PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. What diameter/length muffler for dump?
  2. exciter wire - 98 z28
  3. LS6 intake and PCV help!!
  4. Gauges
  5. Fatty Injectors on the 102 can be done!!!
  6. What intake is best for Ms4 cam
  7. Signs of an exhaust leak
  8. simple but urgent fuel line question.
  9. Lids?
  10. Installed CME exhuast, better tone and look!!
  11. 102mm TB, throttle cable problem
  12. spliced o2 wires? quick question
  13. Throttle body question
  14. Vic Jr intake help
  15. Lets see those chrs1313 HVAC ram air install 1/4 mile gains
  16. Stock ls6 manifold and tb limiting 1/4 e.t.'s?
  17. LT's installed but still another Y-pipe question. Also butt dyno data from LT's
  18. Passenger bank no firing
  19. Ram Air please help
  20. 98 Engine & Trans harness with a 2002 ecu?
  21. 101mm or 96mm TB? Time for a MAF?
  22. 2 step installation?
  23. timing twister car want start
  24. Benefit of running truck coils?
  25. Cat bypass???
  26. Too bad someone doesn't make an alternator/motor conversion
  27. Bigger ipipe? Benefits?
  28. LM1+ Longtubes+O/R Y SUCKS
  29. Any horsepower gains with thyphoon intake
  30. Another ORY with manifolds question?? just a little advice
  31. ***Best Resonator??***
  32. Longtube install, removed steering linkage...key stuck?
  33. Best/Accurate 85-90 MAF sensors?
  34. Stepped Long Tube Headers?
  35. wanting to do an LS6 intake..
  36. 98 LS1 stock bottomend
  37. H/C car combo
  38. Alternators
  39. Will Nick Williams 92mm throttle body fit my FAST 90mm manifold?
  40. Oil filter adapter?
  41. I need to find a good exhaust shop in stl area
  42. Engine Build
  43. Cheap Stepped Headers while supplies last
  44. tranny mount
  45. Which 85mm throttle body?
  46. any news on texas speed headers
  47. JBA Shorties to TSP Long Tubes
  48. Poly Motor Mount question
  49. help with pulleys
  50. How do you think this happened?
  51. Who's running a WS6 Lower box on a NON WS6 car?
  52. Duralast ls1 maf >????
  53. Throttle bracket on FAST Intake bolts/nuts help
  54. trying to decide what to with ls6 intake
  55. best bolt ons
  56. "New Exhaust Set Up With Vid"
  57. How to remove engine?
  58. Pacestetter headers
  59. MAP sensor wiring
  60. ctsv balancer?
  61. pacesetter longtube tip
  62. help please
  63. Fast intake install help!
  64. Just insyalled LT and ORY
  65. ebay valvecovers issue
  66. What the heck did i just find in my throttle body?
  67. New crank has long key installed
  68. Anyone ever add dual mufflers onto an LM1?
  69. I need some advice on an ory.
  70. Alternator question.
  71. Power steering question
  72. Whipplecharged LS6
  73. O2 Sensor position
  74. Quick help with a cut out please?
  75. LS1 airpump removal and catalytic converter function?
  76. Got my LT's in the mail. Got some dents in them. Added more pics.Update w/ more pics
  77. 90+ mm TB w/ 100 mm MAF Set ups...
  78. Muffler options/ideas
  79. Balancer to water pump alignment issue
  80. I need some assistance
  81. Anyone running DR GAS Freq Mod Muffler?
  82. Anybody have a frame mount torque arm and TSP true duals?
  83. My True Dual Exhaust 3" over the axle
  84. SLP LM install, somethings F'd up
  85. Intake swap question!
  86. 360rwhp possible?
  87. What Lid for 02 w/o AIR
  88. What's Next?
  89. AIR Delete
  90. Mangaflow tips
  91. Funny o2 Sensor Issue
  92. 404 stroker w/ 76mm front mount which intake?
  93. Relocate my battery? Yes or no
  94. heads
  95. G5x3
  96. Mission to reduce/eliminate rasp!!
  97. moding valve covers?
  98. Random Tech Catback?
  99. Loosing Vaccum when Brakes applied.
  100. Any word on TSP Headers?
  101. Fast 102 intake question(egr and map)
  102. Which Magnaflow muffler?
  103. Will I need different coupler from TB-MAF with my new Fast 90 TB?
  104. help me decide.tired of thinking!
  105. MS4 Cam Help
  106. Best Bolt-on's
  107. Koolsox Question
  108. Lower Air box - is there a difference between regular and Ram-Air?
  109. High flow cats (Strange)
  110. Catback with best compromise of quiet cruising but loud at WOT?
  111. FINALLY fired motor eps/TSP2.5
  112. Clear lid melted and warped
  113. New exhaust
  114. L33 Knock Sensors With E40 ECM
  115. What is this?
  116. Guess 1/4 et/mph gain with added fast 90/90
  117. alternator where AC goes?
  118. any good exhaust shops by the stl area?
  119. Little Upset w/ Corsa
  120. Does anyone make an egr block off for truck manifolds?
  121. maf sensors
  122. LS1 flexplate?
  123. Best heads for RAPTOR Cam RAPtr Cam
  124. What screw on LS2 MAP sensor do I get for an LS3 intake?
  125. New tsp y-pipe
  126. where to buy ls6 intake manifold
  127. can a bad coil destroy an ECM?
  128. Spark plug on #2 cylinder not wanting to thread
  129. direct drop in ??
  130. American Racing Headers/Y w/tunnel brace tq arm -- anyone have this?
  131. got my throttle body today
  132. how do i remove AIR from 02 ws6
  133. need the idler pulley bolt size
  134. 02 ws6 lid- air hose plug
  135. Mast 275 Cathedral port exhaust port?????
  136. How much power am I leaving on the table? 1 5/8 Headers to 1 3/4's
  137. texas speed headers
  138. Thought or Recs???
  139. ls6 or tpis ls6 intake
  140. Calling those with dumped Y pipes
  141. got some questions about longtube instal
  142. check engine light on cat delete help!!!!
  143. Mass Air Sensor
  144. Im looking for tim aka (408trans_am)
  145. Just got a new fast 102/102 setup but I have questions
  146. 427 with 1 Probelm...wont start HELP!
  147. o2 sensor question
  148. new header questions
  149. Katech's new VISION, LOGO, and 100-PAGE WEBSITE + secrets revealed!
  150. Do these headers look to be in good condition?
  151. race header
  152. trying to figure out an alternator issue...random voltage drops
  153. Issues with it being hard to turn right or left after header install
  154. Questions on QTP E-cutout install...
  155. QTP headers 1 7/8th?
  156. average price to be paid from recycling place for stock cats?
  157. best throttle body mass air combintion for ls6 intake?
  158. Quick cutout question
  159. Header bolts
  160. electric cutout question
  161. LS2 to LS1 head/cam question
  162. New to LS putting the rest of the motor together
  163. 2002 Trans Am ws6 WANTING 400+ rwhp
  164. How do i get this clamp off?
  165. Starter bendix occasionally hits new flexplate/flywheel
  166. my 2000 camaro SS build
  167. header questions for my 408
  168. What 92mm throttle body for fast 102
  169. Help with y pipe
  170. is my block trashed??? see pics :( HELP
  171. K&n FIPK Precharger
  172. Converting to new style MAF
  173. Future upgrades-any imput
  174. Weekend project:Kooks longtubes,ORY and Magnaflow ,LS6 intake
  175. Modded thermostat anyone?
  176. calling all north carolinians
  177. oil pressure switch question
  178. LS1 Heads/Intake on a LQ9
  179. Ls1 spark plug leads
  180. 6 codes no matter what i change, bad computer?
  181. Valve covers that will work with shaft mount rockers???
  182. Great deals new on Edelbrock Victor Jr / MSD 6010
  183. Starting to mod
  184. Thinking of ditching ory for cats
  185. New P/P TB, P0507, Idle problems
  186. 2" or 1.75" Primaries???
  187. 2001 SS. 425 HP goal...help.
  188. Mufflex 4" cat-back
  189. Gains with fast 90 and 90 throttle body over ls6?
  190. lg tube or shorty?
  191. pulley?
  192. what coils do i need?
  193. :::sigh::: question about egr LTs =\
  194. MSD vs Taylor Wires
  195. What kind of car cover do you use?
  196. block and head casting ID help
  197. Header to Y question
  198. MAP sensor...has a breather hose?
  199. Alternator problems / questions
  200. Really need help!!!
  201. SLP air lid - holy crap!!!
  202. New Exhaust on: LT/ORY/Borlamouth
  203. A/C mounting bolts leaking oil?
  204. will a fast 90 accept a 92mm throttle body?
  205. MAF with HPTuners
  206. Measured distance from valley cover to cowl?
  207. Just want to verify. AIR & EGR removal.
  208. Lower water pump hose part number.
  209. Lm7 help
  210. What To Use To Replace Cat bolt?
  211. Painting a LS1 intake???
  212. How much HP out of a stock bottom NA LS!?
  213. cutg outs
  214. Dual cut-outs....or single cut-out.............
  215. Just installed used Meziere and the damn thing leaks!! How hard to do an o'ring kit??
  216. Ls1 engine help
  217. help on how to delete air on 02 ls1
  218. Ls6 intake or ls2 intake
  219. SES Light, Help?
  220. vin number on motor?
  221. Vacuum/hvac questions 98 z28
  222. swapping from ybody to fbody throttlebody etc.
  223. problems pulling out crank pulley bolt
  224. Cleaning up engine bay, catch cans, ect...
  225. 2002 LQ4 LS1 performance build for my 96 caprice
  226. Might rebuild 98 LS1
  227. need some help on head bolt and rod bolt torque specs
  228. exhaust trouble.
  229. Evap and catalyst not ready!
  230. 408?
  231. replacing crankshaft pulley
  232. How to tell the difference between fast 78mm, 90mm, and 92mm intake manifolds?
  233. Gasket or No Gasket?
  234. trick flow heads
  235. Need intake help
  236. spacing k-member to fit pro flo??
  237. Heads?
  238. Quiet duals? XR-1 still the best?
  239. stainless dual exhaust tips
  240. Reassembling blindly, need help!!
  241. Need help finding a y pipe
  242. need part #'s for spark plug wire and ends/relocating
  243. ls6 modified with 90 opening or go fast 102???
  244. WTB: 02 LS1 RH Cat
  245. LS6 TB and LS1 TB interchange?
  246. Ls1 Cat eliminater pipe
  247. what heads do i have
  248. Those with the T.S.P 100mm mass air come in?
  249. Do I have any bolt-ons I can do that would be "worth it"?
  250. Can I use 01-02 headers on a 98-99 fbody?
