PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 [279] 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. MY NEW TOY, Intake Manifold...
  2. X pipe design?
  3. z06 exhaust manifolds
  4. removing AIR fittings off the headers
  5. Water Pump Help
  6. True Dual Exhaust??
  7. More ground clearance, Pacesetter or Jet-Hot?
  8. Borla vs. Dynomax
  9. Hooker Y banging fix?
  10. Installed my Kooks headers today!
  11. FAST 90mm intake and stb clearance question
  12. QTP headers ???
  13. Coil Pack brackets
  14. Good set of headers with ypipe w/ cats for decent price?
  15. crank pulleys
  16. "Maybe" SSRA does work..12.402@111.96
  17. Ok so its the middle of FEB (pulley question)
  18. can a 98 and an 01 swap intakes easily?
  19. Gutted Cats
  20. Questions about my voltage reading for the bump stop mod
  21. Took off steering shaft... Something aint right. HELP!!
  22. Exhaust Dilemma
  23. Bolt Ons
  24. Mod Guide: Induction and Exhaust (PLEASE READ BEFORE POSTING)
  25. Problems with EDEL. Victor long tubes
  26. Magnaflow, Hooker or Spintech
  27. spark plug and wire questions
  28. Driver's side AIR hole is cross threaded.
  29. Got my SLP System
  30. Jet Hot open header Video (1.7 meg)
  31. 98-02 throttlebodies???
  32. Anyone modified an ls6 intake to accept egr?
  33. ls6 intake
  34. Another position for PCV catch <pics>
  35. Jet hot headers with extensions
  36. Getting a new exhaust
  37. LS6 Intake Install HELP!
  38. ticking sound coming from under the car...
  39. just got the longtubes
  40. Very Loud Exhaust Setup.....
  41. SLP headers pics
  42. thread size for a header bolt
  43. Someone suggested Copper anti-seize and aluminum heads = no no?
  44. Anyone make their own catch can?
  45. torqueing header bolts???
  46. Swapping Ls1 to Ls6 intake ???'s
  47. Where to buy ATR pitbull mufflers?
  48. EGR provision on headers ?
  49. Got my true duals put on today!!
  50. Has anybody tried the holley Intake on a 98 to 00 fbody?
  51. SSRA now available without scoop.
  52. best place for electric cutout
  53. If you have true duals dumped at the axle
  54. Kooks Headers
  55. SLP or Hooker headers
  56. Whining from engine (belt tensioner)
  57. Whining Sound
  58. FTRA or SSRA?
  59. Evans Water pump GP
  60. Jet Hot Headers?
  61. NGK TR55ix
  62. not sure witch intake to get.
  63. Dynomouth placement, what's the difference?
  64. SES light came on
  65. Got headers installed, terrible idle now.
  66. Header Decision
  67. AIR Restriction made out of Galvanized Steel? **Pic***
  68. Any LSX install tips??
  69. Any Borlamouth clips on cameras that don't suck?
  70. ASP Pulley Belt Sizes and Bolt size...
  71. gaskets
  72. Recirculating Catch Cans?
  73. Are chambered mufflers (bullet style) restrictive & does anyone have flow #s on them?
  74. Squeaking Cooling Fans?
  75. Y-Pipe Clearance
  76. help installing asp crank and alt pulleys
  77. Question about "ram air" mod on an SS...
  78. Rumbler Video Clip!
  79. pics of my new catch can....
  80. Lt's for lowered Z, stock heads and cubes
  81. Installed Air Flow Smooth Bellow
  82. Best header for these requirements
  83. Heat damage from headers??
  84. pacesetter y with flow collector?
  85. broken exhaust bolts
  86. Installed a Accurate Mach. Works Catch Can!
  87. Which provides better power results? aftermarket CAI or stock WS6 intake with K&N
  88. Fast intake(90MM) and BBK TB
  89. colored plug wires
  90. How hard to install off road pipes
  91. ram jet Intake
  92. Will this be too loud for a daily driver?
  93. bbk intake and throttle body?
  94. Headers: Pain in the butt to Install?
  95. Anyone have a list of bolt hole sizes on the block?
  96. Random Tech VS Hooker VS Loudmouth
  97. Will a billet belt tensioner help?
  98. Rasp, what can be done??
  99. QTEC owners!
  100. thermostat comparison - pics
  101. Thread for asp pulley (3 bolts for removal)
  102. Would you recommend Stage 8 Lock Bolts?
  103. Your thoughts on Kooks Headers?
  104. My FAST came in
  105. need help to see if this an LS6 intake!!
  106. How effective are Bullet mufflers?
  107. 02 PCV converted to old style?
  108. Removing Cats...few questions
  109. header help
  110. Looking for Headers!! Help!
  111. Cut-Off Date for LS1 Intake vs. LS6
  112. $2575, Kooks LT's, x-pipe & true duals good/bad?
  113. new headers
  114. LT Headers For a 84 vette..
  115. slp loudmouth or something else
  116. Any Complaints with new Corsa Cat?
  117. Guys running a vacuum pump instead of PCV?
  118. cut out?
  119. How much should it cost for a shop to fabricate a Y-Pipe
  120. Header Gaskets
  121. Autometer water gauge for a 98'
  122. Need opinions of SLP D/D with Long Tubes and OR Y.
  123. Help, have problem, details inside.
  124. Just got my X-pipe and Flowmasters installed
  125. Questions About Electric Cutout Install
  126. custom exhaust
  127. Track only exhaust? This make or loose power?
  128. PCV valve?
  129. Is this the right ASP Pulley for my car?
  130. Headers/ORY questions?!
  131. how hard is it to change spark plugs
  132. ? about LS1 Speed's true dual setup
  133. Pacesetter LT Troubles
  134. LS1 o2 sensors?
  135. simple question regarding: z06 pcv MOD
  136. gmmg website
  137. Forum Director - Marker
  138. Is 160 T-stat worth it?
  139. 01 ta intake
  140. Need help with driver's side kooks headers
  141. Custom Headers - Do O2 sensors NEED to be in the collector?
  142. Do I need O2 sims?
  143. LS1 Headers
  144. Anyone drive uncap all the time?
  145. how can i make my engine run cooler?
  146. Problems running cut-out open on Daily Driver
  147. Intake for heater blower motor?
  148. Ceramic coating
  149. Cars done and now need an exhaust. need opinions
  150. TSP 85mm lid
  151. Ground Clearance between Mufflex 3" Y pipe and Hooker 3" y pipe
  152. I need a QUIET Exhaust
  153. porting the ls6 intake?
  154. True Duals - muffler selection?
  155. What is the EVAP for? and can i get rid of it?
  156. slp fan switch install?
  157. Hows this look to you guys
  158. So what did Elanor have besides Hollywood enhancing the sound??
  159. AIR Removal Question (With Pic)
  160. bullet mufflers
  161. New Writeup: Air pump to vacuum pump converstion.
  162. LG Motorsports Super Cool Radiator - First track experience
  163. Anybody have the MAC headers MAC Hi-Flow Cats??
  164. Removing AIR/EGR equipment ....
  165. Crank threads are stripped? need help here..
  166. Taking motor mount off. I need help!!!!
  167. Which Headers with True Duals???
  168. Help With Mac Headers
  169. Anyone know what amprage the alternator is on a 2000 ws6?
  170. How do you get the MAP sensor out?
  171. Anyone make stainless steel cutouts and/or bullet mufflers?
  172. Is it worth it to ret the 02' fuel rails and injectors with an LS6 intake?
  173. just installed my pacesetters.
  174. asp pulley.
  175. am sold on the cutout
  176. My Magnaflow muffler is developing cracks,check yours.
  177. Unbelievable Question
  178. new pcv theory and easy fix
  179. Check out my new Edelbrock Competition Headers..
  180. Band clamps vs 3-bolt flanges?
  181. Hooker y-pipe and rust?
  182. MAF question
  183. Power steering cooler has slight leak
  184. Adding catback, what combo next ?
  185. replacement headers?
  186. Holley Intake worth it??
  187. What's the sturdiest lid out there
  188. A few Q's before the cam goes in..
  189. diffrence between ls1 and ls6 intakes
  190. How many 02 extensions?
  191. Where can I buy stainless steel chambered mufflers?
  192. Why all the talk about just the LSx?
  193. intake decisions???????
  194. SLP Blackwing Lid vs SLP Air-Box Lid
  195. What's a good replacement for stock headers?
  196. Which Intake
  197. ls6 intake install
  198. Sounds clip of SLP LT's with Loudmouth
  199. Is the FAST LSX worth it for all bolt-on cars?
  200. FTRA Kit.....does it really works ?
  201. LS6 intake a gain on an LS1?
  202. Bbk Ls1/ls6 Manifold
  203. Corsa muffler hanging low?
  204. What kind of power to expect with bbk 80mm throttle body
  205. what is the most quietest catback on the market?
  206. I need better Clamps for Hooker Ypipe
  207. Who sells an X Pipe?
  208. BORLA owners come
  209. velocity stack.
  210. LS1 Hedman Headers
  211. Introducing Texas Speed's Rumbler Cat-Back Exhaust System!
  212. Where do I go to get some quality swiches w/LEDs?
  213. Lighter crank pulley cause HP loss (read within)
  214. What cat/y-pipe are you Pacesetter people using?
  215. Y-Pipe fitment.....
  216. Annoying noise.....
  217. Cats comparison???
  218. Just installed FTRA and Moved tranny cooler
  219. MAF opinions
  220. Sorry another S2/S3 question
  221. I might be getting a set of MACS
  222. belt noise question
  223. 78 and 90 mm fast intake question
  224. Wanna go Deeep. How to get the bass note?
  225. Who's running duals on LOWERED cars?
  226. Whats the TRUTH about MAC headers?......
  227. Stock catback with 410ci + big cam...too much back pressure?
  228. 90mm fast lsx manifold w/ 85mm maf
  229. Do you need o2 extensions with Macs
  230. Throttle Cable Slack
  231. X-pipe and Some bullet mufflers???
  232. Fast toys ram air
  233. Anyone hear of VeForce Mufflers?
  234. buying used hooker LT question
  235. Why not Flowmaster?
  236. Link needed for Jet hot
  237. Will I need headers with 224/224 114 cam?
  238. When is it time for new O2s?
  239. If I Bought A Stock Maf...
  240. Can i run the QTP Ypipe (electric cut outs) with SFC's?
  241. Magnaflow Question
  242. any real difference in the 85mm lid?
  243. How to get exotic sound
  244. Header bolt broke off , will it leak ?
  245. Catch can Question
  246. LT Headers-what HP increase?
  247. combo LS6 PCV and Catch Can comments/ideas
  248. What do you think???
  249. Looking for dual-dual chrome oval tips. Anybody seen a sexy pair?
  250. How do you attach the seperate header on Hookers?
