PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 [260] 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Tensioner pulley torques specs
  2. O2 sims?
  3. Swapped the ultra flo mufflers for super turbos in my duals
  4. Whining and Lost Air Conditioning
  5. help with throttlebody porting....
  6. Hedman Headers Initial Impressions
  7. headers, what all do i need?
  8. LT + hi-flow cats + y-pipe into SLP D/D
  9. new pvc
  10. Header Install / Needs
  11. Really Strange Sound
  12. !EGR & !AIR Question
  13. Different sound?
  14. Anyone that has installed MAC LS1 Header, I need help?
  15. crank pulley alone or crank and alt?
  16. How much will X pipe help
  17. custom y-pipe with cut-outs and cats
  18. Louder? Old or New???
  19. driver side exhaust clearance
  20. Got true duals on the 408!!!
  21. Problem with trip meter! Help!
  22. Ac problems! Help me out guys!
  23. How to check if coil packs are bad, and where to get new ones (aftermarket?)
  24. who makes these valve covers?
  25. Y-pipe for Mac midlengths
  26. Couple FAST 90mm TB questions
  27. Cleaning o2 sensors and do they go bad from sitting.??
  28. Meziere EWP Died
  29. Next project....maybe this weekend
  30. Flowmaster American Thunder
  31. Rasp
  32. Gmmg Exhaust
  33. Best air filter set up?
  34. TSP 85mm Lids - when?
  35. ls6 manifold help!!!!!
  36. Side pipes with x or h pipe?
  37. Those with a FAST intake and 90mm TB?
  38. Will taking the AIR pump off harm the cat's?
  39. How much gain?
  40. So Cutouts after Collectors are bad... what how about this?
  41. bad to mix PSF?
  42. How much exhaust CFM is necessary?
  43. Anybody know about the Window regulator Rivets?
  44. Stock Header Bolts OKAY for TTS LTs?
  45. Need A/C Line Part # quick
  46. O2 sim ??
  47. heades with removable cats
  48. macs vs. pacesetters
  49. ASP or SLP underdrive pulley?
  50. Temperature gauge.....
  51. Best Bang for the Buck Headers
  52. Belt size for Power Steering Underdrive Pulley
  53. Ground clearance issues?
  54. Installed new toys, want to share my opinions
  55. I need front 01-02 style coolant bypass pipe #12578838!!
  56. Sweet-Thunder (vid)
  57. asp crank pulley owners inside-->
  58. 78mm or 90mm ?
  59. Any PICS of TSP Catted Y-Pipe?
  60. Will these headers fit an '02?
  61. GM electrical connectors
  62. Dual pics...
  63. 2 spark plug questions
  64. Installing ls6 intake, questions.....
  65. 90mm LSx owners question...
  66. Shorty Header Questions (With posting rules)
  67. Electrical Power problem
  68. True Duals on Lowered Car ??
  69. Fan Wiring?
  70. FLP longtubes w/ Cats and Magnaflow Cat back impressions..
  71. MTI Billet Throttle Body...
  72. What do i need for pulleys?
  73. Where are the fluids going??
  74. 02 question....
  75. Header Heat
  76. Belt routing with no power steering
  77. Gut or remove catalytic converter
  78. Why do we hear detonation?
  79. question about LS1 valve covers
  80. Is This Overkill?
  81. They'd be so easy to change
  82. GMMG Impressions
  83. Anyone Else Order a Nasty Sheetmetal Intake?
  84. Bypassing power steering cooler. Is it safe?
  85. power steering pump
  86. hypertech thermostat
  87. Installed lt's got ???
  88. Need Advice Please Help Me!!! (long)
  89. Got Problems!!!
  90. I need help please!
  91. Difference between TPIS and FAST 90mm TB?
  92. Oil Pan Help!!!!
  93. Short pulley belts to bypass the AIR and PS??
  94. ls6 intake question????
  95. True Dual preference
  96. should i order non egr headers
  97. Inside if you have Poly Engine Mounts
  98. FAST 90mm TB- 0 for 2
  99. Kooks builds me a custom Y-pipe to replace my FLP Y
  100. WS6 Lower Air Box w/ SLP Ultra Z Hood
  101. LS6 intake problem...
  102. 90mm still good on stock cubes?
  103. ported LS1 manifold?
  104. Dumb question please answer
  105. Is the LSx intake and TB combo that much better over the LS6/ ported TB (for a 402ci)
  106. Fans running all the time?
  107. exhaust popping
  108. loudmouth to qtp ory problem
  109. Need Block Off Plate
  110. Resistance of Spark plugs
  111. car runs terrible on start up, then clears up. help!
  112. Noticed oil between transmission and oil pan (pics inside)
  113. port your borla
  114. Thermostat and housing..or just buy a new thermostat and put it in the old housing?
  115. not a f-bod ? but its a pontiac
  116. How low will a set of MAC LTs hang below?
  117. Coupler for C5 TB to C5 air bridge
  118. ZO6 MAF specs
  119. 160 T-Stat, and fan temp questions
  120. BBK intake manifold for LS1 - does it really flow better
  121. Replacing A/C???
  122. I bought ENTIRE pcv valve system....
  123. How do you guys like the SOUND of an 80 series Chokemaster?
  124. QTP Dual Cut-out Y-pipe
  125. Header primary sizes comparo
  126. Please Critique Future Exhaust System...
  127. header install-now smoke
  128. Pulley question?
  129. Did the LS1 AC Oil Filter change from PF44 to PF47?
  130. stearing shaft torque spec..
  131. Build my car!!!
  132. what does it take to put a 160 stat in?
  133. Removed my EGR & Now No Air Blows through my vents?
  134. Car won't start. Constant draw on battery
  135. Electric cut-out trouble
  136. Is manifolds/cutout louder than headers/catback?
  137. Surging question from ported TB
  138. Supercar sounds out of the LS1
  139. Cold Air FlowPac = Bad MPG ???
  140. 2 1/2 inch i-pipe?
  141. Where can I get just an I-pipe?
  142. JBA headers gains
  143. Missing
  144. Positive stud on alternator broken?
  145. Finally got it!
  146. y pipe and macs
  147. Can I use 98-00 Mac Midlengths w/ O/R-Y on an 01???
  148. Are Carsound Cats CA Smog Legal?
  149. Cooling Question??
  150. What Y-pipes Fit Jet Hot Lt's
  151. Smaller Exhuast tips, do they hurt performance?
  152. Car is quieter than usual
  153. Starter dying question?
  154. to need or not to need,that is the ?
  155. Question to true dual owners.
  156. Pulleys!
  157. TB Opening Too Much
  158. What is the External Pipe Diameter on Stock Y Pipe and Loundmouth
  159. is it ok to remove this???
  160. TB tourqe question.
  161. mac headers and egr/air
  162. MAF screen removeing?
  163. need sum help! does this sound weird?
  164. Emailed BBK about their new intake...
  165. Best intake for functional hood?
  166. Would I go 12's?
  167. Clearance with QTP catted y?
  168. TPIS 1200 CFM Oval T/B & Intake?
  169. 90mm vrs 78mm LSX Intake and TB
  170. LS6 intake vs stock
  171. Closed thread
  172. car having trouble starting after LS6 install HELP PLEASE
  173. Done myself a small bit of researchin' about my ignition probs
  174. Problems after storage...
  175. A/c compressor?
  176. Air Conditioner
  177. 78mm Fast Intake Gain?
  178. tsp true dual questions
  179. what do you think of these Under the axle duels out the back
  180. Question about using larger Truck MAF
  181. leaking AIR help needed
  182. what size electric cutout?
  183. 1 cutout in the Y and another in the I
  184. stainless
  185. Pacesetters installed!
  186. V-band Exaust Clamps
  187. Y-pipe worth more hp/tq?
  188. after doing !AIR?
  189. True Duals question...
  190. Alternator Overdrive Pulley Install Tool
  191. Theormostat question..................
  192. Do different exhaust tips make for a different sound?
  193. Looking for True Dual system
  194. Does bullets sound kinda like cutouts?
  195. Noise from engine bay after long drive.. AC ?
  196. Trying to kill the rasp
  197. lookin for new setup
  198. How much would a bullet muffler hurt flow
  199. Raptor shift light Wiring on a 2000?
  200. Header Experience Please Come in...
  201. F.A.S.T LSx 90 w/F.A.S.T 90 TB Pics
  202. Can this LS6 intake be fixed/saved?
  203. Found:Long Crank pulley bolt! $3.35
  204. GMMG v/s TSP true duals (or custom true duals)
  205. porting my maf and tb
  206. Ported my tb and now it wistles.
  207. SSRA & Rain? Answerd
  208. Headers cause loss of low end?
  209. help with my idle issues
  210. Has anybody heard the Bassani exhaust
  211. Just got a Magnaflow catback
  212. RPM hanging with FAST 90/90
  213. Best Header Setup??
  214. Edelbrock victors!
  215. If you have a FAST intake and don't have the valley bolts...
  216. Smell Oil Burning at stoplights - But I don't think it's the headers...
  217. Sweet Thunder mufflers
  218. Stock manifold/Y pipe???
  219. Car runs better with screen back in MAF ...
  220. Where, other than A-pillar, do you mount gauges in a Camaro, 98+?
  221. Thinking of re installing stock WS6 catback, bad idea ??
  222. Mac headers
  223. Pacesetter Problem
  224. Help with kooks headers & exhaust
  225. true dual plans
  226. Would a cutout help my setup? Searched
  227. Got my LSX 90 and FAST 90 MM TB
  228. SLP Lid Question
  229. 90mm or higher TB's....is FAST the only one?
  230. Truck coils vs. Fbody coils
  231. MSD Wire Length
  232. Sweet-Thunder True Duals (Video Clip)
  233. open headers
  234. QTP's with stock cat-back.
  235. T/A Headlight Problem
  236. Need help with 02 sensor location
  237. Plug wires...
  238. true duals
  239. hooker or TSP rumbler with Lontubes???
  240. 160 Temp Vs. 210
  241. Emissions C/B + LT
  242. Threw a code P0440 - EVAP Emissions Control Malfunction - WTF?
  243. air pipe gasket
  244. ram air intake question.
  245. HELP ASAP With SLP Intake Install With EGR
  246. parts for dual exhaust
  247. What do ignition wires do for performance?
  248. true dual???
  249. Magnaflow and Cut Out?
  250. borla with my setup????
