PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 [325] 326 327 328 329 330
  1. pace maf and a4?
  2. Need PLate to block EGR off at manifold..
  3. GMMG Chambered Exhaust
  4. Changing plugs-- need to change wires too?
  5. Difference between stock SS exhaust and Dual/Dual?
  6. SLP LT headers offroad y-pipe ?
  7. How much does asp charge to rebalance...
  8. Where's the radiator low coolant sensor located?
  9. any difference between Z28 and Vette airbox?
  10. What's inside an "O2 Sim"?
  11. Should I go intake or exhaust?
  12. Flow-Tech 3"
  13. Anybody have or seen a Auto Button for a Quicktime cutout?
  14. Are Front and Rear O2 sensors interchangable?
  15. Cammed guys, how much power did you pick up with headers?
  16. exhaust cut-out
  17. am i doing this right? says i have 130% duty cycle on my injectors?
  18. What mod??
  19. Ceramic Coating or Sterling From Jet-Hot?
  20. Pro 5.0 noise
  21. 1/8 mile times!
  22. please dont mind this FLP post...(new ? at the bottom)
  23. "Export Pipes"
  24. WANTED: HP gains w/ Hooker LT's on Stock LS1
  25. Mandrel vs Old school
  26. Wires for coil relocation
  27. A.I.R. Tube functions?
  28. Are Ported Throttle Bodies Worth It On a Bolt On Car??
  29. sad day. at least for me!
  30. Converters....
  31. Is the GMAF worth it on a H/C/I car with tuning?
  32. I think I have header leak!
  33. 255lph inline install questions.
  34. Over the Axel Exhaust Pipe
  35. Exhaust, headers, ypipe
  36. lid, mass air,filter
  37. ping?????????
  38. Beginning mods...
  39. does gutting cats throw off SES light?
  40. Dynatech or Hooker?
  41. another question about mac header install
  42. fule injetors?
  43. catback fitting problems...
  44. Walbro 255lph inline question
  45. pros and cons of descreening and porting my MAF
  46. AN to P/S adapter - what size fits our racks?
  47. bassani's for 98's???
  48. Wanted: mid 12's, WHAT DO I GET?!
  49. Porting MAF and Fuel Pressure
  50. JBA Header Gasket Install????
  51. SLP MAF vs G-MAF
  52. Re-calibrated MAF
  53. O2 extensions for Mac headers on 2000 T/A?
  54. Hooker y pipe and cat question
  55. hpp 160* thermo causes knock retard???
  56. A question about NGK's TR55's.
  57. hooker header install document....
  58. AWW... Dam Canada sux!
  59. !DRL Question
  60. Sweeking Noise under acceleration?
  61. Bullet muffler
  62. look at this head and cam and tell me what you think?
  63. when installing headers will I need to weld?
  64. Changing my Differential fluid this week...questions...
  65. would someone be so kind as to explain this install???
  66. Best muffler for dual exhaust setup???
  67. Help: I installed SLP Long Tubes and y-pipe is banging the floor board.
  68. Direct Flo Lids v/s True Ram Air (Suncoast)
  69. Elite Hot Rod or F1, What do I torque my valley pan bolts to?
  70. Car acting weird and my header install is tomorrow
  71. going to get MAC off road y-pipe but are there better ones out threre???
  72. Hooker header problems.. help asap
  73. New Filter MAG....Any opinons
  74. Header Cross Member Interference on Convertible
  75. Water Pump
  76. LS1Speed.com's "race-prepped tranny"
  77. Raspy sound on Borla is GONE!!!
  78. K&N Open Filter
  79. How much RWHP do you think I would pick up with FLP long tubes
  80. Water Pump
  81. What to expect with SLP header install?
  82. WHISPER LID BREATHER INSTALL FOR SMOG PUMP
  83. TIGHT FITTING BORLA CAT-BACK ON CAMARO
  84. PICS OF UNCOATED HOOKER Y PIPE
  85. Does anyone else have an issue with leaning out more, the faster you go?
  86. header install home or shop?
  87. Anyone install Racetronix PnP Fuel System
  88. where the heck am I going to find my next 20HP?
  89. Problems. How to enlarge the male fitting of the Hooker Y to slip over the header?
  90. SLP Timing Tricker & 100 octane fuel
  91. Stupid a$$ cooling fans stopped working
  92. Replacing loudmouth resonator with a 1 chamber flowmaster?
  93. dynomax ultra flo vs. magnaflow
  94. Magnaflow Bullet for my Loudmouth . . . how much will it hinder flow?
  95. stock ignition wires worth a damn?
  96. X-pipe is on!!
  97. Do O2 Simulators Make a engine run richer than The Regular O2 Sensors behind the Cats
  98. FTRA for ls1 WS6?
  99. backfireing noise coming from the exhaust?????????
  100. Which LTs have the LEAST amount of problems...
  101. Where to buy Grotts...
  102. '02 345hp air lid mod
  103. Shorties vs. Stock 2kT/A pipes
  104. Explain your exhauste set up
  105. does anyone have or know where to get a pass. side t-top ?
  106. What's the complete difference from a Z28 to SS ? ?
  107. what will truck intake do?
  108. Brian Green ram air mod + ASCD WS6 hood?
  109. SLP vs. FLP
  110. 1997 Camaro Valve Cover Question
  111. Ignition for LS1
  112. Horrible Dyno results...
  113. Want to pull the A/C, whats involved ???
  114. SLP hi-flow bellows
  115. Strange noise coming from rear of car.
  116. Fuel Rail Cover # Needed
  117. Possible vacuum leak source found..intake manifold.
  118. Hooker Y-Pipes from JET-HOT...(everyone)
  119. What's the difference between stock Z28 and stock SS catbacks?
  120. Torquing things...
  121. JETHOT problems
  122. Which muffler to buy? Just a muffler.
  123. Experience with Electric Cutouts please!!
  124. Whats the differance
  125. Who makes the best mid-length headers?
  126. Best set of shorties?
  127. Please help me.
  128. Air Conditioning Question
  129. Passenger Side Wire Harness Concern after SLP LT Install..
  130. Installed my Holley Intake and now my car Idles alot higher...
  131. Canadians????
  132. Fuel pump power wire
  133. Kill switch question
  134. Everyone PLEASE come in...(exhaust related)
  135. Locating and fixing a bad o2 sensor...where to find it and how to replace it??
  136. morgan motor sports throttle body?
  137. heads
  138. FLP guys reassure my father...(and me i guess)
  139. header comparison
  140. intake manifold question
  141. Have a few basic Q's...
  142. starter/starting problem ..Help!!
  143. Surfacing Headers
  144. What to expect from the dyno
  145. Will a Trans Mount solve my FLPs from banging???
  146. 2002 Z06 MAF
  147. Stock vs Mod --- Autotap Numbers Hmmm
  148. What's a good sounding header/exhaust setup?
  149. Funny sound when coasting out of gear
  150. DOES ANY MAKE A OFF ROAD PIPE FOR TTS LONG TUBE HEADERS FOR F-BODY?
  151. How much does a fully-dressed LS1 weigh?
  152. Installed my Fast Toys ram air....left over parts???
  153. Rapid Motorsports is awesome!!!!
  154. aaarrrgggg! It just doesn't feel the same
  155. Will an Optima battery...
  156. I think ive been mislead....
  157. Stock LCA bolt size needed..Thanks.
  158. Check out Group Purchase section for AUTOTAP deal!!
  159. Are headers worth it?
  160. Air Care (Emissions Testing)????
  161. What size hole for epoxied TB
  162. Mufflex - vrs - SLP Dual Daul Hp difference
  163. Next Induction Mod
  164. shift kit or hypertech programmer
  165. FTRA install documents????
  166. What is a dual/dual exatcly???
  167. Dynatechs....In from the top or the bottom?????
  168. Non-NOS user, any advantages using a valve cover breather?
  169. Dead Miss After Header Install
  170. MTI clear lid questions???
  171. Car starts for a second or two then dies down...
  172. what are that best spark plugs?
  173. Funny noise...
  174. How long to install these bolt ons ?
  175. mister delivery man came to my house just now
  176. somebody give me a clue?
  177. What should my fuel trims be running at (auto-tap)
  178. What's the difference between the old and new FTRA?
  179. Granatelli Motorsports Mass Airflow Sensor?
  180. Lock-Up Switch
  181. installing MAC's on a 02.... what do I need???
  182. thinking of gutting cats vs. ORY pipe...opinions/experiences
  183. 02 sensor question
  184. EGR mod....
  185. Stock Heat Sheilds on Exhaust Manifolds??
  186. Hooker LT Install Questions!!!
  187. Help! Broke a header bolt.
  188. Which intake would be best for a bolt on car??? (z06 or Holley)
  189. TB Bypass question
  190. FLP long tubes floor clearence
  191. K&N part number
  192. Hypertech power pulleys
  193. mack header question
  194. Stock vs Modified Bolt on Track times... Hmmm
  195. Has anyone done this to a C5?
  196. People withHooker Cat Backs...Inside
  197. help on tach problem wire
  198. Who has installed their Holley Intake besides me?
  199. Battery Relocation
  200. HP gains without cats on FLP headers
  201. Quick time cutout Borla exhaust
  202. slp 85mm MAF...
  203. HPP3 160 Powerstat Still Running At 195
  204. Grots vs. Dynatechs
  205. Pinging
  206. Anyone running a FTRA with a Tranny Cooler blocking part of it?
  207. Lid-O-Rama - Data!
  208. 200mph speedo for T/A?
  209. Cat-back or muffler?
  210. Best Lid
  211. Any problems with ASP pulley
  212. Charlotte Area Recommendations, maybe?
  213. What are the best racing headers?
  214. Fast Toys Ram Air
  215. Reeding plugs..
  216. Descreened MAF Conclusions...
  217. Codes 1133 and 1153 after installing headers
  218. Does any know where to get a set of Grotyohann LT Headers?
  219. Installed ported ends, now get KR, will MAFT help?
  220. O2 Simulators?
  221. Suggestions for hi-temp sound damping coating
  222. Ls1 engine weight
  223. !EGR Free mod w/problems...
  224. 38# injectors okay???
  225. Problem with Race gas....
  226. Torque the thermostat bolts to 7 lbs... what if instead...
  227. Lid-O-Rama
  228. Planning new exhaust.. What do you think?
  229. What size are our Throttle Blade screws?
  230. WS6's on Horsepower TV
  231. Install on hooker headers. How was it?
  232. dynomax exhaust questions
  233. Cutout ? Opinions please.
  234. Stupid ? about Mobil 1 oil filters...
  235. Hooker long tube pics please
  236. Relocate Coil Pacs
  237. Y-pipe Coatings/Paint?
  238. rail mount fuel pressure gauge
  239. Pulled maf screen, need help!
  240. FLP header installation and the dreaded SES light
  241. Hooker LTs and OilPlug?
  242. Valve cover breather?
  243. Edelbrock Shorty Header?
  244. No Cats and Borla?
  245. Exhaust Flow Question, Please Help Me!!!!!
  246. Jumping into Mac Header install.
  247. Need some help removing A.I.R. tubes on 2002
  248. Has anyone welded cat's into the Hooker Y-pipe yet??
  249. Custom EGR Blockoff Plate for Intake Manifold Hole
  250. Washing engine w/ Metco breather???
