PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Questions on installing headers myself
  2. FAST questions
  3. PCV delete question
  4. Finished Exhaust setup...link to video inside!
  5. Need help with engine noise [video]
  6. Looking for intake gasket set for Weiand/Lingenfelter manifold
  7. Victor Jr. intake
  8. im installing a magnaflow catback....
  9. What is this?
  10. throttle cable
  11. 98 Camaro SS setups
  12. Fianlly got the L92 Intake from Cary !
  13. powersteering fluid leak/ possible leak into cooling system
  14. Header question
  15. Pictures of Powerbond pulley
  16. New Exhaust ideas...what do you guys think?
  17. BMR Kmember install help ASAP!!!
  18. Cant wait anymore time to spend some cash! Help?Advice?
  19. How to lock engine down
  20. intake wont come off
  21. Intake opinions
  22. alternator swap writeup? the search is down
  23. cant get #7 injector connector off...
  24. LS6 intake/PP TB installed! Now couple quick questions??
  25. Hypertech=Motorad=Duralast? Thermastat WTF
  26. One Gutted Cat??
  27. ZOMG! HaS ANYONE SEEN THE NEW WEIAND INTAKE MANIFOLD?!
  28. Great....
  29. Alright fellas just had the ebay ud pulley installed
  30. High NOx, can't pass smog
  31. Is it worth it
  32. Can I run mechanical gauges in the pillar pod, anyone?
  33. Quick question
  34. aftermarket temp gauge that uses the stock sender?
  35. people with rev xtreme cans
  36. crank pulley socket size?
  37. LPP LS1 Headers
  38. touching kmember
  39. Need some advice...
  40. Borla xr-1's on TSP true duals...?
  41. Need a PS Pulley
  42. P0354 P0352 P0650 Misfire codes
  43. SO im having problems...
  44. Mufflers on true duels
  45. Port my stock heads or buy new?
  46. Stupid question? Will a stock throttle body fit a FAST intake?
  47. LT's and Y/loudmouth 2 or True Duals/Bullets
  48. Best Hi Flow Cat
  49. Wiring Harness Questions!!
  50. Anyone used these headers?
  51. beck sheetmetal..
  52. tr230, whats your exhaust though?
  53. Please Read!!! Car won't start. gotta be at work at 7am
  54. question about T56 fitment on LQ4 blocks
  55. Help me out!!!
  56. Moser M9 owners how's YOUR true dual exhaust setup?
  57. What exhaust for cali emissions
  58. Best setup w/emissions!!
  59. Is this for real? 33.4hp gain with SLP exhaust set-up?
  60. jvt headers
  61. Yet Another Exhaust Question
  62. which ORY..
  63. How much will I gain from mac midtubes?
  64. Best Bang for the buck INTAKE
  65. Question About AFR 225's 72cc Heads.......
  66. Victor Jr bolt size
  67. Seafoam after new headers?
  68. Rockers?
  69. PATRIOT STAGE 2 317 CASTING HEADS wHAT CC?
  70. Intake manifold ratings?
  71. Intake decision
  72. Magnecor wires
  73. 85mm mass air??
  74. Typhoon Intake
  75. what is a stock LS6 timing?
  76. Casting # 317 LS6 Heads
  77. Cranks but wont turn on
  78. BBK ISS manifold vs ls6
  79. Ram Air "Interior" Parts
  80. Cai .....
  81. Finally started my headers!
  82. Ider assembly help 2000 T/A
  83. o2 sims
  84. Embarrassed to ask this but? Engine alignment.
  85. Ls6 Heads
  86. oil pressure gauge needed!?!
  87. Where to buy ARH headers?
  88. Ls1 pcv system
  89. 1 241 / 1 853?????
  90. Manual cutout leak
  91. People Using the Summit Universal X-pipe
  92. really need help on this one...urgent problem
  93. Breaking up from 2-3k
  94. where to get decent 3"-4" y merge
  95. F-Body ASP pulley users
  96. iron heads on 2001 LQ4?
  97. volant installed but got a temperature prob
  98. QTP headers question
  99. magnaflow
  100. 87 GTA intake
  101. Any Ideas For My Next Mod
  102. Anyone ever try Quaker State Q power oil?
  103. LS6 intake with EGR
  104. Post cam clips of your LS1
  105. Ported TB not geting for throttle?
  106. e-cut out question
  107. broken header bolts HELP PLEASE
  108. 98 LS1 How much power can be had with bolt ons and what are the best ones??
  109. Did GM change plug gap?
  110. Is the 2006 Lumina ss same as the 04 GTO ?
  111. Locking header bolts
  112. Need a muffler that is quieter than a spiral flow.
  113. Spark Plug Recommendation
  114. Best way to spend a Grand
  115. just got a nice grip workout
  116. Daily Driver - Bolt-On's?
  117. question about dipstick/oil level
  118. Intake Manifold Dissaembly
  119. Purdy Headers (Kooks)
  120. Alternator crapped out
  121. AC Delete How to????
  122. Suggestions/Ideas?
  123. ported FAST 90/90 overkill on cam only? NOPE
  124. How well do exhaust Butt Joints seal? Lap joints? V-bands?
  125. 85mm MAF info
  126. My jantzer ported tb review
  127. C6 VaraRam looks like it might fit a F-body
  128. Gains from 1 inch carb spacer for Victor Jr. intake?
  129. What weight oil...
  130. Random Cylinder Misfire with a Twist
  131. What is this and where can I get one?
  132. U/D pulley question.
  133. Opinions on PCV removal?
  134. i ported my fast 90 2 100mm guys look at the pics
  135. ? about intake manifold
  136. Throttle body/cable question
  137. 80mm throttle body fit on stock ls6
  138. got ls6 intake and pp tb on!
  139. Anyone heard of these stainless headers???
  140. Decisions Decisions have some cash to spend
  141. Lpp headers
  142. Throttle body qeustion
  143. Home brew hotwire
  144. GMMG installed! (VID)
  145. LPP headers installed, pypes x pipe, and sweet thunders. VIDEO
  146. What length?
  147. Headers and ORYP
  148. whats a good intake to use
  149. Backpressure argument with brother
  150. Fast 90 intake swap
  151. GEN III to old style transmission
  152. tsp ory to low on drivers side help!!!!
  153. LS6 Valley cover install
  154. Mileage decrease with tuneup.
  155. FT 85mm Air lid and Plastic MAF Ends
  156. Engine Drop
  157. Single or Dual Cutouts??
  158. Removing ASP Underdrive
  159. still having startup issues...
  160. Folks with redesigned SLP lids?
  161. summit racing underdrive pulley
  162. 98-2002 tb are they interchangeable
  163. Need help with a couple of ground wires.
  164. Electric cutout blowing open at WOT???
  165. Oil pressure problem?
  166. 02 Temp guage.
  167. under drive pulley where do i set it for timin?
  168. Coolant seal question???
  169. T56 Bump stop - Pro5.0?
  170. Underdrive Pulley
  171. Anyone have a sound clip or vid of a Magnaflow catback on a Stroker???
  172. questions on 5.3L into 94 z28
  173. Do you need any type of flex joint when building a dual exhaust?
  174. ASP Pulley is making me run slow
  175. Dropping motor
  176. TSP True Duals with Cats??
  177. just got the arh 1 7/8" headers on
  178. Header bolts, rusty (sat for winter)
  179. Intake + TB Swap problems
  180. Need help!!!!!
  181. BBK T/B missing hardware
  182. new weiand intake
  183. rectangle head ports
  184. Installing the FTRA
  185. Cam Swap - need opinions
  186. cam swap
  187. Are LTs to ORY to Borlamouth with a cam too much?
  188. Stainless Works 3.5 inch catback
  189. SLP Underdrive Pulley
  190. 1 3/4 vs 1 7/8 header question
  191. Magnaflow
  192. Dash removal....Worth it?
  193. ls1 flow numbers
  194. ls6 intake on stroker?
  195. Help ID these Bassani Headers...F-Body???
  196. FAST 90 install HELP
  197. Open headers?
  198. Random misfires while idling
  199. Which alternator pulley with a ud crank pulley
  200. Alternator relocation or ???
  201. what mufflers to quiet down my duals
  202. Water Pump Question
  203. TB Blade
  204. How do you put a 2000 TB on a 99 LS1 car?
  205. Just ordered headers, checklist of what all I need...
  206. Urgent power steering help needed
  207. How much do you think I would gain from swapping intake/headers...
  208. Exhaust install ??
  209. Ported TB, now high idle.
  210. BBK 80mm TB
  211. LS6 intake help!
  212. slp air lis vs k&n cold air intake
  213. Corsa C/B over $1,000-wtf is goin on?
  214. LS1 Mechanical TB linkage - not cable
  215. New motor from GM, change rod bolts or don't change rod bolts??
  216. what sensor is this?
  217. Kooks Headers vs American Racing Headers
  218. TSP True dual
  219. LS1/Vortec Intake swap
  220. Cheapest Place for LS6 intake?
  221. What is the sensor on the oil pan oil block-off plate?
  222. Help me match heads
  223. Best flowing Filter housing?
  224. How to find an exhaust leak?
  225. Are UD pulleys supposed to be keyed??
  226. P# reclocation pan rod bracket, true duals
  227. Which aftermarket UDP?!?
  228. main cap bolts reusable?
  229. high hp with stock balancer?
  230. PCV System?
  231. Leaky Meziere WP - Any Quick Fixes?
  232. Thunder Racing Headers?
  233. What happens when you overtorque a bolt?
  234. exhaust i made..4" Y pipe...
  235. quick alternator pulley question?
  236. under drive pulley
  237. Ture Duals Costs?
  238. Replacing Intake Manifold gaskets with a BBK SSI?
  239. Whats the catch to this?
  240. Any opinions on oil in my coolant and vice versa
  241. Anyone know if i can purchase a engine bolt kit?
  242. What are the benifits of using a ls6 valley pan
  243. exactly what engine is this
  244. anyone use these headers before?
  245. 500 to spend, what would offer the most gains?
  246. Which Summit UD Pulley?
  247. Cant you swap the vent/steam line around?
  248. Power Steering Pump Pictures
  249. corsa exhaust
  250. Sweet Thunder
