PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 [181] 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Supporting mods
  2. Serious problems
  3. MAF question...
  4. anyone running a Meziere "Race" pump on the street?
  5. Please someone help me get these broken plug boots off!!!!!!!!!!!
  6. Where can I get metal catalytic converters
  7. KOOKS 3" TRUE DUALS, OVER AXLE EXHAUST
  8. Need help with electric cutout switch wiring
  9. oil sensor broke, P/N ????
  10. Engine movement
  11. made a mistake buying SLP headers...
  12. porting LS6 how to
  13. Rough idle and popping
  14. Ported my TB this morning, weird issue.
  15. Put magnaflow metallic cats on my car and not much change in loudness, whats next?
  16. Brake Lights Stay on ?!?!
  17. Where is your cutout?
  18. what do you think
  19. Fast 90/90 Setup worth it????
  20. SLP IAT module?
  21. What goes here ? Need help ASAP please.
  22. What E Cutout to go with?
  23. 96mm TB or larger?
  24. belt tensioner help
  25. Will this intake system be sufficient?
  26. March Pulley
  27. what headers are these
  28. Exact Steps for Intake Manifold Removal??
  29. Race only exhaust set up, would this work?
  30. Do I need a new radiator?
  31. QTP cutout wiring..
  32. 383 kit and H/C what will this spin up to?
  33. Idler Pulley Torque Spec's
  34. Block off plates?
  35. porting stock tb
  36. this maybe a dumb question
  37. aero-turbine muffler
  38. Custom plug wires
  39. what gasket for gmpp intake manifold
  40. The other Dynatech Headers
  41. Z28 style exaust tips
  42. Bolt hole spread on the MArch pulleys?
  43. Cme Exhaust Hangars??
  44. can a breather fit under a strut tower brace?
  45. Resonating noise with no cats-Kooks\Borla
  46. 160 degree t-stat doesn't fit???
  47. Edelbrock Victor Jr. LS1 EFI Intake Manifold or FAST 90
  48. Why new plugs with headers?
  49. Idler Pulley?
  50. ditching the maf. who sells tubing?
  51. Are these headers for an Ls1?
  52. my true duals
  53. BG Ram Air vs SSRA
  54. Exhaust question
  55. Had the car dyno'd today, lost power, think I know why
  56. Whats the point of this exhaust setup????
  57. Couple questions about dual exhaust
  58. Worried!!! Duals with no H or X = 1 side sounds way different!
  59. Texas Speed cat back check in!!!
  60. Jet Hot or ceramic coated Headers rusting?
  61. msd 2 step & ignition
  62. Victor Intake Mani vs FAST 90 Intake Mani
  63. coil pack question
  64. crane cams spark plug wires
  65. QTP Elec Cutout - Need New Motor
  66. still wont stay running
  67. FAST 90mm intake
  68. Point in 3" pipe...
  69. Valve Cover Breathers
  70. Perimiter bolt valve covers...
  71. Anyone used this exhaust?
  72. RapidFire? Platinum? Iridium?
  73. whats next?
  74. can vette's c6 TB be put on my ls1????!!! help plz
  75. Bullet/resonator in the I-Pipe?
  76. LS-6 intake manifold
  77. lt1 trans am best sounding exhaust
  78. TB question, please help!!!
  79. What carb hat are you using on your 4barrel TB?
  80. Maybe changing exhaust...please help!
  81. The Ring of Silence
  82. Injectors & fuel rails
  83. Overflowing Radiator Coolant
  84. Effect of 1 7/8 headers on 346
  85. LS6 Intake or bbk intake?
  86. ! ! ! Stainless Works Non-Chambered Cat Back ! ! !
  87. slp
  88. LS6 intake- how tall?
  89. underdrive pulley experts help plz
  90. pacesetter headers with y-pipe question
  91. exhaust hitting
  92. CME pics needed!!!
  93. ported TB ?
  94. What is the closest alternative to GMMG
  95. Cut wires!!!
  96. Mileage with ported TB
  97. SLP ORY and Pacesetter LT's will it work
  98. Nick Williams 90mm installed... Awesome! Slight warning as well...
  99. Problem with Serpentine Belt....
  100. New F-Body Bassani True Dual Exhaust
  101. just ordered paceseters, tsp ory & mag cat back
  102. PCV question
  103. header question involving years
  104. C5 w/90-90 set up
  105. TR ported TB worth 2rwhp
  106. i need something to quiet my ass down!
  107. long tube headers = problems
  108. Valve covers ?
  109. Sponsor that ports Carb-style manifolds
  110. need a pic of inside of bullet muffler
  111. TSP catted y-pipe
  112. Bell mouth adaptors on true duals / flowmasters?
  113. Just installed headers and now the car is way too loud. What do I do?
  114. Headers & air/fuel ratio??
  115. BBK Intake Manifold
  116. True Duals...will they smog?
  117. Stupid ? about removing fuel rails
  118. SLP Underdrive Pulley Question #100221
  119. SLP Underdrive Pulley #100221
  120. Dart heads? Stock heads?
  121. exhaust help!!
  122. 6.0 oil pan swaps
  123. Headers And Starter Heat
  124. When should you change wires?
  125. what to use? plug EGR hole in intake
  126. custom Y with merge collector or complete piece
  127. Home made O2 sims, anybody done it?
  128. Sheet Metal Valve Covers
  129. gmmg install
  130. Your Typical Install...
  131. hooking up oil temp gauge
  132. Hooker Full Length Headers
  133. Updates on e-bay Y pipe?
  134. ebay stainless headers
  135. mid's Vs. longtubes. and how do true duals looked dumped on ws6
  136. ls6 intake coolant pipe gaskets
  137. Borla XR-1....Where?
  138. Alternator bad?
  139. How many of you guys DD with true duals?
  140. a/c delete question
  141. tuned headers
  142. Throttle voltage issue...
  143. Slp Headers Pic
  144. Need Deeper exhaust, true duals?
  145. for guys with husky catch can
  146. EGR Questions?
  147. Help tone down my exhaust.Please come in
  148. Want my car to sound deep!
  149. Hedman Headers
  150. New ls1 intake system!
  151. SES Light
  152. Which one to choose?
  153. what to expect out of a long tube header tune
  154. valve cover mod?
  155. P&P TB.. Is It Worth It?
  156. I have decided
  157. Does this look normal? *pic*
  158. How to Louden an Exhaust?
  159. LS6 Intake Question?
  160. 90/90 combo?
  161. pacesetters
  162. x-mas mods help
  163. Full Bolt-ons List?
  164. Anyone lowered with 3" TD's???
  165. LS1 exhaust diagram (or good under car pic)
  166. help porting throttel body
  167. Who has the highest flowing CAT's???
  168. Intake And Throttle Body question
  169. Check engine light.
  170. Exhaust hitting after LT installation
  171. Do you think its worth it. FAST 90/90 I have BBK SSI now???
  172. mti clear lid?
  173. for all the aluminum intake haters
  174. Whose fuel economy increased after installing an FTRA?
  175. QTP LT Header issue, problem?
  176. What works best to support engine/k member for removal
  177. Exhaust HELP
  178. Loudmouth II install: not too hard
  179. Why are only the tops welded.
  180. Lt's
  181. True Duals Or Muffler?????
  182. EGR removal ?
  183. What exhaust are you running w/ BMR Trak Pak?
  184. Kook's picts inside,,, 56K beware!!
  185. Low coolant light on, radiator is full
  186. Help!!!!
  187. SLP lid/bellow install...
  188. How well does B&B flow
  189. Magnaflow metallic spun-cat aftermarket catalytic converter
  190. Exhaust ideas...
  191. Changing Tips on Borla Exhaust?
  192. Cat Problems
  193. Torquer V.2 with gmmg exhaust clips???
  194. overheating problem
  195. Help with Maf or Mafless tune?
  196. coil pack relocation ??
  197. ported throttle body
  198. Ls1 To Ls6 Intake Manifold Swap Parts Question
  199. EGR set ups
  200. Water problems with debaffling/sealing the WS6 hood?
  201. quick question!!!
  202. underdrive worth it?
  203. Does anyone make a water pump stud kit?
  204. expansion plug for egr blockoff
  205. ? Ses
  206. *Probably the best headers money could buy for an LS1 F-Body!*
  207. New Warlock Mufflers for My True Duals...
  208. should i run tailpipes on my dual exhaust?
  209. What's this???
  210. search down agian?TB Question
  211. update on wilson manifold
  212. DID some LS1's come with LS6 Intake?
  213. Dynomax Collector/Muffler
  214. Ignition coils
  215. Help with under drive pulley install
  216. Fast 78 or 90
  217. WS6 and aftermarket Ram Air question, is this true?
  218. 4' exaughst sounds great
  219. Sweet Thunders vs. Single Chamber Flowmasters
  220. Crankshaft Position Sensor Code
  221. Oil Pressure Gauge Pinned to the Left
  222. # Needed for check valves
  223. C5 vs, F body water pump ??
  224. True dual vids!!! Over axle, 1 chambers w/ H-pipe
  225. Couple of questions about installing an aftermarket overflow tank...I searched
  226. which long tubes are easiest to install in fbody?
  227. 4th gen camaro stock exhaust question, other
  228. Anyone use MSD coil packs??
  229. just wondering about Throttle adjst screw
  230. !muffler w/ tailpipes vs. !muffler turned down
  231. stock exhaust w/ cutout?
  232. ? about NW 90mm TB...
  233. my new exhaust~
  234. Bumpstop mod
  235. LPE 100mm MAF
  236. Granatelli spark plug wire users inside
  237. Who has a bullet off ypipe and has a cam
  238. lts/ory/cutout...what should i do?
  239. Slp Lm I
  240. Please Read!!! Asap
  241. who ports fast 90
  242. question about headers and cutout...
  243. Using convertible switch to power QTP electic cutout
  244. need to grind that little peice off my block, can anyone help me
  245. Gains in H/C car with header change or FAST 90 over LS6 ???
  246. what would you guys expect from this setup...
  247. Need QUICK help! Where to wire cut out??
  248. HOOOOLD EVERYTHING! Don't even THINK about a cat back!!
  249. Jet Hot/ 02 ext's? what's the deal?
  250. MAF code question
