View Full Version : Generation III External Engine
- Stainless Works says thanks with money for you!
- Does the Kooks catted y match up with SLP
- FAST 90mm Intake w/o 90mm TB??
- flowmaster for a 2001 ss
- TDs or not
- Loud Mouth?
- tsp y pipe leak
- Can someone explain pulleys to me.
- Problems with new intake manifold
- Magnaflow Fitment help
- Header Question
- 99 T/A Borla Exhaust **VID**
- What do you think?
- Plans for headers on A4/stalled FBody....keeping stock cat-back w/ cut-out
- Harmonic balancer/ pulley
- side exhaust question
- Will Kooks clear oil cooler adapter and lines (see attached pic)
- what pully do i need?
- spark plug color
- Kooks header owners... question
- Borla adjustable plates??
- New long tube headers for the LSx??
- Stock Exhaust MOD
- I just got an LS6 intake for 75 bucks
- Wait for TB to tune?
- Muffler swap??
- crackling sound!
- Problem after header install
- U/D Pulleys, anyone use CAT products.
- rear O2 extension harness
- FAST Intake w/78 mm Throttle Body?
- exhaust set up ?'s
- FlowMaster
- Header bolts??
- waterpump gone bad
- Fast 90/ NW 90 ??
- need help with headers
- lowered car need more clearance
- 98 to 99 engine swap
- getting wires through the firewall
- fix my lid
- Help me with headers
- kooks 17/8 headers
- straight pipe or gutt cat?
- header question
- poly motor mount insert hardware?
- OK, I have a question about O2 sims.
- GMMG users inside!
- Anyone have any clips of a Borlamouth setup?
- X pipe
- is this normal?
- lose more clearance w/ SLP's or MAC's?
- pacesetters & extentions?!
- flowtech vs hooker
- mac header system
- Nick Williams Thottle body problem?
- Water Pump Impact on CR & Power?
- QTP Headers ground clearance pictures?
- ignition wires
- Exhaust Bracket won't stay in place
- electric water pump question
- Spohn TQ ARM with X pipes
- Who's running cats with AIR deleted?
- Intake Mods Lower MPG?
- Swapping LS intakes - is this possible?
- Slp cats
- Accel 8mm Superstock wires????
- cat back from an auto to a manual
- Help picking good spark plugs.....
- 80MM BBK TB or PORT STOCK TB??
- newbie pulley questions
- Those with home-made true duals....come inside
- throttle body stacks
- Need to get my headers coated
- Electric water pump leaking!
- Borla Cat back Question
- GMMG on, now vibrations, help
- Need help with with pacesetter LT's ASAP
- front o2
- Header's question
- !Muffler vs. Loudmouth???
- Who makes the best inexpensive ory pipe???
- longtubes, catted x-pipe,true duals on lowered trans am
- Anybody Considering an Optima Battery...
- Why would you need this??
- Sleeper Z06
- PROJECT SS Intake build
- PCV question.
- FAST 90mm problem ??
- Ls1 intake to Ls6 intake?
- Parts for ls6 intake swap?
- March pulley and short belt....
- Stupid SES light
- pricing on header install
- what size header for my application?
- Back pressure question.. exhaust, true dual opinions
- Picking up headers and offroad Y tomorrow...
- 02 sensor threw a code, serious?
- maf?
- Headers
- Flow Pro Twisters or Dynomax Bullet???
- Need help,want to change AC tensioner on 02 ZO6
- Kooks Y-PIPE
- having trouble taking my manifold off
- Crossover Coolant Tube (Front of the motor, connects the heads)
- BBK 80mm TB vs. FAST 78mm TB
- Has anyone used Permatex for an exhaust leak?
- Any one use Hedman Torque step headers
- slp lt headers 450$ worth it?
- FAST Intake manifold install question
- Will LS1 headers fit?
- Anyone tried this Wideband Gauge??
- Wires that wont touch headers?
- stock 6.0 horsepower and compression
- Where To Get Pulleys/belts??
- ls6 intake question
- Dremmel tool to port TB??
- What causes rasp??
- LS6 Intake question
- NEW 90mm Throttle BODY for LS2 Style intakes
- 1 cut-out or 2
- Stainless Works 'Muscleflow' or GMMG exhaust?
- Anyone try out the MTI 90mm thottlebody??
- Need info on exhaust installation......
- no exhaust = bad?
- What header gasket to use?
- what pulley to get
- exhaust question...
- Boy did I F&^% up.....
- March Pulley installation
- MTI Clear Lid I.D.?
- mas air flow sesor?
- Pulling Evap...
- My PCV solution.
- ground clearance with Kook headers?
- can you pull the cam off your TB?
- continual o2 sensor problem (multiple within two weeks)
- Finally went for a cruise with my Corsa.
- GMMG with LT's and cats..
- True Dual Gmmg Setup...?
- Second break... oil on spark plug threads
- Pacesetter w/ Stock Y and cats?
- Cat Selection
- jet hot long tubes with y pipe and cats
- Exhaust comparison (ad nauseam)
- First Break... Spark Plug question
- Linelock?
- ppl with sbc old school metal intakes
- Ported Throtle Body Problem....need help !
- 2000 WS6 with Borla...wanting headers
- !AIR without going catless?
- Emission Shorties...
- 78mm Fast intake problem
- I did it!!!
- Equus sending unit adapters...
- FLP's ground clearance
- My LS1 Has No Spark Please Help
- Can I make a True-Dual setup with pre-made mandrel bent pipe parts?
- MAF part number..
- ASP UD pulley, Shortbelt size??
- Thoughs on FIPK2
- is my speedometer off??
- Just making sure, 02 sensors
- anyone have qtp header pics
- switched 12v source?
- Can u port a stock ls1 intake?
- cut-out on!
- Coolant Issue:
- no tread sealer cause oil usage?
- Which Taylor ignition wires?
- Pacesetters any good?
- Vortex cone inserts
- cutout right before mufflr or GMMG
- Z06 muffler
- Will 01-02 headers fit in my 99?
- any body running a carbed lsx motor?
- kooks
- what is this black vacuum box
- Underdrive Pulley?
- clearance for headers
- Stainless Works?
- Emission Legal Exhaust Set-ups(IL)
- Header install during head swap?
- did u need all of this for a oil pump swap??
- waterpump gasket ID number
- What mods warrant a FAST LSX intake?
- im CONFUSED on cut outs help!!
- Whats the Difference
- will a lid for a 2000 work on a 98?
- Headers??
- Bosch 02's Shit?
- Can you hook up a BTM to the LS1 MSD controller?
- LT4 Dual/Dual on an LS1?
- CME with true duals
- o2 sensors
- O2 sensor identification....
- O2 Sensors (how many)
- need help with duals
- wiring
- Photos of MAFless bellows
- Pacesetter Headers
- Engine mounts
- LT's and ORY. O2 simms or exstensions?
- Will I feel a diffrence?
- o2 sensor messing up my VSS?
- headers and Y pipe
- REAL cold air intake
- Where to install the cut-out in the exhaust?
- which kooks headers 1-3/4 or 1-7/8?
- Please Help!!!!!!! Header Leak
- 1/4 mile gains on my shorty headers/ORY
- kooks catted y
- Stock C5 and F-body exhaust manifolds...
- coolant tubes & oil sending unit...
- drivers side header
- stock y-pipe Is it worth replacing?
- Guess who ported my TB (plenty of pics)
- anyone know how to wire a tach on an ls1 ?
- info.harlan 2 step on a 98 m6
- fipk vs lid and ssra
- Cats and Fuel lines
- What fuse for the Air Pump?
- MSD coils update
- is a 2004 LS6 water pump compatible with a 2002 LS1?
- Questions on Headers
- intake help for a newb
- Installing exhaust...Pain in the A$$
- C5 sidepipes
- HELP! headers, xpipe on, poping sound
- true dual setup
- different ways to install shift light?
- Has anyone gained power switching from Hooker LTs to Kooks/QTP?
- Head striped out from header bolt...help!
- magnaflow louder
- Removing O2 on Hookers?
- who makes a ypipe for pacesetters that fits better?
- Header Interference with SLP SFC's
- Header install in progress
- 3in Collector to 3in Pipe?
- Want hi-flow cats??????????
- Need help with tach install
- post pics of you duals over the axle
- LT headers back to stock question
- 02 simms not working!
- question bout true dual setup
- lose torque with ASP?
- TB spacer?
- Torque Control Switch???
- Stupid cats...
- Headers or Cam
