- what can i hope for geting good exhaust?
- Flowmaster collector on hooker y-pipe
- anyone know the part number to the non egr ls6 intake
- HELP! ati crank pulleys out of stock/ just buy asp?
- Intake Chiller - A/C System Conversion
- get a lid or K&N fipk open pod?
- et's??
- et's???
- SLP LTs and cut-out questions????
- New Mods Installed / Questions
- Water Pump... how hard to get off?
- Will the LS6 intake help me with my cam?
- Header gasket question
- Corsa exhaust top speed question
- which headers to buy?? help!!!
- So what does my "ultimate LS1 exhaust system" sound like? Inside for .wav Ecstasy
- Relocating ignition coils
- Wow, Mac w/ no cats, Flowmaster, and cutout. It roars!
- Just wanted to share pics of my new polished Borla, I think you will like it>>>
- For those wanting to here the X-Pipe setup - Video
- ****True Dual Exhaust Roll Call!!!!****
- Header Advice???
- Which Exhaust Gaskets for Headers?
- New Here, Need Advise
- asp crank pulley+no power steering pump/ WHAT belt size?
- HTF to remove power steering pump?
- car feels slower after flp's and corsa
- Got my in line fuel pump installed!
- Tired of TTS system... looking to Grots + ORY
- MOBIL 1 COMPARED TO AMSOIL
- Hooker long tubes on an '01
- Another Happy Dynomouth owner
- Please evaluate this torque strap design...pic's inside
- After market exhaust...
- what gains should i expect?
- plug question
- need p# for 98 knock sensor!!
- Shifters??? what kind?
- water pump bad?
- Engine is back in.....and true duals are on.... Damn they rock!!!!!!
- flp headers and corsa install
- Anybody burn plug boots with headers?
- Dual exhaust is the $hit!!! My opinions for a muffler choice
- where to buy and have installed
- Just installed bellow and maf ends
- anybody have a slp Rad
- Dry-cell DynaBat question
- serpentine belt tensioners
- Special tools needed for k-memeber a-arm install?
- X-Pipe Installed...questions...
- ORP Blues
- Suncoastcreations ram air box, any good?
- Best place to get 3.5" slash tips
- Throttle Body Bump Stop Mod ???
- Header install on a shop lift...help!
- are swaping out 01 injectors worth it for me?
- A better WS6 Ram Air
- y pipe and cutout questions??
- New combo please help
- Exhausting my options... true dual or Mufflex 4"?
- Gauge Install
- dynomax bullet
- What should I take off to not void my warranty
- Who sells Grotyohann long tube headers???
- Purpose of AIR pump?
- Catback HP gains????
- Need help figuring out fuel problem
- max rwhp for lucas #42lbers
- Corsa vs. Loudmouth
- Am I gonna need O2 extensions with my MAC's??
- What is this tube??
- What lbs injectors do i have
- Car has starting problems...please help!
- Is the 2002 LS1 PCV valve location different?
- Ram Air with non Ram air hood
- Question on headers?
- HP Gain Question??
- Does your Mac ORP hang lower than the rest of the car?
- Installing spark plugs..& oil on threads?
- Want to change CME muffler
- Headers for convertible
- Water Temp Question
- WANT TO ADD HP
- broken belt on asp pulley?
- How much does LS1's oil problem(PCV valve) change timing or ping and KR?
- 98 wiring schematic for heater/fan control panel
- pictures of peoples exhaust
- flowmaster question
- CAN SOMEONE PLEASE HELP ME!!!!
- Anyone know the ID or OD of the MAC Off-Road Y-Pipe?
- pipes in place of cats
- short belt question
- what causes a low MAF failure???
- Best place to buy injectors?
- Which bullet muffler? Experience please.
- THE DRAGON!!!!
- I need dyno proof on which is the best muffler/catback..
- Dynatech headers?
- asp pulleys
- car running chitty after converter/headers install
- What's it gonna take?
- Water Baffles
- What gains with a short belt?
- Oil leak and Clutch problem
- hooker lt's, y-pipe and catback?
- Header Opinions
- !FRA
- bullet muffler
- cheapest place for in stock ASP pulleys??
- Can someone give me some instructions on removing AC....
- Paging Black Sunshine, RE: true duals over the axle
- O2 Sims
- FLP header install help.
- Just finished Hooker LT install
- slp 85m
- How much does a ls6 intake flow?
- Engine torque straps?
- What is the best Y-Pipe to use with an all Hooker set up(LT's and Cat back) ??
- Vortech Supercharger installation
- Cat Back Exhaust
- SLP Fan Switch - always on?
- what milage do i change oem air filter? which aftermarket is best?
- need some header advise
- Borla or Corsa?
- Oil filter clearence problem
- I need help with muffler selection..
- Where is the following O2 Sensor: Bank 1 Sensor2?
- Factory air cleaner assy. ??
- My "Ultimate LS1 Perf Headers" Part II: Results = unbelievable 53HP/49TQ gains!!!
- K&N FIPK on 99 SS?
- LS6 valley cover + vertical PCV =
- Can you replace the PCV valve and line with 2 breather filters?
- A quick PCV question
- Can you install a cam without future problems?
- Looking for X-pipe sound clips
- Loud Mouth vs. Borla in Performance
- Any news on TTS revising their cats?
- Loudmouth w/ gutted cats or cut out w/ gutted cats?
- dynoed over 400+ RWH through Corsa
- Opinions/Recommendations for a Drive Shaft Safety Loop....
- What mods now?
- HOLY CRAP! FRA turned my holley filter white in the rain!!!
- Stall Converters
- LS6 intake on my set-up?
- Belt Tensioner cause Knock Retard?
- Worth going from High Flow Cats to ORP
- how to paint ls6 intake?
- Driveshaft Safety Loop
- slp headers questions
- installed FLP's - now SES light
- Pulley removal Q's........
- How can you tell the difference between 98-00 and 01-02 MAC headers
- Grotyohanns and custom Y, install. Worth .3
- Polyurethane Motor mounts installed...and pictures
- Pics of my dynatech 3" Ypipe
- borla wide open or sell and get 3" bullets w/ turndowns?
- Whipser Lid
- Anyone running longtubes with stock catback??
- Check out my new ram air setup
- Fuel pumps?
- borla and header sound question
- Finally tested my crankcase evac system
- Help!! Gauge lighting???
- installed my inline fuel pump
- questions about intank versus inline fuel pumps
- Help...can't get shifter off!!
- UNDERDRIVE PULLIES
- MAC HEADERS INSTALL ?
- Where do I install the in line fuel pump?
- WHERE CAN I GET HOLLEY POWER SHOOT AIR FILTER?
- Anyone have any gains on "porting the primaries" of macs?
- ASP Crank Pully install saga....not!
- How To Make Corsa Louder, ORP?
- Hooker LT's;Removing the AIR pump
- SLP MAF Sensor
- Corsa exhaust
- RASP IS GOOD!!!!!
- My Throttle Body Bypass is Making Wierd Noises?!?!?
- SLP fan switch
- where to hook up water temp sender?
- Inline Fuel Pump ?
- Come in here to hear the raspiness of the GMMG with no cats!
- Drain from Airconditioning Evaporator Coil
- Need wiring help for inline fuel pump
- Will dual cutouts hurt performance?
- ARP Thread Sealer vs. Assembly Lube
- Who is interested in a Hooker longtube GP???
- Noise in engine bay!!!
- Any sound slips for B&B Tri-Flo?
- Hooker LT , Hooker OFP and Mufflex 4"?
- replacing cats with straight pipes
- All kinds of problems... please advise!
- true dual or catback w/cutout
- LS6 Intake???
- Big news..New intake manifold in the works..
- How many boxes do TTS headers come in?
- BMR Airbox
- Suggestions/Help needed on Problem!
- MAF ends on an A4
- EGR/Manifold bolt size?
- Best exhaust setup front to rear?
- Who has UNCOATED Hooker LT's
- k&n FIPK vs Fast toys ram air
- S.O.S. !!!! PCV problems inside!! please help ASAP
- FTRA question?
- Post your true dual exhaust setup here!
- Octane Booster
- Who all is running the new Racetronix PnP FP?
- Anyone have sound clips of SLP LT, cats, and ANY cat-back system?
- Nine Balls Knock Out Box ROCKS!!!!!
- very Lean air/fuel question
- EXTENDED OIL FILTERS?
- Fasttoys high flow air lid
- Next mod? Ported vs. Descreened MAF
- mufflex
- Pulley install
- Which Air lid is easiest to install uninstall?
- Battery dead 2 times now......what are my choices now???
- maf
- How the heck do you remove the power steering pump ?
- cats hard to install?
- Mac Headers with o/p OR 4.10's with Flomaster Exhaust?
- Grotyohann users, where can I get 2 bolt flanges?
- P1153 HO2S Insufficient Switching Bank 2 Sensor 1
- Where to buy a hooker cat back?
- How i can ported tb ???
- 3.5" Y-Pipe and 3" Muffler
- Answer this!
- FLP vs. Dynatech
- Corsa Visit / Replacement Results...
- Same ol' header questions?
- MAC headers?
- How can you identify a ls6 intake from a ls1 intake.
- True Dual setup's????
- a/c?
- Now Working!: Sound Clips: FLP Headers with GMMG/ Open Headers
- Does anyone use fasttoys ram air?
- hooker headers on stock cats and y-pipe?
- Why the aluminum pipe?
- new engine
- problem after header install
- why is coolat pouring from the driver side head???
- FLP's and Open Headers
- Cut out location
- so why is it some gain and some lose power with true duals?
- Does removing the air filter give you any mph at the track?
- Guys with line locks in here please!!
- FLP header banging - not normal...
- Loudmouth w/ no cats?
