PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 [258] 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. What cats does SLP use for their LT's?
  2. What Ignition system should I get???
  3. Sweet-thunder Vs. Bullets
  4. Taking off the Y-pipe
  5. Dynamaxx headers....compared to Kooks
  6. Installing 90mm Fast Intake &TB& Fuel Rails
  7. HELP PLZ! Think I broke something
  8. Coolant Leak Question - *PIC*
  9. Oval, Round, or Bullet Muffler?
  10. Hooker headers and y pipe installed today!
  11. Need help. (MAF related)
  12. Need SLP intake intructions!!
  13. What brackets
  14. aluminum anodized headers
  15. Hooker or Magnaflow
  16. Anyone got pics of TSP ORY?
  17. Where to angle turndowns?
  18. Edlebrock headers into true duals???
  19. Wires
  20. Cant get 4th motor mount bolt in.....Help!!!!
  21. sewing machine after LTs please help!!!!!!!!!!!!
  22. ‘borlamouth’ install complete
  23. C5 Throttle Body
  24. Oil Press. Gauge Install
  25. Car shuddered at 110mph
  26. Is it bad to run open headders??
  27. FlowTech LT's in, engine running rough
  28. Will pacesetters work with lightweight k-members?
  29. tsp true dual people
  30. Cat back question?
  31. Cars sticks at 2K idle when moving
  32. TB question
  33. GRRR!!! My Jet-Hot coating is flaking off!
  34. Lt Vs Macs And Fast 90mm Vs Ls6
  35. Cleaning stainless headers?
  36. Question about the Edelbrock setup..
  37. Corsa muffler gone bad
  38. Bassani exhaust
  39. nascar boom tube
  40. Anyone ever used oval tubing for true duals?
  41. Dumped Dynomax smog proff?
  42. Coated Pacesetter LT's..how will they hold up to the elements??
  43. Corsa muffler problem
  44. torque specs for motor mount bolts???
  45. Yes another GMMG vs Magnaflow thread
  46. Mufflex LS1-Hr Stainless Steel Hanger
  47. exhaust help please!!!!!!
  48. LS6 intake
  49. Got my Sheetmetal Intake Pics Inside
  50. Need help to settle a debate....
  51. New fabricated valve covers
  52. XR-1...Need ASAP!
  53. upcoming induction and exhaust mods.. tips?
  54. Ditched the Pacesetter Y-pipe and installed duals.
  55. 02 sensor question...........
  56. Mac Mid VS. LT's
  57. Just got Edelbrock Headers - Pics inside
  58. What lid will fit the 85mm MAF?
  59. Gutting Cats/O2 simms?????
  60. What used the 85mm MAF stock (was it the Z06)?
  61. How often do you clean your Holley Powershot
  62. True duals over the axle
  63. Edelbrock or Pacesetter?
  64. K&N cleansing and Re-oiling
  65. Deleting the EGR?
  66. Differences in X crossovers
  67. What Do You Guys Have To Say About This?????
  68. x pipe is too loud...need quiet mufflers
  69. Removed AIR this weekend. What to do with this part?
  70. Headers, Coatings and O2 Codes
  71. AIR question
  72. Is There A Difference Between The Ls1 And Ls6 Throttle Bodies?
  73. tru dual compatibality
  74. Ram air question
  75. high idle on cold start
  76. ? about Sweet Thunder
  77. Gutted Cats?
  78. 02 Question?
  79. MAC Header pictures needed.
  80. QTP Headers
  81. Looking for Cat Y pipe for a set of grott headera
  82. who has seen the biggest gain...
  83. Y pipe for Pacesetter Headers?
  84. oil stamp location
  85. tsp true duals and jet hot headers pics..
  86. how much hp with fast intake/w90mm-on a h&c car?
  87. motor mount help
  88. Need Help Wiring o2 wires
  89. Kooks Came In The Other Day - Pics
  90. FTRA or similar question
  91. cold air intake
  92. What did the recent GMHTP say about the SSRA and why no gain??????
  93. ls1 vs ls6 intake
  94. off road y pipe
  95. Oil temp guage? Mounting
  96. Flowtech Header Collector
  97. pacesetter headers install/help
  98. Aero-Turbine Exhaust?
  99. what headers/exhaust would you get if you had any choice
  100. Installed Shaner S3 Throttle Body today
  101. Ls1 intake or a LS6??
  102. whats the difference?
  103. cut of collector and weld on high velocity collector
  104. Okay, so bottom line: does ls6 intake need a tune?!?
  105. Is it even worth it to use a K&N or a Holley Power Shot Filter?
  106. i love my hooker but...
  107. Stock Y-pipe question
  108. Finished Pacesetter Install...
  109. AC vent issue.....
  110. PaceSetter
  111. motor oil
  112. help with tsp true duals
  113. PCV Question
  114. 90mm TB & intake
  115. Finished LS6 Install :)
  116. Idle is high after TB install
  117. LS6 part number please
  118. Ordered my Sweet Thunders and x-pipe
  119. Any experience with Magnecor ignition wires?
  120. My new trick for more positive seal on airlid
  121. Edelbrock victor y pipe help
  122. EGR Eliminating
  123. Stainless headers, heat issues??
  124. Will the block melt plastic?
  125. parts needed for installation of ls6
  126. Supermaxx headers-Did the "search" but need more feedback!
  127. how much for header and ory install?
  128. got my TSP true duals........OMFG!!!!
  129. Headers or
  130. true duals to catback
  131. Pros&Cons of POLY MOTOR MOUNTS
  132. Your input is requested
  133. Removing TCS???
  134. Water temp guage, mechanical or electric??
  135. Gmmg Exhaust Installed Finally!!!
  136. hooker headers
  137. 13.1@107 plus LS6 intake = 13.4@104???
  138. True dual setup with one muffler.
  139. Buy the x-pipe or x-pipe kit?
  140. ASP install: Longer bolt or threaded rod/washer/nut combo
  141. bad plug wire but no code???
  142. Just bought my new headers...
  143. LS1/LS6 intake gurus inside to clarify an issue please!!!!!
  144. found my setup what do you think?
  145. My car sounds like a drive-by shooting!!!
  146. carb'd LS1
  147. Switched plugs and now the engine breaks up accelerating..
  148. smog Qs
  149. blocking off air tubes w/o pulling air.
  150. Intake Overhaul...
  151. cat swap question
  152. Intstalling FAST 90 TB and Intake?
  153. What's ran? no cats,guttd cats?
  154. Best Cats?
  155. anyone running spohn torque arm with duals
  156. intake manifolds
  157. Missing plug electrode
  158. Need pics of Borla XR-1s on true dual setups
  159. Exhaust System
  160. What exhaust would be louder???
  161. LSX 90 owners with stock cubes, cam, heads
  162. burnt wire on passenger side of headers???
  163. Ory Cutout Location
  164. Loud Mouth vs. Borla in sound
  165. More LSX issues
  166. LT headers and maintenence.
  167. My gains from LSX 90mm intake.TB and headers
  168. F-body coil relocation on a C5...
  169. instead of using restrictor plate for AIR can i make a complete blockoff plate
  170. Corsa Exhaust
  171. Need part number for water pump!!
  172. Just finished LS6 install...
  173. tired of her b*tching, need less interior resonance
  174. 2nd time its happened, I wanna fix it
  175. Exhaust Noise
  176. Dr. Gasket cable operated cutout? Competition for electrics?
  177. ASP or SLP?
  178. Worth it to get rid of borla for gmmg?
  179. Firing order and plug location question.
  180. Oil Dipstick
  181. cop problems with duals???
  182. Worth switching out my stock SS lid for TSP lid?
  183. Unbent exhaust pipe?
  184. Quick AMW catch can question....
  185. Any way to eliminate cruise control for one wire TB?
  186. Ls6
  187. Jet hot long tube and Y pipe install. Banging Floor Boards
  188. is there a site or thread...
  189. How to clean out chambered muffler?
  190. Cat placement with LT's and DD SFC's
  191. scraping/rattling noise driving me nuts!!
  192. how can you tell if your check valves are bad?
  193. Got a Loudmouth that you now hate? I Killed the rasp!
  194. need advice with exhaust that exits out before the rear wheel
  195. what sensor is right next to spark plug on cyl 1
  196. Can a faulty o2 sensor cause one bank to run lean?
  197. March pully fit with a Roll Master w/o machining?
  198. Starter problem...pleas help ASAP!!!
  199. Which Exhaust?
  200. knock sensor short circuit?
  201. Help with posting small vids of exhaust
  202. Backpressure Question
  203. 98 maf same as 99 and up?
  204. Need help with injectors.
  205. Where's all my horsepower?
  206. Kook Headers are installed
  207. Anyone use an autometer oil pressure gauge
  208. Illegal or not?
  209. Coil and Spark Plug Relocation Wire Pics w/ Part #'s
  210. Alternator relocation info/pics?
  211. LS6 knock Sensor cover on an LS1, good idea?
  212. LSX intake manifold?
  213. Magnaflow
  214. Free ram air mod results???
  215. all you guys with longtubes do you get better or worse gas mileage?
  216. Anyone that has JetHot headers, please view.
  217. A/C Condensor went out, $1200 to fix?
  218. Need to pick up band clamps quick...
  219. How much CFM does a ZO6 85 mm MAF flow?
  220. Quick question about header and exhaust clearance.
  221. weird stumble at idle....ideas???
  222. Front O2's same as rears?
  223. Another, will this work ?
  224. good power gains from SLP Loudmouth?
  225. TSP Air Lid?
  226. TSP new catted Y-pipe
  227. How about this exhaust setup for a blower
  228. Any sponsors with Borla XR-1?
  229. How much rwhp from an intake swap?
  230. Y pipe vibration?? HELP
  231. Stainless Steel Header Thread
  232. Need help with odd problem on LS1...
  233. Removing SLP Long Tubes this weekend- Questions...
  234. Gasket Help! Need to fix my Exhaust Leaks!
  235. Need help with catalytic converter on GMC Yukon
  236. TD's with XR-1's ?
  237. Question about cats!??
  238. Which ported TB is best on ls6
  239. Kooks y-pipe install ?
  240. gutting stock cats
  241. How Much Horsepower?
  242. ASP Crank pulley
  243. Part # For GM O2 Sensor
  244. could somebody post a pic of bellows for me
  245. Got my PaceSetter Long Tubes... PICS inside
  246. Will Cats Fit with TD's?
  247. Need To Gain 50rwhp
  248. Removing y pipe back?
  249. Where can I get a Y-pipe that fits on Hooker long tubes?
  250. help with tach install
