- inlet/outlet size
- O2 simms question
- Headers! (again probably)
- holley or k&n
- LS1 lid and 85mm maf. ?????????????
- ? for trans am owners
- where to buy cheap high flow cats????
- ??? About custom Y pipes...
- Dyno'd today
- Forget the mufflers!!!
- True Duals? how to hide cut outs????
- Hands down...what are the best plugs?
- Does my 01 already have the LS6 Intake??????
- Can the LS1 edit do this?
- Just Installed Stealth Lid
- What should I expect?
- Disappointed in new mods...... please read......
- Anybody made a resistor to trick the EGR yet?....JPR?
- AC removal-questions
- How do I get the cruise cable off the TB (non TCS car)
- Which Muffler??????
- Holley/Lingenfelter Intake weighs a TON!!
- Plug wire recommendations
- HP Gains w/Hooker Catback?
- Random tech high flow cats vs. stock cats???
- opinions on Dynatech LT's
- Hooker LT's + Y-pipe - Anyone have any COMPLAINTS!?
- Shorties or stock manifolds?
- FIPK on stocker?
- How bad could it be?
- Cross threaded #1 plug
- approx flowtech cutout install cost?
- FLP collector question...
- Pulley Question.
- Question about DrGas X-Pipe sound
- Mac ORY - Testimonials please!
- What kind of SOTP from these two mods ?
- Dynoed my car today.
- LOUDMOUTH QUESTION???
- Help! Need Walbro 340 in-tank pump install advice!
- Upgrading Fuel lines....CHECK THIS OUT!!!!
- Truck intake plenum volume and runner size?
- PCV valve 101
- low MAF failure?
- QTEC and Mccord pics and comments inside
- How much for
- Is there a point in buying aftermarket MAF on a 01+?
- throttle body ?
- tornado air foil
- How to troubleshoot cruise control?
- Help - scared to death of changing plugs myself PART II
- ET Streets
- Quick Install Question???
- Headers and Gears or Rims and Gears?
- Granatelli MAF Question!! Need Help!!!
- Just ordered a Loudmouth, Qs inside
- Duals and collector size(2.5" vs. 3")
- Throttle cable problems with BBK TB
- What is MAFT???
- Replacement battery...
- spark plug install question
- ATI Pulley better than ASP or about the same?
- car running lean?
- Ultra Z w/lid vs. FTRA
- AC trouble
- What gains in MPG with bolt-ons?
- HELP...How much R-134 freon does my 98 take???
- FLP Header banging > Is an engine torque strap the fix?
- Finally hit the dyno.......!
- Hooker Y-pipe people in here......
- Install of ASP Crank pulley
- Whats the deal with Hookers???
- will different length O2 sensor wires cause problems?
- New lightweight mufflers
- Will ported maf make WOT leaner on 01 Z?
- Fuel pressure regulator?
- Compression check question
- 1/4 mile question
- More powerful
- Electric Water Pump?
- Exhaust in the near future
- just installed slp lt and getting a check engine light???????
- Penultimate Exhaust Setup - Need help
- Exaust choice?
- mufflex exhaust
- True Duals are ON (FLP)
- Worth it to port stock TB and MAF???
- 400hp.. my goal
- MAF Housing, which one is the best???
- Finally did the TB bump-stop mod.
- Lower lid opening
- I hate LS1 cars
- Importance of Injector Cone Spray Patterns??
- need exhaust setup HELP
- SLP LT ?any thing else?
- HELP with my DIET, please!
- Anyone have macs and a corsa?
- Oh Nooooo, Help!!!!
- What is the purpose of upgrading the water pump?
- !TT
- Who sez violence never solves anything? (SLP Y-pipe)
- Bad idea?
- Lower Lids
- Ported MAF worked!!!
- Runing Rough
- What does everyone think I'll Get better HP out of?
- Ported TB questions.......
- Gutted Converters
- Horsepower on stock injectors?
- Need instructions on porting MAF ends...
- how to port a throttle body?
- Header install, what do i need, and can i do it?
- EGR blockoff
- Anybody had problems with MAF ends
- Holley LS6 Intake Manifold ??'s
- Can I run an open Y-pipe?
- Running on open headers
- Has anyone look at or tried Kinsler Fuel Injection
- What do you guys think about this......
- Took out the A/C yesterday....
- For all of you with a FUEL PRESSURE GAUGE AND A SENDER OFF THE FUEL RAIL...read
- Blown Header Gasket
- Torque header bolts down to what??
- took AIR pump out, have question now...
- Security Light Issue......
- Last plug on passenger side *%$#*???????
- Air Bag light coming on when...
- Removing A/C
- First Impressions: SCC Raptor Ram Air v/s Stock and Lid
- FTRA, how do you seal it???
- Best MAF???
- throttle body spacer
- offroads?
- Pros and cons...
- Stealth Airbox
- Best LoudMouth Price
- Which filter with a ram air kit?
- That *%$&@#** MAC ORP!
- Help ASAP - putting engine back in car, have a question!!!
- Holley Filter Question
- descreening the MAF
- Can't Decide: Electric Cutout or full Hooker exhaust?
- 3.5" Collectors
- Hidden Exhaust
- Tick, Tick, Tick, Goes the Fuel Injector!!
- ? regarding a catback system w/factory tips
- difference in airlids
- Vent only comes out the bottom??
- is it true that not everyone sees increased horsepoweresults after a header instal???
- still cant get my macs to stop banging???
- Emissions..we know they suck, but what are ya gonna do?
- Spark Plug Wires??
- hypertech thermostat
- Fastest N/A runs with stock exhaust?
- HELP egr prob.
- truck intake
- Mac header install.......
- Jim Pace supplied K&N FIPK wrong filter!
- hooker long tubes vs slp shortys
- OK...what does the alt pulley really do...
- Exhaust Opinions
- Stock manifold bolt question
- Has Anyone tried the SLP Larger Radiator?
- MAC's are in now need some help.
- Has anyone done true duals w/ GMMG?
- Got the FLP's on the car!!!
- WILL BAD FRONT 02's CAUSE TO RUN RICH?
- NGK IRIDIUM PLUGS?
- How to crank engine without starting?
- For those who installed Hooker LT's with ORY.....running rich???
- Best plug wires??
- Corsa on 2001 Z28 with sport appearance package
- Y-pipes w/ high-flow cats w/in pls.........
- SVO 30# injectors
- Where to get O2 weld-in bungs at a decent price???
- Gutted cats,installed 02sims, now REAL rich.help?
- Header and new air box questions
- Paging Birdman....
- car running hotter than normal after vig
- Ways to get passenger side MAC in.
- Hooker LT or Dynatechs??
- asp AC belt number?
- Low rpm misfire and black smoke..PLEASE HELP
- In the middle of MAC install, need help....
- Installing SLP LT Headers soon, need some tips and advice...
- Info on EGR inside please
- Dyna Batt - opinions?
- Changing spark plugs make any difference?
- ORY on stock manifolds
- Anyone Have an X pipe or true duals on there FLP's?
- How much power should I gain...
- Fuel Lines
- hitting rev limiter on automatic
- Installing Cats in your Hooker Y-Pipe >> Anyone do it?
- changed plugs...lost power :-( Help!!!!!
- Mac header Questions!!!
- Upgrading plan for this summer
- Has anyone's stock battery die unexpectantly??
- SUNCOAST WS6 HOOD STOCK AIRBOX HELP
- Ported MAF ?
- Does my 2002 Z28 have an EGR?
- Where to get O2 wire extensions for LT's and how long?
- Need your opinions!
- Does FTRA really work?
- EGR intake manifold anodized block-off plate?
- LOUDMOUTH SOUND CLIP COMPARISON....
- anyone with a Dr Gas X pipe?
- New member question about autotap
- Intresting testing with Gtech Pro(Bolt ons only)
- anyone got a sound wav of a header/ORP/LM with bullet
- How much will I have to jack the motor on the pass. side for a MAC header install?
- Low coolant light on. Sensor bad???
- What a TB! Candy Apple Red
- Ported/Epoxied AIR LID!
- Fernco Mod ?
- Bullets in place of cats, a good idea?
- Vacuum leak?
- Car did a strange thing after pulling EGR/AIR systems.....wouldn't start
- Wanna know something about my car.
- Y-Pipe options with Hooker LT's within.........
- question about loudmout
- Thinking of selling ASP pulley and getting ATI
- Is it hard to gut cats?
- Would I lose low end by putting 1 cutout on each end of MAC y-pipe? "true dual affect
- Those who have Hooker LTs....
- thermostat mod?
- What kind of cats come with the TTS headers?
- injector cleaning
- Best place for dual cutouts on x-pipe system?
- SoundClips w/ SuperTrapps?
- Dual cutouts on LT header Y??
- Corsa on a TA
- Which header coating is the best?
- bought MAC headers used....do I need anything else?
- Any difference between 2000 & 2002 Throttle body?
- Need to change Spark Plug Wires when changing Plugs?
- Compression Check Question
- ls1edit
- Where do you buy your race gas ?
- Any tips on removing the rear exhaust manifold bolt, ect?
- gm performance
- getting prepared to swap heads/cam/intake
- CHECK THIS CRAP OUT
- Idle Rpms?
- (POLL) how much oil pressure do you have at idle?
- Are '00 TB's interchangeable with '01+
- GP on MTI Clear Lid
- Fast Toys Ram Air Compatibility Question
- True duals is complete!
