View Full Version : Generation III External Engine
- where does the vacum in back of the ls6 manifold connect to???
- Intake Install??
- Not Your Normal Ported Throttle Body ?
- FAST intake question
- Single fan, manual fan switch help
- One more.. bolt length for intake..
- Does magnaflow exhaust install require welding?
- intake or headers/exhaust?
- Bosch oxygen sensor question
- hows the loudmouth II
- fittings for back of intake...
- TB Gasket for Beck's SM Intake..
- PO420 help por favor!
- best plug wires w/ Headers
- Uncle!!!!
- can my water pump warp?
- Burning smell from under hood...
- More power at low rpm?
- Trans Ams with dumps...
- Best Catback
- What is this?
- prohane motor mounts not lining up???
- Just got headers on :), is this normal?
- hose from throttle body to left valve cover
- Just starting mods
- Boom Tube exhaust *pics*
- how low do your header hang
- ? about ls1 intake
- Header install
- Changed TB
- megs tip trouble
- Anyone flowed a ported Victor Jr intake yet?
- Anyone Ever Heard of BELDEN Wires???
- i need another switch for my cut out, what kind ??? and where do i buy it
- Crap trans mount?
- Any Other Bolt-ons?
- Cut-Out input needed!!
- tb bump stop worth it
- X-pipe question
- which is better
- O2 sensor woes
- Ram Air Exhaust Setup
- changing spark plugs
- Went with the Powerstick...
- Did I gap my spark plugs right?
- headers
- Which high flow cats are OBDII certified?
- Loud Water pump ticking sound, I think...
- hooker 2254-1 vs.2469-1 whats the difference
- o2 sensors
- Victor Jr. & carb style TB throttle cable ?
- What LT's To Get
- Fans not turning on
- What muffler
- Water Wetter or Purple Ice
- Best Pullies/Belts setup?
- Intake Install
- Your Opinions on Dynamaxx Headers
- fast 90/90 setup ??? what maf??
- Stealth TB bypass
- Emissions question.
- Post Pics Of Your Ssra
- Stock torque arm
- austin ram air scoop
- Ported Throttle Body
- installing pacesetters on my 02 T/A
- I need a spark plug Recomendation
- Cut out sounds good!!!!
- Pacesetter LT's and Kooks ORY?
- Hooker Headers w/ ORY
- cats and catbacks
- True duals with sweet thunders vs magnaflows
- Starting Pacesetter LT install tomorrow, tools?
- Sweet Thunders
- EGR question.. and headlights
- SLP Linelock kit
- Hooker Catback, couple sound questions
- Spraying out the radiator reserve
- 3.73s or Headers
- TB Bypass + Winter = ???????
- Whats the best throttle body to get for a ls6?
- Does removing this tape effect anything?
- How do you remove Power steering pulley
- Harmonic Balancers
- installed new TSP lid.... need more improvement
- magnaflow not impressed with sound. . help
- Magnaflow Muffler vs. Catback
- radiator
- slp headers
- true dual exhaust ?
- slp headers
- borla vs corsa
- Running Lean
- CAT going bad, just replace whole system?
- Doing AIR removal, and I have a quick question.
- Inlet manifold ls7
- magnaflow or hooker muffler
- Edelbrock headers
- Where Can I Get A Performance Water Pump??but Not Electric??
- FLP header guys:
- stop.. or keep going?
- hood baffles, remove or not?
- Egr??????
- port/polish tb
- ****Open Headers****
- next upgrade+my tb job
- Which bolts to use for header install?
- water flow
- True Dual: sound vs flow
- Exhaust Manifold Studs
- battery cable
- magnamouth or sprial flow
- removing cats
- Side Exhaust?
- lost a part in the engine bay,, can not find.
- is this common after a LS6 intake install??
- Need some help
- dropping the motor with out a lift???
- underdrive pully un-install
- Removing clamped exhaust?
- My new Exhaust makes me a WINNER
- Headers+Y-Pipe+????
- How is everyone....
- exhaust leaking,damnit!
- Headers and Y-pipe?
- ****about To Install Lt Headers
- Throttle body...
- how hard is it to break or a crack an ls6 manifold???
- Does anyone make a 3 1/2" exhaust for the camaro?
- LS6 intake install.. Quick Q..
- Would you buy this?
- air box lid
- Questions about exhaust
- Who has y-pipe/muffler/dump. come inside please with some ideas
- corvette headers and f-body headers...
- alil help with which headers to order from pace setter
- whose dual setup is this at ls1sounds.com?
- Bump Stop Question
- Where to find LS-6 Intake?
- #8 Spark Plug = WOW
- Headers + Y + Cutouts
- 12560894 is this a LS6 Intake?
- FAST TB 78mm bearing removal
- ground clearance ???????????
- T-stat gone to hell? Temps reach 250+, can hear boiling
- If you've considered a catch can, don't wait!!
- Finally Finished Project Header!
- Where can i get borla plates?
- SLP Dual/Dual powerflo owners come on in
- Is there a problem with sanding some of the ceramic coating off my LT's?
- Gas...How long is to long?
- KOOKS or QTP
- glasspacks on an F car!
- HELP any one with Edlebrock LTs!
- Longtubes into a X pipe, with electric cutout from stock muffage.
- Duals: Out The Back vs. Dumped
- What to use to temporarily seal exhaust leak at the Y?
- i have a 85mm massair off a truck. should i de-screen it?
- Y-Pipe? Is it worth it?
- hooker header & 3" Y
- need help with O2 sensor
- FAST 90 & NW TB?
- Big difference in sound with GMMG using stock manifolds vs LT headers + highflow cats
- anyone tried this?......
- LT's + an e-cutout...
- 160 therm
- 3 , 3.5 , 4 in piping
- ls6 intake w/ or w/out provisions
- can i "bend" my NGK's from .06 to .05?
- Quick TBB question
- pacesetter headers
- Ls1 Header Install
- y-pipe for pacesetters?
- installing mac headers and ory...please help
- descreened MAF affect on dyno tune
- My first mods!
- 2 quick and easy questions
- Spark plug help fast!
- Too Loud for IL cops??
- Header help please
- Headers???
- How well do the spiral type bullet mufflers flow?
- Ground clearance q w/lowered car, running Stepped headers?
- CALLING ALL PEOPLE WHO ARE RUNNING B&B or bassani
- is a t-stat worth it?
- Manifold vs. Header
- LS1 bits that fit LS2 & LS7
- LS6 intake swap from 99 to 2000
- Short or Long tube headers??
- any hp/tq gain?
- new electric water pump
- Holley TB's
- New plugs/wires and !AIR,,,ticking sound..
- Anyone done this?
- Coil harness connectors?
- Need help, FAST installation document...
- anyone got the speed inc x pipe?
- Hooker vs. Pacesetter Headers
- Leaking from thermostat..
- LS1 owners: how miles did your factory alternator last?
- when i give it gas it dies?
- installed polly trains & Trq arm mount! :(
- ac turns off at idle
- Austin SSRA affect Tranny cooler?
- Pacesetters with cats on y pipe
- They Are Here !!!
- Anyone having problemsw/ QTP ORY?
- Fast 90 Intake owners, have you tried this?
- SLP Y-pipe banging?...
- LS6 intake Question
- Ported TB and MAF problems...
- What has been your favorite bolt-on??????
- Need your opinions
- turned the car on after LT's install and...
- New problems.
- were do i get this at?
- magnaflow part
- how to install a water temp gauge?
- weight of cats
- Free Ram Air Mod
- best way to remove a Y-pipe?
- FTRA/SSRA Fit With Trans Cooler?
- Post up if you have LT's w/ CATTED y and are running a loudmouth II
- Mods That Dont Need Tuning? Ideas?
- FRA and intake
- IAT Sensor
- was it corsa or borla...
- Valve cover removal
- Will 01 manifolds work?
- Borla->Loudmouth?
- H-pipe with true duals anyone?
- belts?
- Tips for assembling plug wires
- Quick help on tq specs and coolant plug size
- NGK TR55's Changed?
- Pacesetters are on..I feel slower!!
- TPS keeps going out
- QTP vs. Kooks headers-how much HP?
- SLP Blackwing lid?
- should i get a cutout?
- stock exhaust
- o2 sensors
- true dual ??'s
- Mufflex y-pipe
- What do I need from a stock intake...
- 13111 Vette O2's or Stock?
- Finally got some pictures of duals...AND VIDEO!
- Anyone using the new SLP balancer?
