PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 [119] 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Bullet vs. glasspack --what's the diff?
  2. off road headers
  3. Harmonic balancer
  4. Just about have all the pieces for the header/exhaust install... check this list
  5. LS2 Knock sensors on an LS1
  6. Y-Pipe question
  7. New setup clips!
  8. Header Gasket
  9. fast 92mm
  10. egr block off plate
  11. I just picked up these tips on Ebay.
  12. I think I got screwed please help
  13. Throttle Body Help
  14. can u make an fbody sound like a vette?
  15. Hood plugs...? where to get them?
  16. Any gain from 1.8 rockers?
  17. QTP ORY + Cat-Back = Trimming Required?
  18. Plug Wires Question
  19. Why cam only?
  20. Where to buy.....
  21. Dynomax bullets vs. Sweet thunders in person
  22. installed poly motor mounts and trans mount
  23. Exhaust question.
  24. Kooks headers installed, clearance pics
  25. Cars not running right! Help please
  26. ls6 intake fins removal question..
  27. BBK SSI intake and stock TB size
  28. How much torque to rotate bottom end?
  29. Alright, for those of you who have killed the rasp....
  30. Best quality/performing throttle body out there... no crap TB's
  31. At what point will i need to
  32. BBK headers sound clip
  33. Kooks w/cats or without?
  34. Possible manifold leak. . . Questions
  35. ported TB installed
  36. Failed CA visual, need help
  37. Alternator interchange
  38. Y-pipe "Bump Stop"
  39. port matching fast 92 to heads..
  40. Alternator Hookup Problems
  41. Looking for input on upgradeing mass air and throttle body
  42. broken header bolt....what yo think?
  43. Slp 85 mm or stock!
  44. P0102, I am a bit confused...
  45. Idle setting question
  46. header question
  47. installed ls6 intake... need some help
  48. Switch wired, wires ran, e-cutout on monday!
  49. Spark Plugs
  50. how much hp gain...power steering delete???
  51. Plug wires
  52. Stall with TSP 228R
  53. help,need pics of fasttoys ram air (installing problem)
  54. Vic. Jr and Cutting Hood
  55. Bypass mod?
  56. tq spec
  57. wheres the best place to look for a vacuum leak?
  58. What kind of gain with cut out?
  59. Dynatech Suppermaxx Instaled, long
  60. Opinion on Grotyohann headers
  61. will a legal y-pipe make a sound change to my cat back
  62. Head gasket problem...
  63. Fast Toys 85mm Air Lid
  64. lets make a list of ALL intake options
  65. high mile head and cam install
  66. FAST idle issue
  67. Oil pressure sensor?!?!?!?
  68. 2 1/2 X pipe from stock manifolds/cats...Think it'll sound decent?
  69. TSP Duals Sound, Cam
  70. L Terminal on alternator
  71. Ok So I Got Headers, Now What For The Rest of The Exhaust!!
  72. 2000 WS6 Eats Alternators - WTF?
  73. Where to find an 85mm MAF?
  74. FAST 90/ TPIS 90 with TCS?
  75. How much to port a fast 90?
  76. would i need a standalone ecu for ITB's?
  77. lightwieght carpet kit
  78. AIR tech question(in the middle of removal)
  79. Victor jr. info
  80. I Need Quick Help HEADERS!!
  81. Cats
  82. How much of a gain will I see from a SLP ypipe ?
  83. Dry Sump
  84. who can recoat headers with ceramic coating? How much?
  85. XS catted y ??
  86. what TB for 5.3l
  87. Blue Smoke like a Deamon
  88. I think you may need a tune after a ported TB
  89. What are people running for Exhaust.
  90. TB bracket
  91. TB bypass issues
  92. hooker y pipe?
  93. Will Mufflex 4" fit my pacesetter y-pipe?
  94. Lt's and stock catback
  95. Best Cat-back (performance and sound)
  96. Intake swap question
  97. Header Install
  98. 160 T-Stat - Worse mileage?
  99. best o2s
  100. Torque Value for Headers?
  101. new stereo complete custom wiring need help removing old
  102. Big Bolton Install Tomorrow. Any Tips?
  103. Am I running too big of an exhaust?
  104. some opinions please
  105. Stroker plus Boost ?
  106. cracked oil pan
  107. Where to go for Custom Exhaust - VA/MD/DC area
  108. which muffler
  109. Engine Sensor fuse blowing - T56 alternate solution
  110. New Rev Xtreme CNC ported TB
  111. What would give the most speed/hp?
  112. Which High flow cats for stock manifolds?
  113. Valve Cover Bolt
  114. What Type Of Headers Would You Recommend
  115. WTB: hooker LT's and ORY!!!
  116. Pacesetter LongTubes Question
  117. Installed my BBK LTs today, just one problem
  118. Have any of you put cutouts on with you true duals?
  119. Got my Kooks!
  120. Header banging
  121. Intake Setup Q's
  122. hows the quality of the MTI lid?
  123. Downside to an underdrive pulley?
  124. pace setter vs tsp
  125. hooker vs flowmaster
  126. How much is to much? (header size)
  127. Question about WS6 lower air box
  128. Motor mounts
  129. Custom Ram Air
  130. Intake Bots - where do i get some?
  131. rear 02's
  132. Empty Cats
  133. Secondary injection CODE!
  134. 78mm FAST Throttle body
  135. Custom 4" Exhaust
  136. sound clips
  137. New SLP catbacks?
  138. cutout???
  139. adding a borla bullet
  140. intake and tb question??
  141. QTP headers into - ????
  142. Valve cover removal help
  143. FAST 90 TB seal alternative?
  144. Bling bling from Vengeance!!
  145. Who has BBK LT's???
  146. long tube headers intall
  147. Magnaflow muffler on the end of Y pipe??? No catback
  148. !!!CME, True Dual, X-PIPE, 3 Inch, CatBack Exhaust!!!
  149. CME, True Dual, X-PIPE, 3 Inch, CatBack Exhaust
  150. what needed to install an ls2 intake on ls1
  151. slp cold air worth it??
  152. Weiand Intake
  153. turned my stock exhaust into a borla
  154. What headers have the best ground clearance??
  155. ATI Damper Installation
  156. I need a radiator
  157. Why do my QTP headers hit the k-member??
  158. Anybody Broken Their CME Tips??? Help Needed!!
  159. soundclip of Full Kooer Exhaust with QTP ECO
  160. Fixing to order LT's, what else is needed?
  161. just spent 2000
  162. switching powerpacks to powersticks..
  163. Electric Cutout Wiring...PLEASE HELP!!!
  164. muffler eliminator
  165. Question about 90mm intake manifold installation
  166. Motor Mounts Look Correct To You Guys? pics
  167. 408 with vic jr
  168. Has anyone done a true dual CME?
  169. Accessories? (how much can it add up to?)
  170. Launching Problem
  171. ASP underdrive pulleys
  172. cut-outs?
  173. Where does these sensors plug into? And hydraulic clutch question
  174. P0300 random misfire
  175. 92MM TB to air bridge silicone coupler...Where to buy???
  176. Can a bullet muffler blow out?
  177. People with 90mm or bigger Throttle Bodies please help
  178. Cooling/temp issue
  179. Pypes x pipe with cutouts
  180. Is Meziere Water pump worth it
  181. Fast 90/90 problems......
  182. Black Painted Headers
  183. FAST 92mm and NW TB
  184. back in an ls1 but its a project need some help breaking 10.50 in the 1/4
  185. ls1 vette vs ls1 z28
  186. LT1/LS6 swap
  187. Suggestions on how to plug a threaded EGR hole?
  188. what top end pkg for a 383 ls1
  189. true duals/gains from lm1 with H/C/I
  190. How Much Gas do I have when Check Gauge Light comes on in a 99 F Body?
  191. Should I switch LM1 to LM2?
  192. POP/ backfire?
  193. hp tuner or bbk intake
  194. De-wire mod
  195. Want to get rid of your SLP Loudmouth rasp?
  196. Anybody know radiator size for 98 T/A?
  197. real quick question(i searched)
  198. Thread and pitch of stock O2 sensor bung?
  199. SLP LT Owners Come Inside!
  200. Welding Aluminized To Stainless?
  201. Edelbrock Stepped LS1 Headers...
  202. best sounding exhaust for ls1 ????
  203. LS6 intake size MM ??
  204. Just finished LT install, help
  205. Which Y-Pipe for Jet Hot LTs
  206. fairly significant exhaust dilema...
  207. Oil Pressure low when @ running temp LQ4
  208. 560$ for GM intake gasket LOL, any better offer?!
  209. removing air on 02 SS
  210. Exhaust help
  211. Exhausted in Michigan
  212. CME question????
  213. Next mod i should..?
  214. fast 90/90 vs ls6
  215. First mods for first Camaro
  216. most horsepower without cam/heads?
  217. got a good deal on jet hot coated Flowtechs
  218. Over the axel
  219. california exaust??????
  220. Exhaust too close too driveshaft???
  221. Idea for exhaust
  222. Another PVC solution
  223. Legal (CARB) Cam
  224. ws6, ws7, ws9 owners
  225. Car dies after LT install
  226. Long tubes -vs- 3/4 headers
  227. Airbox Q's
  228. WTF, water pump just started dropping a ton of fluid
  229. Waterpump differences?
  230. Not too sure this is going to clear my stock hood...
  231. CME owners... COME IN!
  232. WTB: longtubes and ory!!!
  233. Ls6 intake??
  234. 1/4 mile numbers??
  235. Painting headers?
  236. Weiand LS1 intake ?
  237. Scrap the Cat, is it worth it?
  238. Header install part list and questions
  239. If no water pump, where does a belt tensioner go?
  240. LS6 intake back piece missing...HELP!!!
  241. Neeed Help Please
  242. GN IAT Sensor
  243. 92 MM f.a.s.t. now where do i find the rest..
  244. Whats A Good obnoxiously Loud Cam!!
  245. Air conditioning question...
  246. Mufflex help please...
  247. Pics of my ported and powdercoated throttle bodies with pricing!Cores in stock!
  248. Catch Can Install, that plastic hose along the valve cover...>
  249. cold air
  250. Exhaust Poll, Keep Magnaflow bullets or without?
