PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. LQ4 out of a hummer H2
  2. GM starter questions
  3. Threadlocker for exhaust studs ?
  4. so why are my headers glowing UPDATE!!!!
  5. Help! Exhaust mid pipe is seized to header!
  6. LS2 cam sensor vs LS1?
  7. Dr44 replacement
  8. Protecting painted headers
  9. Need help with intake and TB swap
  10. Valley cover bolt stripped
  11. Question about which flowmaster merge to use
  12. How do I stop my Borla tip from rotating everytime I drive?
  13. TPS Voltages and Holley 105 TB
  14. Question about temperature readings on LS1 swap
  15. 4l60e help!!!
  16. Ls1 sensors
  17. lq4 pinout
  18. LM7 Tensioner
  19. Pedal position not matching throttle body
  20. Oil pan number 12614822
  21. Holley Sniper LS1 Fuel Rail Kit
  22. Crane rocker nuts need asap
  23. Forged ls1 nitrous intake questions
  24. Firehawk Cats
  25. LS1 thermostat ?
  26. Billet LS Oil Pan Front and Rear Cover Alignment Tool Set
  27. trying to replace the truck intake with ls1?
  28. Oil Pan Prep Prior to Installing
  29. HVAC Vacuume line part number
  30. Exhaust Help?
  31. People running eBay headers....
  32. full exhaust research....chime in
  33. American Racing Headers and Wideband Bung?
  34. Truck, 4 Pin, 3 Wire Alternator, 1 Wire Conversion Guide.
  35. True Duals to Y Pipe and Catback
  36. Yuck...this was bad..
  37. 4 inch exhaust or not
  38. Oil entering throttle body from fresh air hose. Check valve?
  39. Fast 102 broken runner, any fixes
  40. Spark Plugs.. NGK TR55 still the best?
  41. Using AN lines for radiator hoses
  42. Dorman ls2 flow# question
  43. Spark plug issue.
  44. Porting services
  45. 4.8 Vortec swap floods on startup help please
  46. Coupler lid options for 102 SD to TB
  47. Need MAF help
  48. Silverado missfire ALMOST solved PLEASE HELP
  49. Speed eng. true dual rear exit exhaust hanger/clamp location
  50. Rear main seal
  51. Speed engineering headers
  52. Intake bolts
  53. My new exhaust setup with dual low profile cutouts
  54. Need help with A/C bracket on Lsa swapped 5.3.
  55. Tsp catted y pipe
  56. Wiring harness?
  57. What water Pump?
  58. Ported 853 heads
  59. LQ4 SFI Harmonic Balancers
  60. From The Headers Back??
  61. Exhaust Setup
  62. Building a N/A 5.3 (First Swap)
  63. black plastic line that runs into throttle body
  64. 413 ls2 vs 6.0 lq4 For turbo application
  65. Schetchy valvesprings?
  66. Tensioner Pulley with EWP
  67. ASR/Cruise activating at idle?
  68. 2k ws6 radiator/wp issue
  69. Squeaky belt or pulley or something else
  70. Intake swap?
  71. ECU question
  72. Maf
  73. Anyone add cats to TSP True Duals?
  74. High torque starter
  75. 2" Primaries....3.5" collectors.......ARH vs Texas Speed........really a difference??
  76. catch can question
  77. manifold help please
  78. Bolt for dipstick tube
  79. Tbss intake
  80. SLP LID Cracked, Try to repair or just replace?
  81. Project Car Help
  82. Front accessories Help
  83. Standard motors pcv
  84. single exit muffler
  85. JEGS / China DBC Throttle bodies
  86. 24x crank sensor bit pattern?
  87. Alternator questions
  88. Fuel pressure
  89. cold air intake question
  90. Hooker Catback, Catted Y, LTs w/Cam??? Final Thoughts Before Purchase?
  91. 615-901 Dorman - need adapter for LS6 throtttle body
  92. Pcv questions
  93. LS7 Exhaust Manifold on LS6
  94. Finally got my heads build time.... but quick question
  95. Magnaflow 18129 vs Magnaflow 14419
  96. Deleting Traction Control on 01 Camaro with 4.8. Which throttle cable?
  97. CAI Or simply cone filter?
  98. LQ4 and T-56, Starter won't engage
  99. Need help on choosing the right MAF...
  100. 02 intake removal
  101. New motor mounts/k-member misaligned
  102. Picked up an LM4 - Track Build
  103. Reman L33 short blocks?
  104. Cutout location
  105. Loud clanking from 1500 to 2k rpms, *resolved*
  106. TSP true duals over the axle recently installed, have questions.
  107. Anyone have Kooks rear exit true duals with cats?
  108. Flywheel, clutch, starter question
  109. Just a few questions
  110. 2000 Trans AM WS6 LS1 Upgrade Kit
  111. Fair Market Value for 2000 Corvette LS1 with 125K?
  112. Add Cats to Speed Engineering ORY
  113. PCV Check Valve Question
  114. Red Loctite- am I screwed?
  115. 92mm maf question.
  116. Wich will fail
  117. L33 to LS6 swap
  118. 4l80e 1-2 servo?
  119. PRC stage 2.5 862 heads
  120. Oil Pressure Sensor Relocation
  121. Stock LS1 with Dorman 615-901 (90mm)?
  122. Headers/catted Y-pipe options?
  123. 98 TA A4 wiring swap
  124. Need Information on heater hose flow direction
  125. Loudmouth 1 w/ LT Headers
  126. Wiring difference 5.3 DBW and LS1 DBW throttle?
  127. Intake Manifold Leak Help
  128. K&N Extreme Flow Air Filter
  129. Anyone try the PHAB catback
  130. Dynomax Bullet exhaust question
  131. LS "transmission squeal" issue..... Vacuum issue?
  132. P1515 Reduced Engine power??
  133. Oil pressure and oil temp for ECU??
  134. Powerstorm gm ls2/6 stage 2 pro series cylinder heads
  135. corsa exahuat
  136. True duals over the axel
  137. GTO pan / LSX innovations oil port adapter. Cant install
  138. Throttle body help!
  139. Fast 90/92 which maf and what size?
  140. Magnaflow 16723 replacement muffler?
  141. any idea why theres metal in the intake
  142. LS6 intake cleaning?
  143. Narrowband A/F Gauge Wiring Question
  144. 5.3 lm7 throttle body help!
  145. injector ?
  146. Ls2 harness will it work with lq9
  147. dorman ls6 intake 615-900 on my 98 ws6
  148. Engine on stand, how to wire battery to turn starter ?
  149. 243/799 heads on same motor
  150. Coolant Resevoir Leak=overheating?
  151. DIY Ls Swap accessory brackets for less than $40
  152. Bellows for MSD 103mm TB to TSP 100mm MAF in 4th gen???
  153. Brake Booster?
  154. Speed density tune?
  155. Edelbrock pro Flo issue
  156. Would swapping intakes be worth it?
  157. Muffler delete kit?
  158. LS6 Valley Cover Swap
  159. L33 cracked starter boss -- fix in place?
  160. What stall
  161. Using a 2011 4l80e with 2005 pcm
  162. Holley Covers and Truck coils
  163. Flip LQ4 steam/coolant tubes to clear ls1 manifold
  164. Exhaust options
  165. ported heads and shorter intake rocker bolts
  166. Problem driving me nuts
  167. Lq4 swap am I forgetting anything?
  168. Yet another blue smoke on startup thread
  169. Ebay Dorman 90mm intake nick Williams tb?
  170. Oil Temp Gauge Suggestions
  171. LS1 Fuel Rail Schrader Valve Port HELP!!!
  172. Difference between 252-846 and 251-744 Water Pumps?
  173. 12 v to neg battery post from alt stud
  174. Another PCV question
  175. Fast 92 disassembly
  176. Starter won't fit?
  177. 10% overdrive pulley on boost
  178. Ideas for new muffler?
  179. Flexplate question
  180. H/C/I opinions for 398"
  181. Going crazy trying to figure MAF / Intake / Air cleaner compatabilty
  182. power steering pully ?
  183. Help Identifying Intake
  184. What size injectors would i need?
  185. Egr block off warning
  186. ls1 lifter or rod knock?
  187. Is a ls1 intake okay?
  188. let's see your 4" catbacks...
  189. TSP Catted Y-Pipe
  190. Engine Change on Truck - Pull Trans Too?
  191. Which heads?
  192. 4l80e question
  193. O-ring for FAST 90mm intake throttle body mount.
  194. Trying to find LS1 75mm Throttle Body
  195. Dual drive by wire throttle bodies?
  196. Lq4??
  197. Injector selection for tbss intake
  198. for those of you that have used lash caps.....
  199. Ed curtis hellraiser ls1!
  200. Is this maf OK to run
  201. Remote water pump routing?
  202. LS1 Alternator I need wire digram
  203. Speed Engineering Y-pipe for 98-02 F-body
  204. Catch Can Fitting On The Oil Filler Cap
  205. LQ4 water pump
  206. Old school look while keeping efi?
  207. LQ4 runs bad after cam swap! Help!!
  208. Installing fast intake trouble
  209. so lets talk air filters
  210. New intake manifold coming from BTR
  211. This powerbond done for?
  212. What throttle cable for 4 barrel throttle body?
  213. Question on using walker exhaust pipes for duals
  214. Advice on new SHP LS Next Nitrous Engine Combo
  215. 2003 lq4 dbw throttle body
  216. Harness routing question
  217. Water temp gauge heat soaking
  218. Cold Air Intake Parts
  219. Vacuum Sound & Injector Ticking?
  220. Anyone selling a borla catback
  221. Need to ID an air cleaner lid
  222. Ls1 water pump pulley
  223. How do you I.D. which intake you have??
  224. oil lines
  225. Porting TBSS Intake (My Approach)
  226. 3k+ vibration ls1 engine
  227. LS6 Intake Bung
  228. i think my car isn't as loud as it should be
  229. What is this?
  230. 4th Gen LS2 Dorman 90mm intake w/ Holley 90mm Sniper TB
  231. Exhaust Size
  232. Catted Y-pipe
  233. Is this underdrive pulley good?
  234. remote mount oil filter LS7 DRY SUMP ,TO RELACE THE FRAM HP4 ,BUT 2INCHES LONGER
  235. Catch can and other related
  236. 4th Gen 3 inch SS Intermediate Exhaust pipe
  237. Bad MAF? Unplugged it and ran better
  238. Funky 1st and 2nd gear
  239. No start, just a click and a burnt connector..coincidence??
  240. Can you add a cut-out to a gmmg exhaust?
  241. Need a 3rd water temperature tapped hole, WHERE?
  242. Adding EGR fitting to LS6 manifold
  243. LS head test...
  244. Water pump always leaks
  245. LM7 acc's on a LQ9 long block?
  246. Which ECU works best for my future combo? MS3Pro or Holley HP
  247. Looking for longtubes anyone selling?
  248. LS1 plug wires
  249. Should I wrap my headers? Why?
  250. Is it possible to hit 400rwhp with this combo?
