View Full Version : Generation III External Engine
- How to know if I have an exhaust leak at header?
- Help with Air Condition
- Need Help!!!!
- best plugs?
- ls1 power steering
- Any gains going from open cutouts to open headers?
- Need to be quieter...
- maf
- loudmouth with off road y pipe
- mods w/o voiding warranty?
- NX intake manifold?
- gettin magnaflow
- Big crank pulley problem. PLEASE HELP!!!!
- Need a catted Y for Flowtech headers
- pacesetterrs
- What do you think about this?
- What air lid do I get?
- IAC Valve Questions...
- 01 SS on a 98 T/A
- Where to get a flowmaster merge?
- U-bolted
- differences in 1998 and 2002 headers
- True Dual Exhaust System
- I'm mad, I need some help!
- Ticking Noise
- Need your help to make www.ls1sounds.com a better site
- pulley problem
- OK I dont wanna sound dumb but....
- Got a delivery last night :)
- Poping Noise In Exhaust!! Help !!
- asp pulley install
- coolant level sensor plug?
- Really stinks!
- Unistalled LS6 intake, installing FAST 90mm tomorow, have some questions.
- Lid power gains?
- low coolant light, but its full.
- Coolant Overflow
- I'm Scared.
- smooth bellow question?
- I hate my car.. ORY realated
- Anyone actually going to buy the MSD coils?
- QTP y-pipe finally fixed!!!
- If our TBs were rated by CFM.....
- MAF and IAS
- pinging and smoking?
- loudmouth 1 or loudmouth 2 or what???
- Aftermarket Bellows Pics
- mids vs. longtubes.....
- Do I have to replace BOTH O2's?
- 02 sims install
- are you guys really using that much torque?
- BMR track pak torque arm w/ true duals
- FAST LSX 90mm question
- 3,000 rpm noise from up front
- Rear seal..write up?
- Please help with 02 sensor......
- True duals size question.....
- PS fluid change - now looks like coffee?
- what airbox do i need?????
- 90mm tb on a LS6 manifold (not TPIS)
- PPC Headers... need Y-pipe
- how bad will a stock catback choke my car now
- How many oxygen sensors 01 Trans AM LS1
- Which Denso O2 sensor to get?
- Small Leak in Kooks LT's
- how many of you 10 and 11sec cars still have the stock crank pully on?
- cheapest place to get a muffler for my LM..
- Stock fan CFM?
- LSX 90 intake problems??????
- quick! is there a way to get that last passenger side coil pack bolt off?
- What kind of MAF?
- LS6 intake guys please HELP QUICK! In the middle of a swap!
- 6.0 stat fit 01 LS1
- SLP air box lid question
- What 85mm MAF w/90mm FAST intake & 90mm Nick Williams throttle body?
- Deleting egr????....
- Those w/85mm MAF and 90mm throttle body, what bellow?
- best exhaust: Loudmouth, Loudmouth 2 or the GMMG?
- Flowmaster 1-chambers or Sweet Thunders
- Flat copper braided wire from O2 harness
- How does a QTP Cutout work?
- Intake to match 80mm BBK?
- My Asp Pulley Is Coming Apart!!!
- Poly motor mounts driving me crazy..
- Changing spark plug question
- where to get longer crank bolt for install?
- how do i pull of my pully system
- Funny noise from exhaust after spark plug change (sound clip)
- Loud Exhaust
- does the throttle body need to be next to the intake?
- 160 Thermostat Q?
- AIR/EGR/Rear O2 Sensor Deletes?
- Covering the exhaust
- Which intake???????
- Another name for bullets
- Just installed slp long tubes and hooker catbalk system and slp cats
- What guages?
- New coolant level sensor problem
- FAST 90mm intake & Nick William TB on the way, upgrade lid & MAF or not?
- ThE NOISE IS GONE! FIXED! FINALLY!!!!! :) :) :)
- crank pulley keeps falling off the car(HELP)
- Raptor Shift Light question
- 25K miles and water pump needs replacing..
- Question for 2OTL owners or whoever knows
- X-Pipe VS. H-Pipe
- exhaust performance ?s
- ca header lt/shorty?
- a/c belt off = okay?
- Alternator WOT cut-off switch...
- exhaust ?
- Is the LS1 intake a wet design?
- Where do I get...?
- F.A.S.T. q's
- 160 Thermostat
- true duals or ory/cut-out/catback
- Idle
- tunnel brace
- Is there an Oil Pressure sensor on the LS Engine?
- first time to post
- Exhaust Question
- leak or? help please!
- QTP Catted Y-pipe question
- Banging Y pipe solutions?
- Shift light
- Kooks installed, few ?'s
- Exhaust tip sizing
- LS6 Intake Manifold: Good Enough For ~2 Tenths??
- ASP non-sfi w/Gates main belt
- tb coolant by pass
- car is missing
- individual throttle bodies????
- need retune after o2's?
- Z06 Exhaust Manifolds on an F-body
- Overheating! HELP needed ASAP
- BBK intake
- Best Underdrive Pulley???
- Exhuast Leak
- Header Question(opinions)
- how many times can u re-use the same under drive pulley?
- How to get TB wide open
- F.a.s.t
- Hooker LT's?
- Mufflex OR pipes...HP gain?
- Is the SS exhaust the "SLP Dual/Dual system?"
- Oil temp gauge install ?
- Another mysterious oil leak
- Free Mods?
- which exhaust is best!?
- parts needed for a 90/90 swap?
- Pacesetters with Catted Y CONFUSION
- Exhaust sound too loud...
- Pulley Removal Issues(help!)
- 3" to 2.75" ball socket flange....will it fit?
- Possible problem with bolt-ons?
- Sweet Thunder vs Standard Dynomax bullet
- header install ?
- Dropped .1 and gained 2 mph w/Bo White TB
- O2 Sensors
- ORY, Rumbler, stock manifolds
- qtp LT's and the high velocity merge
- Search didnt help. Headlights pulsing, guages, voltage drop & another prob. HELP
- what mods for 98 ta
- Will the ZO6 manifold fit on an LS1
- does the 145 Amp escalade/truck alt fit f-bodys?
- Nick Williams TB or 90MM TB?
- ASP Pulley PROBLEM ! Belt is slipping ! HELP
- Got my Hooker coated LT's and TSP y-pipe
- How much of my sound will my cats kill?
- headers and y pipe?
- should i gut my cats ???
- headers and y -pipe?
- Who has had an SLP pulley for awhile??
- What setup up????
- Just bought a WS9 hood, Have a ? about ram air
- Will The z06 manifold fit on an ls1
- what length o2 extensions?
- Dynatech lt's?
- QTP Electric cutout sizing?
- best external bolt-ons!
- exhaust ?
- Help Finding SS Tips
- New Cutout Pics
- How much do your duals shake at idle?
- Bleeding Clutch Master Cylinder
- ???02 sims???
- Spohn torq Arm and true duals Q
- Whisper carbon lid installed
- Could it be tensioner ARM noise?
- Ngk Tr555
- Having trouble with TSP Y-Pipe
- Plug Gap
- Magnaflow XL(3 chamber)?
- Custom EGR block off plates
- WTB: Ram Air Box
- SLP lid + 2002 ws6 = NO FIT
- Vacuum valve plug for AIR removal?
- Custom true duals installed...pics!!!!
- Continual Charing problem
- installing hooker lt
- which spark plugs do you guys suggest?
- intake map hlp ?????
- How good is the slp loudmouth
- Black LSX Manifold
- Power steering pressure line fittings?
- My Car Has A Mind Of Its Own
- headers
- LS6 intake install, can i block off all coolant ports? What about EGR? PN#?
- Loudmouth Exhaust Vs. Custom
- What's considered a bolt-on?
- m.a.f. question
- MAC Headers Installed ! - comments
- Wires
- Pacesetter Mid Length Headers
- Bolts that hold the coolent vent line thingie...
- open headers
- Should I void my 3 year warranty for TD's?
- AMW catch can top hose needs to be easily removable because Engine cover, any ideas?
- LID OR K&N SYSTEM?
- tsp y pipe to gmmg
- New Z28 Owner with Questions
- New SLP Loudmouth 2???
- Voltage drops when hot out??
- hooker or mac
- Autometer shift lite
- For those with MAC's\MAC ORY
- Just wondering....
- throttle cable part number 00+ TB
- Ls1 intake removal
- ABSOLUTE quietest muffler that flows the best
- header gaskets????
- TSP Bullets
- can the maf and tb be combined together?
- Shaner TB Trouble
- Does anyone make...
- Spark Plug Question
- hooker headers?
- Header ?
- juice
- TSP Hanger Bolts
- TSP Rumbler
- Header Bolt
- True Duals that arent dumped
- 4" mufflex question
- True Dual, X pipe question.
- are my headers coated?
- CC insert experiment
- My VaraRam install last weekend
- Filling t/b holes?????
- Question about SS intake and exhaust.
- Paging: slow
