PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 [115] 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Ported throttle body - high idle
  2. Totl
  3. knock sensor questions
  4. O2 extensions with pacesetters
  5. QTP headers hook up to TSP True Duals?
  6. BBK LT's + Y (2 part question)
  7. can you tell what muffler i have?
  8. ls2 coil packs and harness on an ls1
  9. FAST 92 Install
  10. LQ9 intake manifold
  11. pcv catch can
  12. $150 to spend on a temp. exhaust system off headers
  13. exhaust leak at collector
  14. What is a cutout and how is it used?
  15. Question About Upgrading To 85mm MAF
  16. Exhaust suggestions
  17. Hey has anyone ever heard of using escalade heads?
  18. custom CAI pictures needed
  19. rear cover
  20. Dynomax Bullets
  21. Fluttering Sound--AIR Suspected
  22. Vic JR install(Nitrous Outlet Please Chime in)
  23. What do you think of this intake set up for me?
  24. Someone with stock or stockish exhuast....
  25. Is this pcv set correct?
  26. Evans or Eddlebrock LS1 Performance Water pumps???
  27. give it to me straight
  28. Just Bought Pacesetters LT Headers & Y Pipe...
  29. Want to Go Faster N/A
  30. Need pic of stock 02' f-body exhaust from under car
  31. what 90mm throttle body??
  32. Header question
  33. Exhaust
  34. BBK Throttle Body question
  35. Confused on what LT's to order Need Help
  36. Motor Mounts
  37. Yellow strip springs
  38. 1 3/4" Headers vs 1 7/8" Headers ?!?!?
  39. Help fixing I-pipe to borla exhaust opening (need a reducer or something)
  40. Prc springs with stock retainers?
  41. Tyhpoon Intake? any opinions?
  42. AIR Pipe Block Off Plate - Have you Broke the Header Weld???
  43. Anyone here have a loudmouth2?
  44. cme...
  45. Installing TSP's 1 7/8" Headers
  46. Just installed Solid Motor Mounts, questions regarding Trans...
  47. Who makes a good quality AIR block off plate?
  48. ? about replacing header gaskets
  49. meziere waterpump lower outlet??
  50. Battery Relocation question
  51. Katech CNC ported LS cylinder head clearance sale
  52. P/P stock tb vs. BBk 80/85mm tb
  53. couple of questions on kooks y pipe
  54. HELP!! LongTube Rattle
  55. Is this PCV valve and catch can setup properly?
  56. how many of you guys have had their lts welded to your ory
  57. best plugs for an ls1 tune up.
  58. OBDII plug part number?
  59. If you have MAC headers please step in.
  60. Quick Exhaust question
  61. BBK 85mm throttlebody
  62. Cold air Kits
  63. Changed up my exhaust and loving it!
  64. What size butterfly valve do I need for my exhaut set-up?
  65. What if you find an exhaust leak, but don't think you can plug it?
  66. Help Silencing Exhaust- A little
  67. Throttle body question?
  68. Stall converter?
  69. Rockers?
  70. ready to install magnaflow...need pics
  71. Will a 5.7 350 ASP UD pulley bolt up to an LS1?
  72. Some questions about issues after LS6 intake install
  73. CME Owners.... How to tell if its real????? Anyone??
  74. gears or longtubes
  75. Yella terra non adjustables..setting them..
  76. different Y's with different headers?
  77. header install how to??
  78. PCM /harness myth?
  79. oil leak just started... need help
  80. True dual question
  81. Heeeelp!
  82. Random questions about Heads/Cam
  83. Cut out + QTP catt'ed Y?
  84. Seeing a pattern with Pacesetter LT?
  85. leaky injectors, please help
  86. how do i tell what gear ratio i got?
  87. O2 Sensor Extensions?
  88. What top end setup
  89. ? about LS6 intake.
  90. car starting issue
  91. problem with car cutting out in 5th an 6th gear
  92. True Dual ?
  93. Anyone else with a 408 have problems
  94. need help!! cant figure out whats banging!!!
  95. installed slp flow pac
  96. 85mm MAF needed with my setup?
  97. Guys with Kooks, please come in..
  98. Idling problem with new intake.
  99. relocated battery, installed kill switch, battery voltage lower then normal!!
  100. dtc p0174
  101. Stainless AIR Block Off Plates
  102. Miss Fire Codes
  103. small gaskets on coolant vent tube
  104. gains from ls6 intake
  105. E-Cutout or not??
  106. JUST BOUGHT A 98 Z28, WHAT TO BUY AND Q's.
  107. urgent question (oil filler neck)
  108. ls6 intake fitment
  109. is it the corsa or the borla that is....
  110. Noise after header install...please help
  111. Pro- Charger P1sc Tuner Kit For Sale
  112. These headers look OK?
  113. UDP Won't come off crank!
  114. How to Identify an LS1?
  115. Fast 90 idle issues
  116. Best free flowing muffler?
  117. Belt help
  118. ASP Pulley Kit
  119. tsp ory into 3in catback help! lots of play!!
  120. NEW WS6 Owner... Questions
  121. New WS6 Owner... Questions
  122. Cutting the egr
  123. Magnamouth review/installation
  124. SLP Lid and Bellow Install... Pics
  125. QTP manual cutouts
  126. Quick question: Should I buy this used K&N?
  127. y-pipe question
  128. Damian @ spartan performance
  129. Which Heads:
  130. My fan shroud is stuck to my rad..how to separate in the car..dont' need to take out
  131. Winter Mods, Need some info
  132. maf
  133. What Y-Pipe with E-Bay Headers???
  134. Car wont start - please help - info within
  135. Questions before i order my LT's
  136. O2 Extension Question?!?!?
  137. Heads and cam
  138. How beneficial is a 3" Y-pipe with stock cubes??
  139. just heads and intake??
  140. Anyone Found Trouble Descreening the MAF?
  141. any pics of pro products polished manifold installed
  142. 5.3L Questions
  143. what parts should I buy for a ls1 to ls6 heads swap?
  144. harmonic balancer
  145. header bolt size dimensions
  146. 6.0l Cranks But No Start
  147. TR230 cam......What size injectors
  148. new dyno results! im happy!!!!!
  149. Total Horror Show!!!
  150. Adapters for LSX swap?
  151. SLP Flowpac Air filter
  152. Need help with exhaust>?
  153. Scam or good deal?
  154. car fixed it self ?
  155. Information on the SLP 400hp Package For The LS1
  156. We have 1/4mile times how bout your cam install times?
  157. seafoam questions
  158. Vacuum Port Question
  159. Ruff Idle
  160. Fastest LS1 intake'd 346ci car?
  161. Backfires on Start up. Bad Cam Sensor?
  162. what is all needed for the cme exhaust?
  163. charging issues: please help ;)
  164. removing cats on stock exhaust
  165. flanges
  166. Gained 63hp/25tq With H/I/LT's...Normal??
  167. Stock Injectors
  168. Do The 2002 Ls1 Motors Come With Ls6 Intake?
  169. new noise from under teh hood. chirping
  170. Radiator hose extension?
  171. Will removing the air system clog high flow cats?
  172. vararam c5 intake on my 98 z
  173. Bought Headers
  174. Is the FIPK worth it?
  175. speedinc. true duals?
  176. Charging Issues
  177. Question about mods to a car.
  178. Hooker Maxflow? Anybody?
  179. MSD plug wires hit SLP headers
  180. head and intake match
  181. Is It worth putting hacked up CME back together
  182. Exhaust crew... Thoughts on this setup?
  183. Where to buy coated ARH headers
  184. What does these codes mean?
  185. valley cover removal
  186. what is this?
  187. Oil Pump To Oil Pick Up Tube Bolt
  188. PA Racing k-member
  189. damn o2s again i think, help me out here
  190. New exhaust poll
  191. Cut out questions? pics and vids
  192. absolute best exhaust system and setup? ls6
  193. Magnaflow catback vs Direct replacement muffler
  194. Removing SLP loudmouth Problems!
  195. Pics Of LS1 Sensors
  196. Question
  197. EVAP and EGR Removal
  198. tpis 90mm ls6 intake
  199. cut out location?
  200. Engine trouble
  201. LS1 engine stands
  202. American Racing Headers & Intrax 2" lowering springs (lots of pix)
  203. SLP lid plug, where to buy?!?
  204. QTP race headers/Ypipe doesn't bolt up to 01 Ws6 exhuast?!
  205. Escalade?
  206. y pipe bang?
  207. Blow drying an air lid
  208. ses light after header install
  209. BBK CNC Series Headers Question
  210. will polly motor mounts vibrate?
  211. arp ls1 motor mount set do I need one or two sets
  212. Anyone running this setup (exhaust)
  213. Need help! CAR STARTS MISSIN AFTER BOUT A HOUR DRIVIN AND DIES
  214. AIR Removal 2000 Camaro SS PICS
  215. meziere electric water pump problems...
  216. TPS sensor voltage
  217. O2 codes??
  218. ANY pics of TSP True duals with bmr extreme TQ arm?
  219. need name or P/N for eplastic elbow valve out of the brake booster
  220. Another Heater hose , Y pipe question!..
  221. Rear 02 Sensors
  222. throttle adjustment?
  223. Doing h/c install and need A.I.R /EGR removal advise
  224. Pacesetter/Y-pipe from TSP problems
  225. SLP 85MAF VS Stock MAF w/ported ends
  226. LS1 intake porting
  227. LQ4 Block LS1 Camaro Accessories
  228. ls1 intake corvette
  229. I think I made a huge head install boo boo
  230. Halltech Induction Systems Now Available @ Texas Speed & Performance!!!
  231. Merge Collectors?
  232. 85mm mass air flow questions
  233. What do you think of these headers
  234. Kooks headers w/ QTP ORY
  235. removal of one cat
  236. Cross Threaded Head Bolt
  237. Truck Pan in F car?
  238. Brisk LGS Spark Plugs, Revisited...
  239. Exhaust leak? Popping while driving and p1133 code
  240. header problem need help!!!
  241. wierd vibration?
  242. Im Looking For GMMG Exhaust
  243. H-Pipe problems?
  244. High pitch whine driving me crazy
  245. Cam or Headers or Nitrous
  246. Bought a FAST TB off here....TB knowledge needed
  247. ported vs. unported ls6 intake
  248. quick question
  249. Mods?
  250. drivers side lower alt bracket?
