PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 [247] 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Installed Dynatech Supermaxx Headers
  2. LSX intake instructions
  3. cheapest place to order a loudmouth...
  4. Yet another true dual question
  5. Starter bolts knurled?
  6. Adding Flowmaster collector to Hooker Y-pipe?
  7. I need part #s
  8. upgrading alternator power wire
  9. Maf Sensor Throwing Code P0101,p0171?
  10. LS1 exhaust heat shielding identical to the LT1?
  11. MTI Lid , anyone have this problem ?
  12. IAT Mod??
  13. Where to put O2 sensor on merge collector?
  14. coil wiring harness question
  15. Spohn motor mounts on street strip
  16. Z06 Bone Stock Looking For Mods
  17. Importance of CFM flow in exhaust
  18. Need Help! with part number
  19. Powercoating TB !!!
  20. Mechanical cutout
  21. exhaust cutouts
  22. Breather filter, what works ?
  23. muffler question
  24. Battery Relocation Question
  25. holley intake
  26. Part number for spintech muffler used by mufflex?
  27. Remove Cats... Sound?
  28. O2 extensions
  29. Slp Maf
  30. Two piece timing cover?
  31. 160 Thermostat
  32. Gmmg Exhaust
  33. **pics** custom "nitrous" exhaust
  34. TSP catted y-pipe help!?!?!
  35. corsa vs cut out
  36. the OTHER borla cat back
  37. Anyone actually ever screw up their MAF with K&N filter oil?
  38. Corsa help
  39. Kooks LT's fitment problem
  40. Y-pipes and power. Am I the only one who has seen such big variations?
  41. help with plugs
  42. Whats the bad rep on the SLP headers
  43. stupid gutting cats question
  44. questioin about hooker super comps
  45. Vararam velocity stacks?
  46. hooker y-pipe
  47. FAST 90mm users - Does your intake whistle @ part throttle?
  48. 98-02 K&n Fipk
  49. 02 sensor's tip is white/pinkish, still good to use?
  50. Running with Cutout open.
  51. Which intake: Fast 90mm or GMPP w/ 90mm
  52. *PICS* Custom ram air -- lid and FTRA are gone!
  53. Prothane motor mount is in!
  54. I have a question about emissions, and PCM tuning.
  55. LSX Bolt Question
  56. Corvette 02 sensonr for SLP LT's
  57. Cutout?
  58. Stock exhaust manifolds. Which is best?
  59. Mac Ypipe and stock exhaust
  60. Crank position sensor wiring...
  61. dumb header question
  62. true duals: TSP vs Lane's
  63. Radiator & Cooling Circulation
  64. Ticking sound underhood when parked?
  65. identified muffler
  66. 01-02 ls6 Intake Manifold
  67. volant cai
  68. who carries the good catchcan and the braket that bolt to the head?
  69. Single or Dual cutouts?
  70. Installed flowtech headers
  71. No SES light?????
  72. O2 r not reading with LT headers??!
  73. O2 r not reading with LT headers??!
  74. are my cats causing this problem??
  75. flowtech headers, good idea?
  76. SLP radiator
  77. Another NW TB up and running!
  78. Power Steering Leak
  79. pulley is chipped...can i use it
  80. Is Running without a catback ok?
  81. pulleys
  82. AC Delete
  83. 90mm intake?
  84. MTI lid
  85. asp: belt size vette vs. fbod, same??
  86. Stock exhaust removel
  87. SLP LT Headers question...
  88. Is a cutout worth it?
  89. Anyone have any write ups/pictures of removing A/C?
  90. Filing an insurance claim?
  91. Guys with LTs and ORY and hooker cat back, come in!
  92. egr/air
  93. how are you guys running open headers?
  94. Dyno Tune?
  95. Nasty Performance valve cover pics
  96. Replacing flowmaster with magnaflow
  97. Headers and tuning
  98. Torque specs on LSX intake?
  99. Where can i get bolts?
  100. need to block off egr on "slp" ls6 intake
  101. LS6 + dremel tool
  102. HELP! My 180* stat won't fit, my stock one comes out of its housing?!?!?!
  103. Dyno test with Hooker Aerochamber
  104. A.I.R. Delete (yes, I searched)...
  105. AIR tubes?
  106. Headers and ORY w/ Loudmouth..Bad Idea?
  107. 90mm TB Bellows Option - Using Metal Exp./Flex 4" duct from Home Depot
  108. Nick Williams 90MM TB on and running smoothly!!!
  109. Headers or no headers
  110. Rapid Motorsports will be Offering NW 90mm TB's
  111. can you place a cutout on the driver side?
  112. Borlamouth : Round or oval xr-1?
  113. Throttlebodies?
  114. White Smoke
  115. exhaust problem
  116. which headers?
  117. LS6 valley cover - what is the difference?
  118. LS1 motor mounts
  119. will splicing the crank pos sensor wire give a false reading
  120. My car is kicking my ass...
  121. question on true duals?
  122. 01-02 headers on a 98-00 car???
  123. 85mm MAF to stock lid?
  124. FAST 90mm & TPIS 90mm TBs *PICS*
  125. LS6 intake
  126. Dynatech Supermaxx headers- discontiued ?
  127. Descreanig the MAF
  128. Flames coming out of my tailpipes
  129. DYNO results LS1,LS2,LS6, FAST intakes and TBs
  130. Loudmouth 2
  131. Who makes a 1 7/8" Fbody Header
  132. is this TB worth it?
  133. Help, running horrible
  134. Pacesetter LT's Pic's
  135. Aftermarket water temp sender placement?
  136. locating tach wire.
  137. QTP Electric Cutout Rebuild ...
  138. Dual Mccord install locations
  139. Need help, fuse box
  140. fastest car here
  141. muffler
  142. Drivers side fuse box!
  143. 2otl questions???
  144. wow.....love my new sound!
  145. Engine Fuseblock Question - What's Hot Key-On??
  146. Open Headers?
  147. LS1 Edelbrock TB's
  148. Help with Exhaust Choice...
  149. Paint my aluminized ORY pipe?
  150. If Your FAST TB Sticks, Come Inside
  151. Mufflex 4" exhaust or TD's
  152. FAST 90mm TB - *Fix Pics* Voodoo semi completed.
  153. Headers
  154. FAST 90mm and NW 90mm TB Arrived!
  155. Mufflers: bullets vs sweet thunders vs xr1
  156. Idle problem
  157. closest elbow on passenger valve cover
  158. A/C delet questions
  159. header question
  160. Need new lid.
  161. 85 mm lid/MAF on 90 mm LSX 346
  162. Nick Williams 90mm TB arrived today!!!
  163. Which cats for Mac ORY?
  164. My LS1 sounds like a ricer. HELP!!
  165. Took off the Mufflex/Spintech 4" and put on Bassani Duals (out the back)
  166. Which 18in. sweet chamber muffler with duals?
  167. Exhaust Install
  168. Replacement cats for FLP LT headers
  169. Nick Williams 90mm TB's
  170. What is the best electronic cutout?
  171. Tr6
  172. Need some advice...
  173. Do You Liek Your True Duals?
  174. Getting hookers installed TODAY (i hope)
  175. part number # magnaflow carsound cats
  176. Header Gaskets
  177. LS6 Intake vs. Z06 Intake
  178. SuperMaxx Diameter Question
  179. Those of you with a Hooker catback come in!
  180. Best 90mm TB FAST or TPIS
  181. Where to get bellows for 85mm MAF to 90mm Fast Throttle body?
  182. So what do I need ???
  183. How loud would Longtubes w/TD's be compared to a Longtubes ORY w/ cut-out...
  184. LS6 intake install
  185. Best place to buy Kook or OTP headers!
  186. headers
  187. Is this normal.. header question
  188. Borla Exhaust plate
  189. exhaust manifold question
  190. pugs and wires
  191. Intake leak or Maf?
  192. ticking sound on acceleration after LT's installed?
  193. Post header install blues...lend me your brains!
  194. FAST Intake???
  195. Tach install
  196. my cool new exhaust
  197. EGR VS. NO EGR...Wat are the Pros and Cons?
  198. how to remove washer fluid reservoir?
  199. Help!! Rattle!!!
  200. dual setup?
  201. Noob Belt Questions
  202. which pulley for a cammed auto? which lsx intake?
  203. Loudmouth vs loudmouth 2
  204. Driving 3000 + miles
  205. coolant temp sensor
  206. WTF! cooling problem
  207. March Pulley
  208. header installation questions
  209. exhaust help
  210. Alternator pigtail, 99 Formula
  211. Pacesetter Y-Pipe
  212. Edelbrock carb manifold?
  213. Which Headers
  214. HELP!headers..no egr fitting...wat do i do?
  215. problem with qtp cutout???
  216. FI ....Stock Exhaust manifolds?
  217. Truck Coils
  218. which headers?
  219. LS1 mods....with warranty?
  220. is this worth while??
  221. Oil temp gauge - where to get sending unit?
  222. Tsp Y-pipe Question
  223. tsp y-pipe/elec cutouts
  224. dynatech headers?
  225. QTP's are in
  226. NO Air through front vents
  227. LT Header Install....??
  228. need help.. how to get rusted pipes unconnected?
  229. New LS1 guy.....
  230. Ok, I have a question and need an answer...
  231. Polishing my TB
  232. Question about ngk tr55 sparkplugs
  233. Meziere Street Version Pump with no Thermostat?
  234. QTP catted Y pipe
  235. 60000mle 5.3 coils or 26000mile 5.3 coils?
  236. belt issue with asp pulley....
  237. 02 sensors
  238. Jet Hot LT's & TSP Dual Setup?
  239. Cheap exhaust mod -- no muffler?
  240. Stepped?
  241. "Mother of All Bolt-Ons Swap" driving impressions...
  242. FAST Intake/TB
  243. Just Changed my Fuel Filter!
  244. got the flowpro on
  245. smoking exhaust
  246. Which would sound better?
  247. Dual Dual's with FLP headers??
  248. Daily-driver guys, has your Jet Hot coating held up on your headers?
  249. SLP's offering a new style "Dual/Dual" catback....
  250. What headers whould I choose?
