View Full Version : Generation III External Engine
- true duals ?
- Just bought headers! Finally!!
- o2 extensions
- Air Pump Fuse?
- Has anybody done this?
- Header advice please
- FAST 90mm swap, A/F richer or leaner?
- Gmmg?
- O2... matter which side?
- SLP Blackwing Question?
- Poll: WS6 owners... JAAM or FTRA
- ???input On A X-pipe With Flowmaster Mufflers
- Weich Water Pump for ls1, use ls2?
- Figured I would ask...
- XS LT's, ORYP and Flo Pac Muff, rasp?
- the spark advance free mod???
- Autozone German Castrol
- Hooker/Magnaflow on stock?
- 400hp???
- underdrive pully
- Ls6 intake install
- Bad thing happened when swapping O2 sensors...
- P0171 and P0174 after Ported TB, lid
- biggest valve that can put in 5.3 and 4.8 block
- 90mm Weiand/Holley aluminum intake manifold?
- QTP Y PIPE SUCKS!!! Want to start over!
- What MAF with a FAST 90/90 setup?
- Any help in with the noise under my hood???
- SFC's get in way of tranny?
- My Car Just Backfired Really Bad
- How to tell what injectors I have?
- Headers Question.....
- Bad Map Sensor?
- dumps at cats stock manifolds
- Please help me discover A random noise please?
- Exhaust Wrap on Ceramic?
- B&B or GMMG????
- LM2 clip
- Autometer Oil Pressure gauge ?
- 160 T-Stat.....Questions
- Is It Worth It?
- Z06 Exhaust
- Differences in engine & underhood harnesses
- a tad lean or a tad rich
- Alternator issues
- Headers for a 4.8
- exhaust question?
- non-slip fit headers
- What should i do?
- Bad O2 sensors causing idle problems?
- 416" L92...GMPP Carb intake or FAST L92??
- VERY small cats? bullet's? powerpack? Trying to kill rasp & drone on duals
- Bassani true duals and torque arm issues....
- PCV setup
- CME Question
- tru duals with umi tunnel mount torque arm
- any1 have non-coated pacesetters
- 98' knock sensors
- X-pipe Question?
- p&p throttle body?
- Datalogged my new FTRA.
- Classic Chamber Vids
- Ram Air?
- Exhaust gurus!! lol.. Please come in.
- Need a y pipe to bolt up to stock manifolds who makes em?
- Help Surgeing
- fuel rail bolts for fast ?
- car is back firing at high rpms
- Breaking the oil pressure sending unit...
- What 85mm MAF to use besides the SLP MAF?
- Engine Swap Question
- Throttle return spring
- Exciter wire
- baddset head
- 3.5" or 4" coupler, cant decide
- Wait for Weiand intake or get ported LS6 for this?
- coolant light...
- who makes this?
- Electric Cuttoff Problem
- Typhoon Intake issues
- stock harmonic balancer or underdrive
- where to buy a ORY pipe for stock manifolds?
- Help me pick my exhaust!
- lid and the k&n fipk
- CME Exhaust options
- Need to rewire O2 sensor to the other side
- Stock cat-back w/ cut-out will flow just as well any aftermarket cat-back, correct??
- problems with y-pipe..
- Bouncing RPM's
- 6.0 Flex plate touching the block
- Hi Temperature Silver paint..
- Change Exhaust?
- Poly motor mounts
- single cutout on I pipe??
- What Vortec engines are all aluminum?
- What is the correct term for the area that the lid attaches to? pics inside
- Do you know what Hooker and Edelbrock headers look like?
- How much with 17" flo-pro twisters quiet down my car over 12" moroso spiral flows?
- Throttle body porting question. Need experieced Help!
- Wiring????
- hey wanting info on a cam upgrade?
- Overdrive crank pulley?
- Has anyone else had this problem?
- Identify this box in front of the drivers side fender
- 10" bullets or Spiral flows?
- gutting cats
- Header Bolt Torque Specs
- Which Throttle Body?
- Is it safe to buy a used true-dual out the back setup
- Why wont anyone install my XR1???
- headers?????
- Need Help Identifying This Exhaust Sound...
- Slp lid install
- Need help identifying this muffler
- Header Gaskets
- Need to build an exaust for my procharged setup 700+RWHP.
- Stock trottle body
- help which intake?
- Got my Spintech set up together!! VID!!
- How much is a 99 LS1 and A4 tranny with PCM worth?
- Repair ls6 intake? PIC INSIDE
- Installing a power steering pump pulley
- carb recommendations?
- American Racing Headers , Mufflex Catback w/ Magnaflow (Pics)
- need some help on ls1 heads pricing.
- Removing cat-back y-pipe muffler options
- question on header gaskets?
- Tapping the head.
- help on vacuum hose? headers?
- Painting bottom of the intake white?
- F-Body oil filler neck
- Homemade Oil Catch Can
- What exhaust should I keep??
- Just a stupid question about idle
- Solid mounts
- Underdrive Pulley
- need help... what to do??
- whats the difference in the ls1 and ls6 intake?
- which exhaust sounds good
- 90,95,&100mm Billet throttle bodies.
- another exhaust question...
- slp...
- 02 Sensors, too many?
- quick question about fast manifold
- Wich Headers Gives The More Rwhp Andf Torq?
- LS2 knock Sensor Conversion Question
- carb intake
- ls6 INTAKE HP
- vette crank pulley
- Cat recommendations...
- 243 ls2-ls6 head differences-how to tell?
- Solid Motor Mounts
- Question about O2 sensors...(Headers)
- will this work?
- No spark on the #2 coil
- best h/c combo
- GTO Alternator compatibility
- Oil Catch Can?
- Best Bolts On for an LS1!!!!! Lets make a list with dyno proof.
- what sounds better on a xpipe?
- Track times sound about right?
- What size smooth bellow for SD?
- i need some help...
- Just had Kooks headers installed!
- front and mid plate...or solid motor mounts?
- Coil Relocation
- Could it be possible.....
- Okay, new questions about Chamber 1's and Corsa clones
- do i need a new y-pipe?
- ls1 computer for ls2 motor
- head and cam package questions.
- Cheap cutout
- Exhaust leak
- headers
- Magnaflow...Advice & Opinions Welcomed!
- Help with my next mod!
- PROJECT: LS6 Need advice...
- What heads should i use
- hmm cat or no cat?
- intake question for carb
- another FTRA question
- muffler ???
- Stock Items Reused?
- s-10 ls6 and t-56 cam question
- FAST 78 Question
- getting a cutout, need some advice
- anyone have clip of lt/ORY with borla catback CLOSED?
- Where to buy OE motor mounts?
- Valve Covers
- Clean MAF, how-to?
- borla or a cut out
- Help Me Choose Heades... Please!!
- My header bolts are acting like a bunch of ho's.
- lm2 or lm1 exhaust
- Whisper Ram Air or Fast Toys Ram Air? Whats the Difference?
- Will my setup lope??
- flowmaster to true duals
- Inside of car smells like exhaust.
- good headers
- Digital Maf?
- Kooks E-Cutout????
- Long tubes with Cats
- Urgent Radiator Question!!!
- Actual mileage increase figures from FTRA/SSRA?
- Back Firing
- DMH's LOW-PRO CUTOUTS
- AC Delete
- will shorty headers from a 5.3L fit a ls1 5.7 engine?
- GMMG question
- ac compressor question
- Throttle Cable Adjust
- Power flow dual/dual?
- aftermarket tb?
- Magnaflow Problems
- opinions needed on duals w/ cats
- starting header and TD install...have a question
- Slp Dual Dual?
- Are there long tubes that will not add noise?
- best way todo motor mounts?
- Need 12- 13" plug wires
- Fact or Fiction?
- A question on my Pacesetter LTs
- URG- Car decided to belch PS fluid.
- New Headers installed...need exhaust hook up
- Ok the aftermarket is so dizzying I dont know where to start what are gimmicks?
- Installing O2 Simulator
- install prices? please help
- Cutting ls1 valley coolant tubes
- Help Electrical problems
- Will i need a tune yet?
- are the L92/l76 DBW TB and the 05 Lm7 dbw same plug COnnector?
- what do i need to hook up my fast fuel lines?
- intake manifold & TB
- Anyone else notice the Fast 92/92??
- broken bolt in head
- Do i need to be worried
- Lingenfelter Throttle Body?
- Help with wieand intake
- hookers or pacesetters???
- want a quiet catback?
- Throttle Body Torque Specs?
- removing header
- Ravin Mufflers ?????
- LS6 intake install
- MAF Location ??????
- Favorite Headers
- 400 Small Block
- Disadvantages of Solid Mounts?
- Anyone running true duals in an emission state?
- What the f*ck are these?!!?
