- Need V-clamps for FLP's
- stripped O2 sensor...
- Block Off Plates
- What size are O2 sensors?
- So...I'm puttin the bird on operation diet....
- LS1 solutions lid
- Mid-length headers question
- After Hooker install....
- slp 2OTL idea
- SLP
- 200mph Speedo ?
- New EGR Question? What is up with this??
- Where Can I Pick Up a Hooker! ha ha
- Part Number for Airbox on '99 Z28
- corsa vs. borla
- Crap just grinded TB stop past 4.60 volts.....
- can someone please help
- Free Ram Air Mod Question
- will a leaking EGR valve hurt me that much? loss of vaccume?
- Advice installing Harlan Shift light
- NO GAINS!!!!!!
- Dragula gets H pipe and dual XR1 Sportsman mufflers
- Can I get larger Injectors ???
- I want a Long Tube Headers , Please suggest one to me !!
- Paging Chris Pippy
- LT1 Help
- HELP...BANGING ON MY FLOORBOARDS?????
- spark plug questions/SES code
- LS6 manifold port width spec.?
- How do I remove the AIR system?
- Will exhaust leak rob alot of power
- Idle problems with my buddies 99 Firehawk
- HELP WITH SOUND ISSUES....
- custom horn
- Greatest torque "under the curve" > 220/220 .530"/.530" vs 220/220 .560"/.5
- mods not helping at track!! someone help
- First dyno (Need Feedback)
- gutted cat????
- Installed K&N FIPK on Project Dragula
- Electric cutout?
- who makes a dual 3" in/out muffler??
- Need Exhaust Input!!!
- Bassani or Magnaflow Cat-back ??
- mac headers with offroads banging!!!??
- Is everybody that runs a x-pipe system with bullets.....
- Getting Macs, need advise...
- Emissions stuff.
- SES light on - Engine temp sensor module reading high voltage
- Air Box Ideal
- Gale Banks catback installed!
- which headers should I get???
- 1998 to 2000 LT headers on 2001???
- Cutout caps to adjust exhaust note?
- ..finally decided on this h/c combo
- MAC VS SLP
- hooker lt's and mac offrd pipe?
- bad if my MAF housing is loose (leaking are in after the housing)
- H Pipe location ideas please...
- Dynatech headers?
- Will it fit ? Need quick answer on exhaust question...
- Gale Banks exhaust
- Bassani Headers, Test & Tune @ E-Town
- x-pipe into borla?
- Side Exit Exhaust?
- Where to buy Carsound Cats????
- Low end torque or high-end torque headers
- i need your opinion on a good cat-back
- NEED INFO ASAP: How do you REMOVE an ASP pulley?
- anyone running these tpis headers?
- In Tank Fuel Pump Upgrade & External Regulator Kit
- Finally Conclusive proof the FIPK doesn’t work.
- Having fun with an LS1 intake and power tools. ;)
- Question about Lid on 2002 SS
- SLP Air Temperature Module?
- Question on ws6
- egr and air removal.....
- are FLP's unequal length?
- is there a a/f ratio option on autotap?
- High flow cats?
- Hooker Y-Pipe update....
- Air/Fuel, Scanmaster + MAFT help...
- Rough Idle, what to check for
- URGENT: HOw do I get air out of the cooling sytem, thermostat install
- "E-Check" in Ohio???.....I'm moving to Dayton
- ? about lid install
- Does your lid hit your hood??
- Question 'bout O2's
- will I be dangerously lean with SLP 85mm MAF, bellows, timing tricker, maf ends
- Check your Grotyohann 1-7/8th's headers! IMPORTANT!
- Grotyohann 1 3/4 and 1 7/8 headers.... do they use the same y-pipe?
- MEZIERE ELECTRIC WATER PUMP
- SS Battery Cover
- Installing question
- Transmission cooler install with FTRA / ram air / SLP CAI / tranny
- Tranny Cooler
- Direct Hits Ignition
- Two quick Qs about free mods...
- ASP Pulley almost walked off crank snout!!!!
- SLP Headers/Y-pipe before and after Dyno
- EXHAUST SPECS
- MTI Clear Lid Pics
- MAFT Question
- Is GMMG too loud???
- AIR pump removal on 00-02's?
- noise need help
- SQUEEKY BELT!!!!
- Paging Black Sunshine / 00SS..
- LT headers reduce LM drone ??
- Hooker LT guy's
- paging AZLS1
- header install Q(steering shaft)
- dipstick tube won't come out, any help????
- How does an inline fuel pump work?
- Belt walking off the tensioner and power steering
- Were there any changes from the LT1 "SLP DUAL DUAL" to the LS1 dual dual ?
- Track results on FIPK vs Whisper lid & Holley filter
- Will descreening the MAF make you run alot more lean?
- Which ORY pipe to get?
- My A/F Ratio is 11.5 - 11.6 how do I
- Headers and running lean...does it happen?
- Just installed 30# SVO injectors and all Misfires are gone....what's the deal?
- If you installed an LS6 intake, please read! You may have torque problems too!
- custom header time long tubes or short tubes?
- Just got Mac Headers, have egr and air ?'s
- Should I install MAF ends?
- Short Belt part #
- If you have headers, please help
- JBA Headers & Re-routing O2 Sensor
- Where can I buy Carsound highflow cat's & a Flowmaster 3" Y-collector?
- how long does it typically take for a shop to install a pulley
- anyone like dynomax exaust
- Smoke from manifold!
- Hooker Headers Arrived! Y-Pipe anyone?
- FTRA vs BG/ram air
- HELP! cut egr/now service engine light days later
- Corsa Cat Back
- Will SLP dual/dual flow as well as 2OTL??
- Y-Pipe Install
- Engine Missing on hard acceleration???
- Best Y-Pipe
- Update on Fuel Delivery problem ... suggestions
- LS6 Intake
- Engine starting misfiring just before arriving at work today, suggestions????
- removing air pump.
- MAF arrow
- Question about Mufflex 4"
- Cut-Out
- how do i keep my asp crank pulley stop spinning while i'm trying to install it? (A4)
- Overdrive Pulley ?????'s
- too much timing?
- Why after cam install would higher idle be rougher?
- MSD rpm window switch install
- Injectors-which brand is best?
- Dynatech Qs..
- Where to get 98-99 AIR tubes??
- Hooker LT Headers plus what????
- Need a part number.....
- Those with Hooker LT's....
- Blue smoke?
- Should I take it in or try to do it myself?
- Exhaust Manifold Bolts...What Size????
- need help. What size are the...
- Will these gaskets work with MAC headers?
- Why do people use MAF ends being that they jack up Ltrims? Those wanting ends enter!!
- Mac header question
- Coscto Cats Vs Stock cats
- Out with the Macs...In with the dynatechs
- Horrible Vibration... Motor Mount, Drive Shaft, or Rear End?
- Porting MAF ?
- FLP banging...Anyone know how to resolve this?? Problem Resolved
- GROTYOHANN HEADERS
- Sound clip for Corsa and FLP's
- Coolant pipes with Holley Intake...
- TB ported?
- GM tech says no muffler hurts power
- LS1 motorsports lid rubs against the hood
- Hooker Catback or just Hooker Aero Chamber muffler??
- Fuel smell on 98 VETTE
- Did I put my coolant in right?
- Grantelli MAF vs. SLP 85mm MAF
- SLP cold air packages
- HOW MUCH TO EXPECT FOR INSTALL??
- TINTED WINDOWS ???
- FTRA question
- Part # for Coil pack Rails??
- Dual Exhaust
- open exhaust ! fact or fiction?
- plug and wire install??
- Loud mouth w/out cats?
- Corsa's customer service rocks!!
- Mac vs. Hooker
- Couple questions on Mac exhaust and O2 sensors...
- Is it worth it to install the ASP pulley myself?
- Strange Issue... seems fuel related....please help
- Anybody have sound clips of Hooker Cat-B
- SES light??
- what gaines with an offroad y-pipe?
- Is it okay to use 80% water?
- what to gap TR6's at
- Anti-seize on lugnuts question
- How much did it cost.....
- mac headers ?
- Paging Mattf2 ......
- Quick 02Sensor Question
- HAS ANYBODY EVER.............
- x pipe and ds loop????
- Is there an LS6 intake install doc. somewhere???
- SLP LONG TUBES/Y PIPE
- Different Header question!
- SLP Y-Pipe, is it worth it ????
- Do 99+ gas tanks weigh less?
- holley intake porting?
- Can the slp ls6 intake be used on a car without egr???
- What should my next mod be?
- Will MAC headers off of a 2000 Z fit a 98 Z?
- Emission concerns w/ 02 Z exhaust
- alternator pulley question
- where can I get egr block off for my headers
- TTS cats are good after all!!!!
- mac header install
- Late model Mustang Vortech fuel rails Question please come in!!!
- what tools needed...fuel rails off?
- FIPK part 2
- Engine Oil Pressure Sensor???
- Headers??
- Am I asking for trouble?
- Bullet muffler question....
- which plugs/wires to use....
- What is the easiest way to add HP to my '99 Z28?
- Borla XR1 muffler??
- we got a problem?!?!?
- Y not just add a idle adjustment screw?
- Another "what size injector" question
- How the freak do you get the stock pully off?!
- Standard Injector ratings
- fuel pump install?
- Cats and low end torque question
- Grotyohann Long Tube Headers - Installation On Driver's Side?
- Where can I buy the bolt for my crank pulley?
- wieght
- whats all needed to delete the EGR??
- What size cutout for for slp ofp that come with their longtubes??
- Here's a trick question.
- Need help with my idle????
- What size y-pipe for Hooker Longtubes?
- The first few steps....
- Main restriction in stock exhaust is the y-pipe?
- New Weiand Intake for LS1
- Pillar gauges installation question...
- What the average gain from....
