PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 [252] 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. what will flow better?
  2. cutout
  3. new exhaust, what you guys think?
  4. Dent in my new hooker cat-back?
  5. Hooker vs B&B catback
  6. gmmg or true duals or stick with slp d/d?
  7. Radiator cap
  8. Knock off GMMG???
  9. Few of Questions on Induction and Tuning...
  10. Billet vs ported stock TB
  11. 78 or 90 Fast intake?
  12. Tach is dead and car is hard to start . .
  13. Throttle Body
  14. What's the best remedy for the PCV oil sucking problem?
  15. corsa questions
  16. Car won't start suddenly, need suggestions
  17. Catalytic Converter for 2000 Camaro SS
  18. Using 01-02 Headers on 00
  19. help oil in my anti-freeze 3.8L
  20. Rear main seal clarification
  21. S2 & S3 Throttle Body....
  22. Oil Pres. sensor
  23. exhaust questions: open headers/ cutout
  24. Throwing MAF Codes. Any suggestions on which one to buy?
  25. Home Porting TB
  26. Header wrap is bad
  27. best sealing exhaust clamps
  28. FAST 90 tb issues
  29. 90mm intake & TB on A4...
  30. exhaust ??
  31. NX 85mm TB ?
  32. Vacuum Leak
  33. Can you tell me what's wrong? (video)
  34. Bell Housing Bolts
  35. Those with a Whisper Lid...
  36. What gains are A4 and M6 gettin with TBs
  37. Have Pacesetters actually gotten better?
  38. LS6 install question.
  39. people with 85mm MAF, what lid and how
  40. 02 sensors getting wet? (Longtubes)
  41. Edelbrock or Jet-Hot headers
  42. Ls6 Intake
  43. AIR gaskets
  44. ATR & Random tech Catback questions
  45. Noise
  46. What bellow for 90mm TB to 85mm MAF?
  47. GMMG with E-cutout! Is it worth it?
  48. pacesetters for 00 work on a 99?
  49. still wont start
  50. Has anyone ran into problems with a short belt? (no PS or A/C)
  51. Throttle Body Interchangeability
  52. Is there anyway that Longtubes would...
  53. Putting back Intake Manifold
  54. Big misfire problem, please help!!
  55. Y Pipe Hanger?
  56. Do MAF Ends net any gains?
  57. QTP long tubes????
  58. a few questions about tsp true duals
  59. Spintech mufflers/cat back exhaust
  60. Florescent green fluid leaking from A/C compressor??????
  61. anyone with LS1 knowledge
  62. AutoZone Duralast-Gold battery.
  63. A/F guage
  64. which is quiter for true duals bullets or 1 chambers
  65. Changing exhaust-opinions
  66. i wanna get new headers, help me out
  67. vararam or Halltech Trap?
  68. PLEASE don't buy Flow tech or FLOWTECH headers.
  69. LS6 Manifold & !AIR/EGR ?'s
  70. Band Clamps/exhaust leak
  71. Advice on bolt-ons to beat on 04 Cobra!
  72. Cutout
  73. Ported MAF on A4 car...could it have damaged my tranny?
  74. Install LS6 Intake - Now Tach & Oil Pres gauge no work??
  75. Should I get a MAF and ported TB?
  76. question about o2's
  77. Long Tubes: Stepped vs. Non-stepped?
  78. Question on dual x pipe?
  79. question about electric water pumps
  80. Service Engine Light On: P0125
  81. FLP LT w/ Corsa CB help....
  82. S2 or S3 ? Polished to Satin ?
  83. Need Help Deciding
  84. maf
  85. Pacesetter Headers
  86. Should I change lids and MAFs for Fast intake?
  87. lid
  88. ultra cool short belt alternator
  89. Weird Problem--Need Help!!
  90. Jantzer Tb's
  91. Cutout install cost
  92. nasty exhaust sound
  93. Another Newbie Header Question...
  94. Difference between OR-X and OR-Y
  95. QTPs installed...
  96. Airlid
  97. Replacing MAF screen...what are my options?
  98. headers??
  99. Crank Pulley swap
  100. Spark plug wire ??
  101. What sounds better?
  102. Stock CME headers and catted Y Questions
  103. Please help with busted water pump... I think.
  104. Exhaust Dilemma
  105. How many of you have put a cutout on a corsa system?
  106. need new muffelers...
  107. Help a newbie look for headers
  108. SLP Throttle bodies
  109. no need to worry about losing RWHP...right?
  110. Newb header question...
  111. Need deepest sounding catback...HELP!
  112. Borla Exhaust From A 97 Ram Air To A 99 Trans Am
  113. Backfiring
  114. Kooks vs SLP Headers
  115. Possible new exhaust system
  116. Free ram air mod
  117. Descreening a stock MAF, good or bad idea?
  118. PCV catch cans...where to buy?
  119. Anybody buying stuff thru GMPARTS DIRECT soon?
  120. Temp not rising??
  121. why cat-back??
  122. port and polish
  123. Descisions??Descisions??
  124. Backfiring????
  125. building a 3in "catback" for a C5
  126. what kinda intake is this??
  127. some help please!
  128. Denatured Alcohol for Smog
  129. macs vs. long tubes
  130. spark plug gap for F13 cam, and checking them
  131. Valve Covers on Ebay
  132. Installed gears/clutch and tach died?
  133. Rusty headers
  134. Which Alt Bracket
  135. 90mm install pics
  136. How do I bypass the power steering pump?
  137. newb w/ pacesetter question
  138. magnaflow i-pipe
  139. Question about Holley alum. intake manifold
  140. A couple of questions about y-pipes & loudmouths.
  141. New parts!!!!
  142. just finished header install
  143. 02 sensors stuck??
  144. Coil Pack relocation.....
  145. ORY problem
  146. Ignition wires
  147. Hey guys, need help with Header Collector Gaskets......
  148. suggestions, black smoke
  149. 02 sensor problems...
  150. quality of pacesetter vs mac
  151. Wholesale manifold gaskets and bolts?
  152. Anyone running sheet metal valve covers???
  153. video:macs, ory w/dual cutouts
  154. hooker LT
  155. ls1 electric h20 pump
  156. which LT's have the best ground clearance?
  157. Help >!
  158. Who makes the best dry cell battery
  159. Part # help...
  160. Borla Swap??
  161. HP/TQ gain?
  162. True dual exhaust setups?
  163. please help...ac problems
  164. Extending O2 Sensors
  165. Repairing a drilled TB
  166. Muffler?
  167. Header/ypipe question
  168. exhaust help
  169. Exhaust Pipe Fell Off!
  170. Can't get Damn Y-Pipe off!!!
  171. Optima Red Top Battery - doesn't fit :( ! Help !
  172. Why don't people fab up their own Dual systems?
  173. slp headers
  174. ?
  175. throttle body disassembly
  176. header install
  177. do they make oil filter relocation kits for LS1's?
  178. Need an exhaust change...unhappy
  179. important exhaust question
  180. squealing belt
  181. which headers to go with?
  182. In need of solid motor mounts for ls1
  183. hooker cat-back?
  184. Help! header install
  185. which TB with FAST 90mm LSX intake?
  186. what else for header install?
  187. Hedman
  188. EGR Removal
  189. Fast 90mm Intake ports?
  190. QTEC cutout on stock manifolds?
  191. ws6 hood baffles
  192. Offroad Y-pipe
  193. Thrown Codes after Header Install
  194. TB Porting
  195. New LS1 Owner Needs Help...
  196. SEARCH DID NOT WORK!! dynomouth vs. duels
  197. Discolered intake runner? Help
  198. LS1 Waterpump drawing for a Dyno????
  199. HELP A/F after dyno
  200. Which TD setup?
  201. New sound same car!
  202. LT's...HP/TQ Difference
  203. anyone do this?
  204. MAF? and REV limiter?
  205. Where to buy band clamps?
  206. Need Feedback On Dynomax Super Turbo Mufflers
  207. QTP headers install ??
  208. MAC or KOOKS ground clearance?
  209. Help Please!!!!!!!
  210. Has anyone with QTP longtubes lower thier car?
  211. Ordered TSP true dual's how much HP??
  212. Stripped header thread
  213. Do You Pass Emissions Or Not?
  214. horsepower question?
  215. gaskets
  216. Looking for feedback on the Dynatech SupperMaxx Header setup
  217. Difference between Camaro and Vette O2 sensors?
  218. True Dual question
  219. Meziere Water pump LS6 - Meziere WP319
  220. why pay $700 for GMMG...
  221. Fast 90 Vs TPIS oval 90 LS6
  222. O2 sensors/wires (possibly burnt wires?).......can i do this?
  223. Can an LS6 intake install cause pinging/knock?
  224. alternator only problem solved
  225. Source for bolt sizes for 6.0L and Ls1
  226. Throttle body blade air bleed hole size
  227. Ignition or Starter?
  228. Kook header gains over all others?
  229. Low Oil Pressure???Help!!!
  230. Can you get Mac's without emissions fittings?
  231. Spark Plugs/Gap
  232. Question about AIR system
  233. Caddillac CTSV intake manifold
  234. water temp gauge WTF threadsare these!
  235. true dual
  236. FIPK- I was just thinking...
  237. Battery power drops after Pulley ?
  238. GM Weatherpack Connectors
  239. ? about Jet Hot headers and Flowtech headers
  240. 90 mmTB confusion
  241. Flowtech LT's GO OR NO GO?!?!?
  242. alternator only
  243. O2 Extenders for Pacesetter LT's
  244. aftermarket coils
  245. Can you tell me what this is?
  246. headers on a blackbird
  247. Please help: what happened to my oil drain plug?
  248. quick electric cutout question
  249. GMMG install question
  250. why 90mm TB when 85mm MAF?
