View Full Version : Generation III External Engine
- Header/Cat Rattle
- Easy z06 maf quesions
- LS1 to LS6 Swap Problems HELP PLEASE!
- Solid Motor Mounts and Knock???
- LS6 manifold price drop?
- Headers
- Help me decide on a new muffler, ditching my magnaflow for something more aggressive.
- !air Mod
- Replacement O2's
- Why do headers make our engines run rich or
- SLP header warning >>>>
- Flowtech Y-Pipe
- Concerned about 90mm set up
- !EGR freeze plug question, help please
- everyone with jethot catted y pipe please help asap
- Jet hot headers!!!!!
- PPC Headers
- How much power should I expect from Stock TB/ to 80MM BBK?
- Jet hots!!!!!
- Buying jet hot headers!!!!!!!!!!
- ARP header stud installation
- getting rid of the LM
- CTS-V Headers almost done
- I'm broke ... what can I do?
- Anybody not running P/S? Need pics of belt routing
- p&p tb, question inside
- wierd vibration from 2k to redline, but goes away if car sits a few
- ASP Pullies before SFI Approved
- slp dual muffler fabed into loudmouth set up
- Rasp!!!!
- What gives with my A/C
- Y-Pipe/Motor Travel Limiter Kit NOW AVAILABLE
- did i get the right longtubes in the mail?
- smog legal exhaust?!?
- which o2 extensions work for ls1 longtubes? flat 4 pin or small square 4 pin?
- Throttle Bypass Test
- Large Diameter lids 85mm plus
- i love my car and hate my car
- Which longtubes for under $1,000 will give me the best performance?
- How about this true dual idea?
- Header Install Problem
- Dynatech racing cats
- magnaflow catback vs true duals
- Additional oil pressure gauge take-off point??
- HELP!!! Dipstick tube BROKE OFF IN ENGINE on a 96 Z28!!!
- macs VS LT's
- 18' bullet in place of 12'' bullet with LTs ORY?
- Goodbye Flowmaster Hello Hooker!!
- Broken hose: Help me find a replacement...
- New TSP transparent lid
- 90mm induction ideas
- aighty opinions time
- Remanufactured alternators
- WTF was pacesetter thinking with the Y pipe? (another thread)
- SLP LTs vs Mac mids on stock LS1
- Twin throttle body intake?
- Needed: GM part numbers for stock exhaust..
- Interesting Air Filter Test
- Finding leak in AC System..
- Any more news on the BBK SSI intake?
- y pipe ....true duals
- For your information, and entertainment
- MAC y-pipe bolts
- Going to port my TB later, any suggestions
- Car isnt running right.
- More true dual questions...
- Need to get someone to build Pacesetter Y that fits
- Do I need IAT?
- The great LS1 vs. LS6 block debate. I need 100% confirmation!
- o2 question
- Need wiring diagram help ASAP.
- Intake?
- Y-Pipe Banging...Heater Hose???
- changing out mufflers???
- Lights flickering??
- motor mount install nite mare...
- Phew...only half thrown belt...tensioner?
- Want a decent catback for a complete stock car
- Hooker shorty problem...O2 sensor really really close to frame...help?
- want new exhaust..but want to pass smog.
- Where is the A/C low pressure switch?
- Video of my car with LOUDMOUTH
- whats the purpose of cut outs?
- Plug to fill AIR Hose inlet for slp lid?
- Problem ... poly motor mount question ?
- QTP Headers for a C5 Corvette
- Exhaust help???Pacestter LT and ory with stock exhaust
- Exhaust quieting down?
- weird a/c issue
- 2.5" or 3" headers?
- Worthless or Not
- trying to troubleshoot cooling problem
- Home made polly mounts?
- Band clamps???
- lt header ?
- 3" TD's over the axle question
- Dismantling PCM connector HOWTO
- help pls..
- Mechanical or Electrical?
- Where to buy wire loom connectors
- gmmg?
- cfm
- sheet metal vs. lsx intake
- my ls1 motor?
- FlowTechs?
- Anyone port their stock MAF housing's?
- GMMG+LT's vs. GMMG+stock
- Anyway to force the fans to high speed when they are on ?
- Mechanical Water Temp. Guage
- Stock Inlet Hose size from MAF to TB?
- Prob after header install HEELP!
- Header / Power Problem
- Header's, which one?
- I need an overdrive pulley for the Alt
- Need Help
- LS6 Intake : Worth it for my ride ?
- Question on exhaust setup
- Thunder coil relocation?
- Quick disconnects for AC condenser?
- AIR! and EGR! questions?
- question:AMW catchcan
- Different duals.
- AC problem
- Where is the low coolant sensor on a 99?
- will the hooker ory fit pacesetters?
- TSP New Duel Exhaust !!! What Do U think ?
- What are these connectors?
- Loudmouth question
- Catback Pics
- Pulley questions
- PPC LTs and Catted Y are in...
- LSX install part question
- o2 sensor p/n differences
- poly motor mounts. Install this week.
- Header Problem!!!
- Stock gutted cats VS Slp high flow cats
- need some whisper lid dimensions
- just installed pacesetters lt's..........questions and comments
- Vararam (plastic TP "port" item) - comments?
- Cutout cap?
- PVC question
- problem putting cheapy plugs in my c5 for some testing?
- avoiding the pace setter yp ipe
- Spark plugs
- LS6 Intake Manifold, Which is best?
- SSRA vs. Competitors
- What type of gains from my new LS6intake manifold?
- need clip of the TSP true dual
- Best place to get O2 sensors?
- are they FLP or Dynotech LTs
- Do the electric cutouts leak still?
- Anyone lowered with dual cutouts in the Y?
- Going back to Y pipe set up
- rasp still pissing me off
- Looking for a new x/y/h-pipe
- three cutouts?
- headers sticky question....
- What size are the boltholes in the front of the passenger side head?
- Is a 90mm FAST inatake and tb overkill for this setup??
- Coolant Hose?
- GTO exhaust manifolds
- LT1 true duals? Magnaflow muffler....
- Oil and Spark Plug Change
- Duals with or without Cats
- ground clearance issues
- Are QTP's and Kook's LT's the same design?
- Myths about backpressure
- stock manifolds and cats
- Mufflers for Duals
- PaceSetter ORY vibration and banging remedied
- how loud will it be
- fan is squeeling
- Custom "FTRA"?
- Somebody point me in the right direction
- HELP. Vette won't start.
- Flowmaster muffler on a SLP dual/dual?
- ASP Pulley Removal
- Porting my TB ... any tips
- Pics of my custom dual 3" cutout install on my 99 C5 FRC.
- Radiator Plumbing
- Any tricks to reducing resonance? (vette)
- how many header bolts do i need for lt install? dealer says 16?
- When will there be a true dual system...
- exhaust question
- Oil drain bolt not budging!!
- need help
- How Much Hp Will 2.5" Td Support?
- Alternator R&R Question???
- Under-axle true duals problems
- how 2 hollow my borla??
- Help on exhaust!
- tsp dual x system installed on qtp headers
- What do I need to remove ASR?
- Dynomax Bullet or not?
- EGR + AIR Help
- size or diameter of harmonic balancer?
- off road y,2 quick questions...
- O2 sensors?
- GMMG and Corsa
- Header Advice Needed
- TSP's true duals tubing size
- 100$ for header install............
- Question about custom made Underdrive Pulley with pictures
- LSX Intake & TB - Surge/Idling Issues ?
- C5 Throttlebodies: 90mm
- Installed the Jet Hot LTs and ORY
- REtaRded Squeal
- Pacesetters and TSP TR set up
- March Underdrive Pulleys for my 2001 Z28
- Question about the Donaldson Lid
- Anyone replace muffler in stock catback?
- Oh Crap, I've Done It Now!!!!!!!!!!!!!
- Custom Fab True Duals
- Cheapest cats for SLP headers?
- After header/exhaust install.............
- Stay with the D/D
- Hooker ORY....my thoughts...
- StainlessWorks Longtube Headers, Feedback & Dyno Results
- WTF?!! Engine miss at idle I can see a spark between coil pak and valve cover
- Forum Director - Marker
- Jet-hot LT's and ORY installed, got a Q
- exhaust gas temp gauge help!
- Throttle Body Bypass Installation
- Texas Speed True Duals Install Pics--->
- Those with 3" TD and/or lowered, please come in
- Loudmouth guys?!?!
- What kind of gains from pace setter long tubs and catless y pipe?
- Will YPipe make it louder?
- lowering car debating going back to y pipe
- Cat Question
- What mufflers have been used with TSP True Dual set-up
- Air conditioning lost?
- estimated ponies & ft-lbs?
- Installed Magnaflow 4x9's on True Duals
- Fast 90mm is a POS
- Can I retain AC from 3.4 in LS1 conversion?
- headers,exhaust question?
- Question
- Anyone use "muffler tape"...???
- Secondary air injection problem, Need Help
- c5+dynamax headers=no et gain, info +timeslips within
- SSRA and Radiator Shrouds
- Installed Pacesetters, ORY sucks!
- Have a problem...Need help Quick (Exhaust)
- True Duals on a BMR X-Treme Duty Trq-Arm?
- Changing compressor tention pulley? Need picture!
- LT ground clearance
- Removing AC - now system frozen?
- PLEASE help,pcv problems
- which should i do?
