PDA
View Full Version : Generation III External Engine
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Idle/Startup - TPS & IAC problems
  2. 02 Firebird exhausts suggestions
  3. 2000 Chevy 2500 6.0 lQ4 going into limp mode
  4. two broken header bolts/ will the exhaust repair brackets works with headers?
  5. Truck throttle body vs larger tb with adapter
  6. 5th Gen Camaro alternator and bracket on Gen 3 block
  7. Any remedies to mitigate turbulence in air intake?
  8. Valley cover cut
  9. Tensioner Relocation
  10. 98 SS SLP intake paper air filter numbers
  11. Knock Sensor Connector Location
  12. Electric Waterpump?
  13. Lower intake lower shell swap
  14. 408 stroker oil pan windage tray
  15. 5.3 LM& Misfire (internal or external?)
  16. 2001 LS1 - Connector ID please?
  17. Evening all, Need some input please
  18. Quick truck intake question
  19. 2001 5.3 LM7 Starter Issues
  20. Timing Chain Cover
  21. electric waterpump and ud pulley?
  22. e 85 flex sensor
  23. DBW TB to LS6 intake
  24. Steam pipe to radiator hose routing.
  25. lm7 5.3 oil temp?
  26. Exhaust Heat Shield Bolt Size
  27. Part number help for air smog pump piece
  28. LS6 Build Advice
  29. Holley 90mm tapered throttle body...
  30. Belt Length/Part number
  31. Compact DBW TB
  32. Headers interfere with steering shaft
  33. Dorman 264-969 valve cover
  34. 95mm TB on a LS2 intake?
  35. Harmonic Balancer for 5.3L (LM7) with truck accessories
  36. Coolant crossover question
  37. Throttle body without vent tube?
  38. Aptiv (Delphi) connector for Coolant Temperature Sensor
  39. 2002-LS1 EGR/AIR Delete with Header Install Questions
  40. 2004 lq4 intake manifold
  41. Duals vs Duals into y vs single
  42. Possible vaccum leak
  43. LS1 Powermaster Starter Shimming
  44. F-Body Hooker Blackheart - anyone add bullet cats?
  45. What's leaking at the back of my engine? Everything?
  46. '99 383, oil burner
  47. Maf and iat location ideas
  48. Cleaning an Alternator?
  49. Perma-cool 19111 review?
  50. Fbody power steering pump conversion?!?!?
  51. Replace K&N FIPK with Slp Lid
  52. Quality 4 bolt 102 DBC throttle body
  53. BTR LS7 lifters?
  54. What's Been Deleted Here?
  55. 5.3 truck engin and accessories bracket help needed
  56. Best LS-1 ITB Intake
  57. Heat shrink hose clamps... Are they any good?
  58. whats this?
  59. Need an entire 98-02 f-body a/c system
  60. 5.3 with LS6 parts. Catch can install?
  61. Valve covers...Orientation???
  62. Gen 4 in gen 3 swap oil pressure sensor question
  63. Extremely cheap 96MM and 101MM throttle bodies!
  64. A/C Removal
  65. Direct replacement muffler options for my Borla 140028?
  66. Motion Raceworks catch can setup question (with diagram)
  67. Ls6 or Ls2
  68. 0 oil pressure on gauge
  69. Y-pipe slp31035
  70. ls1-6 intake install pics please
  71. WS6 max effort NA Mamo build
  72. Manual fan switch/over cooling
  73. Over it, want a quiet option
  74. 6.0 ls what all u can delete?
  75. P0101 code on 05 lq4
  76. LS3 Dipstick vs Truck Dipstick
  77. LS3 injectors on Fast 102
  78. Coil swap help
  79. Cai
  80. Billet Front Accessory Brackets
  81. Correct MAF adapter harness
  82. Balencer won’t budge
  83. Help With PCV/Catch Can Routing & Holley Valve Covers
  84. LM7 coil packs electrical discharge
  85. 5th Gen exhaust question
  86. Mystery PCV System *Please Help*
  87. Power steering pulley
  88. 5.3 build
  89. Is an electric water pump reliable?
  90. Does Installing a Larger Throttle Body Require a New Tune/Computer Update??
  91. 2002 trans am WS6 GMMG catback
  92. balancer install?
  93. Improved Racing Oil Catch Can Kit for LS Engines
  94. Speed Engineering True Dual Exhaust *VIDEO CLIP*
  95. Intake /throttle body angle problem...resolution???
  96. Off road Y versus SLP Catted
  97. 2005 z71 help
  98. 2000 C5 Corvette Catch Can PCV System
  99. Air pump/valve related quesiton
  100. tbss intake swap
  101. 100mm MAF
  102. Help needed with PCV/vacuum lines
  103. Oil Cooler Block Off Gasket
  104. Crank bolt backed out how to prevent it again
  105. Fast 102/ Tower Brace
  106. Holley MPFI TB intake
  107. Help choosing mufflers
  108. Anyone remote coils behind the dash inside the car???
  109. 1999 Firebird exhaust options?
  110. Looking to replace intake manifold. Need advice and confirmation of fit.
  111. Throttle Body Porting?
  112. Holley mid-mount Harmonic Balancer Damper size
  113. raising stock air box
  114. Added ls6 intake now throttle is open 1/4 of the way
  115. Ls Intakes
  116. How to install steam port system
  117. Pulled motor and found a mystery plug
  118. Long tubes, fast92 with NWTB and fast fuel rails & tune HP?
  119. Can anyone tell me what this bolt is for???
  120. Water pump leakage
  121. Header/tune
  122. CYlinders 1,4,6 and 7 coils not firing
  123. How does this make you feel?
  124. Exhaust flange/exhaust to headers torque spec
  125. Quiet Exhaust Setup
  126. What Y pipe to go with?
  127. Alt, Batt, Surging issues - 02 Trans Am
  128. Plug wires - 02 T/A with 1-7/8 headers
  129. Idle goes up and down.
  130. ATI super damper help
  131. Is this ok? Steam vent port to water pump spacer
  132. Bolt length to head for engine removal
  133. bell housing bolts
  134. Serpentine belt tensioner take up
  135. Need help Converting 4th gen fbody to 6AN
  136. 5.3 dual exhaust design???
  137. Anyone tried the Amazon 4th Gen F-body oil pans?
  138. neutral safety switch help
  139. 180* or 195* thermostat
  140. 4.8L with LS6 intake
  141. Help with LS1 Water Pump part numbers.
  142. Fuel Rail Connection with tall valve covers
  143. ECM Pin out needed.
  144. fast 102 vs btr equalizer?
  145. Swivel thermostat housing (or different options) for LS3?
  146. Intake options
  147. 3d print an intake manifold?
  148. Super quick starting LS?
  149. Best lower cost option for slightly louder and deeper exhaust sound.
  150. ls6 intake
  151. Why not cut the runners shorter on the FAST 102 intake?
  152. Who makes a good 102 TB that doesn't whistle?
  153. Nick Williams 102 throttle body question
  154. Nick Williams TB getting stuck a common issue?
  155. Fast 102
  156. Best catch can ever? ProVent 200
  157. HELP - broke plastic vent connection on NW 102 throttle body
  158. Is there a place to have custom exhaust tips made?
  159. Is this LS6 intake safe to use?
  160. Popping during acceleration
  161. Hard to get into gear at high temp
  162. At what point does the air lid and filter become a restriction?
  163. ported heads 862/706
  164. Throttle Bodies - Holley vs MSD Atomic
  165. Oil sender question. 98 camaro with 2003 5.3 block
  166. Is it normal to have a leak at the throttle body shaft?
  167. What blade style MAF sensor to get for 102.m T.B.???
  168. stock 99 exhaust or aftermarket camaro
  169. L07 Exhaust elbow help
  170. Pulling BCM and Lock Cylinder from Donor Truck
  171. IAC Valve Swap
  172. Fast 92 MAP hole
  173. Lm7 to th350
  174. Muffler Suggestions
  175. Injector and ignition coil help
  176. Header identification! Help!
  177. FIC 550cc EV6 injectors
  178. LQ9 swap misfire- Stumped!
  179. Knock sensors Ls1 vs Ls2 types?
  180. Who makes 2" headers that fit Fbodies?
  181. Speed Engineering headers safety loop
  182. vacuum pump install
  183. Help me choose an Intake - LQ4
  184. Need help with catch can routing
  185. TSP headers vs Kooks or QTP
  186. 98-02 f body exhaust hanger/bracket kit
  187. Excessive oil in intake
  188. 5.3 ls swap throws belt at high rpm
  189. Exhaust questions
  190. LS1 Engine bogging down
  191. Intake & TB questions on a turbo'ed 5.3 build
  192. Nick Williams Throttle Body or Not???
  193. Coolant Thermostat Operation Questions
  194. Oil leak - Oil Pan?
  195. Fast 102 Lxsr to TFS TEA 235 fit.
  196. Coil on Plug setups
  197. Help!! oil sender failure
  198. Looking to relocate my alternator to upper passenger side.
  199. Coolant issue
  200. 5.3 ls MAF sensor what wires go where
  201. Really confused, and don't know why. Intake Gasket Questions.
  202. LSXR 102 broken connector - canister purge fitting?
  203. LS1 Intake Alignment - ports not aligning to gaskets and leaking
  204. LS1 Gen 3 throttle body
  205. Does this sound like a stuck fuel injector?
  206. Pcv fitting for intake/fresh air
  207. Plug wires for headers
  208. Valve cover gasket expanded after removal???
  209. C5Z-LSA swap - new NASTY Squeal
  210. Starter current requirement?
  211. LM7 fuel rail question
  212. What is the strongest/best exhaust manifold gasket for a boosted LS1/LS2 motor?
  213. Question on header swap on 00 ws6
  214. LS mid plate
  215. Crank, No Start (no Spark) condition on Trans Am 448
  216. Exhausting questions
  217. Got fuel and spark but no start. Just flames out the tail pipe
  218. Fbody water pump mounted tensioner relocation
  219. Crankcase VENTILATION 5.3 Gen III ?
  220. Stainless vs zinc bolts
  221. Well.. thinking of power adder and need advice.
  222. throttle body question
  223. LS1/6 intake Vacume port
  224. help at Wits end
  225. Alternator not charging, not the typical thread
  226. Problem With 92MM Throttle Body On Amazon or Ebay
  227. DBW on LS6 intake manifold
  228. New Radiator Question
  229. 2005 CTSV LS6 unconnected hose nipples?
  230. O2 sensor effecting LTFT
  231. 6 pin T/B to 8 pin harness
  232. Why would the ICT oil supply adapter not work on a front sump LS1 (GTO)
  233. 4th Gen F-Body mounting bracket for behind the air dam?
  234. LS Powersteering pump conversion and resivoir
  235. Another TBSS Intake Swap Thread
  236. Motion race works icon throttle body leaking boost
  237. LS1 Speedmaster intake injectors
  238. Holley Hi Ram leaking oil from intake runner sealing surface
  239. ATI Superdamper R&R
  240. How to test ignition coil?
  241. Hesitation on acceleration
  242. Any affordable 92mm+ intake manifolds out there?
  243. Catch Can Help Needed Please
  244. coolant reservoir?
  245. 5.3 rebuild no spark
  246. IAC Relearn?
  247. Spark plug selection for increased compression
  248. 4th Gen F-Body oil cooler with fan behind the air dam?
  249. valve cover torque specs
  250. Difference Between LS1 and LS6 Intakes
