View Full Version : Generation III External Engine
- EGR Question
- Pulley Question
- Car running really rich after headers
- Who makes boltin or custom radiators for the LS F cars?
- Lid?
- What Is On Your 2007 Wish List For New Products??
- cc503 vid: Cold start
- stock c/b with hooker muffler/ cut out restriction?
- How's this look? (Catch can)
- ppl with FAST 90 THROTTLE BODY please come in
- Need Advice!!
- True Dual set up... idk what mufflers to choose?
- Turbo LS1 in a small airplane
- GMMG with Longtubes and ORY
- Coil pack wiring extension???
- finally got my TRUE DUALS!!! clip inside!
- Fast 90 porting???
- Question on year of cats ?
- Louder? Magnaflow or Hooker muffler
- are expensive wires worth it?
- Do I Need O2 Sensors???
- best exhaust tips??
- PCV hose collapsed
- High Mileage Engine (Heads & Cam Swap)?
- Ls6 Intake
- open headers?
- PP Typhoon Intake - For Sale Yet? How much?
- Exhaust Hanger Replacement
- F.A.S.T. Intake or carb setup !!!
- Gutting cats
- cats
- Gotta replace water pump
- Engine prep ?'s
- Difference between FAST 90mm and NW 90mm?
- Lt's, ORY, stock catback question..
- hp gain with true duals
- ls6 heads
- Aluminium exhaust, can it be done? and negtive things?
- How much this worth?
- Burns racing mufflers experience anyone
- anyone have luck getting SLP headers to seal
- Passenger Side Front O2 Sensors????>?
- O2 Simulators!
- slp headers on vette
- California exaust set up?
- Help !! Bbk Tb Feels Like Its Sticking
- Getting My TB P&P
- Throttle body bumpstop mod, Question
- Weiand Intake?
- ls6 intake or not?
- DynaTech Test Pipes
- Switching to TD's, have some questions..
- Problem !
- true duals vs y pipe/catback
- Gut cats with just catbacks?
- Spark plugs
- What catback?
- window switch and e-cutout is it possible?
- muffler with turndown or tailpipes
- vacuum pump.............
- Stainless or Coated Headers?
- y pipe for jet hots!!
- Cam Install Question AC Recharge
- LS6 Pro fogger intake; what size pill for 100 shot.
- length of bullet?
- QTP or Hooker headers.
- bad cats?
- ported fast 78 vs ls6 intake RESULTS
- QTP dual cut out y-pipe or true dual??
- Exhaust manifold numbers for ZL1???
- Removing stock exhaust??
- True Duals and ground clearance
- poly motor mounts....need help
- Headers, Y, Cat delete Help!
- Headers
- Tool for changing spark plugs?????
- LS6 Intake Questions
- Help withe header choise look in side.
- Check engine light....
- Finally Installing my first mod.
- HELP! He Spliced my 02 sensor wires!
- port my TB?
- Header Question
- Longtubes & Y-pipe 3rd Gen...
- Cutout question with borla
- True Duals or not?
- cat problem
- Will a FAST 90/90 Help me that much?
- Lsx Tv Is On
- Deleting pcv...
- Need Help, driver side header install
- Will TDs Hurt My Performance?
- Ported MAF. Does it help or hurt?
- Cost for a straight ls1 swap?
- Where can I get these valve covers (GMPP Cast Bowtie)
- Sheet Metal Intakes
- magnaflow bullets
- Would it be hard to run a torque arm with...
- LS6 question
- qtp cut outs
- are smooth bellows crap?
- y pipe question
- QTP cutout question
- G Tech Pro
- pacesetter shorty headers
- pacesetters clearance???
- Suspension
- eliminating the EGR
- !AIR question....
- B&B v. Flowmaster
- quick exhaust clip: LTs/ORY/Magnaflow Catback/Partially Open Cutout
- Need Header help, want to alter headers
- a/c system
- Quick TB question...????
- an easy, cheap breather solution
- New catch can from JEGS
- Exhaust Videos!
- Anyone running QTP LT's w/ ORY and tunnel mounted Torque arm?
- what size TD's for 450-460 hp?
- Fast 90mm TB any good?
- High flow cats on stock exhaust?
- Y-pipe w/cats sound ?
- kooks header with A.I.R. connection wrong
- 180 degree headers
- Headers ???
- O2 sensor problem
- slp resinator question?
- Kooks Headers owners inside please!
- where can i buy this
- LS7 Stock Manifolds
- Exhaust question
- bad cats????
- tips for installing y pipes?
- What is that sound a Magnaflow makes on decel??
- Question concerning Fast?
- Need help
- 12" or 16" or 18" for true duals
- Stock Y-pipe
- Help!!!
- Need a Picture of Stock Tranny Crossmember Area
- A real Nick Williams throtle body??
- guys with Edelbrock intake here!
- Hooker catback or just muffler swap??
- pacesetter tfx catback?
- Pics of my new TD setup...
- Winter Bolt-Ons
- lost a header bolt..
- What's the difference between the F-body and Corvette Powerbond UD Pulleys?
- oh and future mods... HP expectancy?
- 2001 SS.. LS6 Intake Manifold.. non-existent?!?
- Header Install!!!
- Finding the right sound
- Throttle blade sticking after porting
- Huge Exhaust Problems...please Help
- kooks headers..
- Are my headers hurting my numbers?
- 02 sensors and ses light
- GMMG style muffler with Powerpacks?
- Ported MAF, My personal Experience
- LS2 intake on an LS1
- Hooker aerochamber flow well??
- mechanical fan options
- Thread pitch on powerbond pulley?
- need to make 500 RWHP on N20 with no internal mods
- ??Hedman Tork Step Headers
- what are the intake torque specs
- Open X-pipe = Power loss?
- spyral mufflers???
- headers and spark plugs
- NEED HELP! messed up something! (alternator?)
- muffler
- Questiong about CAT placement...
- Need Help!!!
- Which Exhaust Do I Need????????????
- header and emission ??
- Bellows Help!
- XR-1 Muffler
- Tips
- ORY for Stock Manifolds...Help
- Joining the exhaust sound vid club..
- 99 stock manifolds to 2000+ manifolds
- Pics of Tb
- belt annoying!!!help
- Car getting no power? Please help
- Any Fitment Issues with Pacesetters and There Catted Y Pipe?
- MAC header install
- VIDEO'S: True Duals w/ Flowmaster 1 chambers
- Size of Borla Plates???
- '00 LS1 throttle screw location???
- bbk 80mm throttle body
- Nate Ss Boom Tubes
- ground clearance?
- ARP Studs for Headers (Torque Specs)
- Taylor Thundervolt Wire broke on 1st plug change!
- 98-99 and 00-02 header question
- T/D Powersticks
- Long drive open headers
- turbonator for your exhaust
- who mkaes a lid for 90mm tb?
- How does the ORY hook up 2 the headers?
- Sound clips of TD's with magnaflow or 1 chambers
- Installed the LS6 Intake Sunday
- GMMG, need help please!
- will 99 vette intake maifold fit my 98z
- Few questions about header install
- Bolt problem
- Intersting Cutout Loaction
- 3k to spend, what can I get
- quick breather question
- belt problem???
- Quick Q: Hooker AC Muffler, 3"-3" (centered)
- Post up pics of exhaust from the rear of car
- Pacesetters from Speed Inc?
- Question
- Jet Hot Header ?
- Tune?
- Looking for chrome stock exhaust tips
- oil cap neck thingy
- headers
- pulleys
- Is hooker better quality then pacesetter?
- Need Help Immediately!!!!
- Install guide: Katech Billet Belt tensioner
- Header + Duals Issue
- 160 thermostat issue
- BEST cut outs
- help with high idle problem
- PCV Sytem Idea
- Overheating Problem!!! Help!!!
- Need suggestions for cat.
- Underdrive Pulley Bolts and Belts
- Post any pics of True Dual cars that are lowered...
- What Do You Think Of This Exhaust Combination
- Post pics of your CUSTOM y pipes!!
- Mac Mid's + ORY + LM1 clips anyone?
- Going w/Pacesetters, any other info?
- UD pulley install question....concern...
- flipping fuel lines
- Cutout Placement Problems with LM?
- Dented Headers really effect your performance?
- which to buy: sprial vs. flo pro twisters?
- Intake & Filter??
- anyone have a problem with kooks hearders?
- does any place rent out exhaust separators?
- Where to buy True Duals
- Spark plug gap??
- Question About SLP Y-Pipe with Loudmouth II
- Interchangeable MAF sensor HELP!!!!!!!!!
- 12455209 - WS6 Lower Air Box
