PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 [177] 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. !PCV???? worth it?
  2. looking at true dules
  3. lid + cold air kit
  4. risk of descreening the MAF
  5. Ground clearance with TSP header/true duals?
  6. TSP True Duals under axle pic
  7. Pics of new SSRA bottom for FTRA
  8. True Duals: Cold Start Of The Trans Am
  9. lt1 LT headers please help
  10. What are my options?
  11. Question on True Duals
  12. This is What Everyone wants
  13. different between off road y and catted y?
  14. good poly mounts
  15. ls6 intake
  16. Best Y Pipe for Jet Hot Headers...
  17. Anyone have pics of the True Dual systems...
  18. Best Legal Exhaust Setup?
  19. Whisper air lid being a pain in the @$$!
  20. Using rubber fuel hoze on this? (purge solenoid)
  21. ran duals under axle and love it (pics)
  22. Letter from Pontiac GMC?
  23. Just bought my first go fast parts, you opinion?
  24. Lid fitment issues?...
  25. Let the upgrades begin...
  26. EGR...what to do
  27. power plus intake
  28. JBA Shorties..TA 00 on a Camaro 02
  29. Who removed steering linkage on header install?
  30. dip stick
  31. Changing to SD with FAST 90
  32. Does muffler location make a difference?
  33. Any one have pics of the volant air intake?
  34. Finish Line Performance headers...
  35. intake question?
  36. 2002 T/A GM cat converter recall
  37. 90 mm FAST Intake + TB
  38. EXTENDED WARRANTY OEM Cats
  39. 2.5" True Dual Questions
  40. Ebay Header "S" Mod, how to?
  41. Possible MISFIRE HELP ME!!!
  42. TB issue; PTM or NW 90mm
  43. hi flow cats/ory/headers question..
  44. Do i have to use o2 sims?
  45. Fel Pro or Gm gaskets?
  46. custom true dual guys come in need help!!!
  47. has anyone bought some edelbrock long headers?
  48. Plug for the side of air lid?
  49. True Duals guys
  50. Another M.A.S. Question?
  51. Flowtech Long Tube Header Question
  52. Dynomax exhaust, any clips?
  53. simple stupid question
  54. best way to remove rasp
  55. Need Exhaust cut out opinions...
  56. crush bend true duals hp lose??
  57. Flowmaster Collector with Mac Y, need input
  58. How will these sound?
  59. might be a stupid question
  60. symptoms of faulty cats??
  61. E.G.R and A.I.R ( help)
  62. SLP Center Exhaust
  63. Question About Cut-Outs
  64. Aftermarket Throttlebody worth it w/ my setup?
  65. Pacesetter Owners inside
  66. 98 headers on a 01?
  67. True dual exhaust heat?
  68. ls6 or not
  69. Kooks
  70. Ebay Headers - Please Read
  71. Swinging the other way: quiet exhaust
  72. LS6 would fit?
  73. How much CFM does a 3.5inch OD intake pipe flow?
  74. My biggest undertaking thus far...
  75. Who has cutouts in Ca?
  76. NEED HELP: Exhaust hangar question
  77. header help
  78. ls7 parts
  79. What muffler with LT and ory?
  80. What Bolt-ons
  81. Open Headers Options
  82. aftermarket valve cover question...
  83. a little help please
  84. an idea ???
  85. Putting back on LS1 intake (ls6 is on right now) - question
  86. What is this thing??
  87. who has a power programmer, and is it a noticable gain?
  88. hooker ory on slp headers.
  89. full exhaust components?
  90. Which Underdrive pulley?
  91. is magnaflow muffler direct replacement for stock???
  92. Electric cut out install
  93. corvette fuel rail covers install
  94. Cutout Questions
  95. Stock Exhaust ??????
  96. SLP Off-road y-pipe?
  97. BMR "drag race" alt. mounting on 6.0 block?
  98. ls6 intake to FAST
  99. Granatelli?
  100. Sensor part #s anyone.
  101. magnaflow bullets vs. spiral flow mufflers for TD's
  102. Will I Have Bad Backpressure?
  103. How is the Hooker 1 7/8 compared to the Kooks?
  104. Kooks Headers should i ceramic coat?
  105. qtp LT headers clearance issues???
  106. Ported MAF, ported LS1 intake inlet, and lid swap over weekend for yet more SOP gains
  107. A.I.R. system poll
  108. spark plug wires
  109. Picked up +19/27 w/ American Racing Headers! (see inside)
  110. slp ls6 intake manifold?
  111. truck 85mm sensor
  112. Loudmouth Mufflers
  113. qtech cut out
  114. Under Axel Problems?
  115. ORY Q's
  116. Thread size of the perimeter-bolt valve covers???
  117. ati dampner
  118. Sheet Metal Intakes Who?
  119. QTP Electric Cutout C5 Z06 Video
  120. Pacesetter LTs and MSD wires
  121. A/C delete, but keep heat?
  122. Guys with LT's and Corvette Bosch O2's
  123. Saw a low profile individual runner intake manifold and wanted to share
  124. Magnaflow Cats
  125. FAST 90/90 Worth it with a TR224 Cam?
  126. Install question
  127. where do these coolant pipes go onj my NW TB??
  128. Ported TB - Overported ?
  129. Purchased Ebay Headers
  130. true dual muffer options?
  131. Anyone try the UMI 90mm throttle body yet?
  132. will a 93-97 airbox assembly work for a 98?
  133. How much Shorter is a LS2 Water Pump ??
  134. Burst Panel ??
  135. How bout some sound clips?
  136. 85MM Throttle Body on LS1 Intake
  137. plug wires
  138. just bought a set of long tubes
  139. PCV re-route question
  140. Opinions on exhaust im getting. Couple questions
  141. coated or uncoated LT's?
  142. Anyone have pics of TD under the axle pipes painted black?
  143. Flowmaster 1 chamber ---> rumbler loudmouth
  144. Fuc%!ng rear coil bracket bolt-driver side!
  145. GMMG for corvette?
  146. Spark Plug INSTALL Borg Warner Plug Wires
  147. ls6 identification
  148. Pacesetter lth's w/ tspoffroad ???????
  149. Video: Open Borla vs cutout vs LMII
  150. cleaning my intake
  151. who sell et performance heads?
  152. gibsonmouth?
  153. Dynatech headers
  154. Tsp Ory
  155. Going Pacesetter - to cat or not to cat
  156. Air Fittings On MAC Mids
  157. Finally did the LS6 intake swap!
  158. having idle and decel issues...not sure whats up. any ideas?
  159. Leak somewhere
  160. half way done with intake swap need help FAST
  161. opinions needed on which bullet mufflers
  162. 90mm maf
  163. O2 simulator problem
  164. Take the Holley Intake Survey! Win $500
  165. '98-'99 Lid, Making it work on an '02???
  166. does a 3rd gen exhaust work for a 4th gen?
  167. Comparison between Pacesetters and Edelbrock long tube headers
  168. Should i keep the TES headers i have on my car now for the turbo build?
  169. wat is a B&B & LM1 setup worth?
  170. High-Flow cats that plug into the factory o2 wires?
  171. Custom y-pipe...what type of flanges to use?
  172. Help....Starter won't disengage?
  173. how loud will it be?
  174. true duals with magnaflow mufflers
  175. Is an electric water pump really better?
  176. Removable Starter/Battery?
  177. Throttle Body Bolt Pattern?
  178. header/y-pipe question
  179. Underdrive pulley belts???
  180. New PCV Valve
  181. Belt Part #s for MTI ud pulley??
  182. Ls1 Intake Mod
  183. header questions
  184. Longtube ?
  185. Exhaust ticking
  186. Is it B&B?
  187. longtubes
  188. X-Pipe or H-Pipe with True Duals and Suspension?
  189. Where to get Headers CNC bent???
  190. Will this work?
  191. How you feel about the hooker catback.
  192. Ohhhhh Flapjack!
  193. Z06 Manifolds for 02 Camaro
  194. Gas mileage loss after LT/ory install
  195. P/S Pulley Delete
  196. Dumps
  197. FAST Intake Issue
  198. LS1 Waterpump
  199. So it's the end of November...ebay y pipe?
  200. !!Help!! H pipe or X pipe?
  201. Headers with a Blower?
  202. ques about victor jr. intake clearance
  203. !!!Help!!!! Long Tubes
  204. Witch one flows better?
  205. pacesetters
  206. New Era Throttle Bodies Vs
  207. thinking about selling my LM1 whats it worth?
  208. Ebay header dilemma...
  209. Port My Throttle Body?!?!?!
  210. hanger question?
  211. Ignition button/switch
  212. qtp and pacesetter ory
  213. Noisy Pulleys?
  214. Mac mids and ory
  215. are kooks headers worth it?
  216. Tested all major spark plug wires. My results...
  217. I need H-pipe Pics
  218. Bullet vs. Magnaflow Muffler
  219. SLP blackwing filter question
  220. gmmg exhaust question
  221. gmmg exhaust question
  222. Cross-Flow Magnaflow Muffler?
  223. Pacesetter LT Headers for my SS
  224. Wont Start and all of a sudden Started????
  225. what belts to use with MARCH/EWP?
  226. Car wont Idle at Cold start After TB Port
  227. what is the difference between a ported M.A.S. and not...???
  228. TD clamps
  229. GMPP manifold with oem style mounting rails
  230. Cutting SS Hood???
  231. Is this mod worth it?
  232. Got my Ebay headers Dyno'ed today
  233. 98 ws6 with 01 motor?
  234. trying to get full bolt on's for the before cam dyno.
  235. Anyone had the guts to try OBX headers yet
  236. volant intake vs. lid.
  237. Whistling Noise
  238. rwhp and 1/4 mile gains with intake/headers?
  239. Header question????
  240. I have a ?
  241. x pipe or cat back
  242. What would work with Mac Off Road Y Pipe?
  243. Pacesetter Warping
  244. need help
  245. Most affordable ceramic coated headers and y-pipe
  246. slp vs. hypertech thermostat?
  247. Elbow and 90mm TB vs. 4150 style TB on Victor Intake
  248. ls1 to ls6 intake question (sponsers help me)
  249. '99 Z X-pipe
  250. Looking for the cheapest place to get an ASP pulley
