- Trueduals... I GOT A QUESTION??
- Tourqe specs
- Possible to replace the stock oil pressure sensor with the autometer sending unit?
- help my car wont idle
- Whats involved with legal LT's
- 98 ss engine
- Where does this vacuum line connects?
- witch rear end??????
- How often do cats come apart?
- victor jr help
- lsx block color
- Maping wire????
- Coil question
- looking for shop ?
- Whats all the modifications needed to....
- HEad porting
- Fast 90 installation
- Which head bolt set to use?
- help build my engine, time is here
- what kind of power from ls1/ls6 top end
- Corsa exhaust with LT's???
- bad luck w/ exhuast.
- Alt
- T/D over the axle v. dumped
- Y pipe for stock manifolds
- corsa clone install questions
- Anyone who has a bbk intake
- having a problem with getting the tq convertor to unlock from a 30-40 roll
- victor jr setup help
- Ground strap touching alt case
- Popping
- FAST 90 90mm tb HELP
- are ls6 style partriot stg.2 heads a good performer
- What are you guys using to from z06 MAF to a 90mm TB?
- HELP!! Found this in my oil pan!!
- FAST Intake/Fuel Rails Fuel Lines
- ati super dampener install question
- A/C Compressor ?
- will a 97 Corsa catback fit my 02 Z28?
- quick easy question
- $600 limit on LT headers for an A4
- whats the difference between headers for.....
- Searched but no luck!!!! 1/4 gains from Underdrive pulley
- Reaching an exhuast delimma
- misfiring under load. no codes
- Is there any one besides slp that makes the smooth bellows tube?
- Any one here running a profesional products throttle body?
- How much horsepower?
- Ported MAF
- dynomax bullet dumped off the ORY?
- taking apart my intake manifold
- Oil Pressure- How low is too low?
- cat replacement resonators
- Do gmpp wires come with metal shields?
- SLP LM1 squeaks HELP!
- FTRA guys, come in
- T55's over TR6
- I threw a code
- O2 Sensors
- cutout question
- Chips, no dip
- Magnaflow, Summit UDP and 85mm TB *PICS*
- 241 or 853 heads?
- QTP Header Install HELP
- Ebay Headers for Under 200
- Thinking on going dauls from my setup
- where to buy poly motor mounts
- What would be good for me?
- headser with umi kmember
- Bang for the buck headers
- Jegs dual exhaust with cut outs
- Whats the big deal about throwing a code?
- 6.0 85 monte carlo headers
- Air Pump Guys
- I heard from a friend who I work with that flotech sucks.
- burn a valve with no backpressure?
- Best source for header bolts?
- 408 Lq9?
- SLP magnamouth installed as we speak
- Plan on getting this setup.. opinions please..
- connecting tb to intake lid?
- JAAM WS6 Ram Air Kit - Special Edition
- when to ditch stock intake?
- heads with Cometic .040 gaskets
- SLP Dual Dual
- header installation
- Missing PCV Hose/Fitting
- Custom Loudmouth - Has Anyone Tried This?
- ThunderRacing Throttlebody???
- plug part # question need help asap
- Who's has best deal on LT's?
- Spark plugs and wires - Suggestions
- Sheetmetal Intake
- Heres a tough one...part #
- TR224 Cam
- No power steering + electric waterpump questions
- Last Attempt LS1 gurus enter
- Figured you guys would like this.
- which mufflers for tsp true duals
- ls2 intake manifold on a 5.3
- 425-450 Rwhp
- ECT, Thermostat Recommendation...
- Does any one run MSD Box?
- Horepower
- using slp resonators w/true duals?
- Do balancers go bad?
- LS6 intake modded for 90mm throttle body
- p7p tb and a tune?
- 85mm summit racing tb
- Bassani duals
- Stock looking race seat...26lbs...drop 12 lbs off your drivers seat!!!
- A/F ratio Gauge. HElp
- plugs
- help !! please
- O2 sensors...where to get them??
- IAC and TPS parts number
- Does shift light use stock tach??
- sound level of straight lt's
- exhaust cut-outs
- Lid + Hose
- Y pipe is driving me CRAZY!!!!
- Cutout or not worth it
- 100mm Cable Throttle Bodies
- New Timeslip from SLP induction package
- 59cc heads W/ Ms4?
- custom 3" true dual pics!!!
- umi kmember with solid motor mounts
- Simple Exhaust question
- temp above 210 degrees ?
- base engine statistics on 03 5.3 vortec?
- having problem with ignition
- Tea 5.3 stg 1.5 ls1 heads
- Need some quick help - willl these injectors fit LS1?
- what to do?
- New Intake/throttle body......TPS question
- is it worth it?
- Cam, exhaust & headers question
- 408 L92 users??
- TD question
- Tune with Full exhaust and Intake manifold?
- FAST 90MM Questions.
- LPP/XS Headers and Flowtech X pipe
- Ls6 Install Video
- What is the benifit?
- ARH Headers
- PS Pulley Size
- help with LS6 intake swap
- Help!!!! Wtb Intake
- Pulse Plugs?
- where can i get some 80 lbs injectors?
- Can anyone recommend a good sounding exhaust that'll pass NJ inspection?
- Grott Headers - which Y pipe?
- how can i make my fans come on when the car is running?
- I need a throttle body
- X Pipe and Tunnel Mounted Torque Arm
- expected rwhp numbers for new combo???
- Square tips
- anyone ever heard of these headers?
- how do you weld on the top of pipes when its still on a car?
- Need Some CB opinions
- Radiator: Where to get a new one and what is sufficient?
- looking for a x pipe set up
- Bad coil packs?
- replaced intake...now heater/ac doesn't blow through the vents
- idle jumpimg around
- people with fast 90 mm throtle bodies please enter
- Questions About Water Methanol Alcohol Injection - Post Them Here
- Who makes a nice 4" STAINLESS Catback?
- 100+mm TB
- Intake gains
- Broken 2 starters in a row...help!
- ls1 intake
- oil pan leaking
- Got some money!!!
- What Underdrive pulley for my mods?
- Exhaust leak
- EDELBROCK vs AFR vs PATRIOT heads
- Victor Jr
- slp header ?
- x-pipe fitment question
- do i have everything i need?
- o2 extension question
- will a z06 maf
- Edelbrock headers
- what to do with the vacuum nipple that the fast 90 dosnt have?
- Can I add headers without making the car (much) louder?
- sweet thunder?
- porting the pro products intake
- TSP Rumbler installed
- For all those running the tr230
- 1600 for intake and exhaust... advice
- what causes bucking
- source for coil pack plug wire boot, terminal??
- SLP Headers, Passenger Install, prying tranny
- Benefit to porting the stock TB on an 01 Z06?
- do i have?...
- Water Pump / Intake confusion. Help!!
- knock sensors messed up please help!
- So who has the "Y pipe bump stop" from Thunder Racing and does it work or not?
- 80mm Throtle body ???
- Moving To KRC PS Pump - Line Question
- whats size do i use?
- QTP vs. AR - which would you buy money no object
- fast 90 with 100mm maf
- Can I drive my C5 with open headers for about 15 miles?
- Resonators that look like cats?
- Quiet Muffler For Y pipe?????
- Lsx 90 Mm Help!!
- Intermittent Misfire at Idle and Low RPM's/Partial Throttle... HELP!!!
- LS6 CNC head flow chart
- nitrous intake questions ..
- 2-Piece Timing Cover??
- Weight reduction
- Cross Over Tubes?
- Header bolts...
- What size bolt for factory exhaust manifold to y-pipe?
- XS Stainless Headers and Lanes TD's
- What do I torque the intake manifold to?
- what is needed with msd 6010 ?
- Cheapest place to get gaskets?
- Fast Toys Velocity Stack??
- are 98 and 01 ls1 coils the same?
- Coolant level sensor specs
- Quick ASP pulley belt question
- 99 header on a 02
- Question about ported TB's
- Long tubes and motor mounts install experience
- shorty headers
- new ported and polished TB question
- True Duals????
- Vids Of Corsa Exhaust?
- FLP Headers collecter flanges??
- What are the differences between the FAST intakes?
- LG streets or Kooks 1 7/8s
- Are there big HP gains w/ a FAST 92/92 combo for an LS1/LS2 w/external bolt-ons only?
- Weird exhaust question
- victor junior intake ..
- Sweet thunder TSP Trudual
- Exhaust Rattle
- MAF adapter
- Dipstick tube question
- This or Catch Can?
- Fast toys lid!!!
- Tuning in AZ
- LPP Header Review
- what size allen key for the fast 90 button head bolts?
- Does the weiand intake Flow?
- Is it worth upgrading my TB?
