PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 [295] 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Dual exhaust, no x-pipe??
  2. best xsaust set up
  3. Want more mods and keep factory warrany
  4. Noise From Pulleys??
  5. muffler question
  6. Sparkplug Indexing Questions?
  7. Do I really NEED headers?
  8. Do the Dynomax Ultraflow and Ultraflow SS sound the same?
  9. Wideband O2 ?
  10. Exhaust Tips Hitting Bumper
  11. Aluminum Flywheels Worth the Money??
  12. Need Help with ASP pulley
  13. ATTN: JUSTIN SUTTON
  14. Installing Longtubes Now: Have a Quick Question
  15. Where to get Oval Tubing?
  16. Do i need the alt pulley with a 6 speed
  17. LT's in california
  18. finally! my qtp merge headers are on their way!
  19. Whats a new LS6 crate motor...??
  20. ARP balancer bolt spec?
  21. Fixed banging LTs
  22. Need quick help with 02 Simulators...
  23. Manifold question...
  24. Definitely Smoother
  25. If I remove the AIR
  26. Hooker or Dynatech (kicking the dead horse)
  27. top or bottom??
  28. Homemade coldair, how much piping? where?
  29. Just installed Hooker LT's with no fitment issues !
  30. Hookers or Jet-Hots
  31. A/C STILL LEAKS!!!
  32. Help with rumors.....
  33. SLPheader install..
  34. Where could i buy 2-1/2" or 3" nice exhaust turndowns?
  35. direct flow lid and SLP air temperature module
  36. LS1 LM conversion kit
  37. Stainless Works Headers
  38. Best intank pump for 550+ rwhp?
  39. Duals vs. Y Pipe on Cam & Bolt on car???
  40. 130 amp alternator??
  41. loudmouth,gmmg,or true duals?
  42. Changed my plugs for the first time...
  43. Going for the full Mufflex...
  44. EGR...keep/not to keep?
  45. Would this be a good start?
  46. need help quick - security in car cut off fuel pump
  47. Best Headers Are?
  48. those who live in texas or san antonio area
  49. What is in the slp header installation kit?
  50. How to's for LT install?
  51. mid length headers
  52. Edelbrock Longtube ?s
  53. FINALLY!!! Got my exhaust built- 4" Mufflex, SpinTech, LONG
  54. high velocity merge collector
  55. Will Macs and ORY rasp?
  56. Anyone running the WS6 lower air box on a Camaro?
  57. Removed AIR system, what to use to plug the vacuum line?
  58. Anyone running hooker LTs with a Loudmouth?
  59. Car is surging,dying, Please HELP!!!
  60. Thunder Racing headers- custom y-pipe?
  61. Pacesetter O2 Bungs
  62. ls1 intake
  63. pcv for reduced oil consumtion
  64. external engine
  65. suspension upgrade??
  66. drill thermostat???
  67. What are all the bolt-ons and how much do they help?
  68. Shift Light
  69. Pacesetter Long Tube Dyno Results >>>>>
  70. what are the headers to get?
  71. NGK Plugs
  72. Dampner/Pulley Installation...?
  73. valve cover breathers
  74. Pacesetter owners, come on in!
  75. Another Y-Pipe Question
  76. CAS radiator. Anyone runnin or heard of them?
  77. Bullet Mufflers same as a cutrout??
  78. Header ?
  79. ASP pulley thread size?
  80. 02 ss tips
  81. Running Open Headers Dangerous?
  82. air lid question 00-02
  83. slip on or weld on collectors?
  84. Kooks headers in, PICS!!!
  85. Stock Y pipe vs. aftermarket
  86. Hooker long tube headers and QTP y-pipe
  87. TB bypass?
  88. car runnin rich???
  89. speed up (adjust) factory tach?
  90. Why do headers make the engine run rich?
  91. Safe to run Hooker Long Tubes open?
  92. Anyone make an aftermarket lower air box assembly?
  93. If you were only going to do a Y-pipe swap...
  94. hooker headers hitting steering arm???
  95. Difference between v4.0 and v5.2 MAFT?
  96. Wisper Lid or K&N Induction System?
  97. NEED PART # FOR NGK TR55
  98. Found new shift light
  99. How much power would this header swap be worth?
  100. Throttle Body disassembly?
  101. PCV oil catch-can.....who has them?
  102. TB Bypass and Bellow MOD, did search
  103. WAT SIZE BULLET MUFFLER?
  104. Going to Install my own headers! Any Help Gratefull fellas!
  105. Performance predictions
  106. will vette alt. fit?
  107. Explain this induction system to me....
  108. Installing cat-back tomorrow, looking for tips/tricks!!
  109. Open header, pipe ext. for O2 sensors, how long to run rig
  110. The AGONY of header/Y pipe choices...join in !?!?!???!??!!
  111. Tips on gutting cats
  112. TB Port/Polish Pics and How-To write up
  113. Is this a LS6 Intake ?
  114. TTS HEADERS
  115. HP loss? H/C/I intake /w dual 2-1/2 exhaust, no h-pipe??
  116. What belt do I use with the ASP crank pulley only.
  117. Will NO thermostat make the car run cooler??
  118. New true duals
  119. From TNT ring to MAF, need help?
  120. Problems with SLP 85mm MAF?
  121. Gauge Gurus Inside
  122. cleaning Powershot filters
  123. Tell me EVERYTHING i need to know about FLP
  124. True Dual Mufflers
  125. 02 Sims Needed For True Duals?
  126. Pacesetter Headers
  127. PPC headers, hi-flo cats & Y-pipe
  128. Jet Hot Y owners inside please.
  129. QTP has great customer service....
  130. Question about thermostats
  131. Air lid sensor
  132. Thanks!!!
  133. About to change spark plugs, any last words??
  134. everybody with 98 ls1 and zo6 or aftermarket intake>>>>>>>
  135. Help!!!!!!!
  136. Hooker LTs Have Been Ordered, What All Do I Need Now?
  137. gap on spark plugs??
  138. Exhaust Cutout Question
  139. TB porting question
  140. Do you have a Z06 Intake Manifold?
  141. FTRA GUYS IN HERE ASAP!!!!
  142. Question? Thread size for cylinder head sender?
  143. Is the !MAF and De-Screen Mod Safe to Do???
  144. JET HOT LTS?
  145. Easiest way to change fuel filter...?
  146. ses light
  147. Anyone have a Mecham Exhaust?
  148. what all is needed for pulley change?
  149. Anybody done this mod to TB bypass? (pics)
  150. K&N FIPK SYSTEM FOR SALE
  151. 10 best LS1 mods - HP Pontiac Mag
  152. Thinking about going back to cats and o2's...
  153. Anyone use solid motor mounts?
  154. 1.8hrs to replace the crank bolt?
  155. Having belt problems again
  156. Here is how to kill rasp with Off-Road Y and Loudmouth
  157. engine vaccum lines???? help!!1
  158. More Brandon & Kirby true dual exhaust pics(before &after)
  159. Where can I buy A.I.R. blockoff plates?
  160. Who makes Shorty Headers w/ 1-3/4" Primaries???
  161. How to get rid of rasp with LM & LT's
  162. MSD
  163. Did the search..no luck..are 17" ET Streets being made
  164. I only got 350 hp with boltons and cam; Why
  165. Shortening LS1 Composite Intake for HP Gain?
  166. True Dual exhaust all the way to the rear
  167. Do I need this piece?
  168. (Help) can't get car to idle
  169. catback question
  170. Coolant Leak
  171. LS1 Intake gasket GM part # ?
  172. AC problem (think its compressor)
  173. Problems with Dynatechs?? I have some...
  174. Installing Weiand intake on 99 LS1
  175. Well I've decided on LT headers!
  176. Do CA cars with stioch of 14.2 AFR, run better out of CA
  177. What puller releses ASP pulley?
  178. ls6 intake
  179. Corsa too loud?
  180. FLP Headers
  181. 2.75" exhaust pipe adapter
  182. Hookers with QTP y-pipe
  183. Exhaust headers.....
  184. Drive Shaft Safety Loop?
  185. Anyone have SLP's Break Control Solenoid?
  186. How Many 02 Extensions Needed for Header Install?
  187. TPS problem? engine reving way to high by itself... Help
  188. True Duals or Mufflex 4 inch
  189. Top end engine cleaner and oil change?
  190. Two 4 inch flexable pipes - ram air mod?
  191. Which electric cutout?
  192. Dynomax Ultra Flo vs. Flowmaster
  193. Daily driver
  194. Problem with corvette intake on a camaro...
  195. A few notes regarding install of Prothane poly engine mount
  196. mac oryp
  197. Ported Throttle Bodies?
  198. Pacesetter Dyno #'s
  199. Can ram air hood baffles be easily reinstalled?
  200. How to polish stainless steel headers?
  201. where do i get poly mounts from?
  202. Ripper or 5.0
  203. SLP VS. PPC
  204. What wires to run with Jet Hot headers?
  205. Muffler Decision
  206. free ram air mod
  207. NE FL exhaust shop props
  208. GM top end cleaner W/ the LS6 intake removed?
  209. Your opinion on SLP LT headers
  210. What is that skinny wire that connects to the alternator?
  211. I need your help tonight.
  212. LS6 Block in 2002 SS
  213. Found my exhaust leak! (pics)
  214. Are front and rear o2 sensors the same part?
  215. Seal the FRA?
  216. oryp worth doing
  217. Why not remove the A/C?
  218. LTs bang like hell
  219. Plug Wires ?
  220. Raspy exhuast Gone! - higher CR did it...
  221. next mod--LT headers or 1.85:1 rockers and new springs???
  222. True Dual pics
  223. anybody with random tech catback
  224. Consequences of Eliminating AIR tubes???
  225. Miss In Cylinders 1, 3, 5, 7. Please Help!
  226. Texas Speed WHERE IS MY LID?
  227. Problems with LT headers
  228. BG Ram Air mod.................
  229. NEED PICKS OF TRUE DUAL SET UPS?
  230. expected gains
  231. bad cats
  232. which spark plugs
  233. Spark Plug Indexing
  234. QTP's have been on order for 10 weeks!
  235. CME exhaust problems
  236. Weird stumble between 2000 and 3000 rpms.
  237. Pro 5.0 Shifter
  238. tb bumstop mod.... OOPS!
  239. TO: SSDUDE AND THECHEF
  240. asp pulley
  241. Smoke normal when hammering the pedal?
  242. mass air flow sensor options
  243. Forum Directors - Marker
  244. quick poll !! need votes not views
  245. California legal ??
  246. Plugs for 02 sensor holes
  247. Anyone have problems with Qtech?
  248. True dual?
  249. What's better than a cutout?
  250. tpis headers
