View Full Version : Generation III External Engine
- SLP lid issue
- F-body Oil pan, pick up tube, windage tray
- Stainless cutout/welding question
- Aftermarket Belts
- ls1 hedas+ cam ?
- Dumped @ header no X or H, just mufflers???
- Intake/Valley Cover Swap Part Numbers
- just added a Borla catback
- Help Identifying heads and parts.
- Car bat. Randomly goes dead??
- True dual sugestions for my new motor ?
- Screwed up UMI 92mm
- Is this bend restrictive or is it angled where it won't effect anything
- True duals sound clip
- FTP 98 fits like crap. New idea.
- Opinion On These Headers
- Oily breather problem
- Any one have interest in steel oil pan rails so you could build a pan
- Locking Gas Caps
- Losing power at 2500 RPM
- y pipe question.. Hooker headers
- MAP Sensor/Vacuum Fitting
- best intake to run with with a trex cam
- Ported Fast 92 with pics
- LS1 intake to LS6 intake question
- Stock fuel limitations
- How to buy a GMMG catback
- HELP PLEASE trying to install a Monster tech
- dynomax bullet
- DMH Problems, help?
- TA is back baby full throttle!!!!
- Header bolt size?
- Valley Cover swap on LQ9
- air/egr lines?
- MSD Coil Question
- eBay smooth bellows
- Alternator trouble
- any advice about replacing header gasket?
- 3/16" Throttle Body Blade hole too big?
- pics of ur magnaflow catback
- Throttle body sticks sometimes
- Swapping Slow-master to "?" help needed.
- What was your LT ORY setup first impression
- Chunky Coolant?
- What cam to get???
- upset about header install
- LS6 intake...
- need a little help..
- Headers Installed HELP!!
- Im still looking for a fast 92
- Mass Air Flow Question, Please help.
- Hooker Stainless Headers
- Lpp headers. What y-pipe?
- true duals with cutouts?
- Huge F'ing Issue - Broken Head Bolt
- valve covers
- Exhaust
- Suggestions???
- New Full Exhaust
- muffler or full cat back
- FAST 92mm cleaning and painting
- LQ9 to Carb
- 04 5.3 with ls6 valley cover?
- vic jr or gmpp on a 408ci m6 car?
- Worst Day Ever!!! (alternator)
- Throttle body not opening all the way?
- Coolant crossover tube
- Studdering problem due to O2 sensor
- Which Headers?
- Performance Distributors Mini VIP Ignition booster
- Oil pan kit
- Scarpping sound
- Fuel pump...
- Need pics and ideas-3" Y, 4" merge, 4" bullett, 4" cutout, back to 3"
- Typhoon 96mm intake question
- Throttle Not opening up all the way??
- ORY or Catted Y with Corsa Catback?
- LS6 valley cover vs. catch can on an LS1
- Fast 90/90 has no IAC valve?
- VMAX Velocity Ring. Using 90-92mm TB on FAST 102 Intake
- LPP True Dual Installation Issues.
- New MAP sensor gasket
- question about front and rear covers
- Who sells a TB cable bracket for LS3 Intake for 2001 Fbody
- Truck under-drive pulley?? Which sponsors carry them? Plus other ??
- cutouts behind headers
- Need alittle help before the install
- K & N, Power Pulleys?
- no check engine, parking brake, or ABS light
- ls1 timing tuner and n2o controller
- Just "stole' a crate Ls1 for $600/ prototype motor
- home made TD's
- How to remove vacuum ports from rear of intake?
- ls6 or FAST 92mm lsx intake?????
- Anyone got a 92mm FAST intake
- How to make your own LS1 coil relocation brackets???
- Reusing gaskets that have been sitting?
- TTS Headers.
- LS6 intake O rings
- Thinking about putting a Single Cat in my I-Pipe
- Coil Ticking???
- Differential options for stock 10-bolt in my '00 Z28
- no cats?
- vindicator vs raptr
- Header and Intake install = success
- wire mod snapped vaccuum connection
- Aftermarket Air Filters Overrated??
- 98 ta won't start after motor swap
- weird coolant temperature?
- Duals not loud enough
- Mega Mouth Induction?
- Custom Y pipe!
- new LT's
- Have a TSP y-pipe? come in and vote.
- 241 heads and ls1 cam on 4.8? CAN IT BE DONE?
- help deciding on exhaust
- moroso waterpump
- tb swap help
- Wiring harness on firewall, WTF!!! HELP!!!
- Easy wiring question
- hooker headers and lpp TD's
- What coupler for my build?? Help please!
- Hole repair for SLP intake
- Crappy Gas Mileage?
- P1133 help
- Oil in intake
- LS6 or Holley Intake?
- LM1 to dual/dual
- New Engine, Help Please.
- lq4 intake manifold pcv port replaceable?
- 102 or 89mm intake pipe?
- Does anyone have "new" TSP ORY pics?
- Coils going bad...
- headers, tune, intake
- TSP True Duals
- Need Help with Waterpump, Need the Most Room Possible...
- Which Y?
- magnaflow catback special
- worth putting LS6 intake on mild bolton car?
- Need vendors to chime in
- oil on tb
- need help ls1tech
- ls1 throttlr body on truck intake
- !A/C - How to CLEANLY cap the lines?
- whats the biggest/noticable difference between ls1 and ls6 intake?
- MSD Wire/NGK plug package
- cheap ewp alternative
- 4th gear pull and got Code P0300 (ENGINE MISSFIRE) for the first time.
- volant cai measurements?
- LongTube Questions
- Early LQ4 late 4l60e fitment.
- where to find an 85MM mafs
- random miss feels like a rev limiter
- dual to a catback question
- GMMG True duals?
- 241 heads
- Who has LTs, Ypipe, with Flowmaster catback?
- Mega Mouth cold air intake track results inside
- Anyone install Oil Temp gauge?
- coolant crossover pipes
- Check my list please
- Where to buy FAST 102 Valley Cover bolts?
- lsxr 102mm
- ac delete reverseable?
- Free Ram Air mod
- egr pipe mod...
- Shortys on a stocker - ET/mph?
- Build questions
- Headers tapping after suspension/line lock
- Best Exhaust Manifolds for ls1 motor swap
- Will this work to quiet my car a bit?
- Exhaust is too loud :(
- Much quieter after adding bullet.
- Coil mounts
- Cam ID?
- Stall swap question
- Cme/gmmg
- Hi Flow Cats
- Cat Back exhaust ?
- T-bolt clamps
- Are GM SST's really necessary to replace the rear and front main crank seals??
- ***help*** identify this wire
- Edelbrock 2 piece timing cover
- tail pipe size on slp lm?
- Kooks $1500 new true duel exhaust system.
- Hooker longtubes on LS6 Crate Engine HELP!!!
- Summit racing pulley coming apart. questions.
- replace them or leave them?
- FTTP 104 mm air lid; WHO WANTS ONE!!!
- Who makes best catch can setup?
- help me decide what t-stat to use
- FAST 102mm LSXrt Question
- CME help
- PRNDL setting "HP tune"
- BBK LT's ready to install how high
- 1 7/8 vs 2 inch primarys on a stroker motor
- Waisting fuel anyone !!!!
- offroad y-pipe sits too low ?? anybody with pics
- Car completely dead when trying to start
- A.I.R. tube question
- LS6 PCV Kit
- How long are long tube headers? Making a custom set, advice needed.
- muffler suggestions?
- Help need veteran advice on LS3/6 throttle bodies
- LS6/LS1 intake/ MAP sensor
- How Much is too Much (Ls1)
- Underdrive pulley A/C Belt
- Headers for 02 Trans Am??
- ok what am i forgetting here...
- need some exhaust help i think???
- Cutout for my exhaust ???
- need help pls
- Iat sensor location?
- Best ram air intake setup?
- Air lid ?
- Info on the Flowmaster d-port crossover for duals?
- 5.3 Front drive accessories on ls1?
- Catalytic converters 98-02
- True Duals Got Some Questions
- intake and exhaust pipework
- FAST repair, epoxy needed?
- tsp true duals with flowmaster super 44's
- How do you shave and paint the Fast to look well
- What size silicone coupler
- Custom CAI
- Corsa Break In Period
- Cat replacement pipe
- dyno tune in nc?
- Homemade Electric Cutout, Ghetto or Not?
- BBK 2.5" ory
- TPIS 90mm lS6 intake is it still worth it?
- Anyone have Dyno Results of a Fast LSXR vs LSXRT???
- Do any sponsers still port LS1 TB's?
- cruise control module
- 02 hawk wont start
- a.r.h. question
- K&N HP2006 filter hangs really low...pic inside
- lose battery cables= car to looses power while driving??
- Ls6 manifold?
- texas speed cam selction
- Help
- torque specs
- difference between headers
- Anyone make their own rear coolant block offs?
- ls 6 intake
- LS1 intake with H/C/E what am I leaving on the table?
- exhaust sound
- New Ypipe with Flowmaster Merge
- stripped bolt hole
- need exhaust help
