View Full Version : Generation III External Engine
- Merge pics?
- must read! stock bolts with qtp headers nightmare
- Painting exhaust?
- Squeeking????
- Will corvette exhaust manifolds fit on f body
- Can some bolt-ons offset rich A/F ratio?
- oil pressure problem or so i think
- Used LS6 vs. Z06 intake
- FRA -- seal the front of the box?
- Need a 2 1/16 gauge shift light for pod
- Lane's True Duals?
- catbacks
- Fuel Line Quick Disconnect Help Needed
- those who owned DUALS and GMMG
- CAM and 3" Exhaust?
- Block Off Plate On Holley Intake?
- I have a whistle sound coming from the ypipe area, its loud!
- anyone running a carburated ls1? need tips
- My Misfiring Adventures
- air shroud removal
- Muffler straight off y-pipe?
- my car caught on fire HELP HELP
- How To Eliminate P/s Pump On A 98 Up Z-28
- y pipe and o2 sensors
- can I home port my stock 01 exhaust manifolds
- Need pics of stock y-pipe
- Electric Cut out?
- Gmmg
- Electronic cutouts
- SLP Radiator? Need Opinions
- Wil LS2 coils, bracket wiring harness bolt up to LS1?
- Which true dual setup will be easiest to make work?
- First Drive Since GMMG Install
- 2000 SS, prokit... any problems with under axle duals?
- come in here to cry for me
- Any else remove rear heat shields??
- Fast Toys Ram Air and SLP Hood
- Pacesetters or Hooker
- Magnaflow leak :confused:
- my ported TB
- Supermaxx cat ground clearance?
- TB Bolt stuck in intake
- Quiet Mufflers - not v8 sound?
- (QTP) "supposed" broken catt turns out to be....
- QTP catted y ground clearance comparison??
- DMH Cutouts...
- Oil Pressure sending unit where???
- Cold Air / Ram Air
- Magnaflow and 3" I-Pipe
- Cammin BeaSSt TB.........AWESOME! (pics)
- corsa catback single pipe
- Truck 85mm Tb
- Y pipe clearance w/ lowered car
- LS1 Gurus, i need your help!
- Anyone Delt With Speed Engineering?????
- Loud Mouth II bullet muffler Install
- Power steering line
- has anyone done a complete engine-tranny install in one shot
- Spohn Torque Arm & Tru Dual exhaust
- Is it ok to drive without O2 sims for a while?
- need part number stock manifold studs
- Converting to 02 exhaust
- sweet thunder mufflers
- Engine dying after header install
- Header Install Question! FLP/Dynatech
- custom x-pipe question
- High Perf Alternator + ASP U/D Pulley???
- Help some ticking sound from around fuel rails
- quieter and more hp?
- HELP! Header won't clear steering shaft....
- Blowby? oil drips from plug.
- Is this a stock lid? (Pic inside)
- need exhaust selection help
- A week after ASP installl
- check engine light after header install
- Duals?
- Maximizing cam only setup (T-ReX), wanting 2 upgrade intake system, have some ?s.
- H Pipe on LS1
- which starter?
- Opinions On My Setup Please.
- how is the flowmaster american thunder?
- y pipe noise
- What bellows are you using with FAST 90mm?
- SLP Fan Switch or 160 thermostat???
- Broke my steering shaft...where can I get one?
- Help
- LT's to ory to Flowmaster 80 series?
- Cold air set up...
- mufflex y-pipe bump stop hangar
- where to buy BG ram air kit??
- Engine overheating
- mac exhaust
- mac exhaust
- Flowmaster muffler
- which first
- Bad Cat?
- What R The Best Long Tubes Out There?
- looks like a snapped a header bolt of in the head
- Hi-Flow cats ?
- Egr Issues
- Please Help!! Exhaust Confusion?
- Water Pump leaking
- does arp make bolts for alt, starter etc?
- Too Loud, need advice.
- Stock everything with cutout???
- Turbonator
- Are These Mods Worth Doing?
- Just got td's and drone and a tinny hollow sound
- installed new motor and problems...
- headers banging.....
- Changed spark plugs now exhaust leak?
- Thunders coil pack relocation kit?
- quietest muffler
- Weird Problem, TB Related?
- HHEELLPP!!!!!!(Coil Pack help)
- Exhaust Confusion?
- please help F.A.S.T. LSX intake
- CME set up vs straight tips
- SLP fan switch
- Ported/Polished Throttlebody
- Need help with shift light.
- pics of duals and engine bay
- Broken Cats????Help
- muffler and tip question
- Coill pack main unplugged ... starts/runs fine !!!!
- Car overheated... thermostat? water pump?
- engine dies on right hand turns
- cleaning intake
- QTP's and TSP True Duals
- Opinions - MTI Throttle Body?
- Y-Pipe Trouble
- power steering pulley replacement
- Air Filter
- SLP Pulley work with double timing chain?
- LS6 Intake question
- ASP Underdrive Pulley question
- Dual Cutouts.
- Which chambered mufflers are used with GmMG catback
- Installed Dynatech Supermaxx header system.
- 1 3/4'' to 1 7/8'' stepped kooks with just cam - Will this hurt performance?
- loudmouth is now obnoxious mouth. help!
- pacesetters+loudmouth=headache!!
- Shorty headers
- Hooker headers installed!!
- Helppppp
- Question about the LS6 intake
- which headers & ory pipe to purchase
- jet hot Vs Hooker.... Longtubes...
- How much more power?
- True Duals
- Where to get Powerbond pulley / customs prob.
- hooker shorties
- What is a pressure wave termination box?
- will 3 inch cut out fit the hooker ory?
- Center Mount Exhaust help???
- TD people in here
- Bo White's address
- TB "velocity stack"
- Throttle Body Porting 101
- Got the Loud Mouth II today
- Getting Exhaust tomorrow<quick question>?
- Had to get my cutout redone
- Better Radiator
- Help...Engine is revving out of control :(
- New hissing sound
- went to a local exhaust shop today...
- 90 mm motor control TB for Z06
- Fast 90mm Throttle body fix?
- what are all of the 1 7/8 headers out there?
- tsp duals going in friday!!
- Feedback on QTEC Dual Electric Cutout Y-pipe.
- Throttle body mod
- Lid won't stay SHUT!!!
- High fan switch mod
- 2 Questions: Exhaust and Hood Scoop
- slp induction
- what are cutouts?
- Header instructions
- exhaust manifold bolts torque-to-yield?
- Electric Cut Out
- Belts Won't Stop Squeeling
- MAF's and TB...worth it?
- Wierd exhaust leak i can't find
- LS6 intake part number question.
- True Dual Vrs Cat-Back...Powerloss?
- dont know what to do next?
- Anyone else have SLP headers
- Header Install
- Help With Header Choice Please.
- Can I do this to my headers???
- TSP Question!
- strange nois
- people with mti clear lid please help
- QTP HEADERS/Y-PIPE SALE!!! Quick installing question!
- Help me plz
- ASP Underdrive Pulley?
- need overdrive alt. pulley...where to buy????
- bolt on help
- looking for more clips with the borla xr1
- Just order QTP LT header & TSP true dual exhaust
- 10% or 25% pulley?
- Water Pump Watchdog
- To dump after the Y-pipe?
- Header bolts
- Loudmouth catless
- Warlock muffler for a dual exhaust?
- most compact water pump?
- weird idle
- Those with 90mm LSX and stock MAF, what bellows are you using that fits good?
- QTP/Flowtech cutout question
- Bosch Platinum 4? Where are they, and what happened to them?
- what style of header gaskets to use?
- Headers Shopping list?
- Ceramic coated or stainless steel headers? Which is better??
- Loudmouth or loudmouth 2
- question on Pacesetter LT and slip fit collectors
- vaccum gauge help
- Is this sensor right?
- GMMG to Hooker?
- stealth mods????
- will ls6 exhaust manifolds fit on a 2002 trans am ws6
- Magnaflow duals
- QTP y pipe?
- leak behind intake--cam sensor leak?? PICTURES
- HELP....I'm stumped??
- duals with X pipe..or just stright pipe duals with no x??
- True dual dynomax
- Walk through
- How do you know if your 02's are shot?
- Speed Inc. Installed My New Kook's LTs
- dual cut-outs in the I?
- Need some help with custom fitting my exhaust
- Engine stalls after WOT
- How to clean the MAF sensor?
- New Bbk Ls6 Intake
- keep blowing exhaust gaskets?
- Throttle body sticking closed
- Pacesteer and TSP help....
- Pacesetter Exhaust help
- headers
- Problem with Taylor wires
- confused about headers
- Weiand intake or LS6 intake?
- Autometer Tachometer Installation ?
- EGR Blockoff
- SES light dissappeared
- stock spark plugs
- Exhaust and computer
- I need a good dual exhaust!
- LS6 intake to LSX 90mm
