View Full Version : Generation III External Engine
- LTs and Y-pipe questions
- For those that ported their TB at home with a dremel what attachments did you use?
- What's next for more speed?
- 13111 O2s
- O2 sensor bursting into flames!
- slp cme
- Corsa guys come on in
- Which is louder: An X or H-pipe?
- Mufflers for a X pipe
- electric borla?
- Header to y pipe clamp
- Anyone have pics of F-Body alternator off the car?
- What's this and is it in backwards?
- headers question
- need some help with an ignition problem!
- General corsa feedback
- TB porting
- Choosing the right exhaust set up
- What do you all think?????
- Broken header bolt?
- ANY SLP exhaust removal ???
- Show me Clearance pics of your LS1 F-body Long Tubes!
- cooling trouble
- Pretty much given up on my bird...
- substituting mufflers
- smoking after catback installed?
- Is LM going to sound like crap with my mods
- Truck Oil filter ???
- Can a bad o2 sensor cause idle problems?
- ATI crank pulley and ASP overdrive alt pulley?
- header bolt
- 98 knock sensors?
- LS6 install...Block off's?
- 02 z06 manifolds on 00 z28?
- Small Prob. with Tottle Body port
- Please explain pulleys to me
- LT's What was your MPG before and afte???
- Anyone know of a muffler like this?
- Cabin volume: 4" exhaust vs 3"
- Qtp Ory
- Did anyone else run into this?
- Whats next
- loudmouth is AMAZING!!!
- which ram air is better?
- So.....exactly how crappy is Flowmaster???
- How do Tell if it's a LS1 or LS6 intake manifold?
- Ignition Switch
- I don't know what to do anymore...
- Do Cutouts Leak?
- best fitting Catted Y w/ LT's
- F'ng Corsa Muffler Rusted Apart!!! WTF!!!
- What are all you guys doing to tuck TDs?
- tuning after gutting cats?
- GMMG or duals?
- Oil Pressure Sending Unit
- ground wire on heads...
- QTPs
- Anyone make a fender mount cold air intake?
- 1 7/8 headers
- Help On Fuel Pump Problem
- Factory Z28 mufflers for my El Camino?
- FAST LSX 90MM Intake and TB...
- What to do?
- Problem with 98 wiring harness PLEASE HELP!
- Hooker LT problem
- Which intake for an iron 421?
- Best place for single cutout?
- Cold Air Q
- C5 Running bad after header install
- FAST 90/NW90 throttle body gain on SI car
- ASP Pulley
- FAST Fuel rails, Stock Intake will they work together
- Question on headers?
- ac idler pulley threads
- switching from 1 3/4 to 1 7/8 primaries
- What to do about MAF?
- Need to Know Where a Vacuum Line Goes
- Crank pulley/bolt problem.
- looking for an air filter
- Is $200 for SLPy-pipe worth it?
- Is it worth it to install LT headers from MACs?
- Just Bought z28, What kind of Headers?
- Ported Throtttle Body?
- This sound
- Poly Mount Vibration
- Mccord Cutouts????
- Mac headers and ory good or bad
- How much hp gain
- Pics of my new exhaust 3"-4"-3"(Warning! alot of pics)
- muffler to replace rattling corsa?
- best sounding exhaust
- Cut-out is in!!!!
- loudmouth effeect the exhaust valves?
- help fast
- Poll: Do I have a ported stock throttle body? *PIX*
- Coil Relocation ?
- 4.8 mods
- dumb question
- gains with long tubes/ory/no cats/cut out?
- Which exhaust for the 427?
- Pressure guage to fuel line mounting?
- Dynomax Vs. Loudmouth Bullet?
- Hooker Catback
- ???Throttle Cable???
- Need advice on exhaust setup
- Which works best?
- 90MM Fast intake install questions?????
- rattling noise?????
- Pcv Problem
- Who sells SW stainless steel LT headers?
- Pacesetter warranty ? Could someone from TSP step inside please?
- stock manifolds
- Lets see your exhaust tips!!!!!
- single chamber flows in I-pipe or at tips?
- Best headers for money
- Ordering Prof Products 85mm combo.. Questions
- Noise Pollution.
- Installed March balancer... now belt slipping off
- Knock sensor help please
- Valve Train Noise With True Duals, WTF??
- Will I gain any HP????
- 80mm Professional Products TB
- EGR LS6 intake
- Anybody have the Whisper cold air intake?
- Working on the Hawk as WE SPEAK...
- How can you tell.....
- flowmaster y connector - jethot y pipe
- Always throw codes when lean?
- lid fitment?
- Hooker Muffler question.....please help
- Is there a legal true dual system?
- Which one is louder HOokEr or magnaflow
- TSP Rumbler catback vs. Loudmouth 2
- white smoke from spark plugs? please help
- Anyone want to trade exhaust? Hooker for Magnaflow
- SLP Flowpac Cold-air package
- a/c tensioner pulley
- Dynomax LM resonator swap
- what brand of headers are these?
- Just Put On My New SLP LM!!!!
- I Need A Y-pipe That Won't Scrape, Please Help!
- To Gut Cats or Not To Gut Cats?
- Variable Cutout? Idea....
- Always adding coolant?
- Deleted PCV pics...
- what is this part on my intake???!!!!!!!!!
- subframe connectors and true duals
- A little help before my header install...
- CTS-V balancer + hub overall length
- What IS rasp?
- Catalytic converter ???'s
- Pacesetter's LT's plus a dumped ORY clip
- plug gap
- Vette Exhaust Help
- old school sound?
- SW Stainless Works Headers Arrived!! Pics
- Help me with magnaflow purchase please
- HP from A/C removal?
- high flow cats on EBAY?
- anyone know where i can get this bolt??
- Stock engine+Pacesetters+ TDs +Flowmaster 1 Chambers = AWESOME
- plugs and plug wires
- LT headers, ORY,Cutout
- O2 Hell, please help
- Bassani dual tip alignment
- opinion on exhasut switch
- LTs and tune really worth it?
- Weiand intake is garbage:(
- Rev Limiter??
- SLP Factory replacement Y-pipe
- Opinions?
- Will this affect my performance???
- Flowtech Mufflers
- Exhaust setup question, need answers quick
- what do you guys think of this intake?
- Replacing MagnaFlow silencer w. pipe
- slp y-pipe....again
- part number for a/c idler pulley?
- which is better
- 4" single exhaust
- Anyone have a lowered car with a true dual set-up dumped (w/ Flowmaster 1-chambers)?
- Anything better than Dynomax Bullet Muffler?
- Rasp Question ???
- need help with tb cable/gas peddle
- Granatelli wires
- hooker catback soundclips
- 100 series water pump?
- Running cats and just deleting AIR
- need help QUICK!
- anyone know anythign about these headers??? any experiences???
- Measurements for GMMG chambered exhaust with oval tips...
- BG Ram air question
- Dr Gas
- Exhaust with least "splatter"
- headers. what do i need?
- True Duals Questions
- S10
- Purpose of an X-pipe
- bassani true duals
- Battery Question...
- Exhaust forum.
- What the heck is this????
- LS1 High Flow/Volume Water Pump- NEED ADVISE
- How about this for induction?
- cutout problem, too low.
- Quick Oxygen sensor question
- best flange gaskets??
- My new Race exhaust setup and very cheap!!!!
- does the y pipe really restric flow in a high hp motor??
- 5 Pin MAF connector part numbers
- Tsp Ory ?
- pacesetter install help
- Can anyone tell be a nut size?
- Lid Installation
- running a bit lean, car studders...what is it
- Poly engine and trans mounts are great!
- who made these HEADERS
- Resuts from Mamofied LS2 TB
- relocated dynabatt to trunk, ISSUES....
- LT1 MAF on LS1??
- headers?
- need new cats
- Which Y Pipe
- Here are some Power-mouth pics
- What are the torque specs for...
- Deleting Emissions Fittings on Long Tubes
- LT1 headers WTF???
- Broken Oil Pressure Sending Unit?
- Best sounding bullet: VOTE
- PCV oil consumption... best way to address it?
- What type of lid do you have????
- LS6 intake install/EGR??? Help!!!
- what bullet muffler to get to replace my LM resonator?
- Direct Flow Lid
- Can I run a pulley?
- SES light
- to loud for me
- Running rough after longtube install.
- Why isn't an over-the-axle pipe pre-made?
- Alternator Pulley Question
- Quick ? about stock maf. Thanks.
- Post up your Ractive tips pics please!!!!
- Which Sponsor for SLP underdrive pulley
- Motor Mount bolts
- Couple of header questions
- intake manifold?
- Pacesetter guys please help.....
- coolant thermostat??
- SuperMaxx Install...What Else While I'm At It?
- What exhaust is this??
