PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 [210] 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. water temp sending unit adapter
  2. stock LS1-Ls6 intake mouth size?
  3. Stock LS6 intake mouth inlet size
  4. Shorty headers y-pipe recommendations for a california car
  5. One man LT installation?
  6. Is the NW throttle body supposed to be like this?
  7. Do your true duals fit?
  8. FIPK guys inside! K&N part # help!
  9. Spark Plug Indexing / Pencil Torching
  10. Throttle Cable?
  11. Timing chain and pulley question
  12. Help me decide...
  13. LTs w/ 2.5in y question
  14. flowmaster cat on 98 ta
  15. Installed my motor mounts. (summary inside)
  16. tick and squeek
  17. QTP's any day now...
  18. flowmaster vid
  19. K&N filters
  20. Mufflex single exit with Spintech muffler....pics or info??
  21. SLP LT's??????????
  22. Ported and painted FAST 90 pics
  23. mounting the FAST 90
  24. Ory Hooker Vs Pacesetter
  25. X-pipe
  26. Got my Magnamouth done
  27. Where to buy the clips that hold the lid down?
  28. Catted Y-pipe rocks ! - disbelievers come in !!!
  29. Thoughts about Magnaflow catbacks
  30. coolant temp sensor
  31. help please trying to relocate battery
  32. airlid=problems?
  33. Torque spec
  34. Katech valvecovers, powdercoated metallic blue
  35. Gmmg Day!!
  36. True Duals...
  37. How to seperate pipes?
  38. need some info on porting a fast intake.
  39. Car's dying after header install....
  40. new custom catback is on...(PICS no 56K)
  41. Fast 78mm throttle body?
  42. Whistle
  43. 10% underdrive
  44. Help, anyone running a proform adjustable shiftlight on there 98 t/a-camaro
  45. To do a cut out or not to do a cut out
  46. SLP Lt's?
  47. Fuel rail assembled how?
  48. truck intake
  49. Exhaust for 427 small block
  50. Stock y-pipe diameter
  51. Anyone complain about NW90 TB?
  52. Kooks Vs. Brocks
  53. FAST 90/90 vs. ls6 & ported TB
  54. 85mm lid vs. FIPK, did some calculations
  55. Exhaust leak...help!
  56. Valve Covers (pcv hook ups)
  57. Short belt mod ?
  58. Will exhaust leaks hurt performance?
  59. 90mm Nick Williams question
  60. Flowpac with Ram Air
  61. Maf?
  62. Kooks ORY......
  63. Pacesetter Longtubes / TSP ORY / TSP Rumbler
  64. header bolts, and tsp bolts
  65. egr block off kit to fit slp ls6 intake
  66. Getting rid of td for y/cb.
  67. QTP LTs...What catted Y pipe?? Jethot LT?
  68. phase 1 complete
  69. Pacesetter Headers(probably been asked)
  70. header install front 02 code?
  71. Jet Hot headers and Pacesetter Y-pipe.. will it work?
  72. my vic jr conversion pics/thoughts
  73. Coil relocation for ET Heads??? Anyone?
  74. Easiest install, pacesetters or ls6 int
  75. Lt's,ory, Magnaflow And Rasp?
  76. I want to quiet down my exhaust...
  77. O2 Question - Heat protector boot on wire
  78. no power steering
  79. Torque of header bolts?
  80. Question about porting FAST intake
  81. Cutout Convertible Top Switch
  82. Question for guys with Bassani Catback
  83. mac header and ypipe ???
  84. TSP catted y pipe
  85. NW TB question
  86. Corvette Exhaust (Corsa) Tips
  87. LPE High Flow Maf/LPE Cold Air Intake C-5 System
  88. ls6 intake
  89. headers..
  90. SLP header kit???
  91. Questions about Dual/Dual
  92. Headers/exhaust for 06 TrailBlazer SS?
  93. supertrapp muffler! after turbo??
  94. Who to trust port-matching a FAST intake to ETP heads?
  95. Pacesetters,kooks,or QTP?
  96. SLP 85MM MAFS question
  97. Question: Hacking stock 98-02 manifold
  98. is GMMG loud???
  99. worth the swap?
  100. ? on header/ intake install
  101. LS2 intake on LS1?
  102. Swap suncoast air box for reg lid.....
  103. Bassani Duals Installed with Hooker Headers
  104. write up on intake install needed
  105. Ls6 intake/exhaust/tune help
  106. Porting stock TB?
  107. Fuel-line Quick Disconnect Tool Necessary?
  108. Intake question
  109. pros and cons to poly motor mounts?
  110. how much material to remove from TB
  111. TB porting, and aluminum filings...
  112. header install...help please
  113. starter!!!!
  114. Intake comparisons > LS1 vs LS2 vs LS6 vs FAST w/ 78mm & 90 mm
  115. Need help with fast intake and NW tb!!!!!
  116. LS6 PCV Pipe - GM P/N HELP!
  117. Did you feel a difference?
  118. power differance between mid and long tube headers
  119. ls6 intake ?
  120. 28' Bullets.....OOPSY?
  121. Anyone have a header install link.
  122. Couple bolt on ?'s.
  123. Difference in hp between these 2?
  124. Motor mounts
  125. water pump leak
  126. dynomax bullet 23inch long vs 16inch long difference?
  127. What to do for a Y
  128. question about cme setup
  129. msd for 2002 lsi
  130. Y-pipe to floor clearance (PICS)
  131. Pinning Damper to Crankshaft
  132. Which LT's to use
  133. Granatelli plug wires?
  134. Broken intake manifold stud
  135. Long tubes Catless y-pipe, stock cat back?
  136. Victor vs Fast 90mm LSX
  137. True dual mufflers
  138. K & N FIPK with 85mm MAF...anyone done it?
  139. SLP LOudmouth
  140. Advice please
  141. which intake for carb 5.3 or 5.7 ls1?
  142. Header install questions???????
  143. Mandrel bent tubing?
  144. LTs ORY, stock muffler
  145. porting fast 90, which are the best bits
  146. Open Header Question
  147. LS6 heads/LS1 headers, which gasket?
  148. LS1 Headers- ?
  149. Sending units- Nordskog Gauges
  150. Pedal Slack
  151. A/C system weak links ?
  152. Does someone make a panhard rod for dual exhaust?
  153. any tips?
  154. Would you guys recoomend the LS6 intake with stock heads?
  155. Need Stainless Steel Gaskets for manifolds
  156. B & B Cat backs
  157. c5 with fast 90 intake and ls2 tb
  158. Stock maf vs. SLP's 85 mm
  159. radiator hose ???
  160. Anyone ever seen/heard/used these cats?
  161. Need help and opinions
  162. LS6 intake + what affordable throttle body nets the best results?
  163. Where To Put Cutout??
  164. SLP LT guys....what ORY?
  165. K&N Short Oil Filter Part #
  166. tips
  167. dynomax, dissapointment?
  168. Which Kooks?
  169. Video:2.5" TD's with 1 Chambers
  170. What size belts for ASP pulley???
  171. Does any1 make a 4" inlet to dual 3" muffler?
  172. My new exhaust...(Edelbrock Victor Jr's) pics
  173. camaro wide mouth air induction?
  174. SLP loudmouth & lt's?
  175. quick question
  176. stop running rich until tune?
  177. Mail
  178. best intake......
  179. y pipe bangin curious ??
  180. Installed New wires and plugs high idle
  181. How does a F.A.S.T. intake compare with...?
  182. Volant intake?
  183. Exhaust Bangs No More!!! Poly intalled today..
  184. Catback or True Duals?
  185. Does Dynatech SuperMaxx system clear UMI 3pt SFC's?
  186. TSP True duals and torque arm???
  187. Pacesetter Long Tube Install...Need Help.
  188. FAST intake question
  189. Headers...
  190. What exhaust to keep CME?
  191. Lost...which Headers Should I Buy
  192. Quiet LM2
  193. Anyone run True Duals with LT1 Mac Mids?
  194. dynomax bullets.
  195. PCV Delete - Using AIR Pump for Crankcase Vacuum?
  196. TB porting...What is good to use to fill in holes?
  197. LM II to XR-1
  198. What do you guys think of these True Duals?
  199. Which LT w/ my UMI SFCs?
  200. Ram air hood switch induction?
  201. LT's with dual e cutouts
  202. !AIR Question
  203. Exhaust connections - which is better for what...
  204. Different Air Question
  205. do i need a retune?
  206. stainless works headers
  207. stainless works headers
  208. What is similar to the BGRA set-up?
  209. e-fans for v6 &v8??
  210. BBK VS Edelbrock (shortys headers)
  211. Can I use stock manifold gaskets?
  212. Anyone Running a TD Side Exit Exhaust?
  213. Gmmg
  214. o2 sims or have the computer reprogrammed?
  215. anybody seen or heard of this?
  216. TR55s car run like crap feels down on power
  217. Underdrive alt. pulley for LS1?
  218. TSP dual users quick questions
  219. Are denso Iridium spark plugs worth it?
  220. LM question
  221. Question about muffler/exhaust note
  222. Need help choosing gauges for pillar...
  223. This will work !!!!!!
  224. FAST 90/90 preinstall
  225. Sweet-thunders?
  226. could welding fry the computer?
  227. Cat. Cut Off?
  228. Cat. Cut Off?
  229. Stock Exhaust What part is the most restrictive?
  230. Lm & Headers sound
  231. armor or jethot
  232. egr or no egr headers
  233. speed 10000 NX 85mm throttle body
  234. Stainless Catted Y ?
  235. Slip on collectors
  236. question on ls6 intake
  237. FAST manifold permanant air leak fix
  238. BBK 80mm throttle body ?
  239. LS1 intakes on ebay, look like LS6
  240. The start to my true duals..(pics)
  241. spark plug gaps
  242. spark plug gaps
  243. TCS Questions?
  244. info needed about headers and tune, heard rumor
  245. Cat Y-pipe or Magnamouth for my Loudmouth with Headers?
  246. Needing some help
  247. exhaust pic collection
  248. What tips for my GMMG?
  249. help, Need Advice on True Duals!
  250. water pump
