PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 [103] 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. How much HP differance between LS6 Intake &TB and a Fast 90/90 or 92/92 Setup?
  2. Header install
  3. MAF question
  4. Replacing LM resonator...
  5. Revxtreme oil catch can
  6. lm1 with bullets?? sounds clips
  7. Finally put my duals on...
  8. Stock Y pipe size?
  9. need carbon fiber mti lid to match my katech valve covers wher can i get one
  10. how bad are flowmasters?
  11. LS6 intake installed, now whistle, but no codes and runs well???
  12. FAST 92 Intake Bolts Loosening Up
  13. Throttle body blade hole question
  14. ABS module question
  15. Fast Intake Install question
  16. Removing oil pan from 01 WS6. How much of a PITA is it?
  17. lid
  18. LS1 aftermarket vs. LS7 fuel rail question
  19. Egr Air delete
  20. Misfire after plugs and o2 sensors, HELP
  21. Will Stock MAF Be Ok?
  22. TSP Headers issue
  23. Muffler Swap
  24. Header to go with?
  25. Installing an 85mm MAF
  26. SLP Dual Dual
  27. Dynatech Slip Fit Headers
  28. Just installed FAST intake - no brakes
  29. Porting Ls1 Intake Manifold Questions
  30. LS6 Intake + Idle control valve?
  31. ls6 intake gain WITH cam
  32. Can I run 39lbs Cobra injectors?
  33. FAST 90mm TB....idle screw
  34. no hole on bbk intake for valve cover tube?
  35. Having problems finding carburetor manifolds...
  36. 88 suburban with a 6.0
  37. My homemade ram-air...
  38. Exhaust Clearances and Do I need this?
  39. Exhaust
  40. Do I need anything else for LS6 manifold replacement
  41. 85mm maf and mti lid fit?
  42. Alternator goes up to 18v and dies, what's the deal?
  43. Header for the most Power?...
  44. Dynomax Bullets, how loud???
  45. Idling and boiling coolent issues
  46. Will an LS6 intake work???
  47. Help! Safe method to raise car for header install
  48. Ever heard of this???
  49. Torque specs pulley
  50. gains on stock engine wth ls6 vs fast 92/92
  51. Will a ford 8.8 work on a f body
  52. got my prostars....FINALLY
  53. Stupid 90mm throttle body C5 Vette Question
  54. Stupid F-body 90mm throttle body question
  55. I need help with meziere water pump.
  56. who buys are cats.
  57. MSD wire question
  58. kooks and slp y-pipe
  59. E-cut questions
  60. kooks vs American racing collectors and y pipe
  61. F-Body LS6 PCV Conversion Coolant Crossover Question
  62. Header Bolts
  63. Need help with tsp 1 7/8 headers!
  64. TSP Rumbler catback and 2.73's ?
  65. Moroso Valve Cover Gasket Issues(leaking)?
  66. Anyone use BBK headers and y-pipe?
  67. Who makes a rectangular shaped e/cutout
  68. Oil Pans
  69. Guesses on crate engine....
  70. New mods- Pacesetter LTs, 2.5 true duals, Nitto drags and Magnaflow 4x9s and x pipe
  71. jingle bells
  72. need help fast!
  73. Magnaflows and Tune
  74. 5.3 head on ls1 5.7? PTV?
  75. Y-Pipe Hitting Car
  76. help
  77. Rocker question
  78. blown head gasket/ looking 4 upgrades.
  79. BBK throttle body and intake?
  80. Need help with headers
  81. Speed Inc true duals
  82. Kooks and Hooker exit locations?
  83. Header bolt
  84. hogan's racing manifods
  85. ram air???
  86. Spark Plug Choices
  87. arh vs kooks
  88. any gains in ET or rwhp with an electric water pump?
  89. will an ls2 intake fit on an ls1?
  90. Dual Cutouts
  91. Broke my E-cutout switch (QTP)
  92. Finally gonna get it done...Hooker Exhaust
  93. magnaflow catback question
  94. LS6 Intake Install pics.
  95. Are these the same part?
  96. Underdrive pulley question
  97. Help read my plugs
  98. sparkplug wires
  99. NGK T6 Plugs Or TR55 Plugs?
  100. Spark Plug swap
  101. ***Need you help**Hooker catback fit cme?
  102. Who makes the best sounding exhaust???
  103. Exhaust Tips
  104. Alternator wiring, elec guru needed
  105. Poly Motor Mount Inserts Anybody Got A Write Up?
  106. Combustion Chamber Question
  107. Just installed my cutout
  108. TSP Headers Problems Hitting Steering Shaft ANYBODY??
  109. Installed my E-cutout
  110. Getting ready for headers/TDs...and inspections
  111. a/c compressor torque specs??
  112. Approx whp? Anyone wanna give me a ballpark?
  113. My brother wants to race beltless, possible?
  114. VIDEO: spun bearing or valvetrain?
  115. Arp head bolt torque???
  116. SLP Lid Problems
  117. Anyone here have TSP LT's and Borla?
  118. TSP rumbler owners come in.
  119. Underdrive pulley on A4
  120. FM Merge bullet Sound clip
  121. How much low end power loss from 1 7/8" headers?
  122. What else do i need b4 tuned?
  123. LGM Big 3 vs BBE bullets
  124. ATI Damper Pin Kit??
  125. What to use for TB porting
  126. Truck intake questions
  127. Weiand Aluminum Manifold Install ?
  128. Underdrive pulley during cam swap?
  129. LS1 Exhaust block off question with Borla exhaust
  130. Common header vibration causes?
  131. SSRA and that Y brace
  132. Oval or low profile exhaust tubing
  133. Putting in PowerMaster Alternator....pulley question
  134. LS6 Intake
  135. Stock heads need work
  136. ls1?
  137. slp maf
  138. I have a question...
  139. catback vs muffler swap
  140. TSP True Duals Only Bolt on?
  141. just installed aftermarket valve covers, filter cones dont fit, need a little tip
  142. Anyone know of any tips that look similar to Laser Xtreme exhaust?
  143. Non adjustable Borla...who's got it?
  144. CNC Ported Throttle Bodies & intakes
  145. LPP headers borla setup
  146. stock Header flange gaskets blowing out! (one to y pipe) need solution please!
  147. How to get rid of codes after long Tubes?
  148. broke PS pulley!!
  149. Did I just ruin 2 good o2 sensors?
  150. Help plus advice please
  151. Will these headers work?
  152. Pics of ARH headers
  153. Damn intake broke!
  154. Electric cutout install help (need write up)
  155. Header Install...Which codes are thrown?
  156. bbk tb on 98 trans am
  157. Is Corsa really that much better than Magnaflow?
  158. sponsors: Who carries Magnaflow Metallic Spun Cats?
  159. Help, Can't get oil filter off buddy's 1500
  160. size of bolts that hold the fast intake together??
  161. AIR question
  162. universal X pipe question
  163. Down to deciding headers finally
  164. need intake help ASAP
  165. Installed Heads and Intake
  166. What is an 04 LS6 worth?
  167. are my injectors big enough?
  168. Bent header.
  169. High Quality Catch Can - Pics Inside
  170. Pictures of your 4150 style throttle bodies?
  171. Any way to stay street legal?
  172. timing chain
  173. Installed a few Goodies
  174. Thorttle Body Spring FRE 91 mm
  175. What should a car like mine generally run with these mods?
  176. Cutout Question
  177. knock sensors tuned out
  178. Quick release steering wheel?
  179. Turndowns!????lookin for some!
  180. Will a dual-in dual-out muffler give you all the benefits of an X pipe?
  181. oil filter housing question
  182. Does anyone Make a 3.5in ORY 2 fit 3in Header Collectors?
  183. Can't decide what company to buy from?
  184. does any one have an engine pic
  185. need intake help ASAP
  186. Will 01-02 MAC headers work on 98,99,00
  187. Installing crossbrace after headers and ypipe??
  188. Clear LS1 Air Lids ----> Back In Stock!
  189. new jersey inspection(LTS&ORY)
  190. Guide to a fun/reliable car?
  191. Electric exhaust cutout pissing me off!
  192. corvette manifolds
  193. Can I Grind This Tab?
  194. EGR/AIR Plates
  195. Just picked up set of used headers.
  196. QTP cut-out
  197. LS6 Intake
  198. Cutouts?
  199. ls1 questions
  200. LTs + ORY on '02 Z28 - am I missing anything?
  201. 243 question
  202. Home depot catch can
  203. how to bypass power steering cooler
  204. MAF problem
  205. quick Exhaust question
  206. Should I add a Fast 90/92 or a ported 90/92??
  207. Stock Catback too restrictive for my mods?
  208. Shit ! Little Help Again!
  209. Removing cats
  210. Coil Packs Question
  211. Need help did tune up on 98 ls1 with msd wires and its misfiring now.
  212. EGR/AIR removal. Do i need this?
  213. fast 92mm swap into 2001 z06
  214. Does the TSP duals mount up with the LPP headers?
  215. Epoxy with FAST intake
  216. 1 3/4 LPP headers or TSP 1 7/8 headers??
  217. how do i make the most power on a stock bottom end ls1?????
  218. Harlin 2step wiring question
  219. how come noone runs the typhoon?
  220. Oil Dipstick Tube Stuck
  221. Covers over MSD wires?
  222. Shorty to Pacesetter LT. GAIN???
  223. Used cats
  224. msd timing twister or lingenfelter timing controller
  225. LPP Header install
  226. at a loss on header install
  227. My car is running like crap!
  228. ok to re use head gaskets with 0 miles?
  229. Anyone have LPP headers?
  230. Which cat?
  231. Flowmaster Merge & Spohn TA/Underbody Brace
  232. water in pcv oil catch can
  233. v band clamps leaking, WTF?
  234. True dual mufflers?
  235. Ported intake?
  236. Lanes true duals?? Anyone??
  237. FAST throttle body
  238. porting stock exshaust manifold
  239. Brakes squeaking- help me!
  240. Header suggestion
  241. Question about Headers
  242. Question about Coils?
  243. NO OIL PRESSURE.. first crank up
  244. Looking for bolt on mods for 06 Silverado 1500.
  245. Intake help QUICK!
  246. Wiring harness help... looking for quick response???
  247. CME Question
  248. LPP Header and Y install with Maxflow catback.
  249. Header install gone bad.
  250. what size hardware for GMPP intake?
