PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 [208] 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Manifold malfunction, part question...
  2. Who makes the best Borla E-cutout?
  3. Shopping List for headers
  4. paper air filter
  5. Question about the Weiand intake...
  6. BEST exhaust note yet.....
  7. Flattening Pipes
  8. Going true duals..a simple ?
  9. exhaust questions
  10. poly motor mounts your opinion?
  11. Got my dynatech supermaxx system today!!
  12. SES after installing Pacesetter LT headers
  13. gmmg to slp dual/dual
  14. AIR Removal (not usuall questions)
  15. cant get my mac mids installed
  16. header install
  17. Hard wiring fans........
  18. Who makes a nice Y pipe to fit pacesetter LT's
  19. ls1 intake manifold EGR Block-off plate?
  20. TSP lids are out...what's your 2nd choice?
  21. My new Sweet Thunder catback!
  22. Oil Filter thread size
  23. couple questions about my new pacesetter LT's set up
  24. Getting o2 Simms, need help
  25. underdrive pulley
  26. quick but dumb LM question
  27. for an head and cam car? Worth it to get fast setup or ported ls6 intake?
  28. 1 7/8" Kooks headers
  29. True duals
  30. thinking about buying this intake manifold...need your insight
  31. Gas Mileage
  32. HOW TO: Poly motor mount install
  33. ported MAF?
  34. fast 90mm T/B
  35. S&B air filter
  36. another lame exhaust question
  37. Manifold/Header Bolt Anti-Seize or ThreadLocker?
  38. Quick Answer on Headers
  39. Belts
  40. Autometer Gauge
  41. Underdrive pully
  42. Looking for how to !AC, or any pictures u guys have
  43. Where to get OEM parts (other than dealer)
  44. Manifold install... broken sensor
  45. what do i need
  46. 105mm Throttle Body
  47. DIY Coil pack relocation??
  48. Electric cut out dimensions
  49. B&B Triflo catback or Corsa
  50. is edelbrock victor jr intake better than fast 90
  51. which exhaust do i want?
  52. banging noise please help
  53. Any TB porting horror stories out there???
  54. Do pacesetters bolt right up??
  55. !air, !egr, and tb bypass?
  56. How Loud is Loud?
  57. headers causing trans problems....help
  58. Pic of stock exhaust from DS?
  59. best intake
  60. Who Makes a Mini Starter for the LS1/LS6?
  61. new exhaust installed: Pacesetter LTs, ORY, Sweet Thunder "Rumbler" *CLIPS*
  62. Plug wire problem!!!
  63. pulley offset on GTO/Vette/Fbody Ls1/2/6
  64. headers just in....
  65. Cold Air intake with Ram Air on an SS?
  66. Broken Header Bolt? Fixed mine w/o Removing Head
  67. Does this seam right for an X-pipe?
  68. Throttle spacer
  69. Odd stumble at low RPM's... Help!
  70. They have a purpose!
  71. LOL Header install idea
  72. Pacesetter headers question.
  73. Tsp Catted Y
  74. Any way to know if my front O2s are going out?
  75. I am buying a bullet muffler for LM2 (dont know which one yet) HELP!!!!!
  76. Are front and rear 02's the same other than length of wire?
  77. Dirt Under My Ls1 Intake?
  78. Magnaflow tips too close to my bumper.
  79. Clean the MAF?
  80. where to can i find these parts for the ls6 intake conversion?
  81. Which reaches full temp first, coolant, oil, or engine block?
  82. How much air does the smog/AIR pump put out?
  83. vette MAF on F body ?
  84. Question about O2 sims and extenstions
  85. Loudmouth vs. Used Borla
  86. Balancer bolt
  87. Borla Exhaust Help
  88. How screwed am I? (codes included)
  89. carb intake
  90. Vented Oil Cap
  91. Exhaust backfire
  92. Velocity Stacks on an LSX F-Body Yet?
  93. truck coils
  94. solid mounts and your frame
  95. Put 408 in, forgot a hose! Help
  96. pacesetter long tubes
  97. Best Bullit muffler for SLP LM Exhaust
  98. Moroso spiral flows are kinda loud
  99. A/C compressor part numbers
  100. Harmonic balancer appears to be wobbling at idle? WHAT!?
  101. K&N filter oiling
  102. Dynomax Bullets or Sweet Thunders?
  103. people with Hooker LT's, question
  104. A More Quiet GMMG
  105. L o n g t u b e s . . .
  106. Flowmaster 10 series mufflers
  107. Need some help please
  108. New spark plugs and wires accomplished!
  109. Help with exhaust!
  110. Curious about SLP lid
  111. Crank Dampers harmonic balancers
  112. Fernco "smooth bellow", best > $10 spent!
  113. Shifting
  114. Need Part Number For Exhaust Manifold Gasket
  115. need ory for slp
  116. Weiand Intake Install
  117. TSP True Dual Questions
  118. Catch can/PCV valve?
  119. Makeshift Setup
  120. nice or nasty?
  121. How's this for an exhaust?
  122. Wrong Cam on Throttle Body?
  123. gap on plugs
  124. !air...
  125. Alternator removal
  126. Torque #'s for coolant plug's
  127. Track Proven Results "CUTOUT on SI, stock exhaust"
  128. SLP Header Install - Dipstick
  129. driver side manifold removal
  130. Cutout****
  131. Suncoast set-up to lid swap?
  132. brake reservoir on master cylinder?
  133. Race Magnum 3" Bullet mufflers
  134. Slp pulley any good?
  135. demodding
  136. best headers for lowered car
  137. Engine Oil Sensor?
  138. High RPM Engine Misfire Help?
  139. dry sump oiling for camaros
  140. 2 Questions about Headers/Y-pipes
  141. cut out
  142. overheating problem
  143. throttle body?
  144. How much power is this Y-pipe costing me?
  145. What ypipe will bolt onto QTP headers?
  146. Where does this go?
  147. Cut-Out?
  148. strange problem
  149. Will Pacesetters Work W/SLP Y-Pipe
  150. running rich
  151. Idle/rpm Probs
  152. loss of low end tourqe
  153. TSP ORY and pacesetters???
  154. Which puller do i need to install a slp underdrive?
  155. FAST intake does not want to sit flush?
  156. stamped metal under y pipe.
  157. call me crazy
  158. Muffler Problems Please Help
  159. Need Help Quick!
  160. True Dual Setup To Loud?
  161. Clearance and performance....mids vs. LTs
  162. Mellow Tone Mufflers?
  163. Magnaflow pics on Formulas
  164. Power Steering pump question
  165. Will Hooker ORY work with SLP LT's??
  166. Question for Ozidizr about new Magnaflow catback
  167. Which to choose from QTEC
  168. WS9 hood on a TA...will the WS6 lower box fit?
  169. My whisper lid won't stay on! Ughh
  170. Idling Issues
  171. GMMG vs. Stainless Works
  172. SLP Lid noise
  173. FAST 90 TB Bolt torque?
  174. A/C Compressor on the Driver's side??
  175. Ok. Give me some feedback/opinions on headers
  176. what tools?
  177. air removal q
  178. Water temp sensor thread pitch and type
  179. Random Technology Cat?
  180. band clamp question
  181. Squealing Lower Idler Pully
  182. where to purchase?
  183. Which Exhaust?
  184. help???
  185. help??? with cutout
  186. Most horsepower headers
  187. Whats the better intake setup?
  188. Headers?
  189. What kind of HP/TQ difference should I see with a cut-out?
  190. small inline fuel filter for PCV system
  191. power loss?
  192. Cutting Holes
  193. Spark Plug help from NGK
  194. Just got my long tubes installed (after my h/c package)
  195. Short belt mod?
  196. question about gaskets that came with fast intake
  197. just ordered pacesetter LTs and off road Y
  198. Oil Temp Gauge
  199. LS2 thermostat on LS1...?
  200. What tool makes the 02 sensor removal the easiest?
  201. Throttle blade screws/bolts??
  202. How to stop the banging??
  203. Tru Duals
  204. pacesetter lts, ory and magnaflow
  205. slp loudmouth
  206. quick question before I buy headers.
  207. Sweet Thunder
  208. Installed 160Tstat where should my gauge be?
  209. What to plug coolant temp sensor hole with?
  210. catback removal
  211. A little extreme, but...
  212. Headers without catback possible/worth it?
  213. A/C Delete
  214. Raspy Sound?
  215. Oil Consumption
  216. tq arm and x-pipe question
  217. Does porting the maf lean out a/f ratio?
  218. Do Clear Lids Change color or turn yellow over time?
  219. egr valve removal
  220. VX mufflers on Ebay vs Flowmaster?
  221. what do you think about the SuperSucker ram air extension
  222. Need your advice on exhaust!
  223. tips and tricks for homemade duals?
  224. Rattling Heat Shield
  225. Stuck Crank Bolt Help?????
  226. ford buddy havin 2nd thoughts bout Long tube install...
  227. AC and PS delete question
  228. Went to see about cutout pricing, mechanic says it's not worth it...
  229. Loudmouth II....is it as annoying as the regular LM??
  230. Truck/Camaro Alternator mounting
  231. What headers and mufflers should i get?
  232. Question for people with MSD coil packs
  233. Anyone put a 1 Chamber Flow. in I pipe???
  234. Which Y-Pipe???
  235. Pacesetters & O2's
  236. Just Got Banned
  237. ASP Underdrive Pulley REMOVAL
  238. dual outlet exhaust tips
  239. Props to Melrose headers
  240. pasesetter headers
  241. true dual question
  242. If i get this Corsa exhaust can i get headers later?
  243. Pacesetter catted Y sound clip
  244. what setup will sound the best
  245. Can someone explain the differences in the Borla Exhaust Setups.
  246. O2 Sims
  247. trying to make a set of plug wires
  248. Alternative to Pacesetter ORY???
  249. Which sensors to get?
  250. best headers
