- Externally balanced 382 stroker + ASP pulley???
- The Big Brown Truck dropped off a present for me
- Need new battery, which one
- Header install question, involving oil dipstick
- Is this a LS6 intake......pic inside
- Problem with car...
- Kooks headers
- Gages in A/C vents
- Does this car have headers on it?
- Dynatech Weld-on Collectors
- need somebody to fabricate exhaust
- Need a Muffler
- stiffer steering???
- Which spark plugs to use?
- Header Bolts
- Need help with Header,Cat, Y-Pipes.......
- First Modification to my 98 Trans Am
- Serpentine belt flying off...
- Headers dyno sheets? 1-3/4 vs. 1-7/8???
- Spark plug install question
- CSI LS1 Waterpump
- LSS installation ?
- Is it worth changing from 2.5 to 3 inch dual exhaust pipes?
- magnaflow exhaust
- PROBLEMS WITH A LEAK ON THE STEERING PUMP!!! H E L P !!!!!!!
- Iridium plugs....
- Having problems with rough idle,help please
- Will the new LSX intake be considered a bolt-on?
- LT's with Bullet too raspy/loud?
- Have to tune computer with header install?
- Headers & Dyno sheets
- bolt up dual exhaust???
- does anybody make a "Bolt up" dual exhaust for ls1??
- post pics of your custom X pipe
- LoudMouth with Dynomax Bullet-At the same time???
- Hooker's are on!!!
- Header addition ? power
- Edelbrock LTs...
- Plain duals vs duals w/X pipe
- Anyone hear of ravin mufflers???
- Short Belt Question - Pro's vs Con's
- Which platinum plug?
- cutout on a 2001 SS QUESTION
- Which mod next?
- What are good clamps for the exhaust?
- 1 3/4 or 1 7/8
- Kooks-Dyna Tech- QTP
- Sensor Connectoe Help required ASAP!!!!
- Bump Stop Mod Question
- Decisions, Decisions...Intake or Exhaust.
- dynomax or magnaflow to put on loudmouth
- TSP Carbon Lid question
- LoudMouth vs. True Duals
- Bad Fitment-Kooks Y-pipe
- Question about the DYNA BATTERY from ThunderRacing.
- Service Engine Soon Light
- QTEC headers & Dyno sheets
- maf housing question
- TCI 3800 stall w/ stock 3.23 10 bolt, too loose for street?
- SLP headers
- More evidence that good Y-Pipe matters
- Electric cutouts?
- Throttle Body ?
- FIPK
- Stock vs. SLP Loudmouth RECORDINGS HERE
- Bauer T.B question?
- Random Tech vs. SLP or Borla Y-pipe...any suggestions?
- got my QTP LT's
- Cant decide on exhaust:Loudmouth or Magnaflow
- When are we going to see a header shootout??
- Hooker Headers Install Tips
- MAF ?
- Discussion: Fuel system cleaners
- Exhaust leak??
- How easy did your FLP's go in?
- Long tubes vs. shorties vs manifolds
- Headers
- Radiator fan/shroud?
- Radiator - Low Coolant Sensor Location
- magnaflow true dual setup?
- True dual setups and muffler clearance
- Anyone running WIde Band O2s?
- anyone have charging problems after pulley?
- NO more rasp w/ mt mac's & ORY
- Is this intake a LS6 intake?
- Looking For audio Clip Hooker LT headers w/SLP Loudmouth
- KooKs header Group Purchase
- Is a 2000 MAF the same as a 2002 MAF??
- Kooks 1 7/8" header install a breeze!
- loud exhuast??? gears??? wut else???
- MAFS ?
- Compression Test: What is a normal reading for LS1?
- Autometer coolant temp gauge install ?
- o2 Simulators
- stainless vs coated vs ...
- Spark plug wire; metal shield around boot...
- O2 sensors
- Best muffler to run with 3" duals? Borlo, Dynomax, Magnaflo
- header question- ceramic?? vs. painted???
- Question about install of gauges
- Has anybody used the Flowmaster cat back
- Wanting to replace Flowmaster muffler.....
- Chaffing!!!!
- HOOKER vs MAGNAFLOW or SPINTECH 3.5"
- ok...headers are next...bolt right up????
- borla xr1's
- asp pulley problem?
- LS1 Meziere water pump pictures *56k warning*
- water temp gauge help!
- Best drive shaft??
- slp loudmouth bracket
- what type of sheet metal to use????
- 160 thermostat temp.?
- Ram Air question
- Help Please Descreened MAF
- different intake?
- Please Clarify EGR Removal reasons and what to do?
- FIPK VS. DIRECT FLOW LID WITH FTRA???
- FTRA additional mod
- cam and head suggestions
- Powdercoating Water Pump
- SLP Flow Pac=RA/bellows/lid: worth it?
- Does the Hooker Y pipe cause rasp?
- How long is the emmisions / cat warranty?
- Less power after header install??????? PLEASE HELP!!!!!!!
- Freeze plug for intake?
- TSP Lid Problems *Update*
- Best headers for fitment, ease of install, and power
- Knock Sensors... what to torque to? (does it matter?)
- Can I loose my air pump and keep my cats?
- Motor mount help
- Hooker owners with duals, pics?
- Are the Pacesetter Ypipes crimped like stock ypipe?? Pics-->
- 3" exhaust to 2 1/2" tail pipe power loss question
- True Duals
- hooker catback (a little Dissappointed)
- Got my Hooker LT's on now I have rasp on acceleration !
- How to Remove Cruise Control on a '00 Z-28?
- Not useing the the two rear O2 sensors or O2 sims...
- Why is my car so slow??
- Difference in Z28 and SS exhaust...??
- misfire on number 4
- Important Meziere Street Pump Questions !
- TEXAS Speed Clear Lid....Still on Backorder?
- Any pics of the Meziere Street Pump yet? Need more info....
- Head banging resonance
- Reverse cooled vs. standard flow water pumps on LS1's
- Exhaust Dia.
- BEST oil pump!!
- SLP Loudmouth "drone" note-anybody ever get rid of it
- Removing EGR on a 2000 SS. Hit a snag.
- Recieved my Kooks today... check out my polish job....
- pace setters
- AC condenser/ Trans cooler
- ASP Overdrive Alternator Pulley
- Help, I'm stumped.
- Cruise Control Removal on a '97 LT-1
- Flow #s On Intake Components?
- water temp gauge
- AIR system deprogrammed - still runs?
- SES = EGR problem?
- Do I need an upgraded fuel pump?
- Air Lid Comparison-which one is best
- IFFY on Cutout's Performance (OPINIONS WANTED & NEEDED)
- Header install help needed!!!!!
- Is it worth installing a set of pulley's on a 2001 ss
- LS6 headers vs. aftermarket
- Edelbrock header install info
- Car won't start!!!(Please READ)
- BEST HEADERS FOR MY TAHOE????????
- TPS modification
- SES light after ORP install
- Which electric cutout
- SLP muffler on a V6
- Anyone here running Electric cut outs in the y pipe?
- My Exhaust Idea...Opinions?
- map sensor problem?
- Difference in 98 and 00 manifolds and y-pipe
- BeCool Radiator ?
- Bosch plus 4's do they suck???
- running with no cats
- Lights go up and down when hitting lock/unlock on keyfob...
- Air Conditioning not working.... need help
- gauge hook up help
- Y-Pipe Question Install
- Which Optima Baterry (RED TOP)?
- cheapest way to 400fwhp NA
- $25,000 fine 4 no cats
- A/C Compressor Failure...
- coolant temp sensor help!
- AC Experts I need some help...........
- Factor Hurst/Lou's short stick question...
- Computer chips
- Anyone with 400hp running true duals? Any gains?
- SLP header dyno
- HOLY SH!T I have a Freak!!!!!!!!!!!!!!!!!!!!!!!
- which catback
- Uhhhhhhhh, did the MAF de-screen, problem.
- Corvette guys....need some info....
- running the exhaust straight off the headers?
- MAF resistor mod - helps with lean condition from ported MAF
- Aftermarket Intakes???
- Corsa exhaust... heavy?
- How would this sound??
- Y pipe install... quick question.
- LT Headers or LS6 intake for first major mod?
- any H.P gain from 2.5 oryp to a 3inch ??
- maf ends and tuning
- Need help....got busted with duals/dumps
- Mac vs. SLP
- egr crap removal
- Electrical glitches
- Post your dual exhaust pics here...
- Anyone else get in on the first run of Meziere street pumps?
- #2 plug wire is right against header
- headers
- i got my true duals today!!!
- Quick question about cut-outs..
- Exhaust and Headers Help
- easy questions regarding LT's/ORY
- motor mounts
- Under drive pulley
- How much could I get for used FLP LT's?
- De-screen and Porting the MAF and housing on an A4 2001 SS?
- MSD wires, where to get some?
- From Admin - We'd like pics of the FAST LSX intake manifold
- does kooks headers make this?
- Short Belt mod
- Pulley tensioner part #, please
- Need help with identifying part
- Removing stock exhaust
- Recieved my KOOKs headers today!
- headers
- Street version of the elec. water pump...
- Has anyone seen any gains on Dyno from Spark Plugs?
- under drive pulleys pos/neg
- side exhaust
- Cutout Question
- Ceramic coating of headers worth it?
- C5 maf same as F-body?
- Removing AIR, black canister removal?
- ok... help me go on a diet!
- Takes off Slow....???
- Hooker Y-Pipe & SLP Drive Shaft Loop
- asp installed, Now I have oil at the front behind the pulley
- crank pulley removal help needed!
- Next Question about the Meziere Street Pump
- Best Driveshaft loop with LT's?
- TPS showing .5 volts w/no throttle... but blade is closed
