View Full Version : Generation III External Engine
- INSTALLING crank pulley
- KOOKS headers for LS1???? Yep I've got a set.....
- Ported Stock MAF or SLP MAF
- Anyone use the SVR Lightweight Battery??????
- Hooker LT Problem
- WIll a '98 cat fit on a 2000?
- Anyone interested in pre-made true dual setup?
- headers question???
- Have you guys seen Bubb Rubb's exhaust?
- Thermostat
- Water/Oil temp gauge senders
- Header Question
- I slit my accordion bellows....
- Slp cats?
- PORTED THROTTLE BODY
- Mechanical Oil Pressure Setup - Anyone?
- Performance Opti ????
- general time's question
- Anyone have pics of True Duals over the axle?
- True dual ?
- Stealth Owners
- People with Dr. gas x pipe, quick question
- Exhaust question ...
- o2 sensor bungs
- PCV on 2002??
- LS6 intake on 99 z28??
- LS6 intake on 99 camaro??
- Black Cat true dual exhaust
- qtec electric cutout
- Direct Hits Ignition
- extra O2 bungs for tunning - what location is best?
- HP and mods question
- Clean welds after JetHot?
- LS1-or LS6
- What's my SLP 345HP intake box/lid worth?
- Specific instructions on flushing radiator???
- Green coolant mixture in radiator????
- 2002 Z06 dyno chart needed
- '99 SS---Recommend a Replacement Battery?
- im pinging!
- MAF porting complete, but I have 2 questions???
- finally changed pcv on a 98
- need part #
- at what point??
- Anyone been using the greddy catch can for a while?
- Merge collectors?
- Custom True Duals over Axel
- Hookers vs. SLP and others
- Torque spec for air pipe bolts 2000 TA?
- Just ordered a set of FLP's... have questions...
- People with Jet Hot headers, need info and help
- Which will flow better? Dynomax or Flowmaster
- Horsepower
- How to install A/F Ratio and Fuel Pressure gauges?
- header install halted . . . pass coil pack
- Holley Intake/Direct Port Install How-To (with pics as always)
- Fuel pump install help.
- ASP under drive pulley
- Ls1 Tune-up questions
- How long would it take to install hooker LT and Y
- Throttle body differences
- What should I do?
- is there such a thing as a 4" cutout?
- Ported Throttle Body Problem...Need Help!!
- mac install today, please help
- Poll: what exhaust do you have
- Mac Mid Lengths/ORYP rubbing, vibrating under car, help?
- GM part number for '01 LS6 MAF??
- Where to get muffler bushings?
- My K&N doesnt seal for crap
- How bad did I screw up.
- Wondering why 4 O2 bungs in MAC ORP?
- LS6 intake with EGR question?
- Aftermarket catback with stock Z/28 tips?
- what is the size 4 short belt on stock pulleys
- FTRA or SSRA or SLP CAI
- Throttle Body Modification?
- Which wire goes to fuel pump?
- Is the stock PVC valve supposed to rattle when you shake it?
- Stealth airbox+FTRA?
- how much hp will i loose by adding hi-flo cats?
- Aluminum Oxidation Prevention
- Need a 12v switched source
- any good in tank fuel pump's for my 409 stroker?
- Max bolt-on power?
- Low exhaust pipes
- what size, and brand injectors should i run on a 409 stroker?
- Porting the LS6 intake...whos done it or has opinions?
- Just broke a 2ND REV 1116 Valve spring, this is crap
- MAF screen removal. Is the only way to cut?
- My PS pump is apparently leaking!!
- 42# injector install question
- Where to find ORY pipe
- how to clean iac solenoid
- Granatelli MAF
- FIPK and FTRA Together
- mac header rasp !!!!
- Quick Question about exhaust
- Complete removal of stock gauge cluster
- cam suggestions for SDPC CNC LS6 heads
- Need help with new Injectors.
- cracking lids?
- is this worth it? induction
- My new 1 7/8" stepped to 2" headers.
- K&N Coldair
- ultra z hood with K&N gen2 cold air kit?
- bg ram air
- Will porting mac headers weaken them?
- Does anyone use an electric water pump?
- heat sheild on motor mount - keep it, or loose it?
- Poly Trans. Mount Cures Y-pipe Banging?
- If anyone wants a GP on a FTRA, please go to...
- MAFT replacement ???
- Making your own Adjustable Master
- MAF Ends
- What size Injectors to use?
- Which setup would sound better?
- Jet Hot Long Tube Headers
- Y pipe rattle driving me crazy!!!
- Bad battery or bad alternator?
- 6 liter heads
- What's your fuel milage???
- idel sugering
- Need Help Installing Crank Pulley!!!!
- ;True Dual Question (Dynomax or Borla XS1)?
- Is it ok to reuse the gaskets on the coolant pipes
- mac header instalation ?'s
- Throttle Body Enhancer
- Please take a look at this plug (NGK TR55) I took out today...
- Resonators to rid ORP rasp sound?
- might try sealing leaky dynatech collectors with ---->
- Anyone know how......
- Stock catback: What's the restrictive part?
- VIN # INFORMATION
- Quick Question... Labor on LS6 Intake???
- Need info. and pic of Mufflex y-pipe. Help.
- while doing the GM top end cleaner...
- Damn pcv valve....
- fuel injectors???
- Should I learn how to Mig weld?
- c??utout and hooker???
- Cat Flow # Shootout
- High altitude mods
- Anyone elses car smoke after headers & O/R pipe?
- will 98 coil packs fit 99 valve covers
- Free Ram Air.....The Truth Please!
- Gutting Cats!!! Worth it and does it change sound?
- Gutting Cats!! Worth it, and does it change sound?
- 38lb injectors too much for 422???
- preventive maintnence???
- COST TO INSTALL TPIS HEADERS
- Where to buy a Supersucker?
- IS AN X PIPE JUST STRAIGHT THROUGH PIPE OR DOES IT HAVE BAFFLES INSIDE?
- True dual set up
- Dyno
- Your Thoughts On FAST TOYS RAM AIR
- Anyone know about a plate???
- What cheap mod to buy?
- Polyurethane motor mounts??
- ASP underdrive pulley bolt size?
- When is it necessary to replace intake manifold gaskets
- What type of dyno #'s should I get if I am running>>>
- Hooker any good in terms of flow and sound???
- loudmouth with cutout
- Baker Hose problem
- SLP cross flow muffler - who makes it for them?
- 400 Rwhp possible?
- Part # for K&N breather filter???
- electric water pump
- LS6 Headers vs. aftermarket when limited
- Silverado 5.3 Best induction
- Any one using the Fluid Damper Pully kit?
- O2 Simmulators
- Hooker exhaust
- Exhaust Noise!!!!
- Exhaust Noise!!!!
- Injector duty cycle ?'s
- Who carries the Muflex 3" y-pipe and Flowmaster collector 3"x3"x4" ?
- Stock alternator pulley WHERE in this world can i find one??
- Do your FLP's bang the floor
- big blocks in 4th gen f-body
- Which jet-hot header .....help
- Headers with no air tubes
- Who makes the best lid?
- burning wires
- need help engine pulsing!?
- 400+hp suggestions
- TB years?
- Porting Holley Intake .... Modifying Runners?
- I need help with belt sizes when using an ASP crank pully.pully.
- Cheapest place to get SVO 42 injectors?
- Power steering whining
- Horsepower with this setup?
- Need help: Dealer prodding around
- Installed JetHot LTs ...
- My car puked something...
- how many people are tens or lower without true duals?
- Witch is the best mod
- guys that are using the 6 liter block?
- Lou's short stick
- How long can you let your battery charge?
- Dynatech headers who has??
- Need help installing Vacuum Guage
- EGR HELP!
- Who has "Dynomouth" exhaust??
- SES Light - HELP!!!
- True Dual Exhaust diameters
- Thoughts on Y-pipes
- Hooker Exhaust
- HVAC question
- Worth buying air tubes for 2000 mac install?
- SLP MAFs
- How safe are MAF porting mod and EGR mod???
- need opinions on exhaust set up.
- DO YALL THINK THIS IS POSSIBLE
- SLP Y-pipe
- where can i find SS CME tips
- SLP longtubes and Eibach pro kit, possible?
- Fuel System Plumbing Question
- questions about loud mouth with ORY
- bolt ons
- Paging Justin Sutton...
- Holley Intake....is there an EGR block-off plate?
- Hooker LT vs Jet Hot LT
- Underdrive Pulley ?s
- So who's making the best ported TB's now?
- 3" y-pipe with flowmaster collector
- PCV traps - another option
- Anyone running a sheetmetal intake?
- Where is the cheepest place to get exhaust components?
- Where to mount the air hose
- GMMG Horsepower ?
- Magnaflow catback FYI
- Best place to buy dynomax bullets
- Holley Power Shot sold out..... Donaldson ok?
- Ground clearance with Hooker LT
- 3rd time i posted this with no response...
- Mounting Holley intake...what mod's are needed?
- SLP CAI or Fast Toys Ram Air System??
- Air Lid Installation Problem
- Y-pipe ?'s
- What exactly do o2 simms do?
- Best Headers
- LoudMouth im Mi anyone have one I can check out?
