PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 [140] 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Issues with new O2 sensors
  2. what should a stock auto 01 trans am run ????
  3. easiest way for a catch can?
  4. put my new lid on
  5. Air Vents not working right after Head swap??
  6. What SHould be my next mod?? need info have money
  7. Air Vents not working right after Head swap??
  8. A.I.R. Location on headers
  9. LS1sounds.com not working?????
  10. Is This A Good Aftermarket Throttle Body ??? Opinions Please
  11. New 85mm Fast Toys Lid, if you have a z28 come inside
  12. Stainless Edelbrock Victors
  13. header clearence
  14. Check out this new intake for LS7, L92, C5R
  15. Most free flowing muffler
  16. Help 02 problems
  17. Tune for the Z28
  18. Need to know which engine-bellhousing bolts to get
  19. Profesional Products 85MM Polished Intake Install
  20. just got my kooks 1 7/8 LT header need help on tune and other questions
  21. Intake question..
  22. LS1 grenade
  23. Air pump delete Question????
  24. Kooks banging
  25. Weiand intake, Yes or No.
  26. running hotter plugs?
  27. Will LT1 True duels fit my LS1?
  28. Pacesetter and tsp ory?
  29. Help! Mass Airflow (MAF) Sensor problem
  30. Just bought a 85mm, 5pin maf, who sells an F-body adapter?
  31. what size pipe for true duals?
  32. starter bolts
  33. Gutted Random Technology Cats.....
  34. Pacesetter Install ??
  35. FAST 92mm Intake?
  36. ''fast 90 to much''
  37. Has your MTI Clear Lid cracked?
  38. Which pulleys when bad make a loud mettalic whinning noise?
  39. my makeshift k&n ram air
  40. Dyno Tune Worth it?
  41. Will Running Open Lt Headers Hurt My Car???
  42. Stock Head/Cam 346 LS6 w/ bolton's pre-post Fast 90/90 Results
  43. Exhaust question (CME)
  44. ported tb results
  45. Rare 98 WS6 with SLP LM1...wanting more sound
  46. Can I run a belt around the alt,water pump, and crank only?
  47. Debating over LS6 Manifold...
  48. Where to put DMH cutout on TSP Y Pipe.
  49. True Duals or GMMG??
  50. dyno tune shop in Missouri?
  51. Simple Wideband ???? but can't find my answer??
  52. SLP lid or 85mm Fast Toys Lid ???
  53. new exhaust help for h/c car
  54. egr block off plate for ls1 intake
  55. Double Roller + Underdrive Pulley = Help
  56. Got a ticket for open headers..
  57. HELP! new fast toys lid wont let hood close!
  58. Throttle cable swap TCS to non TCS swap?????
  59. Tick after LS6 install
  60. 99 Camaro throttle cables!!!!!
  61. quiet exhaust
  62. Passenger Side Valve Cover..
  63. Volant Install Question
  64. Cutouts Location in a Dual Exhaust setup, Behind or in Front of X pipe ?
  65. Anyone with AR Header have this problem?
  66. need help with headers!
  67. Aluminum vs plastic intake
  68. Clearance pics w/ 40 series race mufflers.
  69. LQ4 throttle body vs LS1 throttle body.
  70. ok need a little help with 02 sensors
  71. Anyway to lower idle w/o a tuner?
  72. high idle, searching idle
  73. Oil dipstick tube question!
  74. Borla !muffler
  75. What do you guys think about this setup?
  76. Bullet Muffler Placement?
  77. Close bend hose ideas?
  78. Accessing header bolts...
  79. Polished LS1 TB and MAF ends???
  80. World's oldest liveing set of Grotyohann headers?
  81. Help Alternator removal
  82. Heads specs ??
  83. Add bullets to Hooker cat-back?
  84. Header Flange
  85. Open Pacesetters = FUN!
  86. What to expect?
  87. Anyone use these Magnaflow mufflers for duals?
  88. 59cc Ls6 heads
  89. ?on MTIs and ACCUFABs TBS
  90. TB question
  91. Tb????
  92. Which plugs to use???
  93. Found cause of misfires
  94. Where to buy DMH Cutout?
  95. HELP! Passenger side header
  96. whats the cheapest stainless headers?
  97. Kooks / Pace Setter / QTP / Flowtech ?
  98. Muffler question???
  99. major misfiresm no other faults :( help ASAP!! PLEASE
  100. Slp dual/dual muffler
  101. Modding party!!!!!!!!!
  102. may be getting some parts CHEAP
  103. Heard There Is An Oil Pan Alignment Tool?
  104. forged 347 + D1SC = What header Size??
  105. New Crane Rockers
  106. Do I NEED a tune?
  107. Pacesetter, TSP cat pipe and Magnaflow catback sound clip needed!!
  108. Broken header bolt! What to do...
  109. stock radiator, max hp
  110. crackin the plugs?
  111. Header Install
  112. zo6 titanium exhaust.
  113. Anybody else having issues with Jet Hot rust issues?
  114. Pacesetter passenger side LT clearance Question with PIC!
  115. Yet another slow factory tach thread.. Can we mod it?
  116. motor Swap and Elec...
  117. geting some parts what will i gain
  118. PLEASE help!! why would water cause this??
  119. Block Hugger Headers
  120. the pass. side of my y pipe disconnected
  121. which headers to get?!
  122. American Racing LT's Install pics!!!
  123. thoughts on a professinal products tb
  124. 408ci which header?
  125. need help!
  126. h-pipe?
  127. pace setter lt and y
  128. Carbon Fiber Lid
  129. throttle body
  130. Got my 2002 6 speed T/A today!!
  131. New rocker arms for new motor opinion
  132. LS2 tb and intake on an LS1
  133. After air removal
  134. Ceramic Coat Cleaning?
  135. Professional Products 85mm TB
  136. LS2 Or LS6 Intake?
  137. TB help
  138. Copper Header Gasket Install
  139. Single Chamber in I pipe w/GMMG???
  140. Question Re. Pacesetter LT's and TSP Catted Y fitment!
  141. oil pressure sendor
  142. injectors (pics/vid)
  143. JAAM ram air or FTRA?
  144. Shorty Headers?
  145. Painting headers
  146. Header Options
  147. Intake and TB Porting Christmas Special
  148. Kooks headers
  149. Modding Has Begun! Installed Gmmg
  150. 90mm maf any body make one????
  151. how do i wire QTP cut out?? (i bought it used)
  152. x-pipe clarification
  153. Who has an Alternator Overdrive Pulley?
  154. x-pipe for over the axle true duals?
  155. Gmmg
  156. Thottle body question
  157. Street Warrior
  158. Strange Starter Issues
  159. Stock center bolt covers.
  160. Lid question
  161. What breather to use?
  162. throwing codes.. maybe?
  163. EWP worth it on cam and bolt on 98 Z28?
  164. Aftermarket Oil Pan ????
  165. Headers
  166. Question?
  167. whinning noise help?
  168. cutout/weather
  169. Hope somebody can help... Mechanic gods??
  170. Header and true dual question
  171. Need Wisdom, Only Have $750
  172. xs catted y?
  173. catted y for xs headers?
  174. Why Do I Have To Change Balancer Bolt Upon Cam Swap?
  175. Anyone used this Intake?
  176. Whats The Best Bolt Ons
  177. does a underdrive pulley work
  178. Putting Cats on an ORY
  179. vaccum pump for normal driving?
  180. quick exhaust question (video inside)
  181. Fuel Rail Leaks...??
  182. I want to buy a 2 step
  183. Hooking up gauges, what size adapter
  184. exhaust
  185. MAF pigtail?
  186. next upgrade
  187. throttle body porting question
  188. Have Dual Cutouts? COME ON IN
  189. aluminum intake question
  190. 2000 Camaro SS stock exhaust
  191. can someone please tell me lol
  192. Seat of the Pants Bolt Ons?
  193. Need help!
  194. Studs on stock cats
  195. Question on starter return line....
  196. exhaust to header help?
  197. Help Descreening MAF?!?!
  198. positive battery cable
  199. What Intake
  200. What Intake
  201. MAF in SLP lid?
  202. What Intake
  203. What Intake
  204. Any thoughts
  205. Best sounding exhaust
  206. headers question please help??
  207. American Racing LT's just arrived!!!
  208. porting ls6 intake?
  209. Pacesetter install update, need opinion!
  210. Best Exhaust Set UP
  211. absolute quietest muffler...
  212. True Duals question
  213. 98 T/A Signal Lights
  214. What ORY pipe will fit to a stock manifold?
  215. SLP lid question
  216. FAST TOYS 85mm?
  217. What headers to bolt onto Stainless Works off road Y?
  218. What would this sound like? Serious question
  219. Alt overdrive pulley HELP!
  220. ls1junk
  221. Oil Pressure Sending unit torque number?
  222. Where can I buy intake and Tb gaskets for my Fast 90mm intake??
  223. QTP back in stock and free shipping
  224. NGK Spark Plug help!
  225. Which ASP Underdrive Pulley??
  226. Y-Pipe
  227. slp dual/dual muffler
  228. Shortie headers vs Y pipe
  229. Under drive pully?
  230. #7 Dead
  231. Ls6 Oil Pan Work In Fbody Camaro?
  232. Dumped true duels back to stock exhaust
  233. Stainless headers $280 shipped?
  234. ls2 intake??
  235. Electric Cutout
  236. Need it a lil quiter?????
  237. flowtech
  238. ORY or catted Y with Hooker catback??
  239. Fuel Rail Install Problem???
  240. Got A Major Problem
  241. $100 for bolts?
  242. mufflers
  243. 02 Camaro Install Help for Clear Coners
  244. 90mm elbow?
  245. Guys with LS1's and Fast intake step in please. LS1 or LS6 cooling tubes??
  246. Question about plugging the egr on ls1 manifold..
  247. Anyone have flow numbers for ls1 and ls6 intakes?
  248. Type of headers????
  249. HELP: Car dies after startup / shows LOW OIL LEVEL warning message / But NO Codes
  250. Could this be it......
