PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 [157] 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Changing Motor Mounts
  2. WTF!! Header primary blocking oil plug
  3. summit racing tb
  4. transporting my y-pipe/catback??
  5. cooling fan wiring
  6. thermostat bolts
  7. simple Y-pipe question
  8. engine miss MSD wires
  9. Magnaflow cat-back is on...
  10. Catch Can
  11. SLP Y pipe?
  12. is there a writeup on how to remove the fuel line from the manifold?
  13. Tired of listening to exhaust clips HELP!
  14. Could this be a Prolem on my intake??
  15. LTs/ORY with TSP rumbler catback?
  16. true duals sound clips inside..need opinions!
  17. need help with throttle body...
  18. PaceSetter Longtubes, I have some vibration in first,why?
  19. Will drilling a hole in the Throttle body affect performance on a stock cam?
  20. Oil pressure sending unit
  21. LS6 intake manifold?
  22. 99 TB On a 00 ?
  23. WS6 vs SS Air lid base, have you noticed?....
  24. LS1 to LS6 PCV conversion
  25. EDELBROCK 80mm THROTTLE BODY?
  26. Pacesetter Headers.....
  27. true dual sounds clips needed
  28. y pipe to fit between slp longtubes and hooker catback
  29. pcv breather question
  30. Ahhhh RASP!
  31. Cat Back Instalation Queston
  32. Which dipstick when putting in new LS6?
  33. Collant Cross-over Line
  34. SLP air lid for '02 trans am
  35. Media of my ARH headers/intake install
  36. Dyno numbers: longtubes + true duals
  37. TB Coolant Bypass vacuum/idling problem..
  38. how long before your cutout motor crap out?
  39. Where to buy block off place for MAP Sensor?
  40. Long tube install writeup?
  41. Playing w/ my exhaust setup.
  42. cut out were to weld in
  43. collector inserts?
  44. How much more does a stock pulley weigh than a powerbond pulley?
  45. Intake Poll
  46. I am not liking my Kooks LTs + GMMG catback
  47. Clogged cats? How to diagnose? lean>?
  48. LS6 question
  49. Anyone know what this is....Off of manifold
  50. K&N filter question.
  51. Pacsetter Y-pipe removal
  52. Mustang sound?
  53. sorry guys need some help
  54. fast 78 but what tb?????
  55. help with victor jr
  56. Question about Catylic Converters
  57. what muffler produces a muscle car sound?
  58. Show me your Custom air intakes!
  59. Porting stock manifolds? need guidance
  60. Fvcking slip fit exhaust
  61. Holley Intake better than others???
  62. Air System/ Header Install/ SES light Question
  63. dual or single
  64. Dam rusty AIR bolt broke off in the manifold.
  65. EGR tube cracked off.
  66. I'd buy that for a dollar!
  67. jet hot cats
  68. 90mm throttle body on a 78mm fast intake?
  69. need header help ASAP
  70. SLP Loudmouth Catback
  71. Help with ignition system!!!!
  72. Switched to longtubes...power loss???
  73. coil packs (trucks vs cars)
  74. SLP High Flow Cats
  75. slp lt headers
  76. Question about electric cutout
  77. is an X-pipe the cure?!
  78. Any JBA header users out there?
  79. jet hot
  80. TSP Rumbler to SLP dual/dual w/ ecutout
  81. American Racing Headers Just Ordered
  82. Track Results BBK SSI vs. Mamo Ported FAST
  83. Y-Pipe to fit between QTP's and Magnaflow?
  84. Vic Jr o-rings
  85. EGR and LS6 intake
  86. Maf?
  87. new header install
  88. Emissions passing performance
  89. Will Borla work on a Z with factory ground effects?
  90. stock exhaust and cutouts??
  91. exhaust question
  92. Which headers?
  93. Magnaflow catback muffler (muffler only)
  94. wondering about o2 sensors
  95. Time for an exhaust system...
  96. removing washer fluid tank?
  97. headder and ory swap!!
  98. Oil pressure gauge problems
  99. Meiziere electric waterpump or under drive pulley
  100. Need Help
  101. TSP Duals and Kooks?
  102. Flomaster Universal H or Custom H??
  103. Rear Oxygen Sensor
  104. Trying to find this tach...
  105. killing alternators
  106. Quick header install question!!!
  107. Changing my radiator...Coolant drain... what are the basic steps?
  108. How long have your motor mounts last??
  109. catch can
  110. Whats the difference?????????
  111. Anyone ever use this oil filter
  112. LS7 intake manifold on LS6 heads???
  113. intake manafold install?
  114. Ignition wire thread
  115. What clamps go where on SLP LM??
  116. I am ready
  117. about to dremel ribs on Ls6 for clearance, any1 have the pic?
  118. need help with FTRA
  119. Electric Cutout
  120. Ls6
  121. magnaflows louder than spiral flows?!!!
  122. The Big Question re:long tubes
  123. headers almost in!
  124. MAP sensor FAST intake
  125. PS Pump Bushing? What is this?
  126. Water pump swap...
  127. Removing LS1 intake question
  128. Thermal Fan Switch
  129. mac mids, catted y - muffler?
  130. Help with Kooks y-pipes!
  131. What Cat-Back Exhaust gives you the best power
  132. ls1/ls6 Intake Manifolds
  133. Did I get the right belt for my powerbond?
  134. Drive by wire conversion
  135. hooker cat back
  136. Search is down! What is a catch can?
  137. fuel rails??
  138. Header Bolts
  139. Overheating. HELP!
  140. Mike Norris Motorsports GenII PCV Catch Can
  141. pacesetters finally in!!
  142. Fast 90/90 or 73?
  143. Kooks Lt's and Ypipe install advice needed please!
  144. install price for true duals
  145. PS Pump/Reservoir Removal?
  146. Anyone have a Be Cool Radiator in their 4th Gen?
  147. PS Pump Removal?
  148. Exhaust Rattle
  149. Intake manifold options..
  150. Easy as "Pie" to get exhaust diameter
  151. Sound of GMMG
  152. Header Gasget
  153. Loosing Oil Pressure
  154. 6.0 harness, will it work with ls1?
  155. Borla Non-Adjustable
  156. Backprobing 02 sensors
  157. Anyone have experiance with mufflex? (the company)
  158. Full bolt-ons. Time for a tune?
  159. what gap
  160. just install headers
  161. If you could do it all over again...what Lid/induction system would you go with?
  162. qtp electric cutout issues and ?
  163. Lid install help... 02 TA
  164. Next mod for a bolt on car?
  165. mac headers and y pipe
  166. Another Day a new problem...
  167. *Sound Clip* TDs With Cam On Highway
  168. Best place to get O2 simulator?
  169. Plug recommendations?
  170. Heat wrap?
  171. f.a.s.t. throtle bore porting?
  172. custom exhaust
  173. Deletion of AIR and EGR System : Whats the effect on the car?
  174. pp intake.
  175. LS2 intake on a LS!????????
  176. GMMG or something else? Help me decide!
  177. where to get a gmmg?
  178. Do '98 and '02 Z28's have the exact same y-pipe?
  179. O2 sensor placement
  180. True Duals- driver side front hanger
  181. I'm an Idiot...Help needed
  182. Where can i get one???
  183. Little Projects
  184. Air Intake Modification---*POLL*---
  185. Difference between buying catback and going to a shop?
  186. Ferrari vs LS1 sound
  187. wiring problem...please help ASAP
  188. summit tb
  189. Corsa Tips on Magnaflow's new catback???
  190. Intake Modification---*POLL*---
  191. Canton Oil Pan
  192. Intake Modification
  193. Intake Modification
  194. X-pipe w/cats possible? Need pics
  195. hooker or pacesetter lt fitment ?
  196. Best Heads
  197. problem misfire
  198. Exhaust Shop Near Farmington MI
  199. ceramic coat or not?
  200. 02 sensor low voltage codes...help please
  201. custom y-pipe....help!
  202. TSP pacesetter header and y-pipe combo
  203. Help me out! Need to know if I will have fitment issues
  204. Flowmaster + Loudmouth= Saweet!!!
  205. Multiple random misfire. A little help please?
  206. louder street legal exhaust
  207. should i replace my Knock Sensors?
  208. Hooker or Jet hot(pacesetter) Lts
  209. What Plugs To Get???
  210. injectors
  211. well...the cutout is welded in!
  212. bosch plugs
  213. quick question
  214. Which wires do you guys prefer?
  215. Custom...
  216. Fake
  217. BBRC Sheetmetal Vs. Vic Jr Efi Vs ??
  218. Anybody ever use the Professional Products Mani and TB??
  219. SLP Long tube install ???
  220. custom plug wires?
  221. Porting LS1/6 "based" cast aluminum intakes...
  222. qtp electric cutout issues need help asap
  223. Easiest underdrive pulley to take off?
  224. Header Dilemma...help!!!
  225. How much louder with cam
  226. What is this part on a camaro ???
  227. Pacesetter Question
  228. Jet Hot Cats?
  229. victor jr, elbow pics please
  230. Lingenfelter Intake Gasket Question!!!!
  231. Powerbond under drive pulley question?
  232. What else is needed to support 90/90?
  233. Anyone know what this is???
  234. how to get open headers?
  235. How do you wire up A/F gauge with corvette 02's?
  236. ran into a rather odd PCV issue.. take a look
  237. Size of Magnaflow Quad tips
  238. Sound/Flow of Magnaflow Catback
  239. Your thoughts on my Mod list
  240. what work needed to be done for l92 heads?
  241. no-gap spark plugs
  242. aftermarket air lid fit?
  243. oil-less filter
  244. TB and IDLE
  245. Corsa with LT's and ory
  246. Removing the Cats
  247. Y-Pipe questions?
  248. Exhaust quote....
  249. PLEASE help me get this SOUND!
  250. Im back...proof of ported TB gains.
