PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 [200] 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. problems with qtp y-pipe
  2. GMMG fit on a borla I pipe??
  3. installed ported TB!!
  4. Water pump?
  5. Which True Dual Setup???
  6. Polish ceramic headers?
  7. Texas Speed Header Package
  8. PCV system. Do I need it now?
  9. AIR, does it affect the O2's?
  10. getting rid of EGR and AIR.. need plugs?
  11. Go fast save gas?
  12. just installed pacesetter LT header and texas pipe!
  13. SLP y-pipe gains on stock '98
  14. TSP Rep???
  15. what tensioner?
  16. Finished Installing Headers, a few notes
  17. Plug Wires
  18. LOng.. Got my car back :) baseline tune
  19. Antifreeze leak driving me nutz!!!!
  20. Air Conditioning compressor pulley bearings?
  21. Installing headers today
  22. what muffler???
  23. Grrrrrrrrrrrrrr...........
  24. electrical problem
  25. Bassani True Duals with Jethot LT's (56k beware)
  26. intake
  27. 90mm TB CFM ?
  28. pacesetters emissions or race style
  29. MAF worth it?
  30. 85 mm MAF...I know I know
  31. how to make this lid work??????
  32. Graduation Gift Woot - Powerstick questions
  33. Who makes 90mm Black & Clear Lids
  34. FAST Intake provisions?
  35. CA guys dumped or out the back?
  36. Looking to make my LS1 more responsive.
  37. fbody jack points?? where are they
  38. what tips should I get
  39. Ram air box
  40. Velocity Stack
  41. Please Help! Taking Off Oil filter in another car!
  42. help with Y-pipe selection
  43. headers install
  44. Underdrive Pulley?
  45. Ported TB? *Merged*
  46. What exhuast should I get
  47. I need some GM Part #s!!
  48. Header Gaskets, can i reuse?
  49. Post Pics Of True Dual Setups?
  50. Need help!!!Any1
  51. Help me find my dip stick tube hole!
  52. Fuse panel cover replacement?
  53. SSRA good or bad
  54. ls6 im vs fast 78
  55. How do you get the air intake temp. sensor out???
  56. Belts correct?
  57. 2 cutouts or ory
  58. Pro's and Con's of TD's
  59. LS2 intake + boost...
  60. Necessary To Remove Rear O2's w/LT's?
  61. SBC Headers
  62. whats this a/c line called
  63. Where to place my Cats???
  64. quick intake question.
  65. air intake question. need help quick
  66. Best Place To Get Poly Motor Mounts
  67. The Powerstick muffler... pics!
  68. How much am I losing not having a ported Fast 90/90
  69. ***Cats v.s. ORY w/Bullet***
  70. LS6 intake over stock LS1?
  71. Searched... no luck, question about plugging intake for EGR removal
  72. Lift Question with Pacesetter Install?
  73. Ls6 Engine Swap into 98 Camaro
  74. Baffled Breather
  75. Z06 converters??
  76. Broken alternator case
  77. Pacesetter LTs, cats possible?
  78. vaccum hose hookup for modulator valve
  79. 2 cut outs or 1???
  80. What is this fuel line?
  81. Horsepower gains with cat removal
  82. SLP Lid fitment?
  83. HELP!! in need of a intake but which one?
  84. ? about air flow in a stock hood
  85. Will 2.25" intlet on exhaust tips restrict the flow ?
  86. Poly engine mounts..
  87. Pacesetter Guys: DONT Use Those Gaskets!
  88. Finished my header install today...
  89. Since everyone does it, here they are
  90. Low Voltage
  91. Do I leave hp on the table with Flowtech LT's?
  92. Fast 90 -Vs- LS6 intake
  93. wanted:alternator info!
  94. Pacesetters: Ceramic or Painted?
  95. My GMMG and QTPs
  96. Installing LS6 intake ...reuse gaskets??
  97. Underdrive pullys
  98. 1999 suncoast hood...lets water on engine..problems??
  99. What plug wires are you using?
  100. Will changing lid add power
  101. Broke the oil pressure sending unit
  102. IAC Question
  103. o2 simms with catted ypipe
  104. LT1 vs. LS1 headers
  105. Just bought SLP lid, have a simple question.
  106. Y pipe
  107. Kooks LT question
  108. cone filter size?
  109. LM Bullet on stock exhaust
  110. Getting rid of interior exhaust noise???
  111. Should I switch out my macs for Kooks?
  112. Ordered these
  113. Go with true duels or keep my GMMG?
  114. Motor Mount Install?
  115. Exhaust Temperature question...
  116. a few part numbers
  117. Tony Mamo Ported FAST 90 Intake Results
  118. New Slp Dual Dual
  119. Am I missing anything?
  120. New Valvecover Question
  121. Qtp gaskets
  122. clear lid
  123. BBK 80mm or ported stock?
  124. possible intake leak
  125. e-cutout problem
  126. Help with rough idle
  127. SLP Dual/ Dual Exhaust
  128. So my car is still running like crap but...
  129. Header Bolts
  130. QTP headers owners step in please help .........
  131. Replacing exhaust system- one man job?
  132. Reducing Rasp or Loudness
  133. Exhaust sound after Header and cam install.
  134. 02 z28 throttle body coolant hose going-
  135. gains from ported TB
  136. NW - FAST TB bolt question
  137. Rasp?
  138. full boltons??
  139. x-pipe clearance
  140. What setup with 90/90
  141. Should I do it?
  142. porting MAF...
  143. MSD Plug Wires
  144. Msd Plug Wires
  145. LS6 inatake mani install on stock manifolds
  146. Is it possible to purchase a Corsa muffler anywhere?
  147. Firehawk exhaust and headers
  148. Flow Tech Headers-Starter Clearance
  149. Balancer question
  150. TPIS no longer requires cores on 90mm T.B.
  151. Air Hog or K&N?
  152. Restrictor in lieu of thermostat
  153. Thread Size Question
  154. FLP Exhust
  155. Modified Z06 intake
  156. Ram air set up
  157. Driveshaft rubbing on y-pipe
  158. Torque Specs
  159. dual cut outs off headers
  160. Header question: Which left is left?
  161. quirky throttle response and a hesitation
  162. What next?
  163. engine coolant?
  164. Hooker Cat-Back Broke?!?!
  165. is there a trick to coolant flush
  166. AC line hitting header on vette-Longtubes
  167. Pacesetters headers!!
  168. New maf problems?
  169. Exciter wire / voltage regulator wire tore off :(
  170. AC/Heater thing under the hood.
  171. ordering pacesetters
  172. Post pics of your true duals out the back
  173. TB bypass / H20 sending unit install
  174. steering linkage removal (for header install)
  175. TSP y pipes
  176. Is the Fast intake worth money?
  177. what exhaust to go with?
  178. bellows and stock air resonator...
  179. Help: I have a whitish residue?
  180. help???new plugs in car bogs down and dies
  181. Will resonator help me???
  182. Mufflex Cat Bye Pass
  183. what exhaust to go with?
  184. Lid Question
  185. Which Electric Cutouts?
  186. Where to get Carsound Cats
  187. AIR Check Valves Interchangable?
  188. Header install fun....
  189. Ebay Exhaust
  190. drivability issue after LS6 intake swap
  191. z06 maf
  192. Fast vs. LS6 Intake?
  193. Air Pump SES Light
  194. Skip shift plug-in not working all the time....
  195. HELP! Car runs like crap after header install!
  196. anybody use metal header collector gaskets
  197. Stock Open Y-pipe and Manifolds to Headers and Kooks... How much louder?
  198. 3.5" exhaust
  199. oil cooler
  200. QUICK>>Is this my air pump!!!
  201. Vette MAF-No screen??
  202. Started my Header install!!
  203. MAAAAJOR Y-pipe clearing issues
  204. Unhappy Hooker !!
  205. Intake Question
  206. what is this and how do i put it on correctly?
  207. Magnaflow tailpipes ugly
  208. Pacesetters
  209. LS2 TB install
  210. victor jr. users.... need pics of your fuel rails...and some info
  211. removed air pump, a/c, abs ?
  212. Anyone have a diagram on how to wire a F-body convertable switch for a cutout switch?
  213. Headers on Ebay
  214. who's running MSD coilpacks?
  215. FAST Intake Gains
  216. Need exhaust tips.. Help..
  217. which is it?
  218. True Duals HELP!
  219. Borla Exhaust
  220. Spark plug/WOT ping question
  221. Where is the pcv valve?
  222. intake manifolds
  223. get longtubes and ory ...need cats??
  224. How loud is the Loudmouth II?
  225. Help Oil Pressure Gage Buried
  226. How Much Oil Does the Catch Can Hold?
  227. cutout after each header
  228. tired of my hookers :)
  229. Adapting 90mm TB To MAF?
  230. SLP ram air thingy?
  231. Magnaflow's off of Kook's headers!!!!!!
  232. What brand O2 Sensors ...????
  233. Help me pick a catback please.
  234. Hooker/LTs/ORY - sound clips? anyone?
  235. which headers
  236. Car won't start!
  237. NO! Header Problem!
  238. Wifey is giving me 1G to redo my exhaust...
  239. crushed sidepipes
  240. Which HEADERS give you the most power for LS1 Camaros
  241. 2006 Katech catalog PDF
  242. FAST Intake
  243. temperature the same as before
  244. problem hooking up MSD 6AL and timing retard.
  245. How do you get the oil neck off the valve cover?
  246. Spiral Flow REVIEW!
  247. truck PCV
  248. Seafoam?
  249. FLP headers and true duals
  250. O2 sensors died
