PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. 42lb injectors on bolt-on car? yay or neh
  2. What does Basic Operating RPM Range on an intake mean?
  3. LS1 to LS6 intake, PP or Fast Intake
  4. Should I keep it or not!
  5. Should I keep it or not!
  6. pcv ?
  7. TSP catted y-pipe..wtf?
  8. 02 extensions
  9. which heads?
  10. Flowtech headers
  11. Opinions on this setup.
  12. Quietest muffler options for cammed car
  13. Billet Power Steering Pulley
  14. Needing some GM Part #'s...
  15. Worth porting an LS6 int with my setup?
  16. PRC 215s vs PRC LS6 stage 1 Heads
  17. White "X" on back side of cylinder head?
  18. ARH exhaust manifold gaskets with stock manifold
  19. Noob question
  20. anyone had experience with ls2 intake manifold?
  21. Which is better ls6 or ls2 intake
  22. Question on the LSX Block
  23. SLP MAF question with tune
  24. Milky Anti-freeze. Oil is clean.
  25. installing duals.. any tips
  26. SLP LTs touching harness... HELP!
  27. Tsp true duals
  28. 99 ls1 with mac headers , egr and air delete tips
  29. Fast 102 untuned
  30. Different types of mufflers
  31. Custom Y-pipe...cut used? or buy bent pipe?
  32. Oil pan bolts... all the same?
  33. where should it be?
  34. Headers/Exhaust
  35. Which would be faster in THEORY???
  36. New lid suggestion
  37. exhaust loud
  38. Looking to buy hooker headers.
  39. underdrive pulley and mps gains?
  40. Cats and y-pipe
  41. Help with intake install!!
  42. 4150 TB users, step inside.
  43. Freeze plug!!
  44. Smoke in engine bay after L/T header install..?
  45. LS1 & LT1 maf
  46. Where to get a new Fast 92mm Intake?
  47. !!!!EDelbrock SUper Victor or Victor jr???????
  48. All right, guys. I need some help with my on dash BRAKE light.
  49. Vendors: Norris Catch Cans in Stock?
  50. LT y-pipes...inside
  51. Headers on a 383
  52. Crank pulley wobling??
  53. Whats the story on these headers
  54. MSD plug wire issue with 01 WS6
  55. adding a cutout to 2otl catback
  56. Which intake for 90mm tb?
  57. My Budget Exhaust (with track results)
  58. Best y-pipe for my setup
  59. drive belt setup..no a/c or P/S
  60. What 3.5" muffler?
  61. Intake oil leak?
  62. NEED HELP car wont start
  63. ls6 exhaust manifold and plugs
  64. who sells the best cold air kit
  65. 90mm throttle body on BBK Question
  66. maf
  67. CORSA vs MAGNAFLOW
  68. anyone got a stainless works 3.5 inch catback
  69. Next mods?
  70. What RPM should I be shifting at?
  71. New duals finished
  72. More accurate O2 sensor than stock?
  73. Worth it to port LS6 intake?
  74. Motor mounts!!
  75. LS1 Coils
  76. how much HP?
  77. Ls2 maf
  78. oil pressure sensor/ guage
  79. Looking for a LS1 tech in Hawaii
  80. KooKs True Duals
  81. I just picked up a used Meziere water pump, how do I test it?
  82. Truck Manifold w/o turbo
  83. relocated coil packs now what wires?
  84. what are my options - larger maf & lid
  85. Swapping to LS6 pcv got a quick question
  86. Catch Can question
  87. mods to use victor jr manifold and low elbow
  88. harness and computer newbie question
  89. Headers and Daily Driving
  90. issues after minor "modifications"
  91. Crossflow Muffler Questions
  92. wtb 1.85 rockers
  93. LQ4 Identification
  94. picked up a 6.0 got a question
  95. anyone with a starter from kragen?
  96. quick question...
  97. Dual Cutouts Behind Headers?
  98. aps intake?????????????
  99. SLP PowerFlo CB I-pipe?
  100. PICS OF CUSTOM TRUE DUALS with BMR TRAK PAK TQ ARM???
  101. Catch Can and PCV Routing
  102. Low Profile 5.3 vortec oil pan
  103. Any hp gain from modifing TSP y?
  104. About to pull the trigger on TSP duals...last minute advice
  105. Header Q's
  106. Card style MAF
  107. Q about over axle cb pipe
  108. How much tuning required to run an off road Y?
  109. whats this crap in my catch can! help
  110. question about cold air/ ram air installation
  111. junkyard LQ4 or LQ9 for 6.0 w/ .030" milled L92
  112. Stutter or stumble under slow acceleration?
  113. Best headers/y pipe for an eps cam...?
  114. Engine Cuts Out
  115. overheating issues change stat
  116. LH8 oil pan for LS1 engine swap???
  117. Guys Running regular Y's no coating..
  118. IAT sensor?
  119. 92MM Throttle Bodies
  120. Any idea where I can find this? (exhaust)
  121. fel pro intake gaskets?
  122. Throttle body flange dimensions? 4150 Dimensions?
  123. overheating issue
  124. gmmg out of business?
  125. is my pcv set up correctly? (pics)
  126. LQ4 Throttle Body
  127. HELP! 2000 Z28 turns over but no start.
  128. would a hole in the oil dipstick tube...
  129. LS3 Manifold on 317 heads
  130. 1 solid motor mount
  131. oil breather element, yes or nah??
  132. new exhaust, magnaflow true duals
  133. Has anyone purchased from speed tweekerz
  134. HOW do you install Solid Motor Mounts!!??
  135. used FAST 92mm intake
  136. Header paint/coating question
  137. whistling noise all of a sudden
  138. LS7 LUK OEM unsprung Clutch disk? Help ID
  139. Qtp headers problem with secondary air injectionsystem
  140. spintech true dual
  141. Easiest way to turn motor over??
  142. Best Catch Can??
  143. What 4' muffler for mufflex type exhaust
  144. loudmouth true duals
  145. What pulley is this??
  146. Will I make it
  147. Engine oil weight wright-up!..???
  148. Nick Williams 102 Throttle Body
  149. Who has the best deal on a ls1 underdrive pulley to fit camaro/GTO
  150. car running rich and stalls
  151. 99 formy lowered on eibach what lt headers for ground clearance .
  152. Victor Jr Efi V.s Super Victor Efi?
  153. FAST 90 mm TB. TPS reads 0% at all throttle positions. Which wire? Sensor?
  154. bbk vs ls2 intake
  155. Y pipe Exhaust hanger
  156. Guages going haywire
  157. 99 M6. Opinions on making a good DD????
  158. difference in ls1 throttle bodies is 98 different
  159. call me dumb...
  160. LS1 1999 Z-28 Valve Cover Gasket Replacement
  161. 98 into a 99
  162. New Edelbrock Stainless LTs
  163. Best exhaust sound
  164. Non-Mandrel bends, but larger diameter
  165. Who sells a replacement throttle body gasket for a 92mm fast intake?
  166. 100mm MAF - Does it require a retune
  167. Bout to buy ss... Maybe
  168. help with mods?
  169. SLP Cat Back, VS. BORLA Cat Back!
  170. Water Ingestion lol
  171. high idle problems
  172. Ewp
  173. Damaged muffler?
  174. Help with spark plugs!!!
  175. LQ4 guesstimated HP?
  176. Old electronics, on a new 6.0 engine
  177. How does my P&P TB look? with pics
  178. Is fast lower shell part# 54006 discontinue??
  179. P&P TB problem..
  180. injectors
  181. LS1 Overheating
  182. CME on a Loudmouth
  183. LS1-LS6 Swap
  184. looking for good p/n and supplier for ls1 idler pulley
  185. ls3 intake?
  186. 2000 trans am headers
  187. LS1 Valve Cover Breather/// PCV Valve (NEW DESIGN)
  188. Exhaust, intake, headers tune
  189. ls1 wire harness plug diagram
  190. 10 bolt rear end wont cut it..
  191. NGK plug question
  192. I have a FAST 102
  193. Anyone using a 100mm mass air??
  194. LS1 Headers
  195. intake bolt question
  196. TSP or Pacesetter O/R Y pipe
  197. Who makes the best intake setup
  198. Ls6 : Whats a good intake manifold? Edlebrock proflo?
  199. Massive exhaust leak..
  200. Intake Manifold and Cam ?'s
  201. Will a 2005 ls6 corvette harness work with a 2006 gto ls2 engine?
  202. Plastic Hose Intake?
  203. Tac Issues (throttle body)
  204. Intake/injector question
  205. impact plastic behind bumper
  206. PS install, rather post install pics of passenger side please
  207. SLP underdrive pulley.. need different belts?
  208. Kooks y-pipe with non kooks headers?
  209. Get Kookin With Kooks Contest
  210. Slave cylinder question
  211. Header question?
  212. Best true dual package!
  213. Dont know where to post, but here goes.... 99 Camaro SS.. Need advice!
  214. 02 ss a4 misfire
  215. ls1 dead cylinder Help
  216. Breather tank
  217. driveability issues please help...
  218. fuel
  219. Finished FAST 102 install. Have some issues
  220. mufflex owners please step in
  221. Daily Driver exhaust questions!
  222. Paint Stock Coil Packs?
  223. msd coils
  224. Fluid Dampr or ATI?
  225. HELP: what lid and MAF???
  226. Anyone Installed an Edelbrock Carb Kit??
  227. Can you safely weld headers?
  228. Vacuum With Larger Cams
  229. lil Help Please. What does this plug into???
  230. question about exhaust tone. . .
  231. what a freakin night! :/
  232. anyone got a good clip of a BorlaMouth
  233. TSP forget a pipe?
  234. FAST 102 Vacuum Leak problem
  235. Which head is worth porting
  236. What did you use for block off plates?
  237. what power adder works best with a tourqer v3
  238. Have you ever heard a raspy, catted ls1?
  239. ls6 intake swap
  240. Quiestest Mufflers to weld into catback?
  241. Headers... Shorty, mids and lt's
  242. meziere street pump question
  243. ls1 underdrive pulley differences?
  244. Starter grinding after trans swap
  245. No Spark!
  246. Springs- Comp, Patriot, Lunati Are they all pretty much the same ?
  247. few little extras to the car over winter
  248. Hooker catback install question
  249. True Duals dumped after axle like old 1st Gen Camaros?
  250. cooling helpp!!
