PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Doug's Electric Cutout
  2. LQ9 Flywheel, Clutch, Pressure Plate
  3. A.I.R. confusion (pic inside)
  4. Noob shorty question.
  5. Pulley removal...
  6. 4" mufflex exhaust
  7. Bolt-on's
  8. Best "Quality" Shorty Header(i know lt's make more power)
  9. Installing crank pulley
  10. What's the most quiet muffler you an put in a Mufflex catback?
  11. Fuel injector question
  12. Painting LS1 aluminum block - primer?
  13. rear main seal
  14. Painless Perfect System - ECM
  15. Underdrive Pulleys??
  16. I need my headers painted v. Troy, MI
  17. intake swap
  18. LS2 oil pan
  19. Thats not a blower, thats my water pump!
  20. Ignition Coils?
  21. who sells the adapter to put rear C5 o2s in front?
  22. LS4 Accy's on LS1?
  23. What To Do About Y-Pipe Clearance w/LTs?
  24. headlight motor issue
  25. What are these called and where can I buy them??
  26. Alternator plug wiring issue
  27. best muffler for true duals??
  28. Which spark plug for stock LS1 with headers and tune?
  29. Different oil pressure sensor?...
  30. Searching for some more power past bolt-ons, heads/cam/intake
  31. 98-02 Exhaust Hangers NEEDED!!
  32. LMR True Duals
  33. Air pump?
  34. ACCUFAB 4150 / IAT question
  35. cheap O2 extensions?
  36. Anyone running magnaflows...???
  37. Just finished installing new style LPP headers/ory
  38. loosing oil pressure
  39. Broke my alternator connector..
  40. LM2/ORY/LT's+cam
  41. TSP true dual with magnaflow bullet's
  42. solid motor mount question
  43. BIG headers...........
  44. what do yall think?
  45. Thinking about this "slp flo pack".. Need feedback.
  46. LS6 Intake
  47. LPP True duals, pics inside
  48. Electronic Tb to Wire Tb?
  49. Texas Speed headers with Pace Setter ORY
  50. PCm ?
  51. High Press. Power Steering Hose Replacement
  52. LS6 Intake Question
  53. Magnaflow blow out....
  54. 383 and ls1 question
  55. How much is my exhaust costing me???
  56. ls2 intake fit ls1?
  57. Looking at doing a maf, ftra, pulley- worth it?
  58. Stock LSX head flow chart
  59. What kind of gas mileage can i expect from my 408?
  60. GMMG with CME question...
  61. 100 MAF's comparsion
  62. K&n fipk
  63. PLEASE help me find a stock GM trans mount!!!!
  64. GTP 4" cutout is falling apart...
  65. need help with motor
  66. is pulley on far enough?
  67. Have cutout to put on corsa catback. best way to put it in there...
  68. D585 Coil Defect?
  69. PCV system on truck blocks/valve covers?
  70. What's the function of EGR???
  71. Will the ARH y pipe fit Kooks Long Tubes? help
  72. LS1 intake fit lq4 with 317 heads?
  73. Anyone have the Texas Speed 1 7/8' headers ?
  74. help in sugarland
  75. L92 heads swap?
  76. exhaust pipes
  77. which muffler/bullet with lt's to mimic the loudmouth w/ stock manifolds sound?
  78. What gap for tr55????
  79. 07+ truck coils
  80. Anyone looking for parts
  81. Anyone ever deal with StreetsideAuto.com?
  82. LS6 exhaust port dimension?
  83. Which is deeper sounding: hooker or magnaflow
  84. LQ4 water pump clutch fan removal?
  85. Which heads to go with?
  86. Coil relocate questions
  87. misfire on 2 4 6 8
  88. Stock MAF differences: 01 and 99
  89. Need some help with my 98 PCV system
  90. Weiand/Lingenfelter Intake?
  91. Muffler is bad, replacement?
  92. Poly tranny mount with stock motor mount?
  93. Header Tick
  94. stumbles on accel
  95. ls1 vs sbc 355
  96. NGK TR55 vs TR6's ?
  97. Different Plugs
  98. Need pics of harmonic balancer
  99. QTP Electric Cutout Install/Issues
  100. Carb conversion questions..HELP!
  101. ORY dumped, 3" or 3.5" muffler??
  102. bought some goodies.. exhaust, headers,ect.
  103. Catch can installation question
  104. new LS2 Throttlebody install : No start??
  105. Stock Manifolds + Gutted Cats. What Muffler for Throaty, Deep, No Inside Drone Sound?
  106. Kooks 2" race headers and BMR Manual Rack
  107. Attaching Throttle cable?
  108. Modifying hooker into a semi slp loudmouth
  109. Air/ EGR delete ok to drive with codes?
  110. F body alternator operation
  111. ls1 idling low And dying
  112. charging issues....
  113. too loud, what now?
  114. Whats the easiest way to put a new gasket on my EGR?
  115. What throttle cable when removing cruise?
  116. Oil Pressure Sensor compatibility question
  117. waterpump on the way out? help!
  118. Poly Tranny mount install help? Pics?
  119. Air Pump Reversed?
  120. Misfire = Vibrations?, but no codes?
  121. how long of a muffler can you run behind the axle?
  122. Magnaflow Catback issue
  123. My little Header Nightmare
  124. Edelbrock Shorty Headers on a 1998 Ls1
  125. ARP Header bolts
  126. hard starting after long tubes and true dual
  127. Stock FAST throttle body hole size?
  128. how should i run my serp belt
  129. SUMMIT/JEGS X-pipe....
  130. Stupid Oil Pan
  131. What Locktite Or Sealer For Studs In An Aluminum Block?
  132. remain turbo or go N/A????
  133. Stumped
  134. Round peg Square hole????
  135. 241/243 VS. 806 heads.
  136. Reaccuring Exhaust Leaks
  137. Cat / Y pipe question
  138. header wrap...
  139. Need some info on lpp headers
  140. EGR and Air block off plates
  141. How to raise the exhaust up about an inch?
  142. SLP Loudmouth questions
  143. TSP True Dual Exhaust-Need Help/Advice
  144. Need info ASAP!!! Weight of LQ9 for shipping quote
  145. MSD Spark Plug Wire Help
  146. holy y-pipe resriction!!!!
  147. T & D Rocker arms
  148. Header gaskets
  149. starting problem!
  150. Electric cutout install?
  151. Fast 90 install, need some help
  152. exhaust insert
  153. fast90/102 r or pro flow intake?
  154. Fast 90/90 on a stock LS1 in a 3rd gen Formula
  155. What heads do I have?
  156. 12.2's now whats neded to get in 11's?
  157. LS6 intake installtion help
  158. Backfire
  159. Feedback on Dynotune From Hp
  160. cfm on the bbk
  161. Alternator mount
  162. ls6 pcv
  163. 2004 LQ4 Idle issues
  164. Swapping K-Frame-dropping oil pan
  165. wtf engine mount bolt
  166. Abaco MAF's....
  167. Power Steering Pump
  168. Help me troubleshoot smoke!
  169. Help with a fuel line
  170. Does exhaust dumps have to be slashed tips?
  171. My new exhaust 3" X-pipe w/Dynatech Splitflows
  172. Throttle Sticking, Need Some Suggestions please
  173. Crazy Idle....NEED HELP
  174. Water Pump interchangability question
  175. Kooks or ARH worth it?
  176. Tps sensor help please!!!!!!!
  177. Best prices on Fast 90/90?
  178. Drive by wire and auto to manual question.
  179. Seriously annoying DMH E-cutout problem. What can I do?
  180. New car but I hate the exhaust!!!
  181. Need to Cut Welded Y...Ideas???
  182. how hard is it to replace oil pan gasket?
  183. Crankshaft Pulley Wobble?
  184. what factory truck coils would be ideal?
  185. Which Spark Plugs?
  186. 2002 Running rich after long tubes?
  187. header help
  188. people with TSP duals come in please!
  189. lingenfelter 2 step causing car not to run
  190. Nitrous or Heads?
  191. how would i go about making a templet for port matching an intake to the heads?
  192. Which MAP with carb conversion ??
  193. help me...need my oil pan reversed for a sandrail....
  194. longer 02...
  195. Exhaust leak HELP
  196. 317 cast head help please
  197. Is It Safe????
  198. I got a 98 TA WS6 need help with choosing next mods
  199. What does a leaky header/bad gasket sound like
  200. Electric cutout?
  201. FAST 90/92 Guys Come In!!!
  202. anyone running lpp duals yet?
  203. Which Puller to Remove Powerbond Pulley?
  204. Picture request - TSP long tubes
  205. 07 Corvette Injectors?
  206. Will this setup work for cooling my LS1
  207. milling ls6 heads?
  208. Magnaflow C/B Exhaust Rattle, who has it?
  209. pcv in totally differnt place
  210. Help no heat
  211. GM starter VS. Aftermarket starter
  212. exhaust rasp after header install???
  213. Sweet Thunder too loud?
  214. Can you run a cutout in the I-pipe with an SLP style muffler?
  215. Meziere electric waterpump, a few questions.
  216. Normal catch can fluid?
  217. question about idle
  218. Great examples of some hard work:
  219. Headers and cat back question
  220. fuel catalyst
  221. Throwing Belts
  222. Cam spec lsa+2 question??
  223. new TURN ONE power steering pump and wheel
  224. new billet Katech belt tensioner
  225. Need Help with American racing Headers
  226. slp dual dual vs magnaflow
  227. Battery problem, I think
  228. Aftermarket Water temp sensor question
  229. anyone using these mufflers?
  230. fast 92 intake mani
  231. Broke PCV plastic hose on intake install..??
  232. Question about ARP Head Bolts.
  233. BBK Intake Install....Let the surgery begin
  234. A/C Vent lines..
  235. ms3 like custom grind?
  236. Starter Problem!!
  237. O2 Sensor wire routing.........
  238. anyone have any experience with this ebay full exhaust kit?
  239. relocating pcv ?
  240. 6 liter block differences?
  241. SLP air lid
  242. Thinner Head Gaskets
  243. header removal?
  244. New Build, still burns oil ?
  245. intake for 2000 c5 corvette
  246. Dyno before and after QTP longtubes and Y?
  247. Starter not touching flywheel, Please Help
  248. Are 98 injectors the same as 02
  249. X-pipe design
  250. pcv lead?
