View Full Version : Generation III External Engine
- Tru Duals
- X Pipe Kit Help
- who's doing TB's these days?
- LT's + ORY + Borlamouth = good!
- Header Headache Suggestions
- Squeal or chirping sound from engine when <1000 rpm
- Which poly mounts do i need?
- Open headers ?
- Overheating
- Are these the right Kooks headers for my car???
- need help with what mods to get
- LS1 Tach/shift lite Hook-up?
- What gauge wire to use to relocate battery to trunk?
- UnderDrive pullyies
- Stainless Steel vs Ceramic Coated Headers
- cat back muff too noisy
- ZO6 vs earlier intake volume?
- building your own mufflers.
- How would this sound? Has it been done?
- 02 Sensor throwing code
- Why remove EGR????
- Does this sound like a bad sensor?
- pics of pacesetters w/ tsp ory....?
- Looking for Vid of LG long tubes w/ no cats...
- Header bolts
- msd ignition harness
- Will this work...
- T-stat swap problem
- loud mouth or flowmaster american thunder?
- Gmmg Exhaust
- True Duals dumped in front of rear wheels
- ? about Hedmans
- Direct port intake manifold
- exhaust pop/backfire ??
- BG Ram Air Problems?
- Old guy header install completed (long)
- Post Header start up's sluggish sometimes?
- SLP MASS Airflow Sensor Question
- lid and catback
- installed bbk throttle body and now the linkage is to short??
- JBA Shorty Headers 0n LS1-Yes or No?
- I know, I know, not another GMPP vs Edelbrock intake
- cutout pictures please
- Guess my ticking noise *WITH VIDEO*
- A-Pillar gauge install
- Rust plugging up cats?
- Pic Request Dual Dual Exhaust tips for TA
- Using Stock Bolts for headers.......Vol I
- FLP Long Tubes
- What's the best exhaust set up with center mount system?
- Will old Sun Tach Work? I searched first.
- 2 cutouts or 1 cutout
- Qtp Headers??
- Pacesetter LT's/ORY installed (pics)
- Dynatech Header Sale
- Replacement clamps - FLP headers
- TB Bypass - anyone seen gains?
- Any reason to coat Kook SS headers
- Borla Super Turbo vs Borla PRO XS mufflers
- Anyone running Single plane & efi on LSx motor
- I'm looking for header/exaust sound bites
- exhaust tip question
- Borla
- Spark plug issues???
- Stock cat back with 3" dyno bullet?
- Pacesetter/TSP Y install question (o2 sensor)
- emission problems
- What o2's to get...
- Anybody wanna guess where 100 hp went?
- pics of intake setup with 90/90
- cutout
- How did you get your GMMG on?
- MTI clear lid installed today!
- shaner s3 tb
- exhaust poping problem
- Sweet Thunders TD VIDEO
- flo pro or moroso sprial flow
- What ORY for my SS
- Guys with 85mm TSP Lids
- where is the location of cts
- what's the most quite exaust set up
- Fluctuating temp
- Dynomouth
- cats?
- true duals on a ss lowered 1.5" dms springs
- Crank pulley bolt - sqeeling pig!
- Hedman X-pipe Your thought please.
- what size expandable freeplug removing EGR sys. on 99 TA
- installing LTs recomendations on starter heat protection
- installing LTs what lenght of o2 extenders 12" or 24"
- loudmouth true duals
- Header installs: DIY or pay somebody?
- When to buy O2's
- LS6 Brass Threaded Insert Help!!
- ur upinion
- hooker vs pacesetter??
- Pacesetters lts y-pipe sounds like it leaks does your?
- solid motor mounts good or bad
- true duals
- What o2 sensors for pacesetter Long tubes?
- Thinking of buying headers soon need opinions!!!!!!
- Advice: I am looking into the FAST intake and t/b and want some input.
- Borla XR-1 muffler right off header collector
- Aluminum Intakes pros and cons
- Bgra
- anyone clean thier MAF screen ?
- are all paper filter the same?
- 90/90+pulley question..
- is it necessary to get a tune after header install
- Another ? about FRA mod
- How to reduce my exhaust sounds?
- new exhaust running rich
- Thinking of doing dynomax bullet... Any rattles?
- FTRA Install Help
- Is this normal for a Taylor wire?
- MAS SLP 85 MM or Granatelli MAS
- Hooker Exhaust Heat
- Please Help Major Oil Problem
- SSR headers?
- The TSP Catted Y
- Headers...
- muffler options on single exit WS6?
- TSP true dual pics
- muffler delete
- Typical Oil Temperature
- Pics of FLP Y with Flowmaster collector
- Catted TD vs catted Y-pipe setups
- Where are the typical gains in the RPM range after headers/ORY install?
- Engine will turn over, won't start...
- Pics of my loudmouth installed
- Would a Mufflex have less rasp than my Corsa?
- Best price for Meziere pump?
- loudmouths backfiring
- mac headers?
- Pulley on LS1 vs. Pulley on LT1
- QTEC Cutout butterfly valve gone...
- GMMG 4"
- Header coating ?
- which headers
- what does exhaust hitting the floor sound or feel like?
- does this sound like a Bad maf?
- QTP HVMC guys inside please.
- front o2 sensors
- Street Pro Cutouts Orientation
- I have a ws6 is it worth putting 3" i-pipe
- best headers
- Pryas / Pryes ????? Exhaust?????
- TD with Sweet Thunders
- Lots of problems. Please help.
- Who to reduce my exhaust sounds?
- RASP! Did search
- Piggy Backs
- Open headers
- Voltage Drops at stop lights after pulley install....help
- SpinTech 4in
- Need Advice, About to install pacesetter headers
- Will factory manifolds come off w/cats attached?
- building a on road y-pipe /cats/ LTs need advice on o2 sensors
- Do catalytic converters on our cars typically rattle?
- o2 sensors -- how to tell if they're bad?
- p1404 EGR valve-pintle stuck open
- True Dual Owners Inside Please!
- Another fan switch question
- Underdrive Pully?
- Underdrive Pully Question
- Exhaust Question
- This is the Order List
- ***Exhaust cutout, 2 quick questions***
- header break-in
- Glasspac between Y-merger and GMMG?
- 2 Repair Questions
- Exhaust
- Which spark plugs for me? Bolt on car, do I need Iridium?
- cat-back swap vs. muffler swap
- Katech tensioner
- Pacesetters installed!
- after motor swap I have some problems I need help weeding out.
- Kooks LT'S and catted y
- my powerstick video
- Lsx
- Which Cooling Fans to buy??
- Ok so the XR-1s are twice as quiet as Dynomax bullets.
- For those with BGRA?
- 85mm MAF
- Cutout open, cutout closed, how much HP?
- FTRA horror stories?
- Edelbrock SDT Muffler
- SLP long tubes?'s
- FAST 90mm manifold TB bolts?
- Exhaust height question?
- Hooker
- Is there any way......
- testing coils...
- SLP cat back exhaust question, dual dual v. 2OTL
- GMPP or Eldelbrock Victor Jr intake questions
- SLP Lid + FTRA + Smooth Bellows = Rub?
- Question about my Corsa exhaust..
- Longtubes
- !catback = loud :D
- ls1 cooler engine thermostat/ shim mod-- how??
- LS2 intake swap
- Sick of the Muffler!
- Borla Catback
- QTEC or Mccord
- What is stock exhaust size?
- New owner of a GMMG exhaust
- Emissions or no?
- Exhaust systems?????
- Crap! hit some cement, Ypipe Coke Canned.
- Magnaflow vs. Hooker catback, which flows better?
- vette o2 sensors on fbod?
- Header's ORY and LM Replace Resonator?
- whats the difference??
- Can stock cats be welded onto an ORY?
- ? about BGRA and free ram air,
- Run NGK TR55 or TR6 plugs with 11:1 compression??
- funky elelec problem (gauges jumping all over, blowing gauge fuse)
- Muffler in/out diameters
- higher idle after i changed plugs ?
- bad gas milage
- Cut out question about TA
- Anyone Have this Setup???
- granetelli mass air sensor
- Does anyone have a functional cowl hood on a 4th gen
- 3 inch crushed or 2 inch mandrel duals...
- Pacesetter y-pipe
- Intake part number
- New pacesetters recieved, my thoughts
- Theres alot of cold water flooding my car
- AIR! Removel?
- Differnce Between 1-3/4" & 1-5/8" Headers?
- moving traction contol
- high temp silicone hose for smooth bellows???
- For Borla CATback owners
- Dynatech Header Sale (huge)
- Older style pacesetters and the newer style
- coil relocation mod
- Help my car wont start
- QTP Catted Y is leaking
- cats?
- Removed WS6 hood baffles
- LT headers,y-pipe and LM
- Difference in sound between Dynomax Bullets and Borla XR-1s.
- Changed factory plugs to TR55s now Gas Mileage SUCKS!
- EGR effect gas mileage?
- delco belt part #'s
- TD's vs. the world. Honest opinions please.
- Dual cutouts in the y-pipe and Flowmaster y-collector going in Wed
- NW 90mm - Is it the best 90mm TB out there?
- Starter solenoid question
