PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 [149] 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. best flowing exhaust manifolds?
  2. wiring fans up to toggle switch
  3. Ignition or starter?
  4. Will the removal of the smog pump and egr equipment throw a code?
  5. what intake to use on 4.8
  6. Factory Tach Calibration....
  7. Note to self....
  8. please post pics of pcv oil catch cans
  9. Stupid exhaust question
  10. Mechanical Oil Pressure Gauge Help
  11. Egr Gasket Leak
  12. !mufflers on vette....any soundclips?
  13. egr plug mishap!
  14. Oil from Catch can???
  15. annoying squeal from the water pump how to rid of?
  16. Intake Sponges
  17. American Headers ory w/ or w/o cats
  18. bassani true duals?
  19. What are the Best Bang for the buck Boltons
  20. procharger and 90 mm t.b
  21. So i got ripped off...
  22. powdercoat or paint FAST intake
  23. MSD LS2/LS7 coils in high CR/high rpm/boosted application?
  24. TSP Rumbler loud inside car?
  25. Can the LS1 intake bolt onto the 5.3L?
  26. pcv system
  27. 01-02 F-body with 90mm LSX manifold needed at COMP cams for R&D
  28. Exhaust idea
  29. need dipstick tube for ls1 with 5.3 oil pan..
  30. Kooks headers w/ cats and borla ?
  31. Single in/single out???
  32. quietest mufflers
  33. true dual (xpipe) guys w/ spohn ta and crossmember help!!!!!!!!
  34. Radiator service
  35. Fast 90 w/ Nick Williams TB?
  36. HP Gains from Cats out
  37. catch can: why the pcv line but not the fresh air line?
  38. So many FAST 90/90s in the classifieds...
  39. What other cars/trucks use the 3.5" LS1 MAF?
  40. LT's installed, funny smell (not gas) and possible problem
  41. Washing your engine...
  42. American Racing Headers/Corsa Install (Pictures and Video)
  43. Fast 90 EGR?
  44. Just finished throttle body install but have a question.
  45. WTF? I lost a half second
  46. blackwing vs k&n
  47. When do fans kick on?
  48. LS1 Valve Cover Spacers Now Available From UMI Performance!
  49. pics of my cme
  50. coil pack pin placement
  51. Wrong LT's?
  52. need help, nobody can figure it out, can you?!?!?
  53. Which Headers are best for HP?
  54. ned info on Cherry Bomb Extreme mufflers
  55. Help quiet down true duals.
  56. Kooks race headers install!!
  57. need some help please
  58. Horsepower
  59. Video of homemade exhaust "driving"
  60. need some help
  61. Any options for an alternator bracket only?
  62. header install questions PLEASE help me out
  63. Comp Cams Full roller rocker adjustmant help
  64. Pinion Bearing, Axel Bearings Need Advice!!
  65. help with manifold disconnect fuel lines etc.
  66. pacesetter longtube headers ????s
  67. QTP Electric Cutout Controller Issues
  68. headlight motor?
  69. shainer contact info
  70. HELP swapping TB housings
  71. What Gains Can I Expect!?!??!?!?!
  72. question about where to get some parts
  73. Vibration after LT and ORY install?
  74. need info about breathers, pics..
  75. Why won't my slp lid fit right?! pics
  76. Can i use stock valve covers with shaft mounted roller rockers?!?!?
  77. North Florida Tuning
  78. Idling weird
  79. 160 or 180
  80. billy boat shorty header question about yr fit.
  81. Want to remove cats!
  82. Tunnel Brace
  83. Custom Td's should i get them?? PICS
  84. Need help quick getting tomorrow!!
  85. Center Mount Exhaust
  86. poly motor mounts ftmfl!
  87. (LS1/LS6) ported Weiand vs modified LS2 intake comparison w/pics
  88. The strenght of JB weld?
  89. why no egr, maf, o2 sensor?
  90. Bottomed Out! :(
  91. Electrical issue.
  92. Header / Rear 02 Sensor Question
  93. How do fix a dent in my y-pipe?
  94. Havin a few minor problems with the new TA
  95. Help quieting down exhaust
  96. Are 1 chambers really this small?
  97. CAT hitting floor
  98. SPONSORS IN IL: Who can do the job????
  99. alternator
  100. cut out???
  101. Painting and cleaning intake?
  102. y-pipe banging?
  103. LT's, !AIR, and gas smell... help
  104. Rear End Seal
  105. Rasp Worries
  106. Looking for Hi-temp LS-1 coil
  107. Quieting down a QTP+corsa combo
  108. Pulley, gears, or save for cam?!
  109. LS6 valley cover
  110. Adj. vs. Non adj borla catback
  111. Need Advice (stripped thread)
  112. Installing headers with heads on...
  113. corsa clones tips
  114. Cruise Control
  115. I little help?
  116. !EGR done, now exhaust leaks, what to do?
  117. pacesetter headers
  118. Help on dropping motor in car..
  119. Belt problems...
  120. Black chrome tips?
  121. LS1 Swap - PCV Questions
  122. Problems with crank pulley install
  123. bcm/electrical diagram q
  124. Header Install
  125. 85mm maf
  126. Aftermarket cooling fans?
  127. How do you mount hangers on TSP duals..?
  128. Need Help with lights staying on?
  129. mass air flow circuit malfunction code
  130. Which head sensor question...
  131. LS1 block to LQ9 iron block alternator bracket mounting question...
  132. Stock Exhaust Manifold Removal
  133. Need Help. TR55/MSD issue?
  134. i need help
  135. Borla ProXS Muffler?
  136. Replaced Alternator Help!
  137. Exhaust Question!
  138. F.A.S.T. 78mm TB
  139. QTP 2 piece timing cover & oil pump....
  140. Car won't start but cranks over?
  141. I need a sound clip! Kooks LT ORY >> GMMG
  142. Just installed Hooker Catback, my thoughts...
  143. little help with alternator and PCV system.
  144. Help!! LS6 install went wrong...
  145. Ported FAST intake?
  146. Need Help Installing My Autogauge Monster Tach On My 98 Ta Please Help
  147. True Duals ???!
  148. Whats the big deal?
  149. can ls2 or ls7 coil packs be used?
  150. est. LS6 Intake Install time
  151. Suggestions on Wideband O2?
  152. XS Headers
  153. flp header system?
  154. need opinions on livernois motorsports heads
  155. Length of pipe after header collector
  156. Hooking up a mechanical oil pressure gauge
  157. valley cover question
  158. Little help on header install
  159. Tail Pipe and Carbon Rich or Lean
  160. lt1 radiator for ls1?
  161. What kind of valve seals are these?
  162. What do I need to do an LT install?
  163. egr gasket
  164. Idle problems FAST 90/90
  165. QTP Y pipe?
  166. Ported Throttle Body
  167. true dual exhaust: cutouts before or after X?
  168. 90mm LSX worth the money over an LS6?
  169. Those with texas speed true duals come in
  170. Does anyone have an pic of underside of the new SLP lid...?
  171. Those with texas speed true duals come in
  172. Rear O2 Sensors Work for C5 Rear O2 Sensors?
  173. Cat Poll
  174. Cat Poll
  175. An AC Delco Iridium plug gapped at .035
  176. New Ls6 intake
  177. Full Bolt-On driving with out a tune and cats??
  178. 317 cast heads on a ls1...
  179. 160 stat???
  180. crank pulley comes off!!
  181. LS6 Valley Plate
  182. ls6 intake install parts
  183. ypipe and manifold differences
  184. new brand of y-pipe?
  185. Another QTP Header Install
  186. Quick question about Pacesetter y-pipes...
  187. True Duals X or H ideas
  188. what y pipe with qtp headers
  189. Possible to extract 2 functional exhaust tips from a 1 in 1 out muffler?
  190. Another Exhaust Question for the Veterans...
  191. tsp rumbler catback on!!!!
  192. few quick questions on FAST manifold install
  193. whos got pictures of under their car front 02 sensors?
  194. What do you guys think of this exhaust idea?
  195. Gutting Cats!
  196. Is this a 3" QTP valve???
  197. P/p Tb?
  198. Help me choose exhaust
  199. hooker on a slp ypipe
  200. Can anyone tell me what these are? (pics)
  201. I need some part #'s please!
  202. Texas speed True dual exhaust
  203. Texas speed True dual exhaust
  204. accufab 105mm tb
  205. Ported stock TB...or?
  206. I need help fast
  207. Possible newb ? here...but i would like to know
  208. wiring gurus needed.... elec. cut-out & wot switch
  209. Magnaflow + resonator with no cats? Anyone done it?
  210. header gaskets? everybody chime in on your opinion!!
  211. Which pulley and MAF?
  212. Kooks y-pipe with QTP?
  213. ls6 and ls2 manifold differances
  214. Can Factory AIR pump function as a vacuum pump ?
  215. SLP MAF sensor
  216. ARP Crank pulley torque spec
  217. pacesetter headers
  218. ls2 with 88958675 gm manifold
  219. When should the coil packs be changed?
  220. x or y
  221. true duals are in....and stupid loud!
  222. Aircare/B.C. /Emmisions
  223. Wilson Manifolds 78mm Lsx T/b?
  224. Kooks Launches Kookstv.com
  225. LS1 Throttle Body Compatability
  226. Clanking Noise
  227. headers that are 1&7/8s ...between 1&5/8s
  228. pics of elc. cutout switches???
  229. help me decide on a set of LT's
  230. engine bolts
  231. Throttle Cable with Cruise Control
  232. Wilson billet manifold in plastic form? Are they dropping the ball?
  233. Wilson billet manifold in plastic form? Are they dropping the ball?
  234. Removed AIR today but need help.
  235. Question about running duals under axle.
  236. RPMs hanging after Ported TB
  237. fast intake does not fit...problem solved
  238. throttle cable question
  239. What should i expect?
  240. ls1 vs lt1
  241. --->>> BUILD MY EXHAUST <<<---
  242. Best box muffler to replace my Flowmaster 80...
  243. Battery Relocation
  244. 5.3L heads
  245. Inexpensive Fix to That Banging Y-Pipe
  246. Coils
  247. LQ4 w/ LS6 heads?
  248. PCV Question With Oil Catch Can
  249. help me choose a catback
  250. Did a search, couldn't find.. how to convert LS6?
