View Full Version : Generation III External Engine
- cold air intake
- Need Help Finding Writeup
- What size o-rings for injectors to fit in LS2 injector??
- Driver Side Cat Overheating
- Stock Exhaust, what size cutout?
- $$$ What would you buy?
- Overlap v. Exhaust
- Took off my muffler what now?
- 243 castings
- Alternator wiring question
- P+p Tb
- I need quick response PLEASE!
- Will LS2 intake manifold fit directly on LS1?
- pacesetter long tube help
- O2 sensors
- ATI balancer installation question.
- is there a way?
- Just bought my FAST 90 intake,now is there...
- header to x pipe help
- Fluidampr 10% underdrive pulley...belts?
- First Mod
- Cat Question...
- VOLANT CAI and RAM AIR HOOD ???
- Are Dynatech Split flow the same as Borla XR-1?
- Do I need rear o2 simulators/tuning?
- ok.. who has loudmouth and loves it? I do!
- pusher vs puller cooling fan?
- Borla Catback install
- Muffler?
- oil pump question
- Need some Loudmouth advice.....Please
- electric water pump
- Powerbond UD Pulley Install:
- just installed LS6 Intake
- Will I need tuning with Pacesetter LTs, ORY, and sims
- Need a 90 mm tb
- Need help finding cats!!
- borlamouth vs. borla vs. magnaflow
- 90mm bellow? Guys using FAST 90mm intake please help!
- Does your MTI lid........
- Cutout Tripping SES Light and Sensors???
- Need Flexplate Help!!!!!
- what headers for a 427??
- Under Drive Pulley?
- center bolt valve cover bolts PN?
- Scarry Oil Pressure
- Poly engine mount install feedback??
- what else to bolt on?
- 85mm MAF on 2000 LS1?
- LS6 intake swap problems
- Bosch 2 plugs?
- Does MAP Sensor have to be laying flat to function?
- Puzzling problem - please read!
- Oil pressure gauge is screwed up!?!?
- Wheres a good place to find a 99-02 wiring harness?
- 3 bolt flange problem
- Ftra?
- spark plugs....
- valley cover screws for FAST90
- ls1 headers.Gains? installation?
- Going to track...ned 2turn off asr..for real!
- Quick Hooker Header Question?
- mufflex bump stop
- exhaust suggestions
- Power Steering taking a dump..... :(
- DIY C5 FAST 90/90 install instructions ??
- Intake manifold leak
- Headers - Re-Coating?
- Spintech Sportsman.... good or bad???
- plugs for rear o2 sesnors
- exhaust problem quick question
- 90mm intake port matchted to afr205s, will intake work on stock heads?
- XS Stainless Steel Headers
- help me pick spark plugs
- i want to make 400whp and spin to 7k- help
- Slp 1cme finally done!
- FAST 78 and stock TB issue
- exhaust loss without mandrel bends
- oil pressure guage problem
- Torn between True Duals or ORY
- magnaflow catback
- FAST Intake over LS6..
- 98 LS1 vs 99-02 LS1
- Gmmg/stock/cutout
- whats the average hp
- Dust collectors on transmission
- what valve covers?? alum ones perfered
- air, egr, o2 sensors, is that it?
- roller rockers
- band clamp help
- Direct Hits Ignition any body use this?
- Showin off them Powersticks
- need some opinions
- Y-pipe flow and restriction
- 2.5" true duals OVER the axle installed pics!!
- slp underdrive pully need help
- Question about y-pipe
- Bizzare - Steering linkage issue
- Questions about ignation
- which is best 78mm or standard t/b
- Stock exhaust with cam?
- Does anyone sell smoked color lids?
- What's the real difference in Kooks, QTP, ARH ?
- Question on fitting Cats - HELP!!
- For those with dumped duals....
- Some help please....Is this bad?
- underdrive pulley??
- Volant CAI
- For those with XS and banging ypipes.
- Starting after H/C/I install?
- Pulley, pulley
- injectors what brand?
- question about deleteing pcv system.
- How does a dual/dual sound? Need clips.
- who does the best p&p tb's?
- new pcv valve whistling like hell
- spark cuts out
- just got done porting my stock TB but somethings wrong. need nelp!
- mti clear lid
- motor mount help
- stock plug gap?
- True Duals Vid
- Best Quality Accs. Drive Belt?
- Best price on Yello Terra's
- bought a jacked up ls6 intake please help
- Proform balancer install tool?
- Finally got my headers
- taylor wire question
- Edelbrock Headers...??
- pulling timing
- Do I need new Fuel rails for F.A.S.T?
- Do I need new Fuel rails when for F.A.S.T?
- MAC MID owners INSIDE!!
- ls1 Starters and interchange information Info needed
- The Dual Dual is back!
- 243 heads
- Coil Pack Conversion?
- New Oil Cooler Dropped Oil Temp By 50+*
- How to get the crank bolt loose with the motor out of the car? It spins
- Sound clip needed for single-in single out exhaust.
- Carbon Residue...?
- idle drops, inptu and help please
- LS2 Maf work on a LS1?
- HELP??? #8 primary glowing
- Velocity spike and HVMC differences
- ORY Pipe
- Which MAP sensor for Fast 90mm intake? also what intake bolts?
- looking for a quiet 4 inch muffler
- need help with airbox lid and assembly
- tsp rumbler
- Edelbrock Shorties, Best 5.3L Heads for the money?
- electric cut out do any good
- Bad MAF?
- Idler pulley part number?
- Need exhaust advice
- Engine swap question.
- coolant problem - No idea what's wrong
- Something to think about.
- just finished true dual setup
- true dual setup ques.
- Z-28 Exhaust Question
- xr1 borlamouth question
- Anyone put cats on P.S. ORY??
- Hooker catback, Pacesetter LTs w/ORY, Torquer 2 vid
- Touble removing Alternator & power steering pump
- hey guys need help
- Stock or not?
- Loss of power w/Straight pipes.
- headers wont fit
- Question about mufflers off headers and fuel line.
- Porting Your Throttle Body
- oil pan/bellhousing integrity.
- Do Not Epoxy Your Tb
- Are all 85mm MAF's made the same?
- Is this a genuine CME tip?
- TSP Rumbler.. Quick Question..
- Injector Driver
- Ran into a snag Pulling Motor
- custom stainless y pipe. lots o pics....
- Just Got My Pacesetter Lt's And Have A Few ????
- LS1 radiator fit a LT1 car
- yet another Header Thread
- MAF sensor part number?
- Yellow Katech belt tensioners now available
- quietest muffler???
- info on melling oil pump?
- Are my 2.5" duals holding me back?
- Pacesetter LT + A.I.R = problems
- Longtube headers
- Is it worth it?
- Cats in TD setup
- What Cone Filter Fits on a 90mm TB
- bbk 5005 ssi intake VS. ls6 intake
- Headers installed, but rpm's at 3k in Neutral??
- GMMG or Corsa need input
- Motor plate + accessory question
- Anyone make a 4" output F-body air lid?
- true duals or catbk
- $@^%# My Kooks!!!
- Power loss...Duals to y-pipe/catback?
- 02 camaro tb sticking
- free lid mo
- SLP 85mm MAF vs GM MAF
- is this an exhaust leak?
- Slight exaust leak
- where can i find metal clips for my lid?
- How well does the...
- What goes in this spot???
- A.I.R, What is it?
- no heat shields a problem?
- Milled 243's
- Catch can?
- Help please need to know
- True dual exhaust question.
- Stock MAF holding me back?
- X-pipe with stainless works mufflers?
- Anyone have the newest SLP lid?
- Post here if you have overheating problems and/or an aftermarket Radiator!
- Vibration!?! 02 ss
- header coating??
- first start!! H/C/I *video*
- what size bolt
- Why do soo manypeopledislike the Granatelli maf?
- FAST LSX intake direct swap over LS1 intakes?
- NE1 Know an Easy Way to extend vacuum line off back of Intake?
- FAST LS Intake
- ARH install questions and which primany to buy?
- ls6, bbk, weiand?
- TR55 Plugs
- Crossflow Cooling Question
- '93-'97 Throttle body
- FAST 78mm TB cable placement andadjustment
- What to do next?
- Header install questions
- Headers (OBX HEADER )
- LS1-LS6 Intake change over
- Weird noise after throttle body install
- GM OEM metal header gaskets
- Running rich
- How loud is it gonna be "really"
- Any thought on this selection
- I want to change my catback (SLP guys come inside) opinions and sound clips needed
- ported fast intake?
- X Pipe
- 5.3 specs
- Brand new set of Pace Setters LT's for sale!!!
- Hub seal
- LS1 to LS6 Intake swap
- Thumbs down for XS headers
- need a new fan shroud, got two broken tabs
