PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 [125] 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. FAST 90 intake question?
  2. How to Wire Fans
  3. Selling FAST to pick up Warrior??
  4. warrior manifold release date?
  5. main wiring harness
  6. Hanging idle with ported T/B
  7. Best place for wideband with LTs true duals?
  8. Valve Cover Question?
  9. Problems after header install
  10. Which Pacestters?
  11. Brake switch signal
  12. PCV set up
  13. will this work on my car?
  14. Quietest mufflers??
  15. How much to get o2 bung welded?
  16. Idle problems after AIR and EGR delete.
  17. new trans. cross member now speedo doesnt work?
  18. Mccord not opening problem
  19. oil on plug threads
  20. TB Bypass mod writeup with PICS!
  21. need new o2 sensors... help please
  22. stock intake ls6?
  23. O2 sensor swap
  24. How many cats - 1 or 2???
  25. Planning on heads/cam, but quick question
  26. Stock size replacement Pulley
  27. slp loudmouth question
  28. Header Question
  29. Exhaust Backfiring???
  30. Oil pressure sending unit???? vid
  31. SLP LM Install Question: Muffler Only?
  32. poly mounts mounted to the engine ? what way are the motor mounts mounted to the bloc
  33. Another magnamouth sound clip
  34. show me pics of your stock y setups I needa go back to dual in single out.
  35. Exhaust vibrations/banging
  36. Just Ordered!!!
  37. Anyone know the stock throttle body/MAF sizes (ls1/ls6)?
  38. Would doing a MAF help any on my planned mods?
  39. 98 wiring questions
  40. Fast 92/92 install question.
  41. SLP dual dual
  42. 90 TB to MAF hose
  43. Professional Products Typhoon Intake = JUNK!!!! and ebay headers
  44. Intake bellows diameter
  45. Problems with TSP Catted Y
  46. exhuast leak!!!
  47. Chevy Trailblazer fan wobbling
  48. which poly mounts?
  49. Lt headers not clearing K member
  50. Intake Manifold Question?
  51. 2 questions help please
  52. SSAC Stainless steel headers? Cheap??
  53. fast intake install
  54. Header Question
  55. Custom pacesetter y-pipe with flowmaster 3.5" merge
  56. engine reving out of control
  57. Recomendations for single Cat
  58. SLP LMII Installed!
  59. Lost my belt, had to get towed, did I get the right replacement?
  60. Trying to get some ideas on duals pricing for UMI TA
  61. Engine Won't start! Help please =(
  62. Gmmg
  63. dual loudmouth?
  64. SS exhaust video
  65. Is it possible to coat stainless headers?
  66. long tube bolt on?
  67. Exhaust vid
  68. what sensor?
  69. New 02 sensors? Different for each side?
  70. Mass Air Flow Problem?
  71. spal fan
  72. efi or carb
  73. exhaust techs look please..
  74. 3rd gen exhaust question
  75. Sweet Thunder
  76. what is considered a FULL bolt on car?
  77. which flowmaster merge for magnaflow C.B.
  78. please post pics of y pipes
  79. How to test for exhaust leak?
  80. fast 90 TB questions
  81. Seal on thermostat housing and Mr.Gasket 160 part number?
  82. is there going to be a sound difference
  83. Idle problems after porting throttle body
  84. New Exhaust - LOST POWER
  85. EMMISIONS LT's with TSP Y with Cats
  86. Exhaust Jedi's, help! Post install, pre tune ??'s
  87. 99converting to 01-02
  88. Heavy underdrive pulley???
  89. pacesetter lts/ory gains?
  90. Open header question with new motor
  91. Need New Tips
  92. Settle the spark plug gap!
  93. better cold air kit
  94. parts list from mcmaster for fast 90 intake
  95. please help me!!
  96. For those with a 4" cutout
  97. What sensor is this? Pic inside.
  98. help please throttle body
  99. Car feels different with new catback, I almost want to say "feels slower"
  100. What is this?
  101. To gut or not to gut, that is the question.
  102. TD Clearance question
  103. O2 Sensor Question
  104. the chirping and squealing . . .
  105. full bolt ons and cam only enter here.
  106. New Flowmaster Merge Pics
  107. LS1/LS2 intake swap - any issues?
  108. o2 simulators??
  109. QTP cutout
  110. Help changing AC compressor
  111. true duals vs y pipe
  112. Which Lid?
  113. Throttle Body Bypass
  114. Fowtech headers and y-pipe
  115. Deleting EGR/ AIR connections on headers?
  116. heh, will i pass an inspection?
  117. Cut-out?!?!?!
  118. Magnaflow Exhausts
  119. Sportlines and Headers - Clearance in General...
  120. Exhaust
  121. AC with UD Pulley
  122. Exhaust pop when shifting
  123. Belts for my underdrive pulley
  124. What epoxy to repair ls6 intake?
  125. Do you or do you not? Please help asap
  126. anyone buy the new tsp headers yet? questions on fitment!
  127. Let's see how smart you guys are...?
  128. QTP headers, which ORY?
  129. Bad vibration after new tranny mount
  130. Engine sensor fuse.
  131. TSP Rumbler + MTI Lid...how much?
  132. hardcore techs help.
  133. Z06 85mm MAF differences?
  134. ls6 intake from an 01 to a 99 vette coupe... what do i need
  135. slp underdrive pulley?
  136. Why would my stainless headers do this?!?
  137. i need some opinons
  138. help car wont start
  139. F.A.S.T. 92/92 combo
  140. power gains
  141. Mufflex hanger
  142. new some answers please read and comment..
  143. whats wrong with my car
  144. Help throttle stuck on open!
  145. slp dual/dual muffler
  146. my 2002 z stopped while driving!
  147. Sanderson or Edelbrock?
  148. sweet thunder duals good for 550rwhp
  149. Loudmouth Install
  150. changing out front 02 sensors with Bosch 13111
  151. anyone have hooker LTs with TSP catted Y?
  152. need to know the stock compression of a 99z28
  153. BBK Long tubes?
  154. Please help went to dyno and car overheats in 2 minutes
  155. Quietest good exhaust?
  156. Need some intake advice
  157. adapting FIPK to Z06 maf
  158. Powersteering assembly stuck
  159. Advice needed installing Hooker headers
  160. SLP Underdrive pulley
  161. oil in the intake should I use a catchcan?
  162. Just got Elec. Cutout, anybody ever have probs burning wires from the hot exhaust?
  163. finally installed the LS6 (pics)
  164. Tuning question
  165. Pacesetters or Kooks?
  166. TSP 1 7/8 header install....
  167. Switching Flowmaster to Magnaflow
  168. port and polish intake?
  169. Which X or H pipe to buy?
  170. Uncommon exhaust setup. Input needed
  171. throtle body ?????????
  172. Stainless exhaust we made this weekend
  173. headers
  174. LS1 or LS2 spark plug wires (30$more)
  175. Won't Start!!
  176. Will headers on an 01Ws6 work on a 98 SS?
  177. I'm sure this has been answered before, but...
  178. New Car Pictures
  179. Catalytic Converters
  180. need wire connectors to coilpacks
  181. SLP Dual/Dual Not Quiet...
  182. Ls1 spark plugs+MSD wires part # ?
  183. throttle body questions...poll..
  184. What other parts do I need for a LS2 oilpan conversion?
  185. Cutout with LM1?? Where should it go??
  186. Need help with headers
  187. SLP Lid Question 2000+
  188. HELP!!A.I.R Removed/pump Piece on Intake?
  189. rough running after LT/TD install
  190. passing emmissions...
  191. Which Air Induction system is best
  192. wiring help
  193. going to build a ls motor
  194. Evans or Edelbrock water pump??
  195. Exhaust question
  196. cover gaskets
  197. victor jr and cam setup
  198. pacesetter install question
  199. Off road Y-pipe and o-2 codes???
  200. need some help selecting a water pump
  201. Plumbing LS1 for rear radiator?
  202. pacesetter LT install
  203. Oddball fuel pump... WTF???
  204. catback install
  205. loud valvetrain
  206. Intake hose thingy
  207. < 6500rpm FAST90 vs. LS6??
  208. Keyless Entry Question??
  209. Anyone know part # or info on replacment factory powersteering pulleys?
  210. 98 Alternator Wiring Q
  211. tweaking setup speculations
  212. Leaner?? Riddle Me This!!
  213. Headers glowing Red after fast 90 install
  214. what to do first?
  215. Need some quick help
  216. New Tb and now engine light on?????
  217. Dart heads and GM rocker pedastools.
  218. POST Header Install
  219. LS1 F-body Long Tube header measurements
  220. Starter bolts Part #
  221. Removed ac/heater core and I have a question
  222. How To Wire Tach??? Autometer Aftermarket 5"
  223. AIR and EGR Removal
  224. Which Intake?
  225. Need help with exhuast.
  226. Fast 92 vs LS6
  227. $800 for true duals
  228. Custom tune versus tuner
  229. Autolite AR 3911 Questions
  230. 3'' ID exhaust tip for true dual setup
  231. What size TB?
  232. LS1 Pacesetter Install trouble, HELP!
  233. ls6 intake/tune?
  234. Hooker Exhaust Installed (vid & pic)
  235. What cats to go with??
  236. fast 90 intake gasket length
  237. Installed P&P TB
  238. New slp header design?
  239. Oil neck removal
  240. thermostat
  241. Mac headers on 2000 Firehawk
  242. 408 w/ Borlamouth .. dyno & strip
  243. P&P TB: noticeable gain?
  244. Which cars came with LS6 intake?
  245. Victor Jr. injector hole defect
  246. TSP catted Y
  247. Pulley
  248. cat question
  249. Threw a belt today! WTF
  250. LS2, LS1 and LS6 intakes
