View Full Version : Generation III External Engine
- help me choose a catback
- Did a search, couldn't find.. how to convert LS6?
- Homemade, direct bolt-in muffler replacement and....
- ls2 intake question
- mac mids vs. lt's?
- Will LS2 Heads "bolt right in" to a LS1??
- LM2 with lt's?
- CKP, Low Oil Level, Starter Wiring with Headers. Solutions for routing??
- Which Percy gaskets for LT install?
- ticking...
- Oil Pan gaskets????
- Slight hesitation at part throttle?
- injectors
- what the heck is this rattle... with a sound clip... maybe even two
- high flow cats or off road Y?
- finally got headers!!!
- Oil Pan Removal LS6
- Header gasket layers separating
- ---02's---
- Help!! Somebody tell me what this is.
- Anyone Have A Professional Products 85mm Throttle Body??
- AC Problem
- Is Shaner still King of the ported throttle body?
- 2002 Ls1 ???
- Just installed my Loudmouth 1...
- Want to go 12s
- Will lid for a V8 work on a v6 also?
- What would you suggest..
- LS6 Intake VS. Weiand Lingenfelter
- Ported TB Problem
- dual air intake on a C5
- Who makes a good true dual exhaust bolt on???
- true duals...2 quick questions
- Single 3 1/2 over axle?
- Coolant Problem
- Gutting Cats
- Ques. about a Center Mount Ex.
- Has anyones CAT ever broke off?
- MAF help...
- Bolt On Suggestions
- Longtubes, ORY, stock SS catback?
- I have Edelbrock "shorties" on my 98' SS, would full lengths be worth it?
- Ok guys here is one for yea A/C & Cruise Control
- LS6 Intake install / EGR removal - HOWTO
- Dual electric cutouts??
- Thermostat gauge????? Please advise!
- Is It Normal Gettin A Spark From The Very Back Of The Exhasut System?
- Pics of XS LT's with Jet-Hot ORY?
- Which is better...??
- Just bought some headers
- QTP header and y pipe question
- throttle body washer ring around shaft question
- Custom exhaust question pics of...
- bump stop mod disaster
- Victor Jr EFI vs. Fast 90
- DMH Electric Cutout keeps popping fuses.
- 180* Thermostat?
- !egr ?
- Having a problem after LT header mod, please give advice
- balancer?
- Best SFI balancer for LS1?
- 2000 Camaro SS stock TB and MAF?
- Can't get crank pulley off
- Need Help Asap
- About how much HP will I gain with this combo of simple mods? 1999 30th T/A...
- Stainless Steel lower air dam ?
- Hmmmm, Mufflex...
- cutout>flowmaster???
- Custom line locker switch mount
- Intake swap
- Suggestions for duals
- Order of modifications
- how helpfull would a dyno tune be?
- Ignition wire terminals
- header trouble
- 1 7/8 LT's Size difference???
- What radiator hoses do you guys recommend?
- Need hooker catback cam sounds or vids...
- How do you port your stock TB?
- new mass air sensor and intake check engine light help
- LS6 intake swap, now misfire...
- Anyone here know how to recharge a/c?
- How do you port an intake manifold?
- Cracked Radiator
- Oil leak coming from in between the oil filter and motor
- Blowing smoke after LT install?
- Damn Hooker y-pipe!
- Can you buy ONE O2 SIM?
- Volant air intake increases 18hp/40tq?
- QTP or American racing? help me out guys?
- Muffler With Adjustable Internal Baffles
- hooker 1 7/8" headers??????
- need to quiet exhaust "cackle"
- What is this sensor that I broke?
- where to buy tube for lid breather
- Any reason why a truck TB wont work on LS1 intake?
- XS stainless Y-PIPE
- 6500rpms = damage
- my ls6 install w/ ls1 coolant lines. pics inside
- header/ypipe question
- Y Pipe: Merged vs. Slammed
- Guys with SPEED INC. breathers
- oil pan: ls1 to 5.3
- Quick which sensor is this
- oil filler tube removal
- Ported Fast 90/90 Dyno results...
- Simple Ls1 mods
- Stock Crank Pulley differences
- Four Inch Intake Tube.....too BIG?
- Has anyone heard the ls1tech pinks camaro at idle? (vid)
- Rear Main Seal Questions =*(
- A/C Compressor Interchangability.....
- separate radiator for the 4a ?
- ebay sheet metal intake???
- LS6 90 mm manifold does it work?
- Which IAT sensor to use when running an 85mm Truck MAF
- Plain Lid? and Where to Buy?
- Breather filter
- Ls6 vs FAST Intake question
- Duel Duel exhaust sound!
- Which Intake To Buy
- Open headers question?
- Low Coolant light
- LTs and TDs and care is still slow
- Duals finally
- TSP true duals
- Fans run all the time w/160 stat & tune
- water pump need help
- Which Headers?
- exhaust manifold for 5.3 motor
- 500miles on Headers&ORY still no SES. Am I ok???
- flowmast super 44???
- anyone ever use this muffler???
- my ls6 intake install w/ pics and questions.(holy dirty valley)
- Anyone ever used.....
- Best Fit Headers
- Hours labor for dropping and replacing oil pan?
- 3 Hours For Spark Plug Change
- Volant Cold Air
- Header Installation Questions
- How much does XR-1's help on duals?
- new Super 44 Flowmasters?
- Best Place
- Suggestions on Intake Mani's
- 1 7/8" Headers??????
- Help Please
- Steering shaft knuckle rub after new rack/pinion install
- What makes the section of the exhaust on a 98' camaro differ from an 02?'
- header install question
- Anyone w/MTI Clear Lid
- PCV part numbers?
- ASP pulley?
- Edelbrock Headers
- New Pulley Pulling My Belt Off!!!
- Tru Duals On!
- Mac Y
- CME question
- Throttle Body Port & Polish Material Questions
- True Blue, Times Two
- Are all poly motor mounts the same?
- Aftermarket MAF or Stock MAF Ported?
- Random tech poor quality
- LS6 PCV part number???
- where to get stock P/P TBs?
- Underdrive Pulleys
- SLP LM Exhaust needs to be quiet.
- changing valve covers what is needed?????
- Anyone elses Jet-Hot LT's rust up?
- Exhaust Question
- Borlamouth, Dynomouth, or Magnamouth?
- Search Not Working Qtp Headers Questions
- cut out
- Will C5 Corsa tips fit on an F-Body?
- merge collector
- LS6 intake modification
- OMG How to get the second motor mount lined up?
- check engine light after ported TB install
- AC Idler Pulley
- Which intake should I get?
- question about EGR, AIR, and TB bypass
- Rick at SYNERGY
- Your opinion on the Edelbrock RPM XT Heads?
- engine lifting?
- New intake coming out?
- Iridium spark plugs
- Plug wire is driving me NUTS!
- Weiand or LS6?
- Went from catback to duals....
- Needs some opinions on a exhaust set for the car.
- how much for pulley install??
- LS6 Valley cover vs. Catch Can
- 85mm vs 96mm Typhoon intake
- OBX Headers?????
- Cats - how much power do they steal from me...
- Ls6 PCV
- Mufflex 4" Exhaust on 416 with 550rwhp
- summit throttle bodies
- single chamber flows or spintecs?
- Does anyone know.....
- Volant CAI makes annoying whining noise?
- Quick answer,00 tb same as the 01-02 tb
- Bad for the car to drive this way?
- When someone says they have FULL Bolt-Ons...
- benifits of ls6 heads over ls1 heads
- what should i dyno at the rear wheels?
- Edelbrock Header ?
- ported throttle body
- problems wiring up a QTP e-cutout
- What Exhaust Mistakes Have You Made Before You Got it Right?
- What to expect?
- So I Do Not Think That My Oil Catch Can Is Working
- Car failed db inspection. Need help swappin muffler
- Thermostat Install
- Exhaust setup - True duals - Need adivces and opinions
- Which Exhaust Flows More, Mufflex 4inch or 3inch True Duals
- What muffler to pick? Not all of these were on ls1sounds
- coolers, worth it?
- Questions about o2 extensions???
- Homemade smooth bellows?
- My goodness, these are the hotness! Sorry if repost....
- Cam or M6 swap?
- Normal FAST vs ported FAST
- TSP TD's with Hotchkis springs?
- Volant Cold Air Intake
- new headers
- X,H,Y, or straight pipe?
- painted headers.. are they really THAT bad and will they last me here in NY??
- pics of tsp rumbler tips???
- I don't need no stinking lift...
- heads and intake swap? help
- high mileage maintenance
- Power steering cooler install
- exhaust size
- catch can flow
- Hooker Muffler same as Hooker Cat-back?
- off road ypipe options for a 99
- 402 nitrous vs 402 turboed vs ls1 forged
- MAF Testing
- fast 90 vs. victor jr
- Will the QTP Y-pipe fit up to a set of Kooks headers?
- wtf is this rattle!!! help!!! its annoying....
- cracked cat
- Fact or Fiction? Fast Intake and noise
- Holley Powershot Air Filter Cleaner...
- true dual ?s
- Post your true dual vids (over the axle)
- Name that engine/exhaust
- NGK TR55 Plugs gapped at 0.59?
- Pacesetter or Hooker?
