- Best sounding exhaust*I'm aware of the sticky*
- Push Button start??
- What features do you need in an LS wire set?
- Valve cover question
- just FYI: logged car after bolt-ons
- valley cover gasket
- fel-pro valley cover gasket
- Ls7 tbody on lS1 question
- 160* Thermostat
- edelbrock fuel rails
- should I keep my fast 92 mm intake or step up too a 102?
- pro's con's of carb set up
- How much horsepower can you run...
- Missing after header install... got codes.
- Power Steering Pully's?
- low intake
- What alternator to run under drive pulley?
- 5.3 cam choice
- Could improper plug gap on NGKTR55 cause code p0300?
- Do we have removable t stat housings?
- Looking for part number for 10.4 mm opti/LS1 coil ends for spark plug wires
- New at cbm
- Looking for some advice
- summit shipping my stuff weeks late
- Dip stick location.
- How much AC Compressor Oil?
- Difference between fast 90mm and 92mm
- High idle till i come to a stop?
- MTI Lid won't fit over MAF. Pics inside.. Help!
- Need a quick measurement, any help would be appreicated
- Difficulty Installing Shorties vs Longtubes??
- Is this a reverse flow water pump? How else could this work?
- battery dieing overnight
- Belt routing for water pump as the only accessory?
- How big is the TB opening on a LS6 intake itself?
- LS6 intake repair near MAP w/pics
- Drag racing event
- Loud backfiring.
- fast 92mm ... need help
- Quick opinion please...
- A/C compressor removal and reinstall ???
- Header wrap questions..
- Exhaust resonating
- Need a shift light and is my tach really laggin this bad?
- Stiff throttle after FAST 90 install?
- Serious header heat issue
- O2 Sensor Help!
- faster throttle response
- 16mm hole on driver's side of block for temp readings?
- Are all throttle bodies created equal? Help me choose a 92mm tb.
- Need some quick help
- Need help choosing a replacement exhaust
- Good or bad idea?
- Anyone go with TSP true duals and NOT like them?
- What's your 90-92mm TB depth mounted?
- If you have a Voltage Drop at WOT, Here is the Solution
- Best muffler for my '00 z28?
- How bad is Flowmaster?
- speedo or mileage gauge are working
- need help
- pcv valve guestion
- Cracked bolt hole on LS6 intake
- TSP True Duals do they have Rasp or no? Owners chime in!
- Changed Spark Plugs and now MPG socks !!!
- throttle body question
- Fast 92 or 102
- Ls2 throttle body on Ls6 mani
- Exhaust installed!!!!
- Help! My throttle is stuck open when i first start it up.
- NW 102 TB, anyone used it?
- borla with headers question
- Crappy pics of my duals over the axle build
- Slight Rear End Build Advice
- Just installed a CAI on 2004 denali...
- Cruise on an Accufab
- Problem with nick williams 102??
- CBM LS7 Porsche 911 Swap + LSX TV
- coil packs wiring harness ???
- Poly Motor Mounts
- 98 TA Engine Swap
- The Oil Leak.... Continued... Leaking oil above starter area
- Will I get an SES light if I remove AIR system?
- I think I might be sick...
- Taller valve covers ?
- Fast 102 Install Questions??
- Any gains from k&n fipk?
- Loudmouth
- Just installed Powerbond UDP, now alternator is not working?
- C5R heads what intake?
- ls6 intake 90mm
- cam swamp questions
- How loud is an open header LT ls1?
- Looking for LS1 Corvette idler pulley bolt
- T-Brake/2 Step Wiring for Horn Button
- information on kooks true duals install
- Magnaflow cat back
- need a strange part...
- Pic request: Magnaflow 5x8 or (4x9) mufflers AFTER axle true duals setup.
- Don't buy dynomax ory
- Myth or Fact
- Ory to stock heads?
- Ls1 180 T stat, what should my temp be?
- 98 Z28 Verty Engine Transplant Build
- Catalytic Problems
- 102mm Fast LSX. Yes or no?
- Engine stumble and RPM indication spike
- What gains should I see?
- ok to drive after headers
- H/C/I and headers install question
- New black fast 92 installed looks good!
- Fast 92 install
- Cold Feet... True Duals
- Where to get 4" flanges
- Texas Speed Long Tubes! Easy Install, Thumbs Up!
- Throttle cable for a four barrel throttle body?
- Head Casting question
- Cam help first time here
- How much gain from ls6 intake on cam only trans am?
- where to find long sanding rolls and everything i need to port a fast
- doings a battery relocation... kill switch loaction?
- car starts some times need help
- IAT Sensor Placment In A CAI
- MSD 6AL Digital Ignition Module w/Rev Control
- Best Prices On Parts
- Hooker catback fits like crap and chambers are damaged new
- 02 sensor question
- Chrs1313, SES
- anyone have a CAI on a dd?
- Catback-without muffler
- MSD Wires?
- Which muffler for true duals? (opinion and Idea thread)
- TSP X pipe back
- Vacuum Lines
- Proform LS valve covers
- Odd question fellas, help if you can
- You guys are crazy if...
- GTO throttle body question
- Dumped duals
- LS1 Compression Test now Ive got a miss fire???
- has any one had the front seal wear a grove in a underdrive pulley?
- GUIDE:Sakou Michi LS1 Dual Cans/truck PCV Install (w/ pics)
- s2 throttle body.
- KU Coolant Vent system, anyone runnin it?
- truck intake
- off the wall intake question LS6 specific
- Amsoil Drop-In Air Filter EAA-83 Review
- Intake swap questions
- TSP catted y to non-TSP headers?
- what do you guys use to port your fasts/ composite intakes
- Torque on the manifold Bolts
- Dual inlet truck fuel rails
- Another code 1153 thread lol
- oil pressure mechanical gauge
- Intake question
- Header Install...DONE!!!
- getting a custom tune couple of questions.
- MAP sensor wiring?
- how are bbk throttle bodys?
- 99 m6 wiring harness/pcm vs 2002 a4 harness/pcm
- need info on high mount a/c braket
- Need your guys' help on this one. Exhaust.
- Passenger Head Tensioner Pulley Deal...
- push button starter wiring
- TSP Catted Y-Pipe with Ebay header?
- 1998 Camaro dead spot 3000rpm in second gear
- Vertical Mount Throttle body?
- Raptor Performance Digital Mini Shift Light with Launch Feature
- Tsp headers PITA!!
- Don't like your LM1 or LM2? Consider this...
- The vacuum T fitting at the back of the manifold, size of A/C barb?
- New CAI Results..Got rid of my lid and airbox
- Does Texas do visual emissions inspection?
- Can Anyone Tell Me What This Is?
- Cut off my tips
- high volumen master clutch cylinder
- Noise after bbk intake install
- ls1 intake manifold
- Installed my Headers/Y Pipe/Etc..
- Camaro Shorty Headers for LS1 - Cali legal
- WOT: Noise from engine bay area - whine?
- catted Y pipe to fit QTP LTs
- Slim alternator
- Magnaflow exhaust tip broke off
- PCV Catch can question
- how good are 317 heads for LS1
- Trying to find intake/vacuum leak help
- SLPloudmouth 1 or 2 exhaust system
- DSL with TDs?!?
- new ls1 for 3k?
- car wont crank need help asap plz, need car moved asap
- Help first time starting the new motor
- Misfire on cylinder 4....out of ideas
- Knock-Off FAST Throttle Bodies
- Valve cover bolts?
- Quick question
- What sponsor ports tb?
- P&P TB after tune?
- What size belt for SLP/march underdrive pully belts?
- Stall size for Ms3 cam for DD
- Are manifold gaskets the same?
- Corvette Cold Air Intake on Camaro?
- Cons of welding ypipe?
- Got wrong headers in mail, 1 7/8 instead of 1 3/4
- Unique Exhaust need QUIETER!
- New cbm whipple side mount throttle body adapter lsx
- fly by wire tbody?
- whats the best mods for a stock ls1??
- 2OTL Owners, come in!
- Wiring
- Wiring
- building my own ram air..where do they sell sheets of clear or black plastic?
- FAST 92mm Lower Shell
- Header issues
- Where to get hump hose coupler
- How much do cut outs help
- identifying water pump
- Blackwing OE Decal
- Any Suggestions?
- water pump wiring
- Headers on car 8 months.. Oil smell???
- How restrictive are non-mandrel bends?
- Pics of my used Vengace 'ported' FAST 92 I just bought...
- which x pipe???
- help with intake setup
- AC relay
- how much are stock manifolds worth?
- DO NOT BUY professional products 101mm TB
- belt squeal
- AIR and EGR removal with cats
- Turndowns pointed down or angled out?
- Quieter Exhaust Needed..Cammed, LT's, ORY, etc
- LM2 Install Help!!!
- pulled t56 for rebuild.. now bad o2's?
- Headers, intake and disappointed
- Best Bolt on?
- Auburn Gear Differential Installation
- Why does my 02 WS6 not take the correct oil filter???
- EGR removed
- Alt/exiter connection?
- Question About Meth Kit?
- Gasket for AIR tube to manifold??
- oil pressure sensor Teflon tape ?
- Raptr Cam n 243 heads "build"
- head question
- Center Bolt Valve cover PCV routing
- 6.0 LQ9 Swap OR Supercharger on my 4.8?
- wtf new waterpump and now belt wont fit
- starter try to crank motor when battery connected help asap plz
- Corsa Power Pulse vs B&B Exhaust for 98-02 F-Body
- Ground wire for PCV valve
