View Full Version : Generation III External Engine
- What is this part called?
- SLP daul dual, SLP 2otl.
- Hooker sound clips
- Magnaflow or Hooker?
- when installing longtubes should you put silicone on the gaskets tohold them in place
- 98-99 vs 00-02 air box
- flo pro vs dynomax bullets?
- What to make exhaust pipe gaskets with?
- Bermuda Triangle Found!!
- Exhaust tips change sound?
- How loud would this custom system be?
- Electric or Mechanical Gauges?
- Victor Jr. Fuel Injection Kit ???'s
- Do the QTP and Kooks 1 7/8" headers have the same total length?
- Damn EGR code!!!!
- How much was your NW 90MM TB?
- BBK vs. LS6 (Intake Manifold)
- TSP True Duals
- Pacesetters
- will cats throw off A/F ration??????
- Header, Y-Pipe question
- Manual Cutout Pull cord thing?
- Why do cutouts have to leak????
- Header question
- flowmaster,is it that bad??
- hooker or corsa
- bellow for LS6 MAF?
- People Who Have True Duals Does The Exhaust Smell Burn Your Eyes When Your In The Car
- underdrive pulley
- Borla I-Pipe Length
- school me on intakes for a ws6
- Headers, Xpipe, Mufflers?
- stock exhaust size, and what sounds better?
- Where to buy a 12" dynomax bullet muffler?
- Formula owners...post pics of your exhaust
- Who's running shift lights?
- Porting Stock TB
- will TSP ypipe clear aftermarket torque arm?
- Fast 90 question?
- 90mm TB gasket
- hooker aerochamber or 10 series single chamber flowmaster
- Gmmg owners future and present inside.
- GM Vented Oil Cap vs. Breather
- exhaust system questions
- Carburated 5.3L ?
- Should I make more intake changes??
- Qtps or Kooks on my 02 SS
- Can U Use 98-99' SLP Rad in 00' Car - Differences??
- need new exhaust
- ack - Spohn Engine Stands / Solid Mounts
- valve covers
- 160 Stat Question
- True Dual Photos
- Need Tsp Dual Pics
- ahh exhaust change agian
- Too loud?
- Installed Hooker catback....
- Pics please of TD's
- GMMG or True Duals
- Kooks y with qtp headers
- Edelbrock Headers
- Stock TB won't bolt onto FAST 78mm
- Kooks vs Hookers
- Cant decide.
- Headers for my 02 SS
- SLP Performance Pacs
- High Flow cats
- My exhaust setup
- wierd squeal
- Why!!!
- Headers stuff
- what size hanger do i need???
- Advice needed Broken header bolt :(
- Slp headers....
- Water Pump
- Got done with exhaust install
- Edelbrock headers.
- MAF Question???????
- best fit on slammed z28???
- FAST 78MM intake install Qs, (searched but no info)??
- X-pipe oem fitting?
- everyone with true duals can you use dummy tips
- Pacesetter Y-pipe
- bad ignition coils?
- sweet thunder cat-back?
- true duals smoge legal??
- Throttle Body
- What can i do when i get LTs?
- which gasket is better???
- Stuck on manifold removal...heat shield?
- 1 3/4 vs 1 7/8 qtp longtubes please help
- Spark plug question for experienced tech.'s or racers please
- LS1/LS6 Exhaust flange
- Underdrive Pulley
- Headers on an 02 ss
- Intake
- Installed the Corsa today....feelings are mixed
- Opinions needed...
- ORY rattles against floor BAD
- GMPP Intake VS Edelbrok Victor JR (LS1)
- Coated or painted?
- Please check out this poll
- Anyone run a Borla XR1 with 4" Exhaust?
- QTEC owners inside.
- Take out stock exhaust without cutting?
- Kooks worth the money?
- LT vs MAC pics?
- Header Bolt Question?????
- Fast 78mm Questions???
- urethane motor mounts?
- Why does my alternator keep going out??????
- TSP Sweet Thunder X Duals (pics inside)
- attn: all of you who run 11 secomds and quicker 1/4 na?
- Exhaust ideas
- best bolt ons
- How to get motor to take water?
- Spark Plugs ??
- What's a breather filter?
- Should LT's and Catbacks be bought at the same time?
- ORY question
- lts , catted y , and rumbler. anyone runnin this?
- Why not port a ZO6 MAF?
- PIC's inside, Making my own tu-duals over the axle
- True Duals Kick ASS!
- Zo6 Maf Sensor On 02 T/a
- ASP Pulley ? Think it is seperating.
- Power Steering Pulley Replacement????
- Magnaflow won't fit Pacesetter ORY
- Who makes a 3" ORY for TTS LT's
- does year matter?
- opinions please on bullets mufflers
- Meziere or Evans Electric Water Pump
- y pipe
- QTP Anybody use a Diff. ory pipe then flow master
- Mac Midlengths & X pipe modification
- Header Install Question
- What does this connector go to?
- asp pulley
- borla plates
- x pipe,is there really a difference?
- Double Roller / ASP Pulley ?????????
- Exhaust & Headers
- GMMG or Borla
- 1 3/4 or 1 7/8 primaries for headers?
- LM vs Rumbler vs Flowmaster 80
- Differences in the design of the Smooth Bellows
- What else do you need to run true duals out the back? Were talking everything.
- How do heads change the ls1 exhaust note?
- removing stock header?
- Exhaust Hanger Question?
- Pacesetter Headers
- ? about SLP LS6 intake
- Where can I get a stock throttle body blade?
- Anyone else not notice much MPH gain with headers?
- True Dual install question
- Anyone try these headers?
- Egr
- electric cut out
- Is LT's, ORY, and Loudmouth too loud???
- Will my exhaust sound good without tips?
- Short belt mod!!!
- All guys with solid motor mounts, how bad will it shake?
- Whats the deal with runnig maf less
- torque setting
- ls6 motor swap! need PVC help! asap! please!!
- P0300 Ugh!
- Everyone with lanes true duals please check this out
- dumps or run the pipes out back
- cutout=the best
- Spark Plug Wires
- Just rebuilt the top of motor
- BorlaMouth Owners Please Comment!!
- FM13/AFR 205s/No Cats, Mufflex 3.5 Spintech --- LOUD as Sh*&
- removing asp pulley...
- Who has this setup: LT's,ORY, and Loudmouth?
- Inside the BBK SSI manifold
- I *$@#ed up
- ***Shift Light Wiring***
- looking for the stock appearing CME and fascia
- Big tube headers
- Plugs and Wires
- Newby ?? about Water Pump Pulley
- Is it worth a swap from Macs to long tubes?
- Interesting Question!!! Will dropping my exhaust and driving like thataffect my motor
- Short vid of my exhaust
- Ory
- Thinking of ditching the ever popular B&B tips..
- opinions, how to get out broken bolts
- Everyone with true duals please come inside
- stripped
- BBK throttle body blade replacement
- Ways to kill drone on a SLP LMII Cat-back
- true duals, exhaust ? using a spohn body mount t-arm
- Problem with Kooks 1 7/8 LT's on a Vette.
- Pacesetter Headers Failed
- Where to find titanium exhaust tubing?
- how long will they last?
- which one do you like the most with LTs, ORY
- Exhaust Noise Troubeshooting Suggestions...?
- Sound diff between 2.5 and 3"
- need help with tsp ory
- Arr these true duals and longtubes on ebay any good?is this a good company?
- Can anyone name what brand of longtubes these are please?
- Best Headers For My 02 T/a
- would there be any hp difference between 1-3/4 kooks and 1-3/4 qtp longtubes?
- New ZEX Plugs??? Anyone using them Good or bad
- Bassani exhaust using universal mufflers?
- Exhaust questions
- Stock wires...heat shields?
- high idle plz help
- Who makes a direct high flow cat replacement for LS1s
- New Alternator?
- 99 to 02 TB
- Those with unpainted FAST intakes-
- Pacesetter LT's (help)
- gutted cats, now using oil? WTF?
- seafoam??
- Autometer air fuel ratio gauge,will it work off of factory o2 sensor?
- Collector bolts...
- Please, in need of quick response ASP pulley I.D.?
- I can't get my Corsa tips straight...pics please
- 2.5" or 3" Y-pipe with LTs?
- Would like your opinion.
- if i keep my air but dont have cats will it hurt anything?
- Position Sensor
- LS6 intake install help needed ...
- Anyone make exhaust tips like this?
- cermic coating necessary?
- Stock Looking Catback
- Pacesetter header and ORY ground clearance
- what kind of pulleys 2 get?
- exhaust cut outs????
- ceramic coated headers
- Bad vibrations???
- synthetic oil
- crank pulley identification..
- Headers can't bolt up!!
- header install
- Tensioner pulley bolt size
- Size Of Stock Y-pipe
- Fast intake question?
- HELP!!! Hooker LT driver side
- SS cutouts.
- Custom Big Tube Header Sources?
- Question about fabing up some o2 extensions
- what exhaust setup for trex
- does anyone even sell a catted y pipe for slp longtubes
- will tsp true duals work with slp longtubes? and will 17" rims give u more clearance?
- anyone have pics of slp longtubes on a car that isnt lowered
- question about tsp true duals
