PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 [131] 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Fast Toys Ram-Air w/ SLP Lid (stock MAF) Any issues?
  2. Racetronix reliability?
  3. Would this be a bad idea?
  4. Electrical problem
  5. TB question
  6. Extending TSP Duals out the back....
  7. cant get dipstick back in
  8. header ground clearance
  9. What do I need to do about a throttle body
  10. 92 FAST Intake & PTM 92 TB??
  11. Tsp True Duals Owners
  12. Which MAF
  13. Quick Question about my Lighted Cutout Switch
  14. Small Basic Tips For Installing an Electric Cutout
  15. Texas residents....
  16. Need some info on the profesional products intakes
  17. best spark plugs to use?
  18. headers are in
  19. Victor Jr swap...
  20. Weld or clamp Exhaust?
  21. Edelbrock Shorties + Bassani O/R Y installed
  22. does the pacesetter ory fit kooks headers?
  23. air removal
  24. is flowtech's y pipe a 3" ?
  25. Problem with AIR block off plate ... Need help
  26. Thinking about duals on he the cheap
  27. xs header question
  28. Exhaust Question....
  29. Actual Head Size?!?!?!!?
  30. Fans Direction...
  31. Missing anything?
  32. had spark plugs replaced - now have ticking noise and somewhat low idle
  33. Pacesetter LT install ?'s
  34. LS 1 starter Wiring Solution for A body Ignition
  35. slp maf question how to figare out which one you have
  36. LS 7 Exhaust Manifolds Value
  37. **HELP***How Do I Get The Wiring From My CUTOUT Into My Car?*******
  38. The Best Maf
  39. True Dual Help Needed!
  40. ls1 and ls2 water pumps interchangeable?
  41. Need pics of newer style water pump ASAP!
  42. just put poly motor mounts on, can I leave the heat shield off with LT's?
  43. MTI Throttle Body Help?
  44. American Racing Headers....ATTN!
  45. How to remove LS1 Balancer 99 FRC C5
  46. Misfire only at idle...?
  47. do slp h cats have a carb #
  48. cam finally found idle video inside..
  49. guys with strokers post yall soundclips plz
  50. whats the best sounding exhaust on a stroker set up
  51. Will LT's make a big difference?
  52. Can I put a WS-6/SS lower intake on stock Z-28
  53. SLP LM Exhausts Not on SLP site?
  54. mac headers questions
  55. Does the new fast 92 throttle body work w/ the old...
  56. Hooker CB, Hooker Supercomp LTs, 3" ory
  57. QTP elec. cutout help needed.
  58. Help!!!!
  59. anyone heard of TPIS
  60. need to quite my car down
  61. PAGING: Tracy at RevXtreme
  62. best Lid/MAF/TB/Intake combo?
  63. American Racing Headers Review! Super easy install!
  64. Aftermarket truck intake manifolds
  65. Quick ? guys, 6.0 and cam Heads
  66. Headers/Exhaust Help!
  67. TDīs Installed / Sweet thunders
  68. Corsa exhaust, what's it worth?
  69. F1 Racing flywheel!! For all who wanted to know..
  70. Need an estimate on a exuast job...
  71. Any pics of UMI Throttle Bodys?
  72. 02 Sims ??
  73. Header install cost
  74. plugging 02 bungs
  75. why torque through bolt and nut??? motor mount install
  76. Dumped exhaust question
  77. Stock LS1 Head help
  78. O2 sims
  79. LM1 Bullet-Magnaflow
  80. 6.0 to a 4l60e
  81. air bullshit junk
  82. idle change with header install
  83. cam help
  84. H/C swap questions
  85. What is this part number, picture inside...
  86. Quite bullet muffler?
  87. installed headers. cars missing.. please help!!
  88. What's this connector used for?
  89. 408 big cam 13.1 comp. too loud!!!
  90. American racing headers?
  91. SLP LS6 Intake Manifold for 1997-00 LS1 Engines
  92. Katech Valve Covers & Stock Fuel Rail
  93. over axle pipe
  94. 92mm TB on a 90mm FAST
  95. MSD Wires ????
  96. Broke a sensor. Need Help!
  97. What goes here? (pic)
  98. 2 questions
  99. Will Jet-Hot Coated Headers Rust?
  100. A/C delete pulley for ls engines?
  101. Time To Get At The Gettin' At It
  102. Need advice on an exhaust overhall package... Please help me...
  103. LT1 Intake Air Duct Stem Thingy
  104. My jet-hot pacesetters
  105. how hard is it..
  106. Please Help Guys Mid Or Longtube Headers
  107. For header install?
  108. Exhaust Pop/Backfire
  109. ARH Banging issues???
  110. Water Temp Gauge issue
  111. Help Please!!
  112. How to check coil packs?
  113. has anyone bought the z06 85mm MAS from advance auto parts?
  114. Custom TD's with cats, Edelbrok 304
  115. Muffler CFM, how much?
  116. U/D Pully?
  117. exhaust piping size??
  118. ? about fast intake,injectors,cam?
  119. Should I change My spark plug wires?
  120. Cleaned up engine bay a little with AC delete panel
  121. Stiffer engine Mounts??
  122. 90mm nw w/elbow
  123. SLP cold air induction?
  124. Koolsox on MSD wires
  125. Direct Flowmaster 80 replacement?
  126. Help me solve this kpa discrepancy
  127. Pace Setter headers what do you guys think
  128. How much hp from a tune on a c5
  129. Can i remove the vacume solonoid on the drivers side??
  130. Can SBC headers fit onto the ls1 head?
  131. LS1 intake manifold on 01 LS1 block ?
  132. Solid motor mounts?
  133. LM1 yes or no to cats?
  134. LPP GTO Stainless Headers
  135. Best oil to use?
  136. slp dual/dual, ory and kooks LT
  137. Bigger Injectors?
  138. Alright guys, I need some help removing HVAC
  139. broke the oil filler neck..
  140. tuning a stock ls1
  141. Weiand Street Warrior Intake manifold
  142. Electric Cutout ran with TSP's Tru dual system
  143. different cat location between 99 and 02
  144. Header/stock manifold questions
  145. QTP Cutout
  146. Ported TB Issue
  147. Header Leak
  148. will lt hooker super comp headers off a 2000 fit on a 99?
  149. Any ideas on how loud this will be and how it will sound?
  150. Y-pipe H-pipe or x-pipe?
  151. Need to quiet down my exhaust..
  152. TB Porting and Polishing.
  153. ORY for Stock Manifolds
  154. cruise wont hook on my fast 90/90 ??CLIP???
  155. please read
  156. No Start...
  157. Corsa Clones....Where to buy? (Post Pics Please)
  158. Electric cutout with Borla Adj.
  159. PTC Headers? Anyone hear of em? Need info!
  160. What is the differance in altinater years?
  161. Bigger injectors needed for this??
  162. Autometer Tach install problems!
  163. need a bolt kit
  164. next mod?
  165. Magnamouth opinions?
  166. What's that inside LS2 fuel rails?
  167. Spl 2otl?
  168. Air Pump - Is it Necessary????
  169. WTF Fast Intake Blows Up with Pics
  170. lid question
  171. Slp Dual-Dual
  172. Kooks 2" race headers ???
  173. bullet length
  174. Kooks 1 7/8 and ARH y pipe ?
  175. Replacement batteries
  176. LS2 or LS6 INTAKE ON 408
  177. what's the second cable?
  178. SLP flow pack
  179. Throttle cable adjustment...without TCS
  180. Shorty Headers????
  181. do i need to change spark plugs and wires if im putting lts
  182. Installing Headers/Y next weekend..Have stock catback question
  183. header gaskets
  184. ARH LT's???
  185. pacesetter lts
  186. any one still porting tbs??/
  187. EGR Problems - No Plugs?
  188. Can electric fans be "told" to shut "OFF" at highway speed?
  189. Tie up rearend to install under axle true duals
  190. Stock MAF in Granatelli housing?
  191. Best Y pipe for shorties?
  192. need weiand intake gasket part number...
  193. Lower Intake question
  194. Clueless
  195. Hows this going to sound?
  196. Part numbers?
  197. anyone having problems with a NW TB sticking?
  198. Just bought an 2004 corvette
  199. What happened to intakeelbows.com?
  200. 02 ls1 in a 98 camaro...
  201. Exhaust shops around Lafayette, INdiana?
  202. quik info
  203. header sizes
  204. 0.38(20K) Ohm Resistance On A Stock Spark Plug Wire?
  205. Need some ideas
  206. New cats?
  207. Do I need new valve covers?
  208. 1 3/4" or 1 7/8" with my mods???
  209. new headers !AIR !EGR, help!
  210. need help with the alternator..
  211. Headers installed, rear O2
  212. arp balancer bolt
  213. c5 port polish TB Question
  214. how are the true duals from TSP
  215. NAPA sold me a bad coolant temp sensor :(
  216. o2 extentions
  217. MAF/ throttle body
  218. Ti-tech vs. Ceramic
  219. Ok guys I'm sorta new the the whole "Catch can" thing do I need it?
  220. best crank pulley and power steering pully?
  221. DMH Cutouts
  222. egr delete
  223. FIPK intake
  224. Whats in YOUR can?
  225. idle problem after i tap gas???
  226. LS6 intake? Help quick please!
  227. Car sputtering
  228. ported throtle bodie
  229. QTP Headers/ Spohn Trq arm
  230. Cooling fan relay question
  231. '02 ZO6 performance options
  232. Something Very weird happened
  233. Best motor mounts
  234. Spiral flow in I pipe sound clip? (I have searched)
  235. 2001 Corvette Z06 LS6
  236. Prothane Motor Mounts question
  237. Is my TB ported??
  238. Which 1 Do I go with?
  239. LT REInstall Problems
  240. Blowmaster's catback's with Magnaflow muffler???
  241. ***Help! A couple of Exhaust Questions****
  242. Shorty's
  243. Drove in heavy rain / snow. now misfires.?
  244. How can I tell what year my LQ4 is?
  245. Headers question
  246. Stainless steel ebay headers y pipe to use??
  247. difference in 98 99-02 oil sending unit
  248. will 24" O2 extensions do?
  249. Lightweight flywheel vids? Anyone?
  250. Electric cutouts
