PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 [312] 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. PLEASE POST PICS OF BOLA ON FIREBIRD
  2. n00b exhaust questions
  3. GM top end cleaner?
  4. egr mod????
  5. Another True Dual Question.. 2 1/2 or 3 inch?
  6. 1 3/4" or 1 7/8" headers for a S2 heads and cam car??
  7. What kind of HP gains would a Holley intake give me with my setup?
  8. Flashing SES light and a couple quesitons
  9. Loudmouth owners inside please
  10. cutout wingnuts coming off
  11. Heat Shield For wires?
  12. LS6 intake?
  13. Y pipe
  14. Moreperformance headers?
  15. Where can I get GMMG?
  16. Exhuast HELP !
  17. DUAL EXHAUST
  18. ESC Problem!?
  19. GMMG or True Dual?
  20. o2 sims
  21. Anyone ever run true duals past the rear axle???
  22. An idea for getting rid of rasp
  23. If you have changed your shifter--Please Read!
  24. Will the Computer Setting EGR Code Effect How the Engine Runs?
  25. Best headers??
  26. Hooker LT's torque
  27. fuel inj.?
  28. How bad will MACs be on my car w/ Sportlines?
  29. Bye bye y-pipe, hello duals....need muffler help though
  30. which MAF for 422 & tnt 100 shot
  31. How will this exhaust setup sound? Like Loudmouth?
  32. TOTL ls1 exhaust
  33. What size headers for a bore and stroked engine?
  34. Help with noise after slp lm lt's install
  35. SSRA or FTRA?
  36. I need some help/info...
  37. 2002 Z28 Dyno Results within...
  38. OIL question PATMAN!...what's the difference...?
  39. GMMG
  40. Fasest time with only bolt ons
  41. Which syntec oil brand?.....anybody
  42. Anyone have the part number for Accel 9000 heat-resistant wires for LS1?
  43. Paging LG Tech....
  44. Fuel Rails.
  45. gutted cats question
  46. Flashing SES
  47. Anyone has Corsa/Hooker setup
  48. Anyone using NOLOGY Wire sets???
  49. Installed Coil Relocation Pic's Please
  50. Best lid, or headers?
  51. Gap for NGK TR55`s ?
  52. Need some help with electronic cutout install...
  53. QTP QTECH electric exhaust cutout installed
  54. What do you think of the qwik stick?
  55. need instructions on porting/ polishing throttle body...
  56. How to seal my lid?
  57. FLP's- use their header gaskets or use GM exhaust manifold gaskets?
  58. 1 3/4 or 1 7/8 headers???
  59. Band Clamps & Hooker LT's
  60. Hooker Cat-back or JUST the muffler?
  61. Car makes a ticking noise and wants to stall after headers
  62. Porting headers...need help
  63. My exhaust vs. x-pipe
  64. Please help - exhaust cutout install time
  65. which muffler to get? please help!!
  66. ? to the expierenced guy
  67. !EGR Mod?
  68. plz help
  69. New guy to LS1Tech needs help! Please help!
  70. Anyone have engine bay pics of their Hooker LT's installed?
  71. True duals withOUT mufflers???
  72. Am I screwed?
  73. How do fuel injectors go back on?
  74. Do LS1 Hooker LTs come with a flange on them?
  75. PCV Valve?
  76. what is the best Fuel pump money can buy??
  77. If You Want To Change Your LS1 Plugs Come On In
  78. How do u install a Racetronix FP into a 2000yr WS6?
  79. ??Stock exhaust pipe sizes??
  80. ASP Pulley Question
  81. Back to back G-MAF dyno
  82. Sheet metal intake who has the best?
  83. plug wires
  84. Pics of my new exhaust :)
  85. Mac headers and LS6 manifold?
  86. Do you guys with FLPs get bored of running one kind of pipe?
  87. Programming for new injectors?
  88. Loudmouth To Loud need help
  89. ASP Pulley question
  90. which headers
  91. FLP Install Question
  92. Ever seen a Pro charger and a Vortech on a motor at the same time?
  93. What exhaust for a 422?
  94. 2001 LS1 into 1993 Z28?
  95. can u install crane HI-6 TR ignition box on2k SS
  96. slp LT install question
  97. Strange thing happened.. My shaft from the clutch pedal to the cyl broke! HELP please
  98. Borla I pipe is too short for hooker y pipe???
  99. Large drop in gas mileage and now car cuts out at 2500rpm?
  100. anyone have upclose and detailed ls1 injector pics
  101. Octane booster mix questions
  102. Where does this vacuum line go?
  103. Shorty headers
  104. Mac headers installed?
  105. Does Hooker ORY work with stock manifolds?
  106. starter help plz
  107. TTS Headers and Cats In
  108. Headers before `verter??
  109. Any issues with the Hooker Y-pipe?
  110. Which Intake
  111. What could be causing me to go through o2 sensors like water?
  112. X-pipe question
  113. need thread size for hooker EGR connection
  114. cut out question....help!
  115. crank case vacume?
  116. Borla Exhaust
  117. Carsound cats
  118. Pulley/Damper
  119. Are Z06 manifolds different from 02 LS1 manifolds?
  120. Autometer recall tach and remote shift light.
  121. Dynomouth Question
  122. Anyone please help, bad hesitation problem, Please
  123. Header Install Problem... Help!!!
  124. Where does this tube end???
  125. Ordered a Hump Hpse...
  126. YELLOW Plug Wires
  127. want to talk ricer!? What octane booster do you use?
  128. Nuts and bolts what thread?
  129. SLP Cold Air Induction or Free Ram Air mod???
  130. McCord E-cuout(MPP 2) users
  131. Nickel plated headers?
  132. Dr Gas X pipe
  133. Does anyone sell a Y pipe with the new Random Tech cats.
  134. Alternative to Dynabatt battery....???
  135. Stepped Dynatech's make less power across the band than Grot. 1-3/4"?
  136. I need HELP intalling Hooker LTs
  137. Exhaust Heat Temp?
  138. LS6 intake results not good!
  139. Help me with tick...
  140. Are you sure...? ASAP
  141. remove panhard brace ???
  142. What Guages To Use With N/A LS1?
  143. Polishing a GMMG....ya or na?
  144. plug problem
  145. EGR question
  146. Who's got cats w/their Grotts/QTP's ? ? ?
  147. Installed ASP crank pulley and now i have a question
  148. Thinking about some exhaust changes.
  149. Side outlet exhaust
  150. Dynomouth with macs and orp
  151. walbro 340
  152. causes for misfire?
  153. EGR/AIR block off kit, please help?
  154. How can you run rich at base/cruise????
  155. what is the hard tube size for stock pressure line
  156. How much should a custom Y-pipe w/ RT cats for Hooker LT's cost me?
  157. SLP Holiday sales specials on their website now !!!! Loudmouth for under $300.....
  158. Need help with LTs and X-pipe Exhaust
  159. pulleys - just crank or crank & alt?
  160. LT headers & Jet Hot
  161. Why does coolant go through the TB?
  162. ignition and coils
  163. Another X-Pipe Question
  164. Short belt mod question
  165. would this cover up the lope of my cam
  166. Anyone removed a Loudmouth?!? Help!!!
  167. Are you SURE I have posi??
  168. An old fart reminisces
  169. Possibly putting together new setup, got a few questions.
  170. Throttle Body Bump Stop Mod
  171. MAF question
  172. Y pipe for hooker LT?
  173. What belts for ASP underdrive pulley??
  174. Need a wiring diagram for Walbro 255 on an 00' F-Body!
  175. Issues with PLUG change
  176. Puttering after LT install
  177. Exhaust Sound Clips
  178. need help asap
  179. help....please!!!!!
  180. Any tips on how not to ding up headers during install
  181. Ram Air Mod on ASCD WS-6 Style Hood.....????
  182. gas mileage.......WTF!!!!!!!
  183. Radiator cap PSI????
  184. Has anyone ordered from Harlan lately?!?
  185. stock maf.....how much?
  186. LM, GMMG, or High Quality Custom Dynomouth
  187. Exhaust question
  188. Running Lean after Spark Plug Replacement?
  189. Is this possible? Flowmasters on a f-body?
  190. SURGING IN GEAR BUT NOT NEUTRAL/PARK
  191. benefit of bigger injectors on a 98.....?
  192. What mod should i do next?
  193. best way to clamp exaust?
  194. Car is trying to die when coming to a stop
  195. I need your opinion please ...
  196. Where can I get this piece????
  197. Does anybody have this exhaust setup?
  198. headers?
  199. where can i find the new bolt for the asp crank pulley?
  200. Torque Convertor...Should I?
  201. Msd ?
  202. Those who've installed Hooker LTs... Inside
  203. Upgrade to aftermarket headers or keep it stock???
  204. removing the AIR tubes
  205. NEW LS1-ASP PULLEY FOR SALE
  206. SVO #30 Injectors
  207. Where to get 3.5 inch exhaust pipe?
  208. JPR ELECTRIC WATER PUMP
  209. Will Corsa ever get it right? update 3 broken mufflers
  210. URGENT HELP NEEDED
  211. How loud will this be?
  212. headers. Flp or Slp???
  213. has anybody found a fix for the tips on the borla?
  214. Which underdrive pully is better NM
  215. header install price?
  216. Mods
  217. Is this possible?
  218. W/headers vs. without???
  219. ASP Pully info pls ...
  220. What size exhaust pipe should i use.
  221. Header Install... Help!! How the @$*# do I get the old exhaust off?!?
  222. Installing a cut out
  223. Can the factory exhaust manifold gasket be reused?
  224. sound clip - FLP's. no cats, Hooker CB and TR220/114
  225. no headers yet
  226. knock retard ?.....help!!
  227. anybody in houston ?
  228. With a '98 will I have to grind the alternator bolt to run a short belt?
  229. QTP headers/y pipe - clearance?
  230. Best Place To Get LS6 intake from???
  231. FREE FAN MOD = BLOWN FAN FUSES PLEASE HELP
  232. I'm getting misfires or something at low RPM's.....what could be wrong???
  233. ? for loudmouth owners
  234. Just got loudmouth installed ....
  235. HELP New MAF = Service Engine Soon
  236. FLP cats vs. offroad pipes
  237. hooker sound clips?
  238. Need a good "Old Man" exhaust......
  239. GMMG vs Loudmouth ...
  240. Headers
  241. Flowmaster 1 chamber flow #s? sound?
  242. FAN SWITCH PROBLEMS
  243. Need to know what parts void GM engine warrenty...??
  244. SLP Loudmouth on a GTP
  245. Selling Used parts
  246. new fuel system setup?
  247. Source for exhaust parts ???
  248. MSD 6 Ignition on LS1 ??
  249. Help with Free Fan Switch Mod
  250. SLP headers
