PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. will running without tune hurt?
  2. cant find a pcv on my camaro
  3. Pacesetter Longtubes & Y with stock catback?
  4. Replacing Magnaflow 3.5" dual tips
  5. Pvc tube pinched?
  6. flowmaster merge question
  7. Do stock pullies go bad?
  8. Kooks vs. ARH vs LPP
  9. Exhaust Pics
  10. Relocating the MAF - I have a question
  11. lq4 block question
  12. Damn Exhaust! anyone help me out? duals?
  13. Mmm... every guy loves a nice, hot, wet...
  14. Dynomax Bullet or Moroso spiral flow which is better to quiet exhaust?
  15. Why would these be in my LS1?
  16. Y pipe question
  17. Running LS1 on carb setup?
  18. A couple intake and TB questions?
  19. lm7 5.3 questions
  20. Easiest way to pull engine?
  21. Broken Map Clip
  22. Torquer V2 + L92 heads ??
  23. header, ory, intake and flow pac question
  24. Question on Vic Jr with a accufab 4150
  25. BBK intake..
  26. SLP Lids differences?
  27. Any way to get D585 coils out of their holder
  28. coolant sending unit. Can I do this, or is it a problem?
  29. who makes an ORY with a flowmaster merge?
  30. Starting Problem
  31. Timing cover..
  32. Rough Vibration in Car
  33. time to buy TB but what size ?
  34. Draining Water out of my Catch Can,Please Help!!!
  35. Rough Idle Issue
  36. header question
  37. seems like a hell of a deal Full LS1
  38. Lookin for a stock replacement muffler and new tips
  39. lets talk long tubes
  40. calculate my y pipe diameter
  41. starting problem
  42. Knock Sensors
  43. Exhaust Question
  44. 43 WHP gain with shorties, why such a bad rap ?
  45. Intake
  46. Save $110 on Nasty Performance Billet Valve covers
  47. lt1 to ls1 swap
  48. Cutouts worth it?
  49. doing the poly motor mount upgrade which way do they bolt back on?..
  50. anyone know of good site with exhaust fittings?
  51. Car missing erratically. Need some advice.
  52. Just Installed BBK Intake
  53. Has anyone ever tried a borlamouth like this?
  54. Stock muffler size
  55. Victor vs GM Spider?
  56. GMMG exhaust?
  57. Coolant Steam Pipes
  58. Motor mount install info..
  59. ECM issue? I need advice
  60. Alternator Relocation Question
  61. Need help deciding what to do.
  62. Need 1 single MSD spark plug wire
  63. Cutout question...
  64. moblie 1 oil filter
  65. 2.5'' dual setup, better then 3''y with 2.5'' tail pipes
  66. Power Stearing Pump
  67. Ls-6 egr fitment
  68. Are there any bullets that give that high pitched corsa/exotic sound?
  69. What's going on here??
  70. What size hump hose for stock TB and MAF?
  71. Which two wires to check TPS voltage?
  72. advice on where to get stock TB and LS6 ported??
  73. ls6 intake?
  74. Fast 90/90 Stock MAF question
  75. what borla exhaust is louder?
  76. edelbrocks new batch pro-flo intake
  77. Front O2 sensors
  78. 5.3 LS1 Engine questions
  79. truck coil/truck TB fitment issues on Fbody setup, need some input
  80. Tb porting
  81. slp dual/dual with a cam
  82. Need help asap please o2 sensors
  83. help me with my performance shopping list
  84. LT Headers
  85. Squeeky Bearing On My F-Body P.S. Pump-Can It Be Rebuilt?
  86. Meziere race pump and all accessories
  87. help! need info
  88. Weiand intake barb fittings
  89. Single Chamber muffler question
  90. 5.3 heads on 383?
  91. How Do you like my PCV system
  92. a couple of ?s
  93. PCV System from magazine build? Is it OK?
  94. Haven't heard of this yet FAST 102rt
  95. Adapter or way to mate up a P&P LS1 TB to a 96MM Typhoon Intake?
  96. Getting Pissed off!!!!
  97. Will 98 coil packs fit 2000 up brackets
  98. Valve Covers
  99. my duals for your y pipe
  100. TSP Rumbler vs. GMMG clones : opinions?
  101. oil pan help...
  102. Will I need to upgrade fuel injectors??
  103. Narrowed it to 2 TSP cams, don't know which?
  104. Pacesetter TFX catback
  105. Header size...?
  106. Intake manifold decisions.
  107. Starter cover to view the flywheel?
  108. Ls1 inTake and TB
  109. Fast Toys 85mm lid gasket
  110. Need some help on intake and valley cover bolt sizes
  111. Aluminum intake vs. ls6 intake
  112. LS2/3 4 Bolt DBW with LQ4 Help
  113. Oil pressure problem
  114. Coolant Expansion tank for LS1, whats needed?
  115. help on a set of 241 heads
  116. what hp output should i get with this?
  117. LS6 Intake Size?
  118. What intakes will work with 317 heads
  119. has anyone painted their TB and/or MAF red?
  120. Turn the key and all i get is a HORN???
  121. True duals on kooks 1 7/8 headers
  122. 02 z28 swapping in a 03 denali 6.0
  123. hello i have an idea...true duals
  124. ls1 with ls2 typhoon intake ?
  125. Header install help!
  126. Oil pan
  127. Starter tech
  128. Bad pulley squeal! How to figure out which one it is?
  129. Yet another ATI damper question
  130. porting LS2 question
  131. GMMG Guys I need help
  132. balancer bolt
  133. ProCharger install with elec water pump
  134. Plugging the dipstick hole??
  135. Overheating???????
  136. O2 sensor question, PCM section useless, sorry.
  137. Ls6 intake
  138. cut out size?
  139. Performance Starters???
  140. magnaflow metalic cat question
  141. knock sensor ls1-ls2
  142. Mufflex Spintech Question
  143. My exhaust setup (possibly)..comments / criticism
  144. What catch can is everyone using?
  145. sparkplugs...whats everyone using?
  146. LQ4/9 Questions & Front Accessories
  147. PS Pump Reservoir Solution?
  148. No spark while cranking!!!
  149. Exhaust info again....
  150. Just bought a SS with a TSP 408 - what headers?
  151. Nascar power steering cooler?
  152. my power plan any advice?
  153. oil guage and temp guages not working!!! help
  154. 1 chambers or loudmouth
  155. mac ory pipe. cat size?
  156. Typhoon intake?
  157. If you have a a nice deep tone TD set up....come on in.
  158. newb
  159. shorties
  160. Missing on number 1?
  161. power steering pulley
  162. start up problem
  163. Possible Gains from tighter Spark Plug Gap?
  164. Engine Covers
  165. Rattling noise?
  166. 2001 LS1 Stumbles and dies. Ideas?
  167. Car wont start and then it will
  168. TSP Borla Rumbler
  169. Brand New Forged 347 LS1 H/C Needs a Tune?
  170. LQ4 plug n play?
  171. Can I use the 5.3 chevy truck motor in my ls1 car?
  172. quick ? about a rad support?
  173. Alternator bad, or something else?
  174. Bullet Muffler Questions
  175. Ported LS2+NW 90mm tb vs Ported tb+LS6 on 6.0?
  176. How to install LS6 Intake Manifold Video
  177. leak
  178. Dual Cut outs on Y Pipe
  179. Pretty sure i just broke my oil pressure sending unit
  180. 4" cai
  181. Straight thermostat neck?
  182. power steering leak
  183. poly mounts
  184. 2000 camaro ss stock ehaust
  185. Reference source for Sensor locations, functions, connectors, etc?
  186. Need Exhaust Help !! for more Power
  187. What gap and plugs for 16psi max?
  188. New Intake/Cam Debate
  189. heads , exhaust, turbo
  190. what brand of spark plugs???
  191. Strange oil leak...
  192. New Firebird Hood Design
  193. 92 mm maf?
  194. 00 SLP MAF on 04 goat
  195. Can I use a LQ4 Engine in my LS1 car?
  196. Exhaust set up ??
  197. Link to free mods
  198. electrical problems
  199. Vacum System
  200. OPSU question
  201. Differences between Jet Hot and Hooker headers?
  202. texas speed ory (new design)?
  203. Solid or prothane motor mounts?
  204. Alarm/Power
  205. Alarm/Power
  206. Vic Jr. Picture Thread..
  207. Electrical problem after tranny install.
  208. Dayco = Garbage
  209. Electrical short after tranny install.
  210. Who can build true duals over the axle in Kansas, Missouri, Arkansas, or Oklahoma
  211. Anybody tried this aftermarket LS1/LS6 waterpump?
  212. new here and looking for some advice
  213. New Motor and Boost Idea need some feedback
  214. Pictures of my wrapped headers
  215. lifting complete engine - how?
  216. Brand new erl performance 102mm throttle body
  217. all catch cans the same?
  218. HELP car won't idle below 2500 rpm!
  219. Looking for LS1 header bolts or studs?
  220. Wideband gauge question
  221. Will GM Competition valve covers work?
  222. Lowered, LTs, and TDs. any pics?
  223. Welding up Collector Leak
  224. All done with weiand swap
  225. Trying to wire a 2 speed fan to stock wiring? Trying to understand how stock works?
  226. spark plug help, picture inside
  227. Problems at start up HELP
  228. Best *CHEAP* intake for boost?
  229. oil pressure sending unit torque spec?
  230. Engine Build
  231. metal intake help
  232. PCV system heat
  233. Returnless Fuel Rail Help?
  234. Need a Dipstick Johnny!!!
  235. Plastic fkex line delete
  236. intake manifold on a 00 ls1
  237. What Y pipe is this?
  238. Gm vs. edelbrock carb intake
  239. Roller Rockers?
  240. LS1 ECM reflash
  241. fabricated valve covers-AN fittings?
  242. Anyone have True Duals Videos???
  243. plug readers chime in
  244. Valley plate
  245. Where does this hose go!?
  246. quick question.. what size are the radaitor hoses?
  247. true duals
  248. coolant level sensor
  249. Going to a 100 mm MAF from a 85 mm MAF on a stroker?
  250. LS1 To LS6 intake Swap Problem
