View Full Version : Generation III External Engine
- ceramic coated vs uncoated headers?
- Where to get Corsa Tips?
- Car idles good when cold, rough when warm
- PARTS QUESTIONS, PLEASE EVERYONE TELL ME WHAT YOU THINK!!!
- Loudmouth Sound Clips?
- Everybody with asp pulleys please read.
- Anyone ever modified headers...
- where to get the hose/bellow to connect MAF and Lid?
- Help me out with '01 MAF to a 97-98 LS1
- Guys with true duals in hre PLEASE!!!
- Removing the power steering pulley...
- **oil leak help**
- Will true duals make a big cam sound bigger?
- True dual ground clearance pics needed.....
- Do you think this will help me pass emissions?
- Kill Switch ???'s
- New product - 1998-'00 SLP long tubes with NO AIR or EGR fittings
- Duals over axle?
- AIR block off plates
- what mods next?
- LS6 MAF question..
- Used a NON-GM top end cleaner...is my intake okay?
- Lou Short Stick Help
- Non - EGR LS6 intake on a 98' ?????? smog????
- what is EGR?
- Paging: BAUER - TB info needed
- O2 Sensor question
- what size injectors to use?
- NEED HELP!! Please
- FYI > Good info for folks needing to remove crank pulley + P/Ns
- what to use for fuel lines
- Anyone have pictures of their MACs before install?
- Help me out and vote
- TB...Yea or Nay...Would I benefit???
- Help!!! with Bump Stop mod
- header bolt torque
- How 2 block off WS6 airbox for Ram air induction
- 2000-'02 Hooker long tubes available soon!
- Shift Light Install
- Jet Hot Ls1 Long Tubes!!??
- normal idle speed?
- Magnaflow Catback...
- What are your experiences w/ the "free" IAT mod?
- Fram vs Holley w/CAI kit
- FLP off-raod cutouts
- Where to get true duals done??
- air conditioner dryer???
- airbox hood seal
- dyno numbers?
- SLP LS6 intake????
- I have the ls6 intake now what???
- quick!!!! What injectors are these?????
- What fuel pump and regulator ?
- Center Bolt Valve covers
- Estimated Power from my mods?
- Does the search feacher work?
- Great Results from LS6 Intake on H/C car
- SES P0302 Misfire after Headers
- K&N FIPK with 85mm MAF
- Which Thermostat???
- Corsa or GMMG
- Who has GMMG with an X pipe???
- Tranny Cooler install
- Coolant Problem
- Header leaks
- what size dynomax bullet
- Thermostat mod
- Thinking true duals. Any Exhaust shops in SC?
- Relocated coil packs. Show me your pics:
- Paging everyone that has put their battery in the rear of the car
- Idle hunt questions
- car is dieing
- bosch fuel pump part #s
- Are Stage 8 header bolts worth it?
- MAF Sensor
- Help! Mac headers rubbing steering linkage
- Is the coolant sensor bad????
- LS6 Intake part number w/o EGR
- Helix TB Spacers... ..Any Input?
- BBK TB owners please come in...
- Cats with the QTP/Grotty headers and y-pipe
- Stock Exhuast = LOUD!!!!
- Spark Plugs
- MAC HEADERS...help needed please
- Wanna know what QTP, ORP, Cutout, and QTP Y will give you?
- The Ultimate Catback
- factory Ypipe
- Quick A.I.R. System Q?
- Line Lock help?
- Car Over hEating... Dead Radiator fans?
- Filter Swap
- New Edelbrock LTs
- LS6 intake install (no EGR) knocking on start??
- TR55's or TR6 Which one do I need?????
- external
- ASP pully or fluid damper
- Plug ?'s w/ 5.3L heads and nitrous
- 90K miles, Coil, Misc ?s
- Anyone ever gutted a muffler?
- mac header install?
- true duals
- CORSA or BORLA?!?!
- Mustang
- 95 chevy w/ crossed spark plug wires...
- Open headers, almost...
- Headers and Loudmouth... pics inside
- Spark plugs and wires what is the best for me
- home ported TB
- What ways can you modify a car without delving into the motor?
- Whats the highest a bolton car has dynoed or mphed?
- Smallest Cats Available
- What would you do with $500.00
- Bolt On Mods Question
- Throttle Cable Tension?????
- air pump solenoid what is that?
- Serpentine Belt coming off
- Is what I've heard a myth?
- Flange Gasket?
- Those of you w/poly motor mounts inside.
- Mac midlength header install
- EGR Blockoff Q?
- correct size belt for ATI damper?
- Stealth Lid and FTRA
- Mass Air Sensor
- Not enough room to mount sump kit on stock tank with muffler .... How to do it?
- Fernco Hose problems?
- Coolant overflowing through reservoir???
- Installing Mac mids, do I need O2 extensions?
- Removed factory y-pipe to put in hooker ory, now i need to delete my 02 sensor codes
- Search not working
- What do I need for a shift light
- FTRA vs. Supersucker
- MAF choices
- True dual X pipe setup or LS6 intake????
- How do I flush the cooling system?
- No BS please.
- LS6 intake $385 shipped??
- If you have been trying to contact PPC .....>>
- MACs on an 02Z
- muffler
- WILWAXU
- To Merge or not to Merge, That is the Question...
- external fuel pump?????
- SLP rep says, "Free ram air mod is very bad for the LS1."
- Upgraded cooling system clamps?
- QTP Headers
- Differences in MAFTs?
- 02 Z06 or SLP 85mm? which better?
- Possible increase in air flow for WS6 hood??
- What if?
- True Duals w/ Flowmaster?
- Which headers are best for me?
- Leak from Header?
- Difference between '99 and '02 air lids
- Hooker Header doesnt fit!!!
- Lets's try and determine why MACs cause our cars to smoke with a simple 2 ? poll
- QTEC: whats the difference between race and emissions style headers?
- FUEL PUMP --- What does this mean "must be run with a bypass/return style regulator"
- Direct Flo bellows.
- Tornado
- Whats the website for Miami Motorsports??
- Cheapest place to get a LS6 intake? Miami Motorsport?
- Cats??????
- Y-pipe banging please help!!!
- 02 Thottle Body Question
- Header rasp... please help
- Stock 02 SS exhaust questions
- MAFT???
- Exhaust Header Gaskets - Best One?
- benifits of 2" primaries over 1-7/8??
- running bassani mufflers in your true dual???
- Any way to clean MAF wires?
- dyno ?
- Whats it really worth? LS6 Intake, Crank Pulley, Ported Throttlebody.
- Air Filter Comparison?
- Need Help ASAP On Pulley Problem!!!!
- GM Top Engine Cleaner
- Whats the problem with running MAF ends with an A4
- Another airbag question
- Best way to block off EGR on intake?
- Will 02 V8 exhaust fit on 02 V6?
- cutout ---low end tq vs. top end power?
- Just got a set of TPIS headers for my SS.
- Valve Covers off. Now have EGR code.
- dyno #'s
- who has the LOUDEST DAM EXHUAST, but with cats on???
- NEED PArt # - Oil Drain Plug
- Installing shorty headers
- opinion on BG Ram air setup
- Where can you buy the Borla muffler?
- noise coming from intake
- cut the b.s. what is the best headers out there?
- PSJ et al: any word from Meziere?
- Heard of Green High Performace Air Filters?
- Removing AIR with no codes?
- Me too! How many hp? (For fun only)
- Sealed airbox or not???
- MACS WORTH THE MONEY?
- Airbags
- PPC header questions
- Stealth Airbox?
- QTP Headers and Cutout installed. Pics/Vids within.
- Muffler advise
- LG's ASP underdrives are different? Hmm?
- Y-PIPE FOR MY 2000 Z28
- Sheet metal intake..for race only???
- Magnaflow Questions
- Tired of Flowmaster, getting just 1 Bullet
- Where does everybody mount their MAFT?
- Header Question?
- Bassini vs. MAC dimensions?
- I need to quiet my LM and get rid of rasp
- walbro fuel pump question
- Dynoed the Formula yesterday
- (Help) X pipe or H pipe
- Restrictor Plate SLP Dual/Dual Exhaust ?
- QTEC electric cutout dyno results - 12RWHP & 9TQ - graph inside
- WOW the MAF screen
- Header Poll II
- Hooker LT Headers...
- Mac Header EGR block offs?
- K&N FIPK & FTRA
- Stepped headers results
- RANDOM TECH: metalliics (700000)
- which headers?
- HEADER POLL
- O2 simms (millivoltage) vs. A/F ratio
- New kind of exhaust question...
- Should i put in my new clutch in before i dyno my car or should i wait till after.
- Squeeling ... please help!!
- breather filter for 01+ lid
- who has borla XR-1's on true duals
- direct-flo install
- anybody have dyno numbers after gutting cats?
- Granatelli MAF VS SLP MAF
- air system removal
- Hooker LT?
- cat question
- Bench Flow injectors
- do rod bolts take you out of internally stock?
- Hooker LT Questions
- Which Headers?
- Weight difference in BMR and PA Racing Kmembers?
- To do or not to do Torque Converter
- hooker longtubes in a 99z28
- INSTALLING crank pulley
- KOOKS headers for LS1???? Yep I've got a set.....
