS
- JBA Shorty Headers & Random "Y" Pipe
- Stock vs Free Ram Air vs FIPK
- Hypertech Pullies?
- Dealer has my SS..
- Open headers: rich or lean?
- what mod should i do next
- Dyno #'s or Track #'s with true duals..
- SLP Cold Air Upgrade Kit!!
- Do I need 1 or 2 cutouts for my 2.5 ypipe?
- Someone with a mufflex exhaust and LT's
- How much should my 3.73's cost installed?
- Exhaust cut outs LT1??
- Grotts on the way...
- Convertible SLP Y-Pipe Install - Pics & Notes
- MSD sparkplug wire issue
- Anyone have pics of Hooker Ypipe w/ cats?
- SLP Headers... Good or No Good????
- Are Corvette and F-body ASP pulley the same?
- gains from borla?
- ARE headers???
- need part #'s for ls6 coolent pipe and plugs
- how to remove bumper supports
- I Just Bought a 1997 Z28! Which Engine does it have LT1 or LS1?
- Stumble problem.....ideas???
- Turning on fans earlier
- O2 Simm Questions?
- Peeps with true duals, quick question please....
- valve covers, can they be......
- found that "noise"
- EGR...trash can time
- Soft Touch Rev Limiter???
- To Disable Fuel & Ignition for Compression Test
- 98 camaro, doesn't start
- SES light on (O2 sensor help)
- SES Light and Long Tubes
- side exhaust
- Need Borla Stinger Exhaust info now!!!!
- Does anyone make an ORP for TTS headers?
- Maf ends and A4 tranny ?
- Grots vs SLP headers
- Wide Band Tuning > Ok, sounds good, so how do we adjust anything?
- Do you guys see anythign wrong with buying a used MAFT?
- horsepower over stock?
- Any adverse effects to removing the AIR pump?
- Got problems with my car, misfire and O2 problems
- Redline wetter water
- High Idle?
- Ricer (show off) or not?
- Hooker y-pipe.......3 inch? Ground clearance?
- I need a list of bolt ons that actually work.. I seem to be missing some..
- Metco Breather question
- Installing Headers
- True Dual Exhaust pictures and under car video
- 1 7/8 headers on stock 346...
- Ceramic or Jet Hot???
- Newbie with a ?
- Air/Fuel gauge mod link?
- FRONT BRAKES FOR 15's
- when to change spk plugs???
- ATI Pullies
- Headers vs Spark Plug Installation
- Luv my new electric cutout
- Person who recommended the airflo bellow w/in pls
- two quick questions that arent that importan.
- What Puller to use
- Is it ok to run 5 gallons of 108 leaded
- Incar Video of True Dual sound (Drag race)
- y pipe
- ?:Some advaice please. LS6 Intake or no LS6 Intake
- throttle body bypass parts
- Can it be done?!?!
- sound clips of different exhaust systems
- Installing SLP dual dual, any help???
- FLP Headers - What's the difference??
- Gutted Cats on '99 TA
- Any gains possible going from cats to ORP with TTS headers?
- LS1 MAF Question
- Would a bad ASP pulley...
- Can heater hose withstand exhaust temps? Rigging EGR on Hooker LT's
- Help!! Question about exhaust rattle!
- Removing just AC compressor belt??
- Need belt #'s
- inlet/outlet size
- Where can you find GROTS! ON LINE
- Stock cats...I need...
- Bauer Racing Ported TB....
- Headlights went out on '98 Camaro, any ideas?
- Anyone with ground clearance pics or Dr. Gas X pipe?
- SLP Loudmouth is cab noise bad?
- Anyone replace a belt yet?
- Very cool exhaust clamp
- FLP Headers take me from 322 to 352rwhp
- colder thermo and colder temps outside
- HELP... Car died
- GMS MAF
- Dyno #s From Hooker LTs???
- Help: Throttle cable too much slack after maf swap.
- Dyno'd car after SLP LT install - HELP!!!!
- any sound deadening material which will withstand exhaust?
- LS6 INTAKE INSTALL
- Anybody install cruise control on a stripped LS1
- idle and the hole in the throttle body ? ......
- Pics of my dual exhaust >>>>
- Problems with air lid....... Need info ASAP!!!!
- New true dual WOT video clips
- Speed Demon Ported TB????
- "borla" bypass
- With my mods is a 3 1/2 custom Y to 4" mufflex too much?
- Light noises??
- Altenator pulley: replaced one back to stock and now it squeeks! what gives?
- next mod question?
- Hooker Y won't clear....
- LS6 intake gains
- How loud will my Dual/Dual be when I add my Mac's and ORY?
- i want true duals! how do i do it?
- Complete exhaust lineup
- Need help...
- Dynatech stepped headers
- '01's running Hooker LT's pls read..
- FLP rattle fix, removed cat. heat shield pass. side, OK?
- P1416 Secondary Air Injection (AIR) System Bank 2
- Hooker Aerochamber/poor man's borla installed!
- What size are the MAC header ball elimination kits on MTI's website?
- 80mm BBK TB.....yeah or Nay?
- O2's .940, will ported MAF help?
- Got New MAF!!!
- Higher Flow Fuel Injectors
- Mufflex ORP and durability?
- Any gains from open headers at track
- Paging ALL Grot. header PIX...
- Mufflex Sound...
- which MAF to use?
- Swapping camshaft----What size are the bolts in the front of the ASP pulley?
- Problem with my idle... any ideas?
- Bad misfire on passenger head after install stock manifolds??
- 6.0 question
- Very close to ordering hookers
- GMS MAF help
- dual cutouts worth it on my combo?
- post best results from your MAFS
- Does anyone have a sound clip of MAC's with ORY and Dual/Dual?
- Mufflex Y-pipe in w/ hooker LT's.
- Would like some opinions of Hooker vs. Edelbrock Catback
- How much did you adjust your MAFT after installing a ported Throttle Body???
- Pondering doing a True dual setup...Give me some sound clips!!!!
- What cat-back sounds best with FLP headers?
- Car has a bad miss fire....HELP!
- Removing plug for water temp sensor
- New Dyno #'s With Stealth Lid/SLP LT
- SLP bellows kit?
- throttle body
- How badly is my catalytic TTS Y-pipe hurting me? X-pipe setup over axle?
- What parts for a LT header install...
- Whistling Sound with new BBK TB???
- Bolt-Ons
- EGR with LS6 intake manifold???
- oxygen sensor simmulators
- Hooker LT install a sucess (somewhat)
- Is this what I'm getting?
- Are these cats good for the Fbody?
- Where do I connect my 02 pigtail connector?
- Datalogs!
- fog light switch
- Big pics of FLP install.
- Question on Ported MAF
- SES light at 135
- Ran out of gas...now no fuel pressure??!!!!
- Scanned the car tonite, and this is what it said...whats it mean?
- 10.4 taylor wires
- Car won't start, need HELP!
- Why True Duals?
- PLEEEEEEEEEEASE HELP!!!
- Gas tank vapor locked?????
- CAM 2 (110 octane) SAFE??? ASAP
- SLP header install, please help.
- Mac Header Collector Noise....
- Thermostat 101
- EGR question
- I found black soot "carbon?" inside my gmsmaf, Also had a gassy smell to it. Normal?
- So I thought the Holley LS6 intake was supposed to our savior, what happened???
- Help! MAC headers/ORP and Borla sounds horrible...
- glass pack or flows
- SLP y-pipe worth it on a stock engine?
- Rattling/Grinding Noise when going in reverse
- Just a heads up for anyone using a MTI lid (or any other lid)
- Pulled my cats, But help!
- PCM question
- Will Metco valve cover breather hurt anything?
- dyno results
- Corsa exhaust article
- Help - TCS Logic module cuts out by itself!!!
- 160 Stat .. temps go up to 215 even on highway.
- FLP Header install. Does this part go back in?
- MAFS for SALE
- Need quick info about AIR system...
- Help, engine temp gauge not working
- when you guys go internal/build-up, do you keep your MAFT?
- Hooker LTs!!! ...Which Y-pipe???
- Coolant leak
- Where did the HP go?
- HELP!! Need part # for a bearing for my A/C tensioner.
- How to quiet down a car with out loosing flow?
- Engine Dress up Hoses & Alternatives.
- My Borla Rattles?
- Just Got SES checked out
- DSLs and exhaust clearence...
- Trans Cooler mounting
- B&M New Volt
- DS window didn't work.....wiggle rubber boot in door jam, now it works...?
- Ported MAF Housing, SES light on now
- Free thermostat mod works well!
- Removed my MAF Screen now +2.5 deg of timing!!!!
- WORTH DESCREENING STOCK MAF.
- Recharging A/C ??
- Will a milf help me fix my A/F ratio?
- slp temp module
- FLP Header Install
- Pass side airbag resistance?
- 02 Simms Install
- What happened to LG Motorsports headers?
- water pump diagnosis please!
- Exhaust set-up help needed for H/C
- The ultimate LS1 performance headers are finally complete (less Jet-Hot coating!)
- Will MAF ends effect tranny line pressure???
- Would getting a Holley intake JetHot coated decrease the heatsink?
- Does anyone have or know of a link on how to install a shift light?
- header questions again.
- Can a good exhaust shop do this?
- Hi-flow cats on stock manifolds?
- Where are you guys getting your GM Top End Cleaner?
- Loudmouth on Stock LS1
- Synthetic or regular oil with an Auburn?
- TB Specs?
- Wrong Lid sent
- Question about battery cutoff switches
